[U-Boot] [PATCH] powerpc/mpc8536DS:Increase binary size for mpc8536DS board
u-boot binary size for Freescale mpc8536DS platforms is 512KB. This has been reached to upper limit of the platforms and causig linker error. So increase the u-boot binary size to 768KB.
Signed-off-by: Haijun Zhang Haijun.Zhang@freescale.com --- include/configs/MPC8536DS.h | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 57bf04f..2505869 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -42,7 +42,7 @@ #endif
#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#define CONFIG_SYS_TEXT_BASE 0xeff40000 #endif
#ifndef CONFIG_RESET_VECTOR_ADDRESS @@ -326,7 +326,7 @@
/* NAND boot: 4K NAND loader config */ #define CONFIG_SYS_NAND_SPL_SIZE 0x1000 -#define CONFIG_SYS_NAND_U_BOOT_SIZE ((512 << 10) - 0x2000) +#define CONFIG_SYS_NAND_U_BOOT_SIZE ((768 << 10) - 0x2000) #define CONFIG_SYS_NAND_U_BOOT_DST (CONFIG_SYS_INIT_L2_ADDR) #define CONFIG_SYS_NAND_U_BOOT_START \ (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_NAND_SPL_SIZE) @@ -626,7 +626,7 @@ #if defined(CONFIG_RAMBOOT_NAND) #define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET ((512 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_ENV_IS_IN_SPI_FLASH @@ -649,11 +649,7 @@ #endif #else #define CONFIG_ENV_IS_IN_FLASH 1 - #if CONFIG_SYS_MONITOR_BASE > 0xfff80000 - #define CONFIG_ENV_ADDR 0xfff80000 - #else #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) - #endif #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
Applied to u-boot-mpc85xx/master. Thanks.
York
Haijun Zhang
York Sun
