[U-Boot] [PATCH] sh: Add asm/unaligned.h and asm/unaligned-sh4a.h from Linux kernel
zlib.c demands asm/unaligned.h. But, SH does not have these. This commit add asm/unaligned.h and asm/unaligned-sh4a.h from Linux kernel and modifyf for u-boot.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- include/asm-sh/unaligned-sh4a.h | 258 +++++++++++++++++++++++++++++++++++++++ include/asm-sh/unaligned.h | 25 ++++ 2 files changed, 283 insertions(+), 0 deletions(-) create mode 100644 include/asm-sh/unaligned-sh4a.h create mode 100644 include/asm-sh/unaligned.h
diff --git a/include/asm-sh/unaligned-sh4a.h b/include/asm-sh/unaligned-sh4a.h new file mode 100644 index 0000000..9f4dd25 --- /dev/null +++ b/include/asm-sh/unaligned-sh4a.h @@ -0,0 +1,258 @@ +#ifndef __ASM_SH_UNALIGNED_SH4A_H +#define __ASM_SH_UNALIGNED_SH4A_H + +/* + * SH-4A has support for unaligned 32-bit loads, and 32-bit loads only. + * Support for 64-bit accesses are done through shifting and masking + * relative to the endianness. Unaligned stores are not supported by the + * instruction encoding, so these continue to use the packed + * struct. + * + * The same note as with the movli.l/movco.l pair applies here, as long + * as the load is gauranteed to be inlined, nothing else will hook in to + * r0 and we get the return value for free. + * + * NOTE: Due to the fact we require r0 encoding, care should be taken to + * avoid mixing these heavily with other r0 consumers, such as the atomic + * ops. Failure to adhere to this can result in the compiler running out + * of spill registers and blowing up when building at low optimization + * levels. See http://gcc.gnu.org/bugzilla/show_bug.cgi?id=34777. + */ +#include <linux/types.h> +#include <asm/byteorder.h> + +static __always_inline u32 __get_unaligned_cpu32(const u8 *p) +{ + unsigned long unaligned; + + __asm__ __volatile__ ( + "movua.l @%1, %0\n\t" + : "=z" (unaligned) + : "r" (p) + ); + + return unaligned; +} + +struct __una_u16 { u16 x __attribute__((packed)); }; +struct __una_u32 { u32 x __attribute__((packed)); }; +struct __una_u64 { u64 x __attribute__((packed)); }; + +static inline u16 __get_unaligned_cpu16(const u8 *p) +{ +#ifdef __LITTLE_ENDIAN + return p[0] | p[1] << 8; +#else + return p[0] << 8 | p[1]; +#endif +} + +/* + * Even though movua.l supports auto-increment on the read side, it can + * only store to r0 due to instruction encoding constraints, so just let + * the compiler sort it out on its own. + */ +static inline u64 __get_unaligned_cpu64(const u8 *p) +{ +#ifdef __LITTLE_ENDIAN + return (u64)__get_unaligned_cpu32(p + 4) << 32 | + __get_unaligned_cpu32(p); +#else + return (u64)__get_unaligned_cpu32(p) << 32 | + __get_unaligned_cpu32(p + 4); +#endif +} + +static inline u16 get_unaligned_le16(const void *p) +{ + return le16_to_cpu(__get_unaligned_cpu16(p)); +} + +static inline u32 get_unaligned_le32(const void *p) +{ + return le32_to_cpu(__get_unaligned_cpu32(p)); +} + +static inline u64 get_unaligned_le64(const void *p) +{ + return le64_to_cpu(__get_unaligned_cpu64(p)); +} + +static inline u16 get_unaligned_be16(const void *p) +{ + return be16_to_cpu(__get_unaligned_cpu16(p)); +} + +static inline u32 get_unaligned_be32(const void *p) +{ + return be32_to_cpu(__get_unaligned_cpu32(p)); +} + +static inline u64 get_unaligned_be64(const void *p) +{ + return be64_to_cpu(__get_unaligned_cpu64(p)); +} + +static inline void __put_le16_noalign(u8 *p, u16 val) +{ + *p++ = val; + *p++ = val >> 8; +} + +static inline void __put_le32_noalign(u8 *p, u32 val) +{ + __put_le16_noalign(p, val); + __put_le16_noalign(p + 2, val >> 16); +} + +static inline void __put_le64_noalign(u8 *p, u64 val) +{ + __put_le32_noalign(p, val); + __put_le32_noalign(p + 4, val >> 32); +} + +static inline void __put_be16_noalign(u8 *p, u16 val) +{ + *p++ = val >> 8; + *p++ = val; +} + +static inline void __put_be32_noalign(u8 *p, u32 val) +{ + __put_be16_noalign(p, val >> 16); + __put_be16_noalign(p + 2, val); +} + +static inline void __put_be64_noalign(u8 *p, u64 val) +{ + __put_be32_noalign(p, val >> 32); + __put_be32_noalign(p + 4, val); +} + +static inline void put_unaligned_le16(u16 val, void *p) +{ +#ifdef __LITTLE_ENDIAN + ((struct __una_u16 *)p)->x = val; +#else + __put_le16_noalign(p, val); +#endif +} + +static inline void put_unaligned_le32(u32 val, void *p) +{ +#ifdef __LITTLE_ENDIAN + ((struct __una_u32 *)p)->x = val; +#else + __put_le32_noalign(p, val); +#endif +} + +static inline void put_unaligned_le64(u64 val, void *p) +{ +#ifdef __LITTLE_ENDIAN + ((struct __una_u64 *)p)->x = val; +#else + __put_le64_noalign(p, val); +#endif +} + +static inline void put_unaligned_be16(u16 val, void *p) +{ +#ifdef __BIG_ENDIAN + ((struct __una_u16 *)p)->x = val; +#else + __put_be16_noalign(p, val); +#endif +} + +static inline void put_unaligned_be32(u32 val, void *p) +{ +#ifdef __BIG_ENDIAN + ((struct __una_u32 *)p)->x = val; +#else + __put_be32_noalign(p, val); +#endif +} + +static inline void put_unaligned_be64(u64 val, void *p) +{ +#ifdef __BIG_ENDIAN + ((struct __una_u64 *)p)->x = val; +#else + __put_be64_noalign(p, val); +#endif +} + +/* + * Cause a link-time error if we try an unaligned access other than + * 1,2,4 or 8 bytes long + */ +extern void __bad_unaligned_access_size(void); + +#define __get_unaligned_le(ptr) ((__force typeof(*(ptr)))({ \ + __builtin_choose_expr(sizeof(*(ptr)) == 1, *(ptr), \ + __builtin_choose_expr(sizeof(*(ptr)) == 2, get_unaligned_le16((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 4, get_unaligned_le32((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 8, get_unaligned_le64((ptr)), \ + __bad_unaligned_access_size())))); \ + })) + +#define __get_unaligned_be(ptr) ((__force typeof(*(ptr)))({ \ + __builtin_choose_expr(sizeof(*(ptr)) == 1, *(ptr), \ + __builtin_choose_expr(sizeof(*(ptr)) == 2, get_unaligned_be16((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 4, get_unaligned_be32((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 8, get_unaligned_be64((ptr)), \ + __bad_unaligned_access_size())))); \ + })) + +#define __put_unaligned_le(val, ptr) ({ \ + void *__gu_p = (ptr); \ + switch (sizeof(*(ptr))) { \ + case 1: \ + *(u8 *)__gu_p = (__force u8)(val); \ + break; \ + case 2: \ + put_unaligned_le16((__force u16)(val), __gu_p); \ + break; \ + case 4: \ + put_unaligned_le32((__force u32)(val), __gu_p); \ + break; \ + case 8: \ + put_unaligned_le64((__force u64)(val), __gu_p); \ + break; \ + default: \ + __bad_unaligned_access_size(); \ + break; \ + } \ + (void)0; }) + +#define __put_unaligned_be(val, ptr) ({ \ + void *__gu_p = (ptr); \ + switch (sizeof(*(ptr))) { \ + case 1: \ + *(u8 *)__gu_p = (__force u8)(val); \ + break; \ + case 2: \ + put_unaligned_be16((__force u16)(val), __gu_p); \ + break; \ + case 4: \ + put_unaligned_be32((__force u32)(val), __gu_p); \ + break; \ + case 8: \ + put_unaligned_be64((__force u64)(val), __gu_p); \ + break; \ + default: \ + __bad_unaligned_access_size(); \ + break; \ + } \ + (void)0; }) + +#ifdef __LITTLE_ENDIAN +# define get_unaligned __get_unaligned_le +# define put_unaligned __put_unaligned_le +#else +# define get_unaligned __get_unaligned_be +# define put_unaligned __put_unaligned_be +#endif + +#endif /* __ASM_SH_UNALIGNED_SH4A_H */ diff --git a/include/asm-sh/unaligned.h b/include/asm-sh/unaligned.h new file mode 100644 index 0000000..2e0d164 --- /dev/null +++ b/include/asm-sh/unaligned.h @@ -0,0 +1,25 @@ +#ifndef _ASM_SH_UNALIGNED_H +#define _ASM_SH_UNALIGNED_H + +/* Copy from linux-kernel. */ + +#ifdef CONFIG_CPU_SH4A +/* SH-4A can handle unaligned loads in a relatively neutered fashion. */ +#include <asm/unaligned-sh4a.h> +#else +/* Otherwise, SH can't handle unaligned accesses. */ +#include <compiler.h> +#if defined(__BIG_ENDIAN__) +#define get_unaligned __get_unaligned_be +#define put_unaligned __put_unaligned_be +#elif defined(__LITTLE_ENDIAN__) +#define get_unaligned __get_unaligned_le +#define put_unaligned __put_unaligned_le +#endif + +#include <linux/unaligned/le_byteshift.h> +#include <linux/unaligned/be_byteshift.h> +#include <linux/unaligned/generic.h> +#endif + +#endif /* _ASM_SH_UNALIGNED_H */
Nobuhiro Iwamatsu
