[U-Boot] [PATCH v2] efi_loader: Reserve unaccessible memory
On some systems, not all RAM may be usable within U-Boot. Maybe the memory maps are incomplete, maybe it's used as workaround for broken DMA. But whatever the reason may be, a platform can say that it does not wish to have its RAM accessed above a certain address by defining board_get_usable_ram_top().
In the efi_loader world, we ignored that hint, mostly because very few boards actually have real restrictions around this.
So let's honor the board's wish to not access high addresses during boot time. The best way to do so is by indicating the respective pages as "allocated by firmware". That way, Operating Systems will still use the pages after boot, but before boot no allocation will use them.
Reported-by: Baruch Siach baruch@tkos.co.il Signed-off-by: Alexander Graf agraf@suse.de
v1 -> v2:
- Reserve banks that start above ram_top - Improve inline comments - Fix 32bit target with ram_top = 0 (>=4G) --- include/common.h | 11 +++++++++++ lib/efi_loader/efi_memory.c | 32 +++++++++++++++++++++++++++++--- 2 files changed, 40 insertions(+), 3 deletions(-)
diff --git a/include/common.h b/include/common.h index 3f69943887..8f295c2f30 100644 --- a/include/common.h +++ b/include/common.h @@ -106,6 +106,17 @@ int mdm_init(void); void board_show_dram(phys_size_t size);
/** + * Get the uppermost pointer that is valid to access + * + * Some systems may not map all of their address space. This function allows + * boards to indicate what their highest support pointer value is for DRAM + * access. + * + * @param total_size Size of U-Boot (unused?) + */ +ulong board_get_usable_ram_top(ulong total_size); + +/** * arch_fixup_fdt() - Write arch-specific information to fdt * * Defined in arch/$(ARCH)/lib/bootm-fdt.c diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index f225a9028c..3392af59a1 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -551,8 +551,13 @@ efi_status_t efi_get_memory_map(efi_uintn_t *memory_map_size,
__weak void efi_add_known_memory(void) { + u64 ram_top = board_get_usable_ram_top(0) & ~EFI_PAGE_MASK; int i;
+ /* Fix for 32bit targets with ram_top at 4G */ + if (!ram_top) + ram_top = U32_MAX; + /* Add RAM */ for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { u64 ram_end, ram_start, pages; @@ -564,11 +569,32 @@ __weak void efi_add_known_memory(void) ram_end &= ~EFI_PAGE_MASK; ram_start = (ram_start + EFI_PAGE_MASK) & ~EFI_PAGE_MASK;
- if (ram_end > ram_start) { - pages = (ram_end - ram_start) >> EFI_PAGE_SHIFT; + if (ram_end <= ram_start) { + /* Invalid mapping, keep going. */ + continue; + } + + pages = (ram_end - ram_start) >> EFI_PAGE_SHIFT;
+ efi_add_memory_map(ram_start, pages, + EFI_CONVENTIONAL_MEMORY, false); + + /* + * Boards may indicate to the U-Boot memory core that they + * can not support memory above ram_top. Let's honor this + * in the efi_loader subsystem too by declaring any memory + * above ram_top as "already occupied by firmware". + */ + if (ram_top < ram_start) { + /* ram_top is before this region, reserve all */ efi_add_memory_map(ram_start, pages, - EFI_CONVENTIONAL_MEMORY, false); + EFI_BOOT_SERVICES_DATA, true); + } else if ((ram_top >= ram_start) && (ram_top < ram_end)) { + /* ram_top is inside this region, reserve parts */ + pages = (ram_end - ram_top) >> EFI_PAGE_SHIFT; + + efi_add_memory_map(ram_top, pages, + EFI_BOOT_SERVICES_DATA, true); } } }
if (!ram_top)
ram_top = U32_MAX;
Don't you need to &= ~EFI_PAGE_MASK after the U32_MAX assignment too? Perhaps just do that once:
u64 ram_top = board_get_usable_ram_top(0); /* Fix for 32bit targets with ram_top at 4G */ if (!ram_top) ram_top = U32_MAX; ram_top &= & ~EFI_PAGE_MASK;
Otherwise, Reviewed-by: Stephen Warren swarren@nvidia.com
v1 -> v2:
- Get the uppermost pointer that is valid to access
- Some systems may not map all of their address space. This function allows
- boards to indicate what their highest support pointer value is for DRAM
- access.
- @param total_size Size of U-Boot (unused?)
- arch_fixup_fdt() - Write arch-specific information to fdt
- Defined in arch/$(ARCH)/lib/bootm-fdt.c
if (!ram_top)
ram_top = U32_MAX;
Why don't you set ram_top to (1 << 32)? ram_top is u64 anyway. We do not want something ending with 0xfff to be passed to efi_add_memory_map.
Are we sure there will never be 64bit machines with a memory bank ending at 1 << 64? What would be the value of ram_end and ram_top in such a case?
Regards
Heinrich
- /* Add RAM */ for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { u64 ram_end, ram_start, pages;
continue;
} }EFI_BOOT_SERVICES_DATA, true);
v1 -> v2:
- access.
if (!ram_top)
ram_top = U32_MAX;
Ugh, yes. Of course. And obviously that's 0x100000000ULL to make sure it works fine on 32bit :).
I think we can be pretty sure of that, yes :). No machine today even comes close to that many physical address bits supported.
Alex
Alexander Graf
Stephen Warren
