[U-Boot] [PATCH v3 0/3] net: Sanitize DHCP variable override
While trying to boot from network on a RISC-V AX25 platform, I saw that the DHCP IP address did not get populated from the DHCP server IP address. The reason for that was simple: CONFIG_BOOTP_SERVERIP was set.
I don't know the history of that option, but it seems to decrease intuitivity levels of the dhcp command rather than improve it.
What I usually would expect is that explicitly set values populate through all layers. So if I set a TFTP file name, it populates. If I set a target IP address, it populates. If I don't set anything, the values get filled in automatically.
This patch set is trying to move us into that direction without breaking people that rely on the existing behavior. With this patch set applied, boards have the option to prefer the 'serverip' environment variable (ax25-ae350 gets moved to it) over the DHCP given address and any value explicitly set on the command line is always preferred.
This hopefully makes the command line a bit more intuitive.
v1 -> v2:
- new patch: net: Prefer command line arguments - remove README entry - improve Kconfig help texts
v2 -> v3:
- also check for net_boot_file_name_explicit on option 67
Alexander Graf (3): net: Prefer command line arguments net: Add option to prefer bootp/dhcp serverip ax25: Switch to CONFIG_BOOTP_PREFER_SERVERIP
cmd/Kconfig | 11 +++++++++++ cmd/net.c | 10 ++++++++-- configs/ax25-ae350_defconfig | 1 + include/configs/ax25-ae350.h | 1 - include/net.h | 2 ++ net/bootp.c | 21 +++++++++++++++------ net/net.c | 2 ++ 7 files changed, 39 insertions(+), 9 deletions(-)
We can call commands like dhcp and bootp without arguments or with explicit command line arguments that really should tell the code where to look for files instead.
Unfortunately, the current code simply overwrites command line arguments in the dhcp case with dhcp values.
This patch allows the code to preserve the command line values if they were set on the command line. That way the semantics are slightly more intuitive.
The reason this patch does that by introducing a new variable is that we can not rely on net_boot_file_name[0] being unset, as today it's completely legal to call "dhcp" and afterwards run "tftp" and expect the latter to repeat the same query as before. I would prefer not to break that behavior in case anyone relies on it.
Signed-off-by: Alexander Graf agraf@suse.de
v2 -> v3:
- also check for net_boot_file_name_explicit on option 67 --- cmd/net.c | 10 ++++++++-- include/net.h | 2 ++ net/bootp.c | 14 +++++++++----- net/net.c | 2 ++ 4 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/cmd/net.c b/cmd/net.c index f83839c35e..eca6dd8918 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -183,6 +183,8 @@ static int netboot_common(enum proto_t proto, cmd_tbl_t *cmdtp, int argc, int size; ulong addr;
+ net_boot_file_name_explicit = false; + /* pre-set load_addr */ s = env_get("loadaddr"); if (s != NULL) @@ -199,15 +201,18 @@ static int netboot_common(enum proto_t proto, cmd_tbl_t *cmdtp, int argc, * mis-interpreted as a valid number. */ addr = simple_strtoul(argv[1], &end, 16); - if (end == (argv[1] + strlen(argv[1]))) + if (end == (argv[1] + strlen(argv[1]))) { load_addr = addr; - else + } else { + net_boot_file_name_explicit = true; copy_filename(net_boot_file_name, argv[1], sizeof(net_boot_file_name)); + } break;
case 3: load_addr = simple_strtoul(argv[1], NULL, 16); + net_boot_file_name_explicit = true; copy_filename(net_boot_file_name, argv[2], sizeof(net_boot_file_name));
@@ -220,6 +225,7 @@ static int netboot_common(enum proto_t proto, cmd_tbl_t *cmdtp, int argc, printf("Invalid address/size\n"); return CMD_RET_USAGE; } + net_boot_file_name_explicit = true; copy_filename(net_boot_file_name, argv[3], sizeof(net_boot_file_name)); break; diff --git a/include/net.h b/include/net.h index 5760685556..a259b7c530 100644 --- a/include/net.h +++ b/include/net.h @@ -539,6 +539,8 @@ enum proto_t { };
extern char net_boot_file_name[1024];/* Boot File name */ +/* Indicates whether the file name was specified on the command line */ +extern bool net_boot_file_name_explicit; /* The actual transferred size of the bootfile (in bytes) */ extern u32 net_boot_file_size; /* Boot file size in blocks as reported by the DHCP server */ diff --git a/net/bootp.c b/net/bootp.c index 9d7cb5d30c..fdcb4374a0 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -157,7 +157,8 @@ static void store_net_params(struct bootp_hdr *bp) #if defined(CONFIG_CMD_DHCP) !(dhcp_option_overload & OVERLOAD_FILE) && #endif - (strlen(bp->bp_file) > 0)) { + (strlen(bp->bp_file) > 0) && + !net_boot_file_name_explicit) { copy_filename(net_boot_file_name, bp->bp_file, sizeof(net_boot_file_name)); } @@ -889,10 +890,13 @@ static void dhcp_process_options(uchar *popt, uchar *end) case 66: /* Ignore TFTP server name */ break; case 67: /* Bootfile option */ - size = truncate_sz("Bootfile", - sizeof(net_boot_file_name), oplen); - memcpy(&net_boot_file_name, popt + 2, size); - net_boot_file_name[size] = 0; + if (!net_boot_file_name_explicit) { + size = truncate_sz("Bootfile", + sizeof(net_boot_file_name), + oplen); + memcpy(&net_boot_file_name, popt + 2, size); + net_boot_file_name[size] = 0; + } break; default: #if defined(CONFIG_BOOTP_VENDOREX) diff --git a/net/net.c b/net/net.c index a4932f46d9..510d491271 100644 --- a/net/net.c +++ b/net/net.c @@ -165,6 +165,8 @@ ushort net_native_vlan = 0xFFFF;
/* Boot File name */ char net_boot_file_name[1024]; +/* Indicates whether the file name was specified on the command line */ +bool net_boot_file_name_explicit; /* The actual transferred size of the bootfile (in bytes) */ u32 net_boot_file_size; /* Boot file size in blocks as reported by the DHCP server */
Hi Alexander,
https://patchwork.ozlabs.org/patch/929828/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Currently we can choose between 2 different types of behavior for the serverip variable:
1) Always overwrite it with the DHCP server IP address (default) 2) Ignore what the DHCP server says (CONFIG_BOOTP_SERVERIP)
This patch adds a 3rd option:
3) Use serverip from DHCP if no serverip is given (CONFIG_BOOTP_PREFER_SERVERIP)
With this new option, we can have the default case that a boot file gets loaded from the DHCP provided TFTP server work while allowing users to specify their own serverip variable to explicitly use a different tftp server.
v1 -> v2:
- remove README entry - improve Kconfig help texts --- cmd/Kconfig | 11 +++++++++++ net/bootp.c | 7 ++++++- 2 files changed, 17 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index e283cb9a8a..80a5af8a0c 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1121,6 +1121,17 @@ config BOOTP_HOSTNAME help The name may or may not be qualified with the local domain name.
+config BOOTP_PREFER_SERVERIP + bool "Serverip variable takes precedent over DHCP server IP. + default n + depends on CMD_BOOTP + help + By default a BOOTP/DHCP reply will overwrite the 'serverip' variable. + + With this option enabled, the 'serverip' variable in the environment + takes precedence over DHCP server IP and will only be set by the DHCP + server if not already set in the environment. + config BOOTP_SUBNETMASK bool "Request & store 'netmask' from BOOTP/DHCP server" default y diff --git a/net/bootp.c b/net/bootp.c index fdcb4374a0..9a2b512e4a 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -147,9 +147,14 @@ static void store_net_params(struct bootp_hdr *bp) { #if !defined(CONFIG_BOOTP_SERVERIP) struct in_addr tmp_ip; + bool overwrite_serverip = true; + +#if defined(CONFIG_BOOTP_PREFER_SERVERIP) + overwrite_serverip = false; +#endif
net_copy_ip(&tmp_ip, &bp->bp_siaddr); - if (tmp_ip.s_addr != 0) + if (tmp_ip.s_addr != 0 && (overwrite_serverip || !net_server_ip.s_addr)) net_copy_ip(&net_server_ip, &bp->bp_siaddr); memcpy(net_server_ethaddr, ((struct ethernet_hdr *)net_rx_packet)->et_src, 6);
- Always overwrite it with the DHCP server IP address (default)
- Ignore what the DHCP server says (CONFIG_BOOTP_SERVERIP)
- Use serverip from DHCP if no serverip is given (CONFIG_BOOTP_PREFER_SERVERIP)
Hi Alexander,
https://patchwork.ozlabs.org/patch/929826/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
The ax25-ae350 target currently uses CONFIG_BOOTP_SERVERIP which means we ignore the DHCP provided TFTP ip address. This breaks every case where we do now provide a serverip environment variable.
Instead, let's use the new CONFIG_BOOT_PREFER_SERVERIP option to fall back to the DHCP provided TFTP IP if no serverip environment variable is set.
Signed-off-by: Alexander Graf agraf@suse.de --- configs/ax25-ae350_defconfig | 1 + include/configs/ax25-ae350.h | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/ax25-ae350_defconfig b/configs/ax25-ae350_defconfig index fc04c87485..a328555af6 100644 --- a/configs/ax25-ae350_defconfig +++ b/configs/ax25-ae350_defconfig @@ -40,3 +40,4 @@ CONFIG_DM_SPI=y CONFIG_ATCSPI200_SPI=y CONFIG_TIMER=y CONFIG_ATCPIT100_TIMER=y +CONFIG_BOOTP_PREFER_SERVERIP=y diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index b1ca5ac11a..b230896734 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -11,7 +11,6 @@ * CPU and Board Configuration Options */ #define CONFIG_BOOTP_SEND_HOSTNAME -#define CONFIG_BOOTP_SERVERIP
/* * Miscellaneous configurable options
2018-06-16 4:12 GMT+08:00 Joe Hershberger joe.hershberger@ni.com:
Acked-by: Rick Chen rick@andestech.com
Hi Alexander,
https://patchwork.ozlabs.org/patch/929829/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Alexander Graf
Joe Hershberger
Rick Chen
