[RESEND PATCH] rpi: Copy properties from firmware dtb to the loaded dtb
The RPI firmware adjusts several property values in the dtb it passes to u-boot depending on the board/SoC revision. Inherit some of these when u-boot loads a dtb itself. Specificaly copy:
* /model: The firmware provides a more specific string * /memreserve: The firmware defines a reserved range, better keep it * emmc2bus and pcie0 dma-ranges: The C0T revision of the bcm2711 Soc (as present on rpi 400 and some rpi 4B boards) has different values for these then the B0T revision. So these need to be adjusted to boot on these boards * blconfig: The firmware defines the memory area where the blconfig stored. Copy those over so it can be enabled. * /chosen/kaslr-seed: The firmware generates a kaslr seed, take advantage of that.
Signed-off-by: Sjoerd Simons sjoerd@collabora.com ---
board/raspberrypi/rpi/rpi.c | 48 +++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 55afaa54d9f..cdde32c8143 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -499,10 +499,58 @@ void *board_fdt_blob_setup(int *err) return (void *)fw_dtb_pointer; }
+int copy_property(void *dst, void *src, char *path, char *property) +{ + int dst_offset, src_offset; + const fdt32_t *prop; + int len; + + src_offset = fdt_path_offset(src, path); + dst_offset = fdt_path_offset(dst, path); + + if (src_offset < 0 || dst_offset < 0) + return -1; + + prop = fdt_getprop(src, src_offset, property, &len); + if (!prop) + return -1; + + return fdt_setprop(dst, dst_offset, property, prop, len); +} + +/* Copy tweaks from the firmware dtb to the loaded dtb */ +void update_fdt_from_fw(void *fdt, void *fw_fdt) +{ + /* Using dtb from firmware directly; leave it alone */ + if (fdt == fw_fdt) + return; + + /* The firmware provides a more precie model; so copy that */ + copy_property(fdt, fw_fdt, "/", "model"); + + /* memory reserve as suggested by the firmware */ + copy_property(fdt, fw_fdt, "/", "memreserve"); + + /* Adjust dma-ranges for the SD card and PCI bus as they can depend on + * the SoC revision + */ + copy_property(fdt, fw_fdt, "emmc2bus", "dma-ranges"); + copy_property(fdt, fw_fdt, "pcie0", "dma-ranges"); + + /* Bootloader configuration template exposes as nvmem */ + if (copy_property(fdt, fw_fdt, "blconfig", "reg") == 0) + copy_property(fdt, fw_fdt, "blconfig", "status"); + + /* kernel address randomisation seed as provided by the firmware */ + copy_property(fdt, fw_fdt, "/chosen", "kaslr-seed"); +} + int ft_board_setup(void *blob, struct bd_info *bd) { int node;
+ update_fdt_from_fw(blob, (void *)fw_dtb_pointer); + node = fdt_node_offset_by_compatible(blob, -1, "simple-framebuffer"); if (node < 0) lcd_dt_simplefb_add_node(blob);
- /model: The firmware provides a more specific string
- /memreserve: The firmware defines a reserved range, better keep it
- emmc2bus and pcie0 dma-ranges: The C0T revision of the bcm2711 Soc (as present on rpi 400 and some rpi 4B boards) has different values for these then the B0T revision. So these need to be adjusted to boot on these boards
- blconfig: The firmware defines the memory area where the blconfig stored. Copy those over so it can be enabled.
- /chosen/kaslr-seed: The firmware generates a kaslr seed, take advantage of that.
So my question is, why don't you want to use the devicetree provided by the firmware in the first place? Wouldn't that fix all the problems you have?
Regards, Matthias
- int dst_offset, src_offset;
- const fdt32_t *prop;
- int len;
- src_offset = fdt_path_offset(src, path);
- dst_offset = fdt_path_offset(dst, path);
- if (src_offset < 0 || dst_offset < 0)
return -1;
- prop = fdt_getprop(src, src_offset, property, &len);
- if (!prop)
return -1;
- return fdt_setprop(dst, dst_offset, property, prop, len);
- /* Using dtb from firmware directly; leave it alone */
- if (fdt == fw_fdt)
return;
- /* The firmware provides a more precie model; so copy that */
- copy_property(fdt, fw_fdt, "/", "model");
- /* memory reserve as suggested by the firmware */
- copy_property(fdt, fw_fdt, "/", "memreserve");
- /* Adjust dma-ranges for the SD card and PCI bus as they can depend on
* the SoC revision
- copy_property(fdt, fw_fdt, "emmc2bus", "dma-ranges");
- copy_property(fdt, fw_fdt, "pcie0", "dma-ranges");
- /* Bootloader configuration template exposes as nvmem */
- if (copy_property(fdt, fw_fdt, "blconfig", "reg") == 0)
- /* kernel address randomisation seed as provided by the firmware */
- copy_property(fdt, fw_fdt, "/chosen", "kaslr-seed");
Matthias Brugger
Sjoerd Simons
