i.MX8QXP MEK does not boot with latest U-Boot
Hi Peng,
I am trying to boot the latest U-Boot mainline on a imx8qxp mek board and this is what I get:
U-Boot SPL 2020.01-rc5-00001-g3dd6a9300b-dirty (Dec 17 2019 - 12:33:57 -0300) Normal Boot WDT: Not found! Trying to boot from MMC2_2 Load image from MMC/SD 0x46800
U-Boot 2020.01-rc5-00001-g3dd6a9300b-dirty (Dec 17 2019 - 12:33:57 -0300)
CPU: NXP i.MX8QXP RevB A35 at 1200 MHz at 31C
Model: Freescale i.MX8QXP MEK Board: iMX8QXP MEK Build: SCFW 550f3079, SECO-FW d7523fe8, ATF f92d379 Boot: SD1 DRAM: 3 GiB Failed to enable ipg clk MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 Net: Failed to enable ipg clk
Error: ethernet@5b040000 address not set.
(It hangs here).
I am using the SC and seco firmware from the 4.19.35 release.
Here is the updated README that I am following: http://code.bulix.org/i8bhp8-1018627
Any ideas as to how to fix this boot problem?
Thanks
Hi Peng,
On Tue, Dec 17, 2019 at 12:46 PM Fabio Estevam festevam@gmail.com wrote:
Hi Peng,
(It hangs here).
Did you have a chance to look at this boot regression?
Thanks
Fabio Estevam
