[PATCH] mkimage: fix segfault on MacOS arm64
mkimage segfaults due ASLR mechasim on MacOS arm64
It is required to use _dyld_get_image_vmaddr_slide() to prevent segfault on MacOS arm64
This patch ased on the discussion https://github.com/u-boot/u-boot/commit/3b142045e8a7f0ab17b6099e9226296af459...
Thanks to Ronny Kotzschmar and ptpt52 github user
Signed-off-by: Sergey V. Lobanov sergey@lobanov.in --- tools/imagetool.h | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/tools/imagetool.h b/tools/imagetool.h index e229a34ffc..13775ff9b3 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -271,11 +271,16 @@ int rockchip_copy_image(int fd, struct image_tool_params *mparams); * b) we need a API call to get the respective section symbols */ #if defined(__MACH__) #include <mach-o/getsect.h> +#include <mach-o/dyld.h>
-#define INIT_SECTION(name) do { \ +#define INIT_SECTION(name) struct image_type_params \ + **__cat(__start_, name), **__cat(__stop_, name); \ + do { \ unsigned long name ## _len; \ char *__cat(pstart_, name) = getsectdata("__DATA", \ #name, &__cat(name, _len)); \ + __cat(pstart_, name) += \ + _dyld_get_image_vmaddr_slide(0); \ char *__cat(pstop_, name) = __cat(pstart_, name) + \ __cat(name, _len); \ __cat(__start_, name) = (void *)__cat(pstart_, name); \ @@ -283,7 +288,6 @@ int rockchip_copy_image(int fd, struct image_tool_params *mparams); } while (0) #define SECTION(name) __attribute__((section("__DATA, " #name)))
-struct image_type_params **__start_image_type, **__stop_image_type; #else #define INIT_SECTION(name) /* no-op for ELF */ #define SECTION(name) __attribute__((section(#name)))
Hello,
Can someone please review this?
- b) we need a API call to get the respective section symbols */
- **__cat(__start_, name), **__cat(__stop_, name); \
- do { \ unsigned long name ## _len; \ char *__cat(pstart_, name) = getsectdata("__DATA", \ #name, &__cat(name, _len)); \
char *__cat(pstop_, name) = __cat(pstart_, name) + \ __cat(name, _len); \ __cat(__start_, name) = (void *)__cat(pstart_, name); \_dyld_get_image_vmaddr_slide(0); \
2.30.1 (Apple Git-130)
Sergey V. Lobanov
