[U-Boot] [RFC PATCH 15/21] dm: core: Allow uclass to set up a device's child before it is probed
Some buses need to set up their devices before they can be used. This setup may well be common to all buses in a particular uclass. Support a common pre-probe method for the uclass, called before any bus devices are probed.
drivers/core/device.c | 4 ++++ drivers/core/uclass.c | 13 +++++++++++++ include/dm/test.h | 3 +++ include/dm/uclass-internal.h | 11 +++++++++++ include/dm/uclass.h | 1 + test/dm/bus.c | 46 ++++++++++++++++++++++++++++++++++++++++++++ test/dm/test-fdt.c | 7 +++++++ 7 files changed, 85 insertions(+)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 2639fcb..b050272 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -227,6 +227,10 @@ int device_probe_child(struct udevice *dev, void *parent_priv) } dev->seq = seq;
+ ret = uclass_pre_probe_child(dev); + if (ret) + goto fail; + if (dev->parent && dev->parent->driver->child_pre_probe) { ret = dev->parent->driver->child_pre_probe(dev); if (ret) diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 29811be..8c91370 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -391,6 +391,19 @@ int uclass_resolve_seq(struct udevice *dev) return seq; }
+int uclass_pre_probe_child(struct udevice *dev) +{ + struct uclass_driver *uc_drv; + + if (!dev->parent) + return 0; + uc_drv = dev->parent->uclass->uc_drv; + if (uc_drv->child_pre_probe) + return uc_drv->child_pre_probe(dev); + + return 0; +} + int uclass_post_probe_device(struct udevice *dev) { struct uclass_driver *uc_drv = dev->uclass->uc_drv; diff --git a/include/dm/test.h b/include/dm/test.h index f08c05d..707c69e 100644 --- a/include/dm/test.h +++ b/include/dm/test.h @@ -67,6 +67,8 @@ enum { struct dm_test_priv { int ping_total; int op_count[DM_TEST_OP_COUNT]; + int uclass_flag; + int uclass_total; };
/** @@ -88,6 +90,7 @@ struct dm_test_uclass_priv { * * @sum: Test value used to check parent data works correctly * @flag: Used to track calling of parent operations + * @uclass_flag: Used to track calling of parent operations by uclass */ struct dm_test_parent_data { int sum; diff --git a/include/dm/uclass-internal.h b/include/dm/uclass-internal.h index f718f37..f2f254a 100644 --- a/include/dm/uclass-internal.h +++ b/include/dm/uclass-internal.h @@ -44,6 +44,17 @@ int uclass_bind_device(struct udevice *dev); int uclass_unbind_device(struct udevice *dev);
/** + * uclass_pre_probe_child() - Deal with a child that is about to be probed + * + * Perform any pre-processing that is needed by the uclass before it can be + * probed. + * + * @dev: Pointer to the device + * #return 0 on success, -ve on error + */ +int uclass_pre_probe_child(struct udevice *dev); + +/** * uclass_post_probe_device() - Deal with a device that has just been probed * * Perform any post-processing of a probed device that is needed by the diff --git a/include/dm/uclass.h b/include/dm/uclass.h index 5c5b8f4..d6c40c6 100644 --- a/include/dm/uclass.h +++ b/include/dm/uclass.h @@ -83,6 +83,7 @@ struct uclass_driver { int (*post_probe)(struct udevice *dev); int (*pre_remove)(struct udevice *dev); int (*child_post_bind)(struct udevice *dev); + int (*child_pre_probe)(struct udevice *dev); int (*init)(struct uclass *class); int (*destroy)(struct uclass *class); int priv_auto_alloc_size; diff --git a/test/dm/bus.c b/test/dm/bus.c index c123ed7..faffe6a 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -53,6 +53,15 @@ static int testbus_child_pre_probe(struct udevice *dev) return 0; }
+static int testbus_child_pre_probe_uclass(struct udevice *dev) +{ + struct dm_test_priv *priv = dev_get_priv(dev); + + priv->uclass_flag++; + + return 0; +} + static int testbus_child_post_remove(struct udevice *dev) { struct dm_test_parent_data *parent_data = dev_get_parentdata(dev); @@ -91,6 +100,7 @@ UCLASS_DRIVER(testbus) = { .name = "testbus", .id = UCLASS_TEST_BUS, .flags = DM_UC_FLAG_SEQ_ALIAS, + .child_pre_probe = testbus_child_pre_probe_uclass, };
/* Test that we can probe for children */ @@ -469,3 +479,39 @@ static int dm_test_bus_child_post_bind_uclass(struct dm_test_state *dms) } DM_TEST(dm_test_bus_child_post_bind_uclass, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* + * Test that the bus' uclass' child_pre_probe() is called before the + * device's probe() method + */ +static int dm_test_bus_child_pre_probe_uclass(struct dm_test_state *dms) +{ + struct udevice *bus, *dev; + int child_count; + + /* + * See testfdt_drv_probe() which effectively checks that the uclass + * flag is set before that method is called + */ + ut_assertok(uclass_get_device(UCLASS_TEST_BUS, 0, &bus)); + for (device_find_first_child(bus, &dev), child_count = 0; + dev; + device_find_next_child(&dev)) { + struct dm_test_priv *priv = dev_get_priv(dev); + + /* Check that things happened in the right order */ + ut_asserteq_ptr(NULL, priv); + ut_assertok(device_probe(dev)); + + priv = dev_get_priv(dev); + ut_assert(priv != NULL); + ut_asserteq(1, priv->uclass_flag); + ut_asserteq(1, priv->uclass_total); + child_count++; + } + ut_asserteq(3, child_count); + + return 0; +} +DM_TEST(dm_test_bus_child_pre_probe_uclass, + DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index dfcb3af..b8ee959 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -51,6 +51,13 @@ static int testfdt_drv_probe(struct udevice *dev)
priv->ping_total += DM_TEST_START_TOTAL;
+ /* + * If this device is on a bus, the uclass_flag will be set before + * calling this function. This is used by + * dm_test_bus_child_pre_probe_uclass(). + */ + priv->uclass_total += priv->uclass_flag; + return 0; }
