[U-Boot] [PATCH] arm: layerscape: Enable UUID & GPT partition for NXP's ARM SoC
Enable UUID and GPT partition support for NXP's ARM based SoCs i.e. LS1012A, LS1021A, LS1043A, LS1046A and LS2080A.
Also enable DOS partition for LS1012AFRDM boards.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- include/configs/ls1012afrdm.h | 5 +++++ include/configs/ls1012aqds.h | 4 ++++ include/configs/ls1012ardb.h | 4 ++++ include/configs/ls1021aiot.h | 3 +++ include/configs/ls1021aqds.h | 3 +++ include/configs/ls1021atwr.h | 3 +++ include/configs/ls1043aqds.h | 4 ++++ include/configs/ls1043ardb.h | 4 ++++ include/configs/ls1046aqds.h | 4 ++++ include/configs/ls1046ardb.h | 4 ++++ include/configs/ls2080aqds.h | 3 +++ include/configs/ls2080ardb.h | 3 +++ 12 files changed, 44 insertions(+)
diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index f6f88e8..94f7460 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -42,6 +42,11 @@ #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
+#define CONFIG_DOS_PARTITION +#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT + #define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 0cc1791..ec4b825 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -154,6 +154,10 @@ #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT + #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE_LAYERSCAPE /* Use common FSL Layerscape PCIe code */ #define FSL_PCIE_COMPAT "fsl,ls1043a-pcie" diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 15410dd..1e8cc45 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -67,6 +67,10 @@ #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT + #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE_LAYERSCAPE /* Use common FSL Layerscape PCIe code */ #define FSL_PCIE_COMPAT "fsl,ls1043a-pcie" diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 7af4bc4..a441022 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -180,6 +180,9 @@
#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION +#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT
/* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 128da8a..86b42dd 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -398,6 +398,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_GENERIC_MMC
/* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1458332..25bebc0 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -299,6 +299,9 @@ #define CONFIG_GENERIC_MMC
/* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 561a05a..431c8f8 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -100,6 +100,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
+#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT + /* EEPROM */ #define CONFIG_ID_EEPROM #define CONFIG_SYS_I2C_EEPROM_NXID diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 71c26bd..36df331 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -310,6 +310,10 @@ #define SCSI_DEV_ID 0x9170 #define CONFIG_SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID}
+#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT + #include <asm/fsl_secure_boot.h>
#endif /* __LS1043ARDB_H__ */ diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 29e0aa5..3618a06 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -143,6 +143,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
+#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT + /* EEPROM */ #define CONFIG_ID_EEPROM #define CONFIG_SYS_I2C_EEPROM_NXID diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 2fe8fc1..42597ac 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -225,6 +225,10 @@ #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT + #define CONFIG_BOOTCOMMAND "sf probe 0:0;sf read $kernel_load" \ "$kernel_start $kernel_size;" \ "bootm $kernel_load" diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 838568f..b3872b5 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -63,6 +63,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT
/* undefined CONFIG_FSL_DDR_SYNC_REFRESH for simulator */
diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 31df781..9ffb48c 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -71,6 +71,9 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_PARTITION_UUIDS +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_GPT
Hi Prabhakar Kushwaha,
I'm not sure this is the expected way today...
These are the common (not board specific) things and I think today we expect it to come through the Kconfig instead of the old config files.
Igor,
They are not totally common. The board has to support the device. I would recommend to use Kconfig as well if such config is in Kconfig. However it is not the case here.
York
Igor,
Right. They are not in Kconfig yet... We are making efforts to move stuff to Kconfig. Care to land a hand and move these ones to Kconfig?
Igor,
Can't promise. I have been doing just that for powerpc. Still have many left.
York
Igor,
Yeah, great job on those patches! Thanks! I think it is still worth waiting instead of applying and moving afterwards...
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Well, of course it is your call, but that's sad. Why not request people to move things to Kconfig?
I would suggest removing these from scripts/config_whitelist.txt...
The problem with the partition table and related options is that it ends up being a non-trivial conversion to do and remain size neutral. Patrick, have you had a chance to look at your patch again? Thanks!
Igor Grinberg
Prabhakar Kushwaha
york sun
