[U-Boot-Users] [PATCH 13/18] include/configs: Use new CONFIG_CMD_* in various R* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/R360MPI.h | 35 ++++++++++++---------- include/configs/RBC823.h | 64 +++++++++++++++++++++-------------------- include/configs/RPXClassic.h | 15 ++++++---- include/configs/RPXlite.h | 11 ++++-- include/configs/RPXlite_DW.h | 42 ++++++++++++--------------- include/configs/RPXsuper.h | 27 ++++++++++-------- include/configs/RRvision.h | 25 +++++++++------- include/configs/Rattler.h | 28 ++++++++++-------- 8 files changed, 131 insertions(+), 116 deletions(-)
diff --git a/include/configs/R360MPI.h b/include/configs/R360MPI.h index 82228c0..c00ed3d 100644 --- a/include/configs/R360MPI.h +++ b/include/configs/R360MPI.h @@ -111,20 +111,23 @@ #define CFG_I2C_KEY_ADDR 0x9 /* Keyboard coprocessor */ #define CFG_I2C_TEM_ADDR 0x49 /* Temperature Sensors */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_BMP | \ - CFG_CMD_BSP | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_NFS | \ - CFG_CMD_PCMCIA | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BMP +#define CONFIG_CMD_BSP +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCMCIA +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options @@ -134,7 +137,7 @@
#define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -228,7 +231,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/RBC823.h b/include/configs/RBC823.h index 242c837..d73a367 100644 --- a/include/configs/RBC823.h +++ b/include/configs/RBC823.h @@ -94,42 +94,44 @@ #define CFG_EEPROM_WRITE_BITS 4 #define CFG_EEPROM_WRITE_DELAY_MS 10
-#define CONFIG_COMMANDS ( CFG_CMD_ALL & \ - ~CFG_CMD_BSP & \ - ~CFG_CMD_DATE & \ - ~CFG_CMD_DISPLAY& \ - ~CFG_CMD_DTT & \ - ~CFG_CMD_EXT2 & \ - ~CFG_CMD_FDC & \ - ~CFG_CMD_FDOS & \ - ~CFG_CMD_HWFLOW & \ - ~CFG_CMD_IDE & \ - ~CFG_CMD_IRQ & \ - ~CFG_CMD_JFFS2 & \ - ~CFG_CMD_MII & \ - ~CFG_CMD_MMC & \ - ~CFG_CMD_NAND & \ - ~CFG_CMD_PCI & \ - ~CFG_CMD_PCMCIA & \ - ~CFG_CMD_REISER & \ - ~CFG_CMD_SCSI & \ - ~CFG_CMD_SETGETDCR & \ - ~CFG_CMD_SNTP & \ - ~CFG_CMD_SPI & \ - ~CFG_CMD_UNIVERSE & \ - ~CFG_CMD_USB & \ - ~CFG_CMD_VFD & \ - ~CFG_CMD_XIMG ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_all.h> + +#undef CONFIG_CMD_BSP +#undef CONFIG_CMD_DATE +#undef CONFIG_CMD_DISPLAY +#undef CONFIG_CMD_DTT +#undef CONFIG_CMD_EXT2 +#undef CONFIG_CMD_FDC +#undef CONFIG_CMD_FDOS +#undef CONFIG_CMD_HWFLOW +#undef CONFIG_CMD_IDE +#undef CONFIG_CMD_IRQ +#undef CONFIG_CMD_JFFS2 +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_MMC +#undef CONFIG_CMD_NAND +#undef CONFIG_CMD_PCI +#undef CONFIG_CMD_PCMCIA +#undef CONFIG_CMD_REISER +#undef CONFIG_CMD_SCSI +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_SNTP +#undef CONFIG_CMD_SPI +#undef CONFIG_CMD_UNIVERSE +#undef CONFIG_CMD_USB +#undef CONFIG_CMD_VFD +#undef CONFIG_CMD_XIMG +
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -205,7 +207,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/RPXClassic.h b/include/configs/RPXClassic.h index 591382c..2091735 100644 --- a/include/configs/RPXClassic.h +++ b/include/configs/RPXClassic.h @@ -93,10 +93,13 @@ #define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */
-#define CONFIG_COMMANDS ((CFG_CMD_ALL & ~CFG_CMD_NONSTD) | CFG_CMD_ELF) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF
/* * Miscellaneous configurable options @@ -104,7 +107,7 @@ #define CFG_RESET_ADDRESS 0x80000000 #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -182,7 +185,7 @@ #define CFG_SDRAM_BASE 0x00000000 #define CFG_FLASH_BASE 0xFF000000
-#if defined(DEBUG) || defined (CONFIG_VIDEO_SED13806) || (CONFIG_COMMANDS & CFG_CMD_IDE) +#if defined(DEBUG) || defined (CONFIG_VIDEO_SED13806) || defined(CONFIG_CMD_IDE) #define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ #else #define CFG_MONITOR_LEN (128 << 10) /* Reserve 128 kB for Monitor */ @@ -222,7 +225,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/RPXlite.h b/include/configs/RPXlite.h index 48ada0e..a478a06 100644 --- a/include/configs/RPXlite.h +++ b/include/configs/RPXlite.h @@ -64,15 +64,18 @@
#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT | CONFIG_BOOTP_BOOTFILESIZE)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -154,7 +157,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/RPXlite_DW.h b/include/configs/RPXlite_DW.h index 3102547..9bf7770 100644 --- a/include/configs/RPXlite_DW.h +++ b/include/configs/RPXlite_DW.h @@ -120,24 +120,23 @@ #if 1 /* Enable this stuff could make image enlarge about 25KB. Mask it if you don't want the advanced function */
+ +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_PING +#define CONFIG_CMD_ELF +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_DHCP + #ifdef CONFIG_SPLASH_SCREEN -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_BMP | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_PING | \ - CFG_CMD_ELF | \ - CFG_CMD_REGINFO | \ - CFG_CMD_DHCP ) -#else -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_PING | \ - CFG_CMD_ELF | \ - CFG_CMD_REGINFO | \ - CFG_CMD_DHCP ) -#endif /* CONFIG_SPLASH_SCREEN */ +#define CONFIG_CMD_BMP +#endif +
/* test-only */ #define CFG_JFFS2_FIRST_BANK 0 /* use for JFFS2 */ @@ -147,16 +146,13 @@
#endif /* 1 */
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "u-boot>" /* Monitor Command Prompt */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -200,7 +196,7 @@ #define CFG_SDRAM_BASE 0x00000000 #define CFG_FLASH_BASE 0xFF000000
-#if defined(DEBUG) || (CONFIG_COMMANDS & CFG_CMD_IDE) +#if defined(DEBUG) || defined(CONFIG_CMD_IDE) #define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ #else #define CFG_MONITOR_LEN (128 << 10) /* Reserve 128 kB for Monitor */ @@ -239,7 +235,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/RPXsuper.h b/include/configs/RPXsuper.h index 45907aa..c39aff1 100644 --- a/include/configs/RPXsuper.h +++ b/include/configs/RPXsuper.h @@ -150,13 +150,19 @@ /* Monitor Command Prompt */ #define CFG_PROMPT "=> "
-/* What U-Boot subsytems do you want enabled? */ -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_IMMAP | \ - CFG_CMD_ASKENV | \ - CFG_CMD_I2C | \ - CFG_CMD_REGINFO & \ - ~CFG_CMD_KGDB ) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_I2C +#define CONFIG_CMD_REGINFO + +#undef CONFIG_CMD_KGDB +
/* Where do the internal registers live? */ #define CFG_IMMR 0xF0000000 @@ -176,13 +182,10 @@
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else # define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -310,7 +313,7 @@ */ #define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/RRvision.h b/include/configs/RRvision.h index 3885bcd..2c590af 100644 --- a/include/configs/RRvision.h +++ b/include/configs/RRvision.h @@ -135,23 +135,26 @@ #endif /* CONFIG_SOFT_I2C */
-#define CONFIG_COMMANDS ( ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_DATE ) & \ - ~( CFG_CMD_PCMCIA | \ - CFG_CMD_IDE ) ) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_DATE + +#undef CONFIG_CMD_PCMCIA +#undef CONFIG_CMD_IDE
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -228,7 +231,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/Rattler.h b/include/configs/Rattler.h index dbc57e8..5c64314 100644 --- a/include/configs/Rattler.h +++ b/include/configs/Rattler.h @@ -125,22 +125,24 @@
#define CONFIG_BAUDRATE 38400
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - | CFG_CMD_DHCP \ - | CFG_CMD_IMMAP \ - | CFG_CMD_JFFS2 \ - | CFG_CMD_MII \ - | CFG_CMD_PING \ - )
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +
#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ #define CONFIG_BOOTCOMMAND "bootm FE040000" /* autoboot command */ #define CONFIG_BOOTARGS "root=/dev/mtdblock2 rw mtdparts=phys:1M(ROM)ro,-(root)"
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ #define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ #undef CONFIG_KGDB_NONE /* define if kgdb on something else */ @@ -158,7 +160,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -184,7 +186,7 @@
#define CFG_DIRECT_FLASH_TFTP
-#if (CONFIG_COMMANDS & CFG_CMD_JFFS2) +#if defined(CONFIG_CMD_JFFS2) #define CFG_JFFS2_NUM_BANKS CFG_MAX_FLASH_BANKS #define CFG_JFFS2_SORT_FRAGMENTS
@@ -256,7 +258,7 @@ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
#define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
Jon Loeliger
