[U-Boot-Users] [PATCH 0/6] Update sbc8560; enable fdt/powerpc support
[Resending with Ben's network setting removal done in patch #3; there were no other request for changes, so this should be good to go...]
The following six patches update the sbc8560 support to fix a memsize bug + some bitrot (1st three), and then add/enable the powerpc/fdt support (the second three). One additional patch required for using the sbc8560 on 1.3.x; the setting of the UART clk in mpc85xx/fdt.c isn't included here, as that wasn't a fix in a board specific file, and so it is being reviewed/submitted separately.
Thanks, Paul.
0001-sbc8560-proper-definitions-for-TSEC.patch b/include/configs/sbc8560.h | 32 ++++++++++++++++++++++----------
0002-sbc8560-properly-set-cs0_bnds-for-512MB.patch b/board/sbc8560/sbc8560.c | 4 ++++
0003-sbc8560-define-eth0-and-eth1-instead-of-eth1-and-eth2.patch b/include/configs/sbc8560.h | 22 +++++++++++++---------
0004-sbc8560-add-in-ft_board_setup.patch b/board/sbc8560/sbc8560.c | 28 ++++++++++++++++++++++++++++
0005-sbc8560-add-default-fdt-values.patch b/include/configs/sbc8560.h | 34 +++++++++++++++++++++++++++++++---
0006-sbc8560-enable-CONFIG_OF_LIBFDT-by-default.patch b/include/configs/sbc8560.h | 5 +++++
The definitions for the TSEC have become out of date. There is no longer any such options like "CONFIG_MPC85xx_TSEC1" or similar. Update to match those of other boards, like the MPC8560ADS.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com Acked-by: Ben Warren biggerbadderben@gmail.com --- include/configs/sbc8560.h | 32 ++++++++++++++++++++++---------- 1 files changed, 22 insertions(+), 10 deletions(-)
diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index 146eafe..f07fbc0 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -215,16 +215,28 @@ #define CFG_PCI_MEM_PHYS 0xC0000000 #define CFG_PCI_MEM_SIZE 0x10000000
-#if defined(CONFIG_TSEC_ENET) /* TSEC Ethernet port */ - -# define CONFIG_NET_MULTI 1 -# define CONFIG_MII 1 /* MII PHY management */ -# define CONFIG_MPC85xx_TSEC1 -# define CONFIG_MPC85xx_TSEC1_NAME "TSEC0" -# define TSEC1_PHY_ADDR 25 -# define TSEC1_PHYIDX 0 -/* Options are: TSEC0 */ -# define CONFIG_ETHPRIME "TSEC0" +#ifdef CONFIG_TSEC_ENET + +#ifndef CONFIG_NET_MULTI +#define CONFIG_NET_MULTI 1 +#endif + +#ifndef CONFIG_MII +#define CONFIG_MII 1 /* MII PHY management */ +#endif +#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1_NAME "TSEC0" +#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2_NAME "TSEC1" +#define TSEC1_PHY_ADDR 0x19 +#define TSEC2_PHY_ADDR 0x1a +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define TSEC1_FLAGS TSEC_GIGABIT +#define TSEC2_FLAGS TSEC_GIGABIT + +/* Options are: TSEC[0-1] */ +#define CONFIG_ETHPRIME "TSEC0"
#elif defined(CONFIG_ETHER_ON_FCC) /* CPM FCC Ethernet */
The sbc8560 board ships with 512MB of memory installed, but the current cs0_bnds is hard coded for 256MB. Set the value based on CFG_SDRAM_SIZE.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8560/sbc8560.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/board/sbc8560/sbc8560.c b/board/sbc8560/sbc8560.c index 2946ca1..3b6b541 100644 --- a/board/sbc8560/sbc8560.c +++ b/board/sbc8560/sbc8560.c @@ -421,7 +421,11 @@ long int fixed_sdram (void) #ifndef CFG_RAMBOOT volatile ccsr_ddr_t *ddr= (void *)(CFG_MPC85xx_DDR_ADDR);
+#if (CFG_SDRAM_SIZE == 512) + ddr->cs0_bnds = 0x0000000f; +#else ddr->cs0_bnds = 0x00000007; +#endif ddr->cs1_bnds = 0x0010001f; ddr->cs2_bnds = 0x00000000; ddr->cs3_bnds = 0x00000000;
The existing config doesn't define CONFIG_HAS_ETH0, and so the fdt support doesn't update the zeros in the dtb local-mac with real data from the u-boot env. Since the existing config is tailored to just two interfaces, get rid of the ETH2 definitions at the same time.
Also don't include any end user specific data into the environment by default -- things like MAC address, network parameters etc. need to come from the end user.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- include/configs/sbc8560.h | 22 +++++++++++++--------- 1 files changed, 13 insertions(+), 9 deletions(-)
diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index f07fbc0..f4408ad 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -327,9 +327,8 @@ #define CFG_ENV_SIZE 0x2000 #endif
-#define CONFIG_BOOTARGS "root=/dev/nfs rw nfsroot=192.168.0.251:/tftpboot ip=192.168.0.105:192.168.0.251::255.255.255.0:sbc8560:eth0:off console=ttyS0,9600" +#define CONFIG_BOOTARGS "root=/dev/nfs rw ip=dhcp console=ttyS0,9600" /*#define CONFIG_BOOTARGS "root=/dev/ram rw console=ttyS0,115200"*/ -#define CONFIG_BOOTCOMMAND "bootm 0xff800000 0xffa00000" #define CONFIG_BOOTDELAY 5 /* -1 disable autoboot */
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ @@ -405,19 +404,24 @@ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
-/*Note: change below for your network setting!!! */ #if defined(CONFIG_TSEC_ENET) || defined(CONFIG_ETHER_ON_FCC) -# define CONFIG_ETHADDR 00:01:af:07:9b:8a -# define CONFIG_HAS_ETH1 -# define CONFIG_ETH1ADDR 00:01:af:07:9b:8b -# define CONFIG_HAS_ETH2 -# define CONFIG_ETH2ADDR 00:01:af:07:9b:8c +#define CONFIG_HAS_ETH0 +#define CONFIG_HAS_ETH1 #endif
+/* You can compile in a MAC address and your custom net settings by using + * the * following syntax. Your board should be marked with the assigned + * MAC addresses directly on it. + */ +#if 0 +#define CONFIG_ETHADDR 00:01:af:07:9b:8a +#define CONFIG_ETH1ADDR 00:01:af:07:9b:8b #define CONFIG_SERVERIP 192.168.0.131 #define CONFIG_IPADDR 192.168.0.105 -#define CONFIG_GATEWAYIP 0.0.0.0 +#define CONFIG_GATEWAYIP 192.168.0.1 #define CONFIG_NETMASK 255.255.255.0 +#endif + #define CONFIG_HOSTNAME SBC8560 #define CONFIG_ROOTPATH /home/ppc #define CONFIG_BOOTFILE pImage
Add in for the sbc8560, the ft_board_setup() routine, based on what is in use for the Freescale MPC8560ADS board.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8560/sbc8560.c | 28 ++++++++++++++++++++++++++++ 1 files changed, 28 insertions(+), 0 deletions(-)
diff --git a/board/sbc8560/sbc8560.c b/board/sbc8560/sbc8560.c index 3b6b541..d9e598c 100644 --- a/board/sbc8560/sbc8560.c +++ b/board/sbc8560/sbc8560.c @@ -33,6 +33,8 @@ #include <ioports.h> #include <spd_sdram.h> #include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h>
long int fixed_sdram (void);
@@ -456,3 +458,29 @@ long int fixed_sdram (void) return CFG_SDRAM_SIZE * 1024 * 1024; } #endif /* !defined(CONFIG_SPD_EEPROM) */ + + +#if defined(CONFIG_OF_BOARD_SETUP) +void +ft_board_setup(void *blob, bd_t *bd) +{ + int node, tmp[2]; +#ifdef CONFIG_PCI + const char *path; +#endif + + ft_cpu_setup(blob, bd); + + node = fdt_path_offset(blob, "/aliases"); + tmp[0] = 0; + if (node >= 0) { +#ifdef CONFIG_PCI + path = fdt_getprop(blob, node, "pci0", NULL); + if (path) { + tmp[1] = hose.last_busno - hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } +#endif + } +} +#endif
Add in the default fdt settings and the typical EXTRA_ENV settings as borrowed from the mpc8560ads. Fix a couple of stale references to the mpc8560ads dating back to the original clone/fork.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- include/configs/sbc8560.h | 34 +++++++++++++++++++++++++++++++--- 1 files changed, 31 insertions(+), 3 deletions(-)
diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index f4408ad..324120e 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -24,8 +24,8 @@ * MA 02111-1307 USA */
-/* mpc8560ads board configuration file */ -/* please refer to doc/README.mpc85xx for more info */ +/* sbc8560 board configuration file */ +/* please refer to doc/README.sbc8560 for more info */ /* make sure you change the MAC address and other network params first, * search for CONFIG_ETHADDR,CONFIG_SERVERIP,etc in this file */ @@ -424,6 +424,34 @@
#define CONFIG_HOSTNAME SBC8560 #define CONFIG_ROOTPATH /home/ppc -#define CONFIG_BOOTFILE pImage +#define CONFIG_BOOTFILE uImage + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=sbc8560.dtb\0" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_NFSBOOTCOMMAND
#endif /* __CONFIG_H */
Make the default build for the sbc8560 board be powerpc capable with libfdt support.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- include/configs/sbc8560.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index 324120e..cf2f41c 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -200,6 +200,11 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
+/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + /* * I2C */
On Fri, Jul 11, 2008 at 2:33 PM, Paul Gortmaker paul.gortmaker@windriver.com wrote:
Applied, thanks
Andy
In message 2390b6bccc0e647f1fd12e2512fb6095a0355ec5.1215803423.git.paul.gortmaker@windriver.com you wrote:
- "netdev=eth0\0" \
- "consoledev=ttyS0\0" \
- "ramdiskaddr=2000000\0" \
- "ramdiskfile=ramdisk.uboot\0" \
- "fdtaddr=c00000\0" \
- "fdtfile=sbc8560.dtb\0"
- "setenv bootargs root=/dev/nfs rw " \
- "tftp $loadaddr $bootfile;" \
- "tftp $fdtaddr $fdtfile;" \
- "bootm $loadaddr - $fdtaddr"
- "setenv bootargs root=/dev/ram rw " \
- "tftp $ramdiskaddr $ramdiskfile;" \
- "bootm $loadaddr $ramdiskaddr $fdtaddr"
Indentation by TAB, please.
Ah, sorry -- I inherited that verbatim from MPC8560ADS.h -- I'll respin and send an independent fix for MPC8560ADS as well.
P.
On Fri, Jul 11, 2008 at 5:02 PM, Paul Gortmaker paul.gortmaker@windriver.com wrote:
I made the changes for you, and added the change for the 8560 as a separate patch.
Andy
Applied, thanks
Andy
- the * following syntax. Your board should be marked with the assigned
- MAC addresses directly on it.
That's a good way of doing it. I know people generally don't like #if 0, but you're conveying useful information.
regards, Ben
In message 8dee444198e3c87ef471198cbd2e25c4e1b558fb.1215803423.git.paul.gortmaker@windriver.com you wrote:
Bogus '*' here?
I think this should be removed. There is really no good reason to add network configuration at all to the board config file (with the exception of the 2 or 3 boards which actually boot from real ROM).
No problem. I'll remove and resend.
Thanks, Paul.
On Fri, Jul 11, 2008 at 5:03 PM, Paul Gortmaker paul.gortmaker@windriver.com wrote:
As a compromise between removal and keeping the useful information for developers who are doing early bringup on similar boards, I have applied this patch, and replaced the above with:
/* You can compile in a MAC address and your custom net settings by using * the following syntax. Your board should be marked with the assigned * MAC addresses directly on it. * * #define CONFIG_ETHADDR de:ad:be:ef:00:00 * #define CONFIG_ETH1ADDR fa:ke:ad:dr:es:s! * #define CONFIG_SERVERIP <server ip> * #define CONFIG_IPADDR <board ip> * #define CONFIG_GATEWAYIP <gateway ip> * #define CONFIG_NETMASK <your netmask> */
Wolfgang, if you still object, I can totally remove it before you pull (git rebase --interactive is a wonderful thing).
I also corrected some whitespace issues where comments trailed off the end of the line for no good reason.
Thanks, Andy
In message 2acbd3e40807141751i39bd23a4v304dd03a65905a93@mail.gmail.com you wrote:
- the following syntax. Your board should be marked with the assigned
- #define CONFIG_ETHADDR de:ad:be:ef:00:00
- #define CONFIG_ETH1ADDR fa:ke:ad:dr:es:s!
- #define CONFIG_SERVERIP <server ip>
- #define CONFIG_IPADDR <board ip>
- #define CONFIG_GATEWAYIP <gateway ip>
- #define CONFIG_NETMASK <your netmask>
That's OK with me.
Indeed, isn't it? I still remember times when we had to use CVS - or even ClearCase...
That's OK with me.
Why did you have to bring up ClearCase? Today was just starting to show some promise :-)
That seems like a reasonable compromise to me. Thanks for doing this and merging the rest of the patches.
Paul.
Thanks, Andy
Applied, thanks Andy
Applied, thanks!
Andy
Andy Fleming
Ben Warren
Paul Gortmaker
