[U-Boot] [PATCH 8/8] a83t: Enable PSCI, non-secure mode, and cluster / cache setup
Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- board/sunxi/Kconfig | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index fa78720..4b82d3d 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -85,8 +85,13 @@ config MACH_SUN50I config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT select SUNXI_GEN_SUN6I select SUPPORT_SPL + select ENABLE_CLUSTER_1 + select ENABLE_CCI400_SNOOP_CLUSTERS_0_1 + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN9I bool "sun9i (Allwinner A80)" @@ -623,4 +628,12 @@ config SPL_STACK_R_ADDR default 0x4fe00000 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I || MACH_SUN7I || MACH_SUN8I || MACH_SUN50I default 0x2fe00000 if MACH_SUN9I
+config ENABLE_CLUSTER_1 + bool + default n + +config ENABLE_CCI400_SNOOP_CLUSTERS_0_1 + bool + default n + endif
tpearson@raptorengineering.com
