[U-Boot] [PATCH] patman: fix series-notes handling for buildman
A patman series with a 'Series-notes' section causes buildman to crash with:
self.series.notes += self.section TypeError: cannot concatenate 'str' and 'list' objects
Fix by initializing series.notes as a one-element array rathen than a scalar.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net ---
tools/patman/series.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/patman/series.py b/tools/patman/series.py index 3399f2c..e8aad59 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -69,7 +69,7 @@ class Series(dict):
# Otherwise just set the value elif name in valid_series: - self[name] = value + self[name] = [value] else: raise ValueError("In %s: line '%s': Unknown 'Series-%s': valid " "options are %s" % (commit.hash, line, name,
Hello Simon,
Note: just spotted a typo, 'rathen' instead of 'rather'. If this patch gets applied, please fix that on-the-fly.
Amicalement,
On 9 November 2015 at 14:36, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hello Simon,
Amicalement,
Albert.
Fixed typo and
Applied to u-boot-dm, thanks!
Hi Albert,
Hello Simon,
Amicalement,
Albert.
Fixed typo and
Hmm, actually I've had to drop this as it breaks 'Series-version'. That currently does not expect a list.
I wonder if Series-notes needs a special case, instead?
Hello Simon,
On Thu, 19 Nov 2015 20:29:11 -0700, Simon Glass sjg@chromium.org wrote:
Hi Albert,
Hello Simon,
Amicalement,
Albert.
Fixed typo and
Hmm, I can't reproduce this here. How do you trigger the Series-version break?
Amicalement,
Hi Albert,
On 31 January 2016 at 09:51, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hello Simon,
Hi Albert,
Hello Simon,
Amicalement,
Albert.
Fixed typo and
I created a commit with a Series-version: in it. Then, running patman gives a run-time error because it is expecting a single value, not an array.
Amicalement,
Albert.
Hello Simon,
Thanks.
Weird. That's what I'd done when starting v2 (so that I could test my commit with itself) except I also had Series-note: in it, and it would not trigger this. Then I rolled back to v1 and did it again, and this time I get the error. And before anyone asks, I'd run git clean- xfd so there was no precompiled Python in the way.
Oh well.
v2 just sent.
Amicalement,
Albert ARIBAUD
