RE: [U-Boot-Users] Network problem in u-boot.
Hi! Yes the mac is valid. I use 100Mbps FD and bootp to get an adress. U-boot gets IP 172.18.22.66 and netmask is 255.255.255.0
I´ll try to enable debugging later and post the results.
//Andre
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de] Sent: den 14 november 2005 16:20 To: u-boot-users@lists.sourceforge.net Cc: Wolfgang Denk; André Berggren Subject: Re: [U-Boot-Users] Network problem in u-boot.
On Monday 14 November 2005 16:12, Wolfgang Denk wrote:
The problem is that sometimes the network in u-boot stops, e.g. just getting TTT in a tftp transfer. I foud out that this occurs when another packet not involed in the tftp fransfer arrives. It could be a TCP-connect attempt from another host to u-boot or a ARP request. With a network sniffer I can se that u-boot still send data, but all data ariving is never processed. A reset of the board is needed to get it up and running again.
The board is a custom bord whith AMCC440ep based on bamboo.
I cannot confirm this. I just tested approx. 20 downloads on a bamboo board without any such problems.
What exactly is your network configuration? 10 / 100 Mbps? FD / HD? IP addresses? Netmask?
And do you use a valid MAC address? Did you try to enable debugging in the 4xx ethernet driver? If not, please do this and post some results here.
Viele Grüße, Stefan ###########################################
This message has been scanned by F-Secure Anti-Virus for Microsoft Exchange. For more information, connect to http://www.f-secure.com/
André Berggren
