[U-Boot] [PATCH 1/2] Allow CONFIG_REGEX to be disabled when CONFIG_NET
Instead of selecting REGEX when NET is enabled, make it the default, but allow boards that are tiny to disable it and lose functionality on all but the first Ethernet adapter.
cm-bf548, bf538f-ezkit, and bf533-stamp need this. None appear to have more than one Ethernet interface.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com ---
include/env_callback.h | 4 +++- lib/Kconfig | 1 + net/Kconfig | 1 - 3 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/include/env_callback.h b/include/env_callback.h index ab5d42d..90b95b5 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -33,8 +33,10 @@
#ifdef CONFIG_REGEX #define ENV_DOT_ESCAPE "\" +#define ETHADDR_WILDCARD "\d?" #else #define ENV_DOT_ESCAPE +#define ETHADDR_WILDCARD #endif
#ifdef CONFIG_CMD_DNS @@ -53,7 +55,7 @@ "nvlan:nvlan," \ "vlan:vlan," \ DNS_CALLBACK \ - "eth\d?addr:ethaddr," + "eth" ETHADDR_WILDCARD "addr:ethaddr," #else #define NET_CALLBACKS #endif diff --git a/lib/Kconfig b/lib/Kconfig index 7ec8c98..c98d399 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -38,6 +38,7 @@ config SYS_VSNPRINTF
config REGEX bool "Enable regular expression support" + default y if NET help If this variable is defined, U-Boot is linked against the SLRE (Super Light Regular Expression) library, which adds diff --git a/net/Kconfig b/net/Kconfig index 9a9846e..915371d 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -4,7 +4,6 @@
menuconfig NET bool "Networking support" - select REGEX
if NET
bf533-stamp, bf538f-ezkit, and cm-bf548 are very space limited.
This was introduced by: 6e0d26c0502e (net: Handle ethaddr changes as an env callback) by enabling CONFIG_REGEX, which is too big for these boards.
This patch disables CONFIG_REGEX at the expense of working with more than the first ethaddr.
configs/bf533-stamp_defconfig | 1 + configs/bf538f-ezkit_defconfig | 1 + configs/cm-bf548_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/bf533-stamp_defconfig b/configs/bf533-stamp_defconfig index 154dc26..4956078 100644 --- a/configs/bf533-stamp_defconfig +++ b/configs/bf533-stamp_defconfig @@ -2,4 +2,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF533_STAMP=y # CONFIG_CMD_SETEXPR is not set CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y +# CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/bf538f-ezkit_defconfig b/configs/bf538f-ezkit_defconfig index 6cb6c6b..668f9cb 100644 --- a/configs/bf538f-ezkit_defconfig +++ b/configs/bf538f-ezkit_defconfig @@ -2,4 +2,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF538F_EZKIT=y # CONFIG_CMD_SETEXPR is not set CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y +# CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index 949612d..49d59dd 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -2,4 +2,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF548=y # CONFIG_CMD_SETEXPR is not set CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y +# CONFIG_REGEX is not set CONFIG_LIB_RAND=y
Hi Tom,
On Mon, Jun 22, 2015 at 5:57 PM, Joe Hershberger joe.hershberger@ni.com wrote:
This is a build fix, so it should probably be part of v2015.07.
Cheers, -Joe
Hi Tom,
Cheers, -Joe
Joe Hershberger
Joe Hershberger
