[U-Boot] [PATCH v2] spl_nor.c: Support devicetree sizes different from 16k
The devicetrees for various platforms already exceed 16k. Add a define CONFIG_SYS_FDT_SIZE to specify the FDT size, and set to 16k for the two boards that define this CONFIG_SYS_FDT_BASE parameter. This allows platforms with larger devicetree blobs to boot from NOR.
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- v2: Instead of a default, just specify the value for the two boards that use it. common/spl/spl_nor.c | 4 ++-- include/configs/a3m071.h | 1 + include/configs/microblaze-generic.h | 1 + 3 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index da2422f..8ea874c 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -40,11 +40,11 @@ int spl_nor_load_image(void)
/* * Copy DT blob (fdt) to SDRAM. Passing pointer to - * flash doesn't work (16 KiB should be enough for DT) + * flash doesn't work */ memcpy((void *)CONFIG_SYS_SPL_ARGS_ADDR, (void *)(CONFIG_SYS_FDT_BASE), - (16 << 10)); + CONFIG_SYS_FDT_SIZE);
return 0; } else { diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index 8f17dd1..ab2477c 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -334,6 +334,7 @@
#define CONFIG_SYS_OS_BASE 0xfc200000 #define CONFIG_SYS_FDT_BASE 0xfc1e0000 +#define CONFIG_SYS_FDT_SIZE (16<<10)
#define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 047e756..e5bf700 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -305,6 +305,7 @@ 0x60000) #define CONFIG_SYS_FDT_BASE (CONFIG_SYS_FLASH_BASE + \ 0x40000) +#define CONFIG_SYS_FDT_SIZE (16<<10) #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_TEXT_BASE + \ 0x1000000)
This misses a few boards: $ git grep SPL_NOR_SUPPORT include/configs include/configs/a3m071.h:#define CONFIG_SPL_NOR_SUPPORT include/configs/edminiv2.h:#define CONFIG_SPL_NOR_SUPPORT include/configs/microblaze-generic.h:# define CONFIG_SPL_NOR_SUPPORT include/configs/uniphier.h:#define CONFIG_SPL_NOR_SUPPORT include/configs/x600.h:#define CONFIG_SPL_NOR_SUPPORT
Please update, thanks!
On Tue, Jul 26, 2016 at 8:24 AM, Mike Looijmans mike.looijmans@topic.nl wrote:
Only boards that define "CONFIG_SYS_FDT_BASE" need to set "CONFIG_SYS_FDT_SIZE", since CONFIG_SYS_FDT_BASE is required as second arg for the memcpy call, boards that don't define it apparently don't support booting directly from NOR. Apparently, of the five boards with SPL_NOR support, only these two boards support booting into a kernel directly:
$ grep -r CONFIG_SYS_FDT_BASE * common/spl/spl_nor.c: (void *)(CONFIG_SYS_FDT_BASE), include/configs/a3m071.h:#define CONFIG_SYS_FDT_BASE 0xfc1e0000 include/configs/a3m071.h: "fdt_addr=" __stringify(CONFIG_SYS_FDT_BASE) "\0" \ include/configs/microblaze-generic.h:#define CONFIG_SYS_FDT_BASE (CONFIG_SYS_FLASH_BASE + \
Ah, OK, thanks!
Mike Looijmans
