[PATCH 0/2] Add AM64x Support to PRUSS and PRU_RPROC driver
This series adds AM64x related compatibles to PRUSS and PRU_RPROC drivers. This series is a prerequisite for ICSSG Ethernet driver.
Once Support for AM64x is added to PRUSS and PRU_RPROC driver, I'll send another series to enable ICSSG Ethernet driver for AM64x as well.
MD Danish Anwar (2): remoteproc: pru: Add support for AM64x PRU / RTU cores soc: ti: pruss: Add support for AM64x
drivers/remoteproc/pru_rproc.c | 9 +++++++-- drivers/soc/ti/pruss.c | 1 + 2 files changed, 8 insertions(+), 2 deletions(-)
base-commit: ff0de1f0557ed7d2dab47ba976a37347a1fdc432
Add support for AM64x PRU cores by adding compatibles for AM64x.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/remoteproc/pru_rproc.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/remoteproc/pru_rproc.c b/drivers/remoteproc/pru_rproc.c index 6ec55e27d9..5e9334e117 100644 --- a/drivers/remoteproc/pru_rproc.c +++ b/drivers/remoteproc/pru_rproc.c @@ -399,10 +399,12 @@ static void pru_set_id(struct pru_privdata *priv, struct udevice *dev) { u32 mask2 = 0x38000;
- if (device_is_compatible(dev, "ti,am654-rtu")) + if (device_is_compatible(dev, "ti,am654-rtu") || + device_is_compatible(dev, "ti,am642-rtu")) mask2 = 0x6000;
- if (device_is_compatible(dev, "ti,am654-tx-pru")) + if (device_is_compatible(dev, "ti,am654-tx-pru") || + device_is_compatible(dev, "ti,am642-tx-pru")) mask2 = 0xc000;
if ((priv->pru_iram & mask2) == mask2) @@ -448,6 +450,9 @@ static const struct udevice_id pru_ids[] = { { .compatible = "ti,am654-pru"}, { .compatible = "ti,am654-rtu"}, { .compatible = "ti,am654-tx-pru" }, + { .compatible = "ti,am642-pru"}, + { .compatible = "ti,am642-rtu"}, + { .compatible = "ti,am642-tx-pru" }, {} };
Reviewed-by: Roger Quadros rogerq@kernel.org
Add support for AM64x by adding it's compatible in pruss driver.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/soc/ti/pruss.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/soc/ti/pruss.c b/drivers/soc/ti/pruss.c index 461390925d..5317b8335b 100644 --- a/drivers/soc/ti/pruss.c +++ b/drivers/soc/ti/pruss.c @@ -205,6 +205,7 @@ static int pruss_probe(struct udevice *dev)
static const struct udevice_id pruss_ids[] = { { .compatible = "ti,am654-icssg"}, + { .compatible = "ti,am642-icssg"}, {} };
Hi Tom,
I was working on the latest u-boot/next (d4781422d1 (origin/next) "Merge tag 'v2024.07-rc3' into next") and I don't see this series being part of u-boot/next.
I checked the git logs, you had merged this series but on 18th may you committed [1] ("Revert "Merge patch series "arm: dts: am62-beagleplay: Fix Beagleplay Ethernet""") which reverts bunch of changes and as part of this commit, this series was also reverted.
Now when I am trying to verify ICSSG, it doesn't work as this series is not part of u-boot/next anymore.
Can you please pull / merge this series again to u-boot/next? Or do I need to send these patches for merge again?
Please let me know.
[1] https://source.denx.de/u-boot/u-boot/-/commit/d678a59d2d719da9e807495b4b0215...
On Tue, May 21, 2024 at 02:31:44PM +0530, MD Danish Anwar wrote:
Hi Tom,
Please let me know.
Please re-post based on current next, sorry for the rework.
Hi Tom,
Hi Tom,
Please let me know.
I see that now this series is part of u-boot/next. Your commit [1] has restored the changes. Thanks for that.
[1] https://source.denx.de/u-boot/u-boot/-/commit/03de305ec48b0bb28554372abb40cc...
MD Danish Anwar
Roger Quadros
