[U-Boot] [PATCH v2 0/5] rockchip: video: rk3399: enable HDMI output
This series provides HDMI enablement for the RK3399 and will support video console on the RK3399 either with VOP-lit or VOP-big: - pinctrl and clk support for the hdmi node - a refactoring of rk_vop.c and rk_hdmi.c to allow for the minor differences between the RK3288 and RK3399 VOP and HDMI blocks
To see the full series in the context of a working configuration (i.e. including DTS, defconfig, etc. and on top of the MIPI enablement change series from Rockchip), refer to https://git.theobroma-systems.com/puma-u-boot.git/log/?h=puma-hdmi-rfc
This has been tested (on top of Eric Gao's change series for MIPI-DSI) using 'bmp display' and 'setenv stdout vidconsole' on the RK3399-Q7 with various HDMI monitors, both for VOP-lit and VOP-big (setting the other one to 'disabled').
Changes in v2: - removed DEBUG from the patch (as was done in our production branches, but missing from the patch-prep branch) - updated SJG's comment (with a TODO for the RK3288) to reflect the new code structure
Philipp Tomsich (5): rockchip: clk: rk3399: allow requests for HDMI clocks rockchip: pinctrl: rk3399: add support for the HDMI I2C pins rockchip: video: rk3399: enable HDMI output (from the rk_vop) for the RK3399 rockchip: video: rk3399: add HDMI TX support on the RK3399 rockchip: dts: rk3399: enable HDMI output in the DTS
arch/arm/dts/rk3399.dtsi | 110 +++++++++++++++ arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 7 + arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 11 ++ drivers/clk/rockchip/clk_rk3399.c | 7 + drivers/pinctrl/rockchip/pinctrl_rk3399.c | 26 ++++ drivers/video/rockchip/rk_hdmi.c | 164 +++++++++++++++++----- drivers/video/rockchip/rk_vop.c | 178 ++++++++++++++++++++---- 7 files changed, 438 insertions(+), 65 deletions(-)
This allows requests (via the DTS) for PCLK_HDMI_CTRL/PCLK_VIO_GRF, which are clock gates in the HDMI output path for the RK3399.
As these are enabled by default (i.e. after reset), we don't implement any logic to actively open/close these clock gates and simply assume that their reset-default has not been changed.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
Changes in v2: None
drivers/clk/rockchip/clk_rk3399.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 72395e2..d820ea6 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -879,6 +879,9 @@ static ulong rk3399_clk_get_rate(struct clk *clk) case SCLK_UART0: case SCLK_UART2: return 24000000; + break; + case PCLK_HDMI_CTRL: + break; case DCLK_VOP0: case DCLK_VOP1: break; @@ -916,6 +919,10 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) case SCLK_SPI0...SCLK_SPI5: ret = rk3399_spi_set_clk(priv->cru, clk->id, rate); break; + case PCLK_HDMI_CTRL: + case PCLK_VIO_GRF: + /* the PCLK gates for video are enabled by default */ + break; case DCLK_VOP0: case DCLK_VOP1: ret = rk3399_vop_set_clk(priv->cru, clk->id, rate);
On 28 April 2017 at 10:33, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Changes in v2: None
Changes in v2: None
Applied to u-boot-rockchip/next, thanks!
To add HDMI support for the RK3399, this commit provides the needed pinctrl functionality to configure the HDMI I2C pins (used for reading the screen's EDID).
Changes in v2: None
arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 2 ++ drivers/pinctrl/rockchip/pinctrl_rk3399.c | 26 +++++++++++++++++++++++++ 2 files changed, 28 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h index cbcff2e..22d8d97 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h @@ -439,9 +439,11 @@ enum { GRF_GPIO4C0_SEL_SHIFT = 0, GRF_GPIO4C0_SEL_MASK = 3 << GRF_GPIO4C0_SEL_SHIFT, GRF_UART2DGBB_SIN = 2, + GRF_HDMII2C_SCL = 3, GRF_GPIO4C1_SEL_SHIFT = 2, GRF_GPIO4C1_SEL_MASK = 3 << GRF_GPIO4C1_SEL_SHIFT, GRF_UART2DGBB_SOUT = 2, + GRF_HDMII2C_SDA = 3, GRF_GPIO4C2_SEL_SHIFT = 4, GRF_GPIO4C2_SEL_MASK = 3 << GRF_GPIO4C2_SEL_SHIFT, GRF_PWM_0 = 1, diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3399.c b/drivers/pinctrl/rockchip/pinctrl_rk3399.c index 6eb657f..0226731 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3399.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3399.c @@ -247,6 +247,23 @@ static void pinctrl_rk3399_gmac_config(struct rk3399_grf_regs *grf, int mmc_id) } #endif
+#if !defined(CONFIG_SPL_BUILD) +static void pinctrl_rk3399_hdmi_config(struct rk3399_grf_regs *grf, int hdmi_id) +{ + switch (hdmi_id) { + case PERIPH_ID_HDMI: + rk_clrsetreg(&grf->gpio4c_iomux, + GRF_GPIO4C0_SEL_MASK | GRF_GPIO4C1_SEL_MASK, + (GRF_HDMII2C_SCL << GRF_GPIO4C0_SEL_SHIFT) | + (GRF_HDMII2C_SDA << GRF_GPIO4C1_SEL_SHIFT)); + break; + default: + debug("%s: hdmi_id = %d unsupported\n", __func__, hdmi_id); + break; + } +} +#endif + static int rk3399_pinctrl_request(struct udevice *dev, int func, int flags) { struct rk3399_pinctrl_priv *priv = dev_get_priv(dev); @@ -296,6 +313,11 @@ static int rk3399_pinctrl_request(struct udevice *dev, int func, int flags) pinctrl_rk3399_gmac_config(priv->grf, func); break; #endif +#if !defined(CONFIG_SPL_BUILD) + case PERIPH_ID_HDMI: + pinctrl_rk3399_hdmi_config(priv->grf, func); + break; +#endif default: return -EINVAL; } @@ -342,6 +364,10 @@ static int rk3399_pinctrl_get_periph_id(struct udevice *dev, case 12: return PERIPH_ID_GMAC; #endif +#if !defined(CONFIG_SPL_BUILD) + case 23: + return PERIPH_ID_HDMI; +#endif } #endif return -ENOENT;
Changes in v2: None
Changes in v2: None
This commit enables RK3399 support for HDMI through the following changes: - adds a driverdata structure to mirror some subtle version differences between the RK3399 VOPs and those in the RK3288 (e.g. the pin-polarity configuration) - configures the VOP to output 32bpp for HDMI - handles whether a VOP can output 10BIT data or not (i.e. RGBaaa vs. RGB888) using the driverdata structure
And as we touch this file anyway, we also increase the size of the framebuffer to a slightly overzealous 4K2K@32bpp.
Changes in v2: None
arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 11 ++ drivers/video/rockchip/rk_vop.c | 178 ++++++++++++++++++++---- 2 files changed, 159 insertions(+), 30 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h index 0ce3d67..bca6860 100644 --- a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h +++ b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h @@ -196,9 +196,20 @@ enum vop_modes { #define V_DSP_DEN_POL(x) (((x) & 1) << 6) #define V_DSP_VSYNC_POL(x) (((x) & 1) << 5) #define V_DSP_HSYNC_POL(x) (((x) & 1) << 4) +#define V_DSP_PIN_POL(x) (((x) & 0xf) << 4) #define V_DSP_OUT_MODE(x) ((x) & 0xf)
/* VOP_DSP_CTRL1 */ +#define V_RK3399_DSP_MIPI_POL(x) ((x) << 28) +#define V_RK3399_DSP_EDP_POL(x) ((x) << 24) +#define V_RK3399_DSP_HDMI_POL(x) ((x) << 20) +#define V_RK3399_DSP_LVDS_POL(x) ((x) << 16) + +#define M_RK3399_DSP_MIPI_POL (V_RK3399_DSP_MIPI_POL(0xf)) +#define M_RK3399_DSP_EDP_POL (V_RK3399_DSP_EDP_POL(0xf)) +#define M_RK3399_DSP_HDMI_POL (V_RK3399_DSP_HDMI_POL(0xf)) +#define M_RK3399_DSP_LVDS_POL (V_RK3399_DSP_LVDS_POL(0xf)) + #define M_DSP_LAYER3_SEL (3 << 14) #define M_DSP_LAYER2_SEL (3 << 12) #define M_DSP_LAYER1_SEL (3 << 10) diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index bc02f80..c9b7124 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -28,11 +28,78 @@
DECLARE_GLOBAL_DATA_PTR;
+enum vop_pol { + HSYNC_POSITIVE = 0, + VSYNC_POSITIVE = 1, + DEN_NEGATIVE = 2, + DCLK_INVERT = 3 +}; + struct rk_vop_priv { struct rk3288_vop *regs; struct rk3288_grf *grf; };
+enum vop_features { + VOP_FEATURE_OUTPUT_10BIT = (1 << 0), +}; + +struct rkvop_driverdata { + /* configuration */ + u32 features; + /* block-specific setters/getters */ + void (*set_pin_polarity)(struct udevice *, enum vop_modes, u32); +}; + +static void rk3288_set_pin_polarity(struct udevice *dev, + enum vop_modes mode, u32 polarity) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs; + + /* The RK3328 VOP (v3.1) has its polarity configuration in ctrl0 */ + clrsetbits_le32(®s->dsp_ctrl0, + M_DSP_DCLK_POL | M_DSP_DEN_POL | + M_DSP_VSYNC_POL | M_DSP_HSYNC_POL, + V_DSP_PIN_POL(polarity)); +} + +static void rk3399_set_pin_polarity(struct udevice *dev, + enum vop_modes mode, u32 polarity) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs; + + /* + * The RK3399 VOPs (v3.5 and v3.6) require a per-mode setting of + * the polarity configuration (in ctrl1). + */ + switch (mode) { + case VOP_MODE_HDMI: + clrsetbits_le32(®s->dsp_ctrl1, + M_RK3399_DSP_HDMI_POL, + V_RK3399_DSP_HDMI_POL(polarity)); + break; + + case VOP_MODE_EDP: + clrsetbits_le32(®s->dsp_ctrl1, + M_RK3399_DSP_EDP_POL, + V_RK3399_DSP_EDP_POL(polarity)); + break; + + case VOP_MODE_MIPI: + clrsetbits_le32(®s->dsp_ctrl1, + M_RK3399_DSP_MIPI_POL, + V_RK3399_DSP_MIPI_POL(polarity)); + break; + + case VOP_MODE_LVDS: + /* The RK3399 has neither parallel RGB nor LVDS output. */ + default: + debug("%s: unsupported output mode %x\n", __func__, mode); + } +} + void rkvop_enable(struct rk3288_vop *regs, ulong fbbase, int fb_bits_per_pixel, const struct display_timing *edid) { @@ -89,50 +156,77 @@ void rkvop_enable(struct rk3288_vop *regs, ulong fbbase, writel(0x01, ®s->reg_cfg_done); /* enable reg config */ }
-void rkvop_mode_set(struct rk3288_vop *regs, - const struct display_timing *edid, enum vop_modes mode) +static void rkvop_set_pin_polarity(struct udevice *dev, + enum vop_modes mode, u32 polarity) { - u32 hactive = edid->hactive.typ; - u32 vactive = edid->vactive.typ; - u32 hsync_len = edid->hsync_len.typ; - u32 hback_porch = edid->hback_porch.typ; - u32 vsync_len = edid->vsync_len.typ; - u32 vback_porch = edid->vback_porch.typ; - u32 hfront_porch = edid->hfront_porch.typ; - u32 vfront_porch = edid->vfront_porch.typ; - uint flags; - int mode_flags; + struct rkvop_driverdata *ops = + (struct rkvop_driverdata *)dev_get_driver_data(dev); + + if (ops->set_pin_polarity) + ops->set_pin_polarity(dev, mode, polarity); +} + +static void rkvop_enable_output(struct udevice *dev, enum vop_modes mode) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs;
switch (mode) { case VOP_MODE_HDMI: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_HDMI_OUT_EN(1)); break; + case VOP_MODE_EDP: - default: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_EDP_OUT_EN(1)); break; + case VOP_MODE_LVDS: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_RGB_OUT_EN(1)); break; + + default: + debug("%s: unsupported output mode %x\n", __func__, mode); } +}
- if (mode == VOP_MODE_HDMI || mode == VOP_MODE_EDP) - /* RGBaaa */ - mode_flags = 15; - else - /* RGB888 */ - mode_flags = 0; +void rkvop_mode_set(struct udevice *dev, + const struct display_timing *edid, enum vop_modes mode) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs; + struct rkvop_driverdata *data = + (struct rkvop_driverdata *)dev_get_driver_data(dev); + + u32 hactive = edid->hactive.typ; + u32 vactive = edid->vactive.typ; + u32 hsync_len = edid->hsync_len.typ; + u32 hback_porch = edid->hback_porch.typ; + u32 vsync_len = edid->vsync_len.typ; + u32 vback_porch = edid->vback_porch.typ; + u32 hfront_porch = edid->hfront_porch.typ; + u32 vfront_porch = edid->vfront_porch.typ; + int mode_flags; + u32 pin_polarity;
- flags = V_DSP_OUT_MODE(mode_flags) | - V_DSP_HSYNC_POL(!!(edid->flags & DISPLAY_FLAGS_HSYNC_HIGH)) | - V_DSP_VSYNC_POL(!!(edid->flags & DISPLAY_FLAGS_VSYNC_HIGH)); + pin_polarity = BIT(DCLK_INVERT); + if (edid->flags & DISPLAY_FLAGS_HSYNC_HIGH) + pin_polarity |= BIT(HSYNC_POSITIVE); + if (edid->flags & DISPLAY_FLAGS_VSYNC_HIGH) + pin_polarity |= BIT(VSYNC_POSITIVE);
- clrsetbits_le32(®s->dsp_ctrl0, - M_DSP_OUT_MODE | M_DSP_VSYNC_POL | M_DSP_HSYNC_POL, - flags); + rkvop_set_pin_polarity(dev, mode, pin_polarity); + rkvop_enable_output(dev, mode); + + mode_flags = 0; /* RGB888 */ + if ((data->features & VOP_FEATURE_OUTPUT_10BIT) && + (mode == VOP_MODE_HDMI || mode == VOP_MODE_EDP)) + mode_flags = 15; /* RGBaaa */ + + clrsetbits_le32(®s->dsp_ctrl0, M_DSP_OUT_MODE, + V_DSP_OUT_MODE(mode_flags));
writel(V_HSYNC(hsync_len) | V_HORPRD(hsync_len + hback_porch + hactive + hfront_porch), @@ -249,8 +343,7 @@ int rk_display_init(struct udevice *dev, ulong fbbase, return ret; }
- rkvop_mode_set(regs, &timing, vop_id); - + rkvop_mode_set(dev, &timing, vop_id); rkvop_enable(regs, fbbase, 1 << l2bpp, &timing);
ret = display_enable(disp, 1 << l2bpp, &timing); @@ -341,19 +434,44 @@ static int rk_vop_bind(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev);
- plat->size = 1920 * 1080 * 2; + /* + * Let's allocate an excessively large framebuffer (i.e. the + * maximum any of the supported VOP variants can output), so + * we are prepared for the day when someone first tries to + * drive a 4K2K HDMI signal from the bootloader. + */ + plat->size = 4096 * 2160 * 4;
return 0; }
-static const struct video_ops rk_vop_ops = { +struct rkvop_driverdata rk3288_driverdata = { + .features = VOP_FEATURE_OUTPUT_10BIT, + .set_pin_polarity = rk3288_set_pin_polarity, +}; + +struct rkvop_driverdata rk3399_lit_driverdata = { + .set_pin_polarity = rk3399_set_pin_polarity, +}; + +struct rkvop_driverdata rk3399_big_driverdata = { + .features = VOP_FEATURE_OUTPUT_10BIT, + .set_pin_polarity = rk3399_set_pin_polarity, };
static const struct udevice_id rk_vop_ids[] = { - { .compatible = "rockchip,rk3288-vop" }, + { .compatible = "rockchip,rk3288-vop", + .data = (ulong)&rk3288_driverdata }, + { .compatible = "rockchip,rk3399-vop-big", + .data = (ulong)&rk3399_big_driverdata }, + { .compatible = "rockchip,rk3399-vop-lit", + .data = (ulong)&rk3399_lit_driverdata }, { } };
+static const struct video_ops rk_vop_ops = { +}; + U_BOOT_DRIVER(rk_vop) = { .name = "rk_vop", .id = UCLASS_VIDEO,
This commit enables the RK3399 HDMI TX, which is very similar to the one found on the RK3288. The differences between the two SoCs (mainly the input VOP selection) is abstracted away through the driverdata.
Note that the I2C communication for reading the EDID works well with the default settings, but does not with the alternate settings used on the RK3288... so this configuration aspect also is part of the driverdata.
Having some sort of DTS-based configuration for the regulator dependencies would be nice for the future, but for now we simply use lists of regulator names (also via driverdata) that we probe.
arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 5 + drivers/video/rockchip/rk_hdmi.c | 164 +++++++++++++++++++----- 2 files changed, 134 insertions(+), 35 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h index 22d8d97..ddd558e 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h @@ -462,6 +462,11 @@ enum { GRF_UART_DBG_SEL_MASK = 3 << GRF_UART_DBG_SEL_SHIFT, GRF_UART_DBG_SEL_C = 2,
+ /* GRF_SOC_CON20 */ + GRF_RK3399_HDMI_VOP_SEL_MASK = 1 << 6, + GRF_RK3399_HDMI_VOP_SEL_B = 0 << 6, + GRF_RK3399_HDMI_VOP_SEL_L = 1 << 6, + /* PMUGRF_GPIO0A_IOMUX */ PMUGRF_GPIO0A6_SEL_SHIFT = 12, PMUGRF_GPIO0A6_SEL_MASK = 3 << PMUGRF_GPIO0A6_SEL_SHIFT, diff --git a/drivers/video/rockchip/rk_hdmi.c b/drivers/video/rockchip/rk_hdmi.c index db07588..5d11ab8 100644 --- a/drivers/video/rockchip/rk_hdmi.c +++ b/drivers/video/rockchip/rk_hdmi.c @@ -1,4 +1,5 @@ /* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH * Copyright (c) 2015 Google, Inc * Copyright 2014 Rockchip Inc. * @@ -16,12 +17,25 @@ #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/clock.h> +#include <asm/arch/hardware.h> #include <asm/arch/grf_rk3288.h> +#include <asm/arch/grf_rk3399.h> #include <power/regulator.h>
struct rk_hdmi_priv { struct dw_hdmi hdmi; - struct rk3288_grf *grf; + void *grf; +}; + +struct rkhdmi_driverdata { + /* configuration */ + u8 i2c_clk_high; + u8 i2c_clk_low; + const char * const *regulator_names; + u32 regulator_names_cnt; + /* setters/getters */ + int (*set_input_vop)(struct udevice *dev); + int (*clk_config)(struct udevice *dev); };
static const struct hdmi_phy_config rockchip_phy_config[] = { @@ -65,6 +79,60 @@ static const struct hdmi_mpll_config rockchip_mpll_cfg[] = { } };
+static int rk3288_set_input_vop(struct udevice *dev) +{ + struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + int vop_id = uc_plat->source_id; + struct rk3288_grf *grf = priv->grf; + + /* hdmi source select hdmi controller */ + rk_setreg(&grf->soc_con6, 1 << 15); + + /* hdmi data from vop id */ + rk_clrsetreg(&grf->soc_con6, 1 << 4, (vop_id == 1) ? (1 << 4) : 0); + + return 0; +} + +static int rk3399_set_input_vop(struct udevice *dev) +{ + struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + int vop_id = uc_plat->source_id; + struct rk3399_grf_regs *grf = priv->grf; + + /* hdmi data from vop id */ + rk_clrsetreg(&grf->soc_con20, GRF_RK3399_HDMI_VOP_SEL_MASK, + (vop_id == 1) ? GRF_RK3399_HDMI_VOP_SEL_L : 0); + + return 0; +} + +static int rk3288_clk_config(struct udevice *dev) +{ + struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + struct clk clk; + int ret; + + /* + * Configure the maximum clock to permit whatever resolution the + * monitor wants + */ + ret = clk_get_by_index(uc_plat->src_dev, 0, &clk); + if (ret >= 0) { + ret = clk_set_rate(&clk, 384000000); + clk_free(&clk); + } + if (ret < 0) { + debug("%s: Failed to set clock in source device '%s': ret=%d\n", + __func__, uc_plat->src_dev->name, ret); + return ret; + } + + return 0; +} + static int rk_hdmi_read_edid(struct udevice *dev, u8 *buf, int buf_size) { struct rk_hdmi_priv *priv = dev_get_priv(dev); @@ -83,20 +151,16 @@ static int rk_hdmi_enable(struct udevice *dev, int panel_bpp, static int rk_hdmi_ofdata_to_platdata(struct udevice *dev) { struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct rkhdmi_driverdata *data = + (struct rkhdmi_driverdata *)dev_get_driver_data(dev); struct dw_hdmi *hdmi = &priv->hdmi;
hdmi->ioaddr = (ulong)dev_get_addr(dev); hdmi->mpll_cfg = rockchip_mpll_cfg; hdmi->phy_cfg = rockchip_phy_config; - hdmi->i2c_clk_high = 0x7a; - hdmi->i2c_clk_low = 0x8d; + hdmi->i2c_clk_high = data->i2c_clk_high; + hdmi->i2c_clk_low = data->i2c_clk_low;
- /* - * TODO(sjg@chromium.org): The above values don't work - these ones - * work better, but generate lots of errors in the data. - */ - hdmi->i2c_clk_high = 0x0d; - hdmi->i2c_clk_low = 0x0d; hdmi->reg_io_width = 4; hdmi->phy_set = dw_hdmi_phy_cfg;
@@ -107,13 +171,15 @@ static int rk_hdmi_ofdata_to_platdata(struct udevice *dev)
static int rk_hdmi_probe(struct udevice *dev) { - struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + struct rkhdmi_driverdata *data = + (struct rkhdmi_driverdata *)dev_get_driver_data(dev); struct rk_hdmi_priv *priv = dev_get_priv(dev); struct dw_hdmi *hdmi = &priv->hdmi; struct udevice *reg; struct clk clk; + const char *regulator_name; int ret; - int vop_id = uc_plat->source_id; + int i;
ret = clk_get_by_index(dev, 0, &clk); if (ret >= 0) { @@ -125,33 +191,27 @@ static int rk_hdmi_probe(struct udevice *dev) return ret; }
- /* - * Configure the maximum clock to permit whatever resolution the - * monitor wants - */ - ret = clk_get_by_index(uc_plat->src_dev, 0, &clk); - if (ret >= 0) { - ret = clk_set_rate(&clk, 384000000); - clk_free(&clk); - } - if (ret < 0) { - debug("%s: Failed to set clock in source device '%s': ret=%d\n", - __func__, uc_plat->src_dev->name, ret); - return ret; + if (data->clk_config) { + ret = data->clk_config(dev); + if (ret < 0) + return ret; }
- ret = regulator_get_by_platname("vcc50_hdmi", ®); - if (!ret) - ret = regulator_set_enable(reg, true); - if (ret) - debug("%s: Cannot set regulator vcc50_hdmi\n", __func__); + for (i = 0; i < data->regulator_names_cnt; ++i) { + regulator_name = data->regulator_names[i]; + debug("%s: probing regulator '%s'\n", __func__, regulator_name);
- /* hdmi source select hdmi controller */ - rk_setreg(&priv->grf->soc_con6, 1 << 15); + ret = regulator_autoset_by_name(regulator_name, ®); + if (!ret) + ret = regulator_set_enable(reg, true); + }
- /* hdmi data from vop id */ - rk_clrsetreg(&priv->grf->soc_con6, 1 << 4, - (vop_id == 1) ? (1 << 4) : 0); + if (!data->set_input_vop) { + debug("%s: data->set_input_vop not set\n", __func__); + return -1; + } + + data->set_input_vop(dev);
ret = dw_hdmi_phy_wait_for_hpd(hdmi); if (ret < 0) { @@ -170,8 +230,42 @@ static const struct dm_display_ops rk_hdmi_ops = { .enable = rk_hdmi_enable, };
+static const char * const rk3288_regulator_names[] = { + "vcc50_hdmi", +}; + +static const struct rkhdmi_driverdata rk3288_driverdata = { + /* + * TODO(sjg@chromium.org): The values used for the RK3399 + * (before refactoring: "above values") don't work - these + * ones work better, but generate lots of errors in the data. + */ + .i2c_clk_high = 0x0d, + .i2c_clk_low = 0x0d, + .regulator_names = rk3288_regulator_names, + .regulator_names_cnt = ARRAY_SIZE(rk3288_regulator_names), + .set_input_vop = rk3288_set_input_vop, + .clk_config = rk3288_clk_config, +}; + +static const char * const rk3399_regulator_names[] = { + "vcc1v8_hdmi", + "vcc0v9_hdmi" +}; + +static const struct rkhdmi_driverdata rk3399_driverdata = { + .i2c_clk_high = 0x7a, + .i2c_clk_low = 0x8d, + .regulator_names = rk3399_regulator_names, + .regulator_names_cnt = ARRAY_SIZE(rk3399_regulator_names), + .set_input_vop = rk3399_set_input_vop, +}; + static const struct udevice_id rk_hdmi_ids[] = { - { .compatible = "rockchip,rk3288-dw-hdmi" }, + { .compatible = "rockchip,rk3288-dw-hdmi", + .data = (ulong)&rk3288_driverdata }, + { .compatible = "rockchip,rk3399-dw-hdmi", + .data = (ulong)&rk3399_driverdata }, { } };
This commit enables HDMI output in the DTS by adding the necessary nodes to vopl/vopb and by adding the HDMI node.
Changes in v2: None
arch/arm/dts/rk3399.dtsi | 110 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 110 insertions(+)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index d94d780..4d40198 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -684,6 +684,116 @@ status = "disabled"; };
+ vopl: vop@ff8f0000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3399-vop-lit"; + reg = <0x0 0xff8f0000 0x0 0x3efc>; + interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; + clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + resets = <&cru SRST_A_VOP1>, <&cru SRST_H_VOP1>, <&cru SRST_D_VOP1>; + reset-names = "axi", "ahb", "dclk"; + status = "okay"; + vopl_out: port { + #address-cells = <1>; + #size-cells = <0>; + vopl_out_mipi: endpoint@0 { + reg = <3>; + remote-endpoint = <&mipi_in_vopl>; + }; + + vopl_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_vopl>; + }; + }; + }; + + vopb: vop@ff900000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3399-vop-big"; + reg = <0x0 0xff900000 0x0 0x3efc>; + interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; + #clock-cells = <0>; + clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + resets = <&cru SRST_A_VOP0>, <&cru SRST_H_VOP0>, <&cru SRST_D_VOP0>; + reset-names = "axi", "ahb", "dclk"; + status = "okay"; + vopb_out: port { + #address-cells = <1>; + #size-cells = <0>; + vopb_out_mipi: endpoint@0 { + reg = <3>; + remote-endpoint = <&mipi_in_vopb>; + }; + + vopb_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_vopb>; + }; + }; + }; + + hdmi: hdmi@ff940000 { + compatible = "rockchip,rk3399-dw-hdmi"; + reg = <0x0 0xff940000 0x0 0x20000>; + reg-io-width = <4>; + rockchip,grf = <&grf>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_i2c_xfer>; + power-domains = <&power RK3399_PD_HDCP>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_SFR>, <&cru PLL_VPLL>, <&cru PCLK_VIO_GRF>; + clock-names = "iahb", "isfr", "vpll", "grf"; + status = "disabled"; + + ports { + hdmi_in: port { + #address-cells = <1>; + #size-cells = <0>; + hdmi_in_vopb: endpoint@0 { + reg = <0>; + remote-endpoint = <&vopb_out_hdmi>; + }; + hdmi_in_vopl: endpoint@1 { + reg = <1>; + remote-endpoint = <&vopl_out_hdmi>; + }; + }; + }; + }; + + mipi_dsi: mipi@ff960000 { + compatible = "rockchip,rk3399_mipi_dsi"; + reg = <0x0 0xff960000 0x0 0x8000>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru SCLK_MIPIDPHY_REF>, <&cru PCLK_MIPI_DSI0>, + <&cru SCLK_DPHY_TX0_CFG>; + clock-names = "ref", "pclk", "phy_cfg"; + rockchip,grf = <&grf>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + ports { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + mipi_in: port { + #address-cells = <1>; + #size-cells = <0>; + mipi_in_vopb: endpoint@0 { + reg = <0>; + remote-endpoint = <&vopb_out_mipi>; + }; + mipi_in_vopl: endpoint@1 { + reg = <1>; + remote-endpoint = <&vopl_out_mipi>; + }; + }; + }; + }; + pinctrl: pinctrl { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pinctrl";
On 28 April 2017 at 10:34, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Changes in v2: None
Philipp Tomsich
sjg@google.com
