[U-Boot] [PATCH V2 1/3] gpio: Add DW APB GPIO driver
Add driver for the DesignWare APB GPIO IP block. This driver is DM capable and probes from DT.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- drivers/gpio/Kconfig | 7 ++ drivers/gpio/Makefile | 1 + drivers/gpio/dwapb_gpio.c | 167 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 175 insertions(+) create mode 100644 drivers/gpio/dwapb_gpio.c
V2: Obtain the bank name from the "bank-name" property instead.
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 0c43777..c04388d 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -8,6 +8,13 @@ config DM_GPIO particular GPIOs that they provide. The uclass interface is defined in include/asm-generic/gpio.h.
+config DWAPB_GPIO + bool "DWAPB GPIO driver" + depends on DM && DM_GPIO + default n + help + Support for the Designware APB GPIO driver. + config LPC32XX_GPIO bool "LPC32XX GPIO driver" depends on DM diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 67c6374..603c96b 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -6,6 +6,7 @@ #
ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_DWAPB_GPIO) += dwapb_gpio.o obj-$(CONFIG_AXP_GPIO) += axp_gpio.o endif obj-$(CONFIG_DM_GPIO) += gpio-uclass.o diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c new file mode 100644 index 0000000..72cec48 --- /dev/null +++ b/drivers/gpio/dwapb_gpio.c @@ -0,0 +1,167 @@ +/* + * (C) Copyright 2015 Marek Vasut marex@denx.de + * + * DesignWare APB GPIO driver + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/root.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIO_SWPORTA_DR 0x00 +#define GPIO_SWPORTA_DDR 0x04 +#define GPIO_INTEN 0x30 +#define GPIO_INTMASK 0x34 +#define GPIO_INTTYPE_LEVEL 0x38 +#define GPIO_INT_POLARITY 0x3c +#define GPIO_INTSTATUS 0x40 +#define GPIO_PORTA_DEBOUNCE 0x48 +#define GPIO_PORTA_EOI 0x4c +#define GPIO_EXT_PORTA 0x50 + +struct gpio_dwapb_platdata { + const char *name; + int bank; + int pins; + fdt_addr_t base; +}; + +static int dwapb_gpio_direction_input(struct udevice *dev, unsigned pin) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + clrbits_le32(plat->base + GPIO_SWPORTA_DDR, 1 << pin); + return 0; +} + +static int dwapb_gpio_direction_output(struct udevice *dev, unsigned pin, + int val) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + setbits_le32(plat->base + GPIO_SWPORTA_DDR, 1 << pin); + + if (val) + setbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + else + clrbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + + return 0; +} + +static int dwapb_gpio_get_value(struct udevice *dev, unsigned pin) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + return !!(readl(plat->base + GPIO_EXT_PORTA) & (1 << pin)); +} + + +static int dwapb_gpio_set_value(struct udevice *dev, unsigned pin, int val) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + if (val) + setbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + else + clrbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + + return 0; +} + +static const struct dm_gpio_ops gpio_dwapb_ops = { + .direction_input = dwapb_gpio_direction_input, + .direction_output = dwapb_gpio_direction_output, + .get_value = dwapb_gpio_get_value, + .set_value = dwapb_gpio_set_value, +}; + +static int gpio_dwapb_probe(struct udevice *dev) +{ + struct gpio_dev_priv *priv = dev_get_uclass_priv(dev); + struct gpio_dwapb_platdata *plat = dev->platdata; + + if (!plat) + return 0; + + priv->gpio_count = plat->pins; + priv->bank_name = plat->name; + + return 0; +} + +static int gpio_dwapb_bind(struct udevice *dev) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + const void *blob = gd->fdt_blob; + struct udevice *subdev; + fdt_addr_t base; + int ret, node, bank = 0; + + /* If this is a child device, there is nothing to do here */ + if (plat) + return 0; + + base = fdtdec_get_addr(blob, dev->of_offset, "reg"); + if (base == FDT_ADDR_T_NONE) { + debug("Can't get the GPIO register base address\n"); + return -ENXIO; + } + + for (node = fdt_first_subnode(blob, dev->of_offset); + node > 0; + node = fdt_next_subnode(blob, node)) { + if (!fdtdec_get_bool(blob, node, "gpio-controller")) + continue; + + plat = NULL; + plat = calloc(1, sizeof(*plat)); + if (!plat) + return -ENOMEM; + + plat->base = base; + plat->bank = bank; + plat->pins = fdtdec_get_int(blob, node, "snps,nr-gpios", 0); + ret = fdt_get_string(blob, node, "bank-name", &plat->name); + if (ret) + goto err; + + ret = device_bind(dev, dev->driver, plat->name, + plat, -1, &subdev); + if (ret) + goto err; + + subdev->of_offset = node; + bank++; + } + + return 0; + +err: + free(plat); + return ret; +} + +static const struct udevice_id gpio_dwapb_ids[] = { + { .compatible = "snps,dw-apb-gpio" }, + { } +}; + +U_BOOT_DRIVER(gpio_dwapb) = { + .name = "gpio-dwapb", + .id = UCLASS_GPIO, + .of_match = gpio_dwapb_ids, + .ops = &gpio_dwapb_ops, + .bind = gpio_dwapb_bind, + .probe = gpio_dwapb_probe, +};
Add "bank-name" property to each GPIO bank to give it unique name. The approach here is exactly the same as with the "regulator-name" property for regulators.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- arch/arm/dts/socfpga.dtsi | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index e17e9f4..125034b 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -550,6 +550,7 @@
porta: gpio-controller@0 { compatible = "snps,dw-apb-gpio-port"; + bank-name = "porta"; gpio-controller; #gpio-cells = <2>; snps,nr-gpios = <29>; @@ -570,6 +571,7 @@
portb: gpio-controller@0 { compatible = "snps,dw-apb-gpio-port"; + bank-name = "portb"; gpio-controller; #gpio-cells = <2>; snps,nr-gpios = <29>; @@ -590,6 +592,7 @@
portc: gpio-controller@0 { compatible = "snps,dw-apb-gpio-port"; + bank-name = "portc"; gpio-controller; #gpio-cells = <2>; snps,nr-gpios = <27>;
Enable the DWAPB GPIO driver for SoCFPGA Cyclone V and Arria V.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Dinh Nguyen dinguyen@opensource.altera.com --- configs/socfpga_arria5_defconfig | 2 ++ configs/socfpga_cyclone5_defconfig | 2 ++ configs/socfpga_socrates_defconfig | 2 ++ include/configs/socfpga_arria5.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- 5 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 4d1cd21..b90686e 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_OF_CONTROL=y CONFIG_SPI_FLASH=y +CONFIG_DM_GPIO=y +CONFIG_DWAPB_GPIO=y CONFIG_SPL_DM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_DM_SEQ_ALIAS=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index ae3a1de..5d7362b 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -10,6 +10,8 @@ CONFIG_SPI_FLASH=y CONFIG_DM_ETH=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y +CONFIG_DM_GPIO=y +CONFIG_DWAPB_GPIO=y CONFIG_SPL_DM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_DM_SEQ_ALIAS=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 71d4711..6ef2f97 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -10,6 +10,8 @@ CONFIG_SPI_FLASH=y CONFIG_DM_ETH=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y +CONFIG_DM_GPIO=y +CONFIG_DWAPB_GPIO=y CONFIG_SPL_DM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_DM_SEQ_ALIAS=y diff --git a/include/configs/socfpga_arria5.h b/include/configs/socfpga_arria5.h index e1cd9cc..3193684 100644 --- a/include/configs/socfpga_arria5.h +++ b/include/configs/socfpga_arria5.h @@ -23,6 +23,7 @@ #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_GPIO #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC @@ -30,7 +31,6 @@ #define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
- /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SoCDK */
diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 9b31741..9e733e5 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -23,6 +23,7 @@ #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_GPIO #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC @@ -30,7 +31,6 @@ #define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
Hi Marek,
Please see nits/suggestions below.
Are you going to submit a GPIO binding change for this?
+config DWAPB_GPIO
default n
help
You could expand this to talk about bank naming, features supported, chips which use it.
- (C) Copyright 2015 Marek Vasut marex@denx.de
- DesignWare APB GPIO driver
should go just below common.h
What's the deal with C structures? Has the policy on this changed? I can't help thinking that your GPIO_ prefix is unnecessary.
const char *name;
int bank;
int pins;
fdt_addr_t base;
int val)
if (val)
else
if (val)
else
if (!plat)
fdt_addr_t base;
if (plat)
return -ENXIO;
-EINVAL I think, since this is an invalid parameter
node > 0;
continue;
plat = NULL;
if (!plat)
return -ENOMEM;
plat->base = base;
plat->bank = bank;
if (ret)
goto err;
plat, -1, &subdev);
if (ret)
goto err;
bank++;
+err:
free(plat);
return ret;
.id = UCLASS_GPIO,
2.1.4
I thought we no longer need to access registers via structs, and accessing them via base + offset, like the kernel does is OK in U-boot: https://www.marc.info/?l=u-boot&m=142609602127309&w=2
Regards,
Fabio Estevam
+Tom
Hi Fabio,
Thanks for the link. No I did not know that.
Perhaps we should add the type-checking referred to in that thread? What is it and who is doing it?
On Wednesday, August 12, 2015 at 04:15:00 PM, Simon Glass wrote:
Hi Marek,
You mean for the bank-name ? Yes, I think it only makes sense to do it.
+config DWAPB_GPIO
default n
help
Done
config LPC32XX_GPIO
Yup
I think we don't do that anymore. The GPIO_ stuff is copied from Linux.
const char *name;
int bank;
int pins;
fdt_addr_t base;
if (val)
else
if (val)
else
if (!plat)
fdt_addr_t base;
if (plat)
return -ENXIO;
OK
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- drivers/gpio/Kconfig | 10 +++ drivers/gpio/Makefile | 1 + drivers/gpio/dwapb_gpio.c | 167 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 178 insertions(+) create mode 100644 drivers/gpio/dwapb_gpio.c
V2: Obtain the bank name from the "bank-name" property instead. V3: Tweak the description, replace ENXIO with EINVAL, fix Simon's comments.
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 5934597..8db48d1 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -14,6 +14,16 @@ config DM_GPIO particular GPIOs that they provide. The uclass interface is defined in include/asm-generic/gpio.h.
+config DWAPB_GPIO + bool "DWAPB GPIO driver" + depends on DM && DM_GPIO + default n + help + Support for the Designware APB GPIO driver. This driver can + be probed only from device tree. Each DW APB GPIO controller + can contain multiple GPIO banks, use the "bank-name" property + in the OF to select reasonable name for each bank. + config LPC32XX_GPIO bool "LPC32XX GPIO driver" depends on DM diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 26f2574..ba18594 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -6,6 +6,7 @@ #
ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_DWAPB_GPIO) += dwapb_gpio.o obj-$(CONFIG_AXP_GPIO) += axp_gpio.o endif obj-$(CONFIG_DM_GPIO) += gpio-uclass.o diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c new file mode 100644 index 0000000..cee93e8 --- /dev/null +++ b/drivers/gpio/dwapb_gpio.c @@ -0,0 +1,167 @@ +/* + * (C) Copyright 2015 Marek Vasut marex@denx.de + * + * DesignWare APB GPIO driver + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <malloc.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/root.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIO_SWPORTA_DR 0x00 +#define GPIO_SWPORTA_DDR 0x04 +#define GPIO_INTEN 0x30 +#define GPIO_INTMASK 0x34 +#define GPIO_INTTYPE_LEVEL 0x38 +#define GPIO_INT_POLARITY 0x3c +#define GPIO_INTSTATUS 0x40 +#define GPIO_PORTA_DEBOUNCE 0x48 +#define GPIO_PORTA_EOI 0x4c +#define GPIO_EXT_PORTA 0x50 + +struct gpio_dwapb_platdata { + const char *name; + int bank; + int pins; + fdt_addr_t base; +}; + +static int dwapb_gpio_direction_input(struct udevice *dev, unsigned pin) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + clrbits_le32(plat->base + GPIO_SWPORTA_DDR, 1 << pin); + return 0; +} + +static int dwapb_gpio_direction_output(struct udevice *dev, unsigned pin, + int val) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + setbits_le32(plat->base + GPIO_SWPORTA_DDR, 1 << pin); + + if (val) + setbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + else + clrbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + + return 0; +} + +static int dwapb_gpio_get_value(struct udevice *dev, unsigned pin) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + return !!(readl(plat->base + GPIO_EXT_PORTA) & (1 << pin)); +} + + +static int dwapb_gpio_set_value(struct udevice *dev, unsigned pin, int val) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + if (val) + setbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + else + clrbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + + return 0; +} + +static const struct dm_gpio_ops gpio_dwapb_ops = { + .direction_input = dwapb_gpio_direction_input, + .direction_output = dwapb_gpio_direction_output, + .get_value = dwapb_gpio_get_value, + .set_value = dwapb_gpio_set_value, +}; + +static int gpio_dwapb_probe(struct udevice *dev) +{ + struct gpio_dev_priv *priv = dev_get_uclass_priv(dev); + struct gpio_dwapb_platdata *plat = dev->platdata; + + if (!plat) + return 0; + + priv->gpio_count = plat->pins; + priv->bank_name = plat->name; + + return 0; +} + +static int gpio_dwapb_bind(struct udevice *dev) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + const void *blob = gd->fdt_blob; + struct udevice *subdev; + fdt_addr_t base; + int ret, node, bank = 0; + + /* If this is a child device, there is nothing to do here */ + if (plat) + return 0; + + base = fdtdec_get_addr(blob, dev->of_offset, "reg"); + if (base == FDT_ADDR_T_NONE) { + debug("Can't get the GPIO register base address\n"); + return -EINVAL; + } + + for (node = fdt_first_subnode(blob, dev->of_offset); + node > 0; + node = fdt_next_subnode(blob, node)) { + if (!fdtdec_get_bool(blob, node, "gpio-controller")) + continue; + + plat = NULL; + plat = calloc(1, sizeof(*plat)); + if (!plat) + return -ENOMEM; + + plat->base = base; + plat->bank = bank; + plat->pins = fdtdec_get_int(blob, node, "snps,nr-gpios", 0); + ret = fdt_get_string(blob, node, "bank-name", &plat->name); + if (ret) + goto err; + + ret = device_bind(dev, dev->driver, plat->name, + plat, -1, &subdev); + if (ret) + goto err; + + subdev->of_offset = node; + bank++; + } + + return 0; + +err: + free(plat); + return ret; +} + +static const struct udevice_id gpio_dwapb_ids[] = { + { .compatible = "snps,dw-apb-gpio" }, + { } +}; + +U_BOOT_DRIVER(gpio_dwapb) = { + .name = "gpio-dwapb", + .id = UCLASS_GPIO, + .of_match = gpio_dwapb_ids, + .ops = &gpio_dwapb_ops, + .bind = gpio_dwapb_bind, + .probe = gpio_dwapb_probe, +};
Fabio Estevam
