[U-Boot] [PATCH 1/4] ARM: mx6: ddr: Make debug prints work with tiny printf
The %08X format returns just zeroes with tiny printf, which is horribly confusing, especially when debugging DRAM calibration problems. Change the format to %08x (with lowercase x), which behaves correctly with either implementation of printf in SPL.
Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/mx6/ddr.c | 24 ++++++++++++------------ 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/ddr.c b/arch/arm/mach-imx/mx6/ddr.c index 84b9236249..e6f69e904f 100644 --- a/arch/arm/mach-imx/mx6/ddr.c +++ b/arch/arm/mach-imx/mx6/ddr.c @@ -214,14 +214,14 @@ int mmdc_do_write_level_calibration(struct mx6_ddr_sysinfo const *sysinfo) writel(esdmisc_val, &mmdc0->mdref); writel(zq_val, &mmdc0->mpzqhwctrl);
- debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08X\n", + debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08x\n", readl(&mmdc0->mpwldectrl0)); - debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n", + debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08x\n", readl(&mmdc0->mpwldectrl1)); if (sysinfo->dsize == 2) { - debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08X\n", + debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08x\n", readl(&mmdc1->mpwldectrl0)); - debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n", + debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08x\n", readl(&mmdc1->mpwldectrl1)); }
@@ -557,20 +557,20 @@ int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo) */ debug("MMDC registers updated from calibration\n"); debug("Read DQS gating calibration:\n"); - debug("\tMPDGCTRL0 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl0)); - debug("\tMPDGCTRL1 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl1)); + debug("\tMPDGCTRL0 PHY0 = 0x%08x\n", readl(&mmdc0->mpdgctrl0)); + debug("\tMPDGCTRL1 PHY0 = 0x%08x\n", readl(&mmdc0->mpdgctrl1)); if (sysinfo->dsize == 2) { - debug("\tMPDGCTRL0 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl0)); - debug("\tMPDGCTRL1 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl1)); + debug("\tMPDGCTRL0 PHY1 = 0x%08x\n", readl(&mmdc1->mpdgctrl0)); + debug("\tMPDGCTRL1 PHY1 = 0x%08x\n", readl(&mmdc1->mpdgctrl1)); } debug("Read calibration:\n"); - debug("\tMPRDDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mprddlctl)); + debug("\tMPRDDLCTL PHY0 = 0x%08x\n", readl(&mmdc0->mprddlctl)); if (sysinfo->dsize == 2) - debug("\tMPRDDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mprddlctl)); + debug("\tMPRDDLCTL PHY1 = 0x%08x\n", readl(&mmdc1->mprddlctl)); debug("Write calibration:\n"); - debug("\tMPWRDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mpwrdlctl)); + debug("\tMPWRDLCTL PHY0 = 0x%08x\n", readl(&mmdc0->mpwrdlctl)); if (sysinfo->dsize == 2) - debug("\tMPWRDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mpwrdlctl)); + debug("\tMPWRDLCTL PHY1 = 0x%08x\n", readl(&mmdc1->mpwrdlctl));
/* * Registers below are for debugging purposes. These print out
Pull out the code turning SDQS pullups on and off into a separate function, since it is replicated in two places in the code and it is the single place in the entire function which is SoC dependent.
Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/mx6/ddr.c | 46 ++++++++++++++++++++++--------------- 1 file changed, 28 insertions(+), 18 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/ddr.c b/arch/arm/mach-imx/mx6/ddr.c index e6f69e904f..e917b04f3d 100644 --- a/arch/arm/mach-imx/mx6/ddr.c +++ b/arch/arm/mach-imx/mx6/ddr.c @@ -245,12 +245,36 @@ int mmdc_do_write_level_calibration(struct mx6_ddr_sysinfo const *sysinfo) return errors; }
+static void mmdc_set_sdqs(bool set) +{ + struct mx6dq_iomux_ddr_regs *mx6_ddr_iomux = + (struct mx6dq_iomux_ddr_regs *)MX6DQ_IOM_DDR_BASE; + + if (set) { + setbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); + } else { + clrbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); + } +} + int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo) { struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; - struct mx6dq_iomux_ddr_regs *mx6_ddr_iomux = - (struct mx6dq_iomux_ddr_regs *)MX6DQ_IOM_DDR_BASE; bool cs0_enable; bool cs1_enable; bool cs0_enable_initial; @@ -272,14 +296,7 @@ int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo) setbits_le32(&mmdc0->mapsr, 0x1);
/* set DQS pull ups */ - setbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); + mmdc_set_sdqs(true);
/* Save old RALAT and WALAT values */ esdmisc_val = readl(&mmdc0->mdmisc); @@ -524,14 +541,7 @@ int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo) writel(esdmisc_val, &mmdc0->mdmisc);
/* Clear DQS pull ups */ - clrbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); + mmdc_set_sdqs(false);
/* Re-enable SDE (chip selects) if they were set initially */ if (cs1_enable_initial)
Hi Marek,
- if (set) {
- } else {
- int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo) { struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR;
bool cs0_enable; bool cs1_enable; bool cs0_enable_initial;(struct mx6dq_iomux_ddr_regs *)MX6DQ_IOM_DDR_BASE;
Reviewed-by: Eric Nelson eric@nelint.com
Pull out the code turning SDQS pullups on and off into a separate function, since it is replicated in two places in the code and it is the single place in the entire function which is SoC dependent. Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Eric Nelson eric@nelint.com
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Instead of explicitly setting up each SDQS register, use a loop. No functional change.
Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/mx6/ddr.c | 27 ++++++++------------------- 1 file changed, 8 insertions(+), 19 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/ddr.c b/arch/arm/mach-imx/mx6/ddr.c index e917b04f3d..b2402f75db 100644 --- a/arch/arm/mach-imx/mx6/ddr.c +++ b/arch/arm/mach-imx/mx6/ddr.c @@ -249,25 +249,14 @@ static void mmdc_set_sdqs(bool set) { struct mx6dq_iomux_ddr_regs *mx6_ddr_iomux = (struct mx6dq_iomux_ddr_regs *)MX6DQ_IOM_DDR_BASE; - - if (set) { - setbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); - setbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); - } else { - clrbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); - clrbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); + u32 sdqs = (u32)(&mx6_ddr_iomux->dram_sdqs0); + int i; + + for (i = 0; i < 8; i++) { + if (set) + setbits_le32(sdqs + (4 * i), 0x7000); + else + clrbits_le32(sdqs + (4 * i), 0x7000); } }
Hi Marek,
- if (set) {
- } else {
- u32 sdqs = (u32)(&mx6_ddr_iomux->dram_sdqs0);
- int i;
- for (i = 0; i < 8; i++) {
if (set)
else
} }clrbits_le32(sdqs + (4 * i), 0x7000);
Instead of explicitly setting up each SDQS register, use a loop. No functional change. Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Eric Nelson eric@nelint.com
This patch adds support for iMX6SX MMDC into the DDR calibration code. The only difference between MX6DQ and MX6SX is that the SX has 2 SDQS registers, while the DQ has 8.
Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/mx6/ddr.c | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/ddr.c b/arch/arm/mach-imx/mx6/ddr.c index b2402f75db..8ed8b79c8b 100644 --- a/arch/arm/mach-imx/mx6/ddr.c +++ b/arch/arm/mach-imx/mx6/ddr.c @@ -247,12 +247,22 @@ int mmdc_do_write_level_calibration(struct mx6_ddr_sysinfo const *sysinfo)
static void mmdc_set_sdqs(bool set) { - struct mx6dq_iomux_ddr_regs *mx6_ddr_iomux = + struct mx6dq_iomux_ddr_regs *mx6dq_ddr_iomux = (struct mx6dq_iomux_ddr_regs *)MX6DQ_IOM_DDR_BASE; - u32 sdqs = (u32)(&mx6_ddr_iomux->dram_sdqs0); - int i; + struct mx6sx_iomux_ddr_regs *mx6sx_ddr_iomux = + (struct mx6sx_iomux_ddr_regs *)MX6SX_IOM_DDR_BASE; + int i, sdqs_cnt; + u32 sdqs; + + if (is_mx6sx()) { + sdqs = (u32)(&mx6sx_ddr_iomux->dram_sdqs0); + sdqs_cnt = 2; + } else { /* MX6DQ */ + sdqs = (u32)(&mx6dq_ddr_iomux->dram_sdqs0); + sdqs_cnt = 8; + }
- for (i = 0; i < 8; i++) { + for (i = 0; i < sdqs_cnt; i++) { if (set) setbits_le32(sdqs + (4 * i), 0x7000); else
Hi Marek,
- struct mx6dq_iomux_ddr_regs *mx6dq_ddr_iomux = (struct mx6dq_iomux_ddr_regs *)MX6DQ_IOM_DDR_BASE;
- int i;
- struct mx6sx_iomux_ddr_regs *mx6sx_ddr_iomux =
- int i, sdqs_cnt;
- u32 sdqs;
- if (is_mx6sx()) {
sdqs_cnt = 2;
- } else { /* MX6DQ */
sdqs_cnt = 8;
- for (i = 0; i < sdqs_cnt; i++) { if (set) setbits_le32(sdqs + (4 * i), 0x7000); else
This patch adds support for iMX6SX MMDC into the DDR calibration code. The only difference between MX6DQ and MX6SX is that the SX has 2 SDQS registers, while the DQ has 8. Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Eric Nelson eric@nelint.com
Hi Marek,
- debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08x\n", readl(&mmdc0->mpwldectrl0));
- debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08x\n", readl(&mmdc0->mpwldectrl1)); if (sysinfo->dsize == 2) {
}debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08x\n", readl(&mmdc1->mpwldectrl1));
- debug("\tMPDGCTRL0 PHY0 = 0x%08x\n", readl(&mmdc0->mpdgctrl0));
- debug("\tMPDGCTRL1 PHY0 = 0x%08x\n", readl(&mmdc0->mpdgctrl1)); if (sysinfo->dsize == 2) {
} debug("Read calibration:\n");debug("\tMPDGCTRL1 PHY1 = 0x%08x\n", readl(&mmdc1->mpdgctrl1));
- debug("\tMPRDDLCTL PHY0 = 0x%08x\n", readl(&mmdc0->mprddlctl)); if (sysinfo->dsize == 2)
debug("Write calibration:\n");debug("\tMPRDDLCTL PHY1 = 0x%08x\n", readl(&mmdc1->mprddlctl));
- debug("\tMPWRDLCTL PHY0 = 0x%08x\n", readl(&mmdc0->mpwrdlctl)); if (sysinfo->dsize == 2)
- Registers below are for debugging purposes. These print out
The %08X format returns just zeroes with tiny printf, which is horribly confusing, especially when debugging DRAM calibration problems. Change the format to %08x (with lowercase x), which behaves correctly with either implementation of printf in SPL. Signed-off-by: Marek Vasut marex@denx.de Cc: Eric Nelson eric@nelint.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Eric Nelson eric@nelint.com
Eric Nelson
sbabic@denx.de
