[U-Boot] [PATCH 1/2] 85xx/p1_p2_rdb: p1020: add muxed usb2 handling
This patch adds the 2nd USB (muxed with eLBC) node depending upon enabling the 'usb2' environment variable via hwconfig i.e. "setenv hwconfig usb2", so that linux has the 2nd USB controller enabled, which will lead to the disabling of the eLBC (NAND, NOR etc).
Also the 2nd USB controller has been left disabled in the u-boot, otherwise any changes in the environment won't be saved. Enabled agent mode support in USB2 depending upon "setenv hwconfig usb2:dr_mode=peripheral"
Updated copyright year too.
Signed-off-by: Vivek Mahajan vivek.mahajan@freescale.com --- board/freescale/p1_p2_rdb/p1_p2_rdb.c | 23 +++++++- cpu/mpc85xx/fdt.c | 105 ++++++++++++++++++++++++++++++++- include/asm-ppc/immap_85xx.h | 4 +- include/fdt_support.h | 1 + 4 files changed, 130 insertions(+), 3 deletions(-)
diff --git a/board/freescale/p1_p2_rdb/p1_p2_rdb.c b/board/freescale/p1_p2_rdb/p1_p2_rdb.c index 3af660e..2bb7ba2 100644 --- a/board/freescale/p1_p2_rdb/p1_p2_rdb.c +++ b/board/freescale/p1_p2_rdb/p1_p2_rdb.c @@ -1,5 +1,5 @@ /* - * Copyright 2009 Freescale Semiconductor, Inc. + * Copyright 2009-10 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -21,6 +21,7 @@ */
#include <common.h> +#include <hwconfig.h> #include <command.h> #include <asm/processor.h> #include <asm/mmu.h> @@ -41,6 +42,7 @@ DECLARE_GLOBAL_DATA_PTR; #define SGMII_PHY_RST_SET 0x00020000 #define PCIE_RST_SET 0x00010000 #define RGMII_PHY_RST_SET 0x02000000 +#define USB2_PORT_OUT_EN 0x01000000
#define USB_RST_CLR 0x04000000
@@ -200,8 +202,11 @@ int board_eth_init(bd_t *bis) #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { + volatile ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + volatile ccsr_gpio_t *gpio = (void *)CONFIG_SYS_MPC85xx_GPIO_ADDR; phys_addr_t base; phys_size_t size; + int agent;
ft_cpu_setup(blob, bd);
@@ -209,6 +214,22 @@ void ft_board_setup(void *blob, bd_t *bd) size = getenv_bootm_size();
fdt_fixup_memory(blob, (u64)base, (u64)size); + + if (!hwconfig("usb2")) + return; + + agent = hwconfig_subarg_cmp("usb2", "dr_mode", "peripheral"); + + /* + * Add the 2nd usb node and enable it. eLBC will + * now be disabled since it is MUXed with USB2 + */ + + fdt_fixup_add_2nd_usb(blob, agent); + + setbits_be32(&gpio->gpdir, USB2_PORT_OUT_EN); + setbits_be32(&gpio->gpdat, USB2_PORT_OUT_EN); + setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_ELBC_OFF_USB2_ON); } #endif
diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index af0e78e..37d3d15 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -1,5 +1,5 @@ /* - * Copyright 2007-2009 Freescale Semiconductor, Inc. + * Copyright 2007-2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -397,3 +397,106 @@ void ft_cpu_setup(void *blob, bd_t *bd)
ft_fixup_dpaa_clks(blob); } + +void fdt_fixup_add_2nd_usb(void *blob, int agent) +{ + const char *soc_compat = "fsl,p1020-immr"; + const char *lbc_compat = "fsl,p1020-elbc"; + const u32 *addrcell, *sizecell, *ph; + int off, lbcoff, len, err; + u32 *regbuf = NULL; + u32 *irqbuf = NULL; + + off = fdt_node_offset_by_compatible(blob, -1, soc_compat); + if (off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_compat, fdt_strerror(off)); + return; + } + + lbcoff = fdt_node_offset_by_compatible(blob, -1, lbc_compat); + if (lbcoff < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + lbc_compat, fdt_strerror(lbcoff)); + return; + } + + addrcell = fdt_getprop(blob, off, "#address-cells", NULL); + sizecell = fdt_getprop(blob, off, "#size-cells", NULL); + + off = fdt_add_subnode(blob, off, "usb@23000"); + if (off < 0) { + printf("WARNING: could not add 2nd usb node %s.\n", + fdt_strerror(off)); + return; + } + + err = fdt_setprop_cell(blob, off, "#address-cells", 1); + if (err < 0) + printf("WARNING: could not set #address-cell property: %s\n", + fdt_strerror(err)); + + err = fdt_setprop_cell(blob, off, "#size-cells", 0); + if (err < 0) + printf("WARNING: could not set #size-cells property: %s\n", + fdt_strerror(err)); + + err = fdt_setprop_string(blob, off, "compatible", "fsl-usb2-dr"); + if (err < 0) + printf("WARNING: could not set compatible property: %s\n", + fdt_strerror(err)); + + err = fdt_setprop_string(blob, off, "phy_type", "ulpi"); + if (err < 0) + printf("WARNING: could not set phy_type property: %s\n", + fdt_strerror(err)); + + if (agent) { + err = fdt_setprop_string(blob, off, "dr_mode", "peripheral"); + if (err < 0) + printf("WARNING: could not set dr_mode property: %s\n", + fdt_strerror(err)); + } + + if (addrcell && *addrcell == 2) { + regbuf[0] = 0; + regbuf[1] = CONFIG_SYS_MPC85xx_USB2_OFFSET; + len = 2; + } else { + regbuf[0] = CONFIG_SYS_MPC85xx_USB2_OFFSET; + len = 1; + } + + if (sizecell && *sizecell == 2) { + regbuf[len] = 0; + regbuf[len + 1] = 0x1000; + len += 2; + } else { + regbuf[len] = 0x1000; + len++; + } + + err = fdt_setprop(blob, off, "reg", regbuf, len * sizeof(u32)); + if (err < 0) + printf("WARNING: could not set <%s> %s\n", + "reg", fdt_strerror(err)); + + irqbuf[0] = 0x2e; + irqbuf[1] = 0x2; + + err = fdt_setprop(blob, off, "interrupts", irqbuf, 2 * sizeof(u32)); + if (err < 0) + printf("WARNING: could not set %s %s\n", + "interrupts", fdt_strerror(err)); + + ph = fdt_getprop(blob, lbcoff, "interrupt-parent", 0); + if (!ph) { + printf("WARNING: could not read interrupt-parent property\n"); + return; + } + + err = fdt_setprop(blob, off, "interrupt-parent", ph, sizeof(u32)); + if (err < 0) + printf("WARNING: could not set %s %s\n", + "interrupt-parent", fdt_strerror(err)); +} diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index 957ad76..b48e21c 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -1,7 +1,7 @@ /* * MPC85xx Internal Memory Map * - * Copyright 2007-2009 Freescale Semiconductor, Inc. + * Copyright 2007-2010 Freescale Semiconductor, Inc. * * Copyright(c) 2002,2003 Motorola Inc. * Xianghua Xiao (x.xiao@motorola.com) @also@ -1880,6 +1880,7 @@ typedef struct ccsr_gur { #define MPC85xx_PMUXCR_SD_DATA 0x80000000 #define MPC85xx_PMUXCR_SDHC_CD 0x40000000 #define MPC85xx_PMUXCR_SDHC_WP 0x20000000 +#define MPC85xx_PMUXCR_ELBC_OFF_USB2_ON 0x01000000 u8 res6[12]; u32 devdisr; /* Device disable control */ #define MPC85xx_DEVDISR_PCI1 0x80000000 @@ -2032,6 +2033,7 @@ enum { #define CONFIG_SYS_MPC85xx_L2_OFFSET 0x20000 #define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x21000 #define CONFIG_SYS_MPC85xx_USB_OFFSET 0x22000 +#define CONFIG_SYS_MPC85xx_USB2_OFFSET 0x23000 #ifdef CONFIG_TSECV2 #define CONFIG_SYS_TSEC1_OFFSET 0xB0000 #else diff --git a/include/fdt_support.h b/include/fdt_support.h index 0a9dd0d..e7b005d 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -74,6 +74,7 @@ int fdt_pci_dma_ranges(void *blob, int phb_off, struct pci_controller *hose); void ft_board_setup(void *blob, bd_t *bd); void ft_cpu_setup(void *blob, bd_t *bd); void ft_pci_setup(void *blob, bd_t *bd); +void fdt_fixup_add_2nd_usb(void *blob, int agent); #endif
void set_working_fdt_addr(void *addr);
- Copyright 2009 Freescale Semiconductor, Inc.
- Copyright 2009-10 Freescale Semiconductor, Inc.
- project.
int agent;
- if (!hwconfig("usb2"))
return;
- agent = hwconfig_subarg_cmp("usb2", "dr_mode", "peripheral");
- fdt_fixup_add_2nd_usb(blob, agent);
- setbits_be32(&gpio->gpdir, USB2_PORT_OUT_EN);
- setbits_be32(&gpio->gpdat, USB2_PORT_OUT_EN);
- setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_ELBC_OFF_USB2_ON);
} #endif
- Copyright 2007-2009 Freescale Semiconductor, Inc.
- Copyright 2007-2010 Freescale Semiconductor, Inc.
- (C) Copyright 2000
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
Isn't this specific to the p1020 board? Shouldn't we put this in board/freescale/p1_p2_rdb/p1_p2_rdb.c?
- const char *soc_compat = "fsl,p1020-immr";
- const char *lbc_compat = "fsl,p1020-elbc";
- const u32 *addrcell, *sizecell, *ph;
- int off, lbcoff, len, err;
- u32 *regbuf = NULL;
- u32 *irqbuf = NULL;
- off = fdt_node_offset_by_compatible(blob, -1, soc_compat);
- if (off < 0) {
return;
- lbcoff = fdt_node_offset_by_compatible(blob, -1, lbc_compat);
- if (lbcoff < 0) {
return;
- addrcell = fdt_getprop(blob, off, "#address-cells", NULL);
- sizecell = fdt_getprop(blob, off, "#size-cells", NULL);
- off = fdt_add_subnode(blob, off, "usb@23000");
- if (off < 0) {
fdt_strerror(off));
return;
- err = fdt_setprop_cell(blob, off, "#address-cells", 1);
- if (err < 0)
fdt_strerror(err));
- err = fdt_setprop_cell(blob, off, "#size-cells", 0);
- if (err < 0)
fdt_strerror(err));
- err = fdt_setprop_string(blob, off, "compatible", "fsl-usb2-dr");
- if (err < 0)
fdt_strerror(err));
- err = fdt_setprop_string(blob, off, "phy_type", "ulpi");
- if (err < 0)
fdt_strerror(err));
- if (agent) {
if (err < 0)
fdt_strerror(err));
- if (addrcell && *addrcell == 2) {
regbuf[0] = 0;
len = 2;
- } else {
len = 1;
- if (sizecell && *sizecell == 2) {
regbuf[len] = 0;
len += 2;
- } else {
len++;
- err = fdt_setprop(blob, off, "reg", regbuf, len * sizeof(u32));
- if (err < 0)
- irqbuf[0] = 0x2e;
- irqbuf[1] = 0x2;
- err = fdt_setprop(blob, off, "interrupts", irqbuf, 2 * sizeof(u32));
- if (err < 0)
- ph = fdt_getprop(blob, lbcoff, "interrupt-parent", 0);
- if (!ph) {
return;
- err = fdt_setprop(blob, off, "interrupt-parent", ph, sizeof(u32));
- if (err < 0)
- MPC85xx Internal Memory Map
- Copyright(c) 2002,2003 Motorola Inc.
- Xianghua Xiao (x.xiao@motorola.com)
The prototype doesn't belong here. This should be for code mostly in common/fdt_support.c.
#endif
1.5.6.5
Kumar Gala
Vivek Mahajan
