[U-Boot] [PATCH v1 0/2] ARM: mvebu: a38x: updates
This small series represents some low hanging fruit needed before we can bring in the updated version of Marvell's DDR training code. These are things that really shouldn't have been part of the DDR code in the first place but for one reason or another ended up there.
Patch 2 is borrowed in part from commit 09275c77 in https://github.com/MarvellEmbeddedProcessors/u-boot-marvell.git
Chris Packham (2): ARM: mvebu: a38x: move definition of PEX_CFG_DIRECT_ACCESS ARM: mvebu: a38x: move sys_env_device_rev_get
arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h | 1 + arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c | 24 ++++++++++++++++++++++ .../ddr/marvell/a38x/ddr3_hws_hw_training_def.h | 2 -- drivers/ddr/marvell/a38x/ddr3_init.c | 24 ---------------------- 4 files changed, 25 insertions(+), 26 deletions(-)
PEX_CFG_DIRECT_ACCESS was defined in ddr3_hws_hw_training_def.h despite only being used in the serdes code. Move this definition to ctrl_pex.h where all the other PEX defines are. Also remove the duplicate definition of PEX_DEVICE_AND_VENDOR_ID which is already defined in ctrl_pex.h.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h | 1 + drivers/ddr/marvell/a38x/ddr3_hws_hw_training_def.h | 2 -- 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h b/arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h index ca8a4d206a36..d6f0d4fcd381 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h +++ b/arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h @@ -47,6 +47,7 @@
/* Controller revision info */ #define PEX_DEVICE_AND_VENDOR_ID 0x000 +#define PEX_CFG_DIRECT_ACCESS(if, reg) (PEX_IF_REGS_BASE(if) + (reg))
/* PCI Express Configuration Address Register */ #define PXCAR_REG_NUM_OFFS 2 diff --git a/drivers/ddr/marvell/a38x/ddr3_hws_hw_training_def.h b/drivers/ddr/marvell/a38x/ddr3_hws_hw_training_def.h index 06d0ab10aa2a..bca0af89a72d 100644 --- a/drivers/ddr/marvell/a38x/ddr3_hws_hw_training_def.h +++ b/drivers/ddr/marvell/a38x/ddr3_hws_hw_training_def.h @@ -422,8 +422,6 @@
/* Power Management Clock Gating Control Register */ #define POWER_MNG_CTRL_REG 0x18220 -#define PEX_DEVICE_AND_VENDOR_ID 0x000 -#define PEX_CFG_DIRECT_ACCESS(if, reg) (PEX_IF_REGS_BASE(if) + (reg)) #define PMC_PEXSTOPCLOCK_OFFS(p) ((p) < 8 ? (5 + (p)) : (18 + (p))) #define PMC_PEXSTOPCLOCK_MASK(p) (1 << PMC_PEXSTOPCLOCK_OFFS(p)) #define PMC_PEXSTOPCLOCK_EN(p) (1 << PMC_PEXSTOPCLOCK_OFFS(p))
Move sys_env_device_rev_get() from the ddr training code to sys_env_lib.c (which currently resides with the serdes code). This brings sys_env_device_rev_get() into line with sys_env_device_id_get() and sys_env_model_get().
arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c | 24 ++++++++++++++++++++++++ drivers/ddr/marvell/a38x/ddr3_init.c | 24 ------------------------ 2 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c b/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c index cc3e5e23c0dd..4f15746c092b 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c +++ b/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c @@ -235,3 +235,27 @@ u32 sys_env_device_id_get(void)
return g_dev_id; } + +/* + * sys_env_device_rev_get - Get Marvell controller device revision number + * + * DESCRIPTION: + * This function returns 8bit describing the device revision as defined + * Revision ID Register. + * + * INPUT: + * None. + * + * OUTPUT: + * None. + * + * RETURN: + * 8bit desscribing Marvell controller revision number + */ +u8 sys_env_device_rev_get(void) +{ + u32 value; + + value = reg_read(DEV_VERSION_ID_REG); + return (value & (REVISON_ID_MASK)) >> REVISON_ID_OFFS; +} diff --git a/drivers/ddr/marvell/a38x/ddr3_init.c b/drivers/ddr/marvell/a38x/ddr3_init.c index 55baad498ae5..032c4d54f359 100644 --- a/drivers/ddr/marvell/a38x/ddr3_init.c +++ b/drivers/ddr/marvell/a38x/ddr3_init.c @@ -108,30 +108,6 @@ static int ddr3_hws_tune_training_params(u8 dev_num); /* A39x revisions */ #define MV_88F69XX_Z1_ID 0x2
-/* - * sys_env_device_rev_get - Get Marvell controller device revision number - * - * DESCRIPTION: - * This function returns 8bit describing the device revision as defined - * Revision ID Register. - * - * INPUT: - * None. - * - * OUTPUT: - * None. - * - * RETURN: - * 8bit desscribing Marvell controller revision number - */ -u8 sys_env_device_rev_get(void) -{ - u32 value; - - value = reg_read(DEV_VERSION_ID_REG); - return (value & (REVISON_ID_MASK)) >> REVISON_ID_OFFS; -} - /* * sys_env_dlb_config_ptr_get *
Chris Packham
