[U-Boot] Pull request: nand flash
The following changes since commit e3a4facdfc07179ebe017a07b8de6224a935a9f3:
checkpatch: remove unnecessary + after {8,8} (2014-09-25 09:31:24 -0400)
git://git.denx.de/u-boot-nand-flash.git master
for you to fetch changes up to f9860cf081efdf32c8a01b9fc271fe55e2a79f8d:
nand/denali: Document CONFIG symbols (2014-09-25 13:54:58 -0500)
---------------------------------------------------------------- Chin Liang See (1): nand/denali: Adding Denali NAND driver support
Rostislav Lisovy (1): mtd: nand: am335x: Fix 'bit-flip' errors in SPL
Scott Wood (1): nand/denali: Document CONFIG symbols
Stefan Roese (1): mtd: nand: Fix length bug in ioread16_rep() and iowrite16_rep()
doc/README.nand | 6 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/am335x_spl_bch.c | 12 +- drivers/mtd/nand/denali.c | 1205 +++++++++++++++++++++++++++++++++++++ drivers/mtd/nand/denali.h | 467 ++++++++++++++ drivers/mtd/nand/nand_base.c | 4 +- 6 files changed, 1688 insertions(+), 7 deletions(-) create mode 100644 drivers/mtd/nand/denali.c create mode 100644 drivers/mtd/nand/denali.h
Scott Wood
