[U-Boot] [PATCH 0/8] ARM: sunxi: Support PSCI for sun6i and sun8i
Hi everyone,
I finally got around to rebasing and fixing up my PSCI stuff. This series adds PSCI support for sun6i and sun8i. This is based on sun7i PSCI support by Marc, and the SMP support routines found in both mainline Linux and Allwinner's Android kernel.
I've tested this on my Hummingbird A31 board and Ippo q8h v5 tablet. Given the A23 SMP routines work on the A33 as well, I see no reason it would not work, so A33 support is included as well, but more testing is always welcome.
Patch 1 and 2 address a build failur on sunxi/next I ran into, which is related to the new NAND SPL support.
Patch 3 adds some comments to the sunxi PSCI code, for easier reading.
Patch 4 moves sun7i PSCI code aside.
Patch 5 adds sun6i PSCI code. Differences from sun7i are the separate PRCM block for power gating/clamps, and support for more than 1 secondary CPU core.
Patch 6 enables PSCI for sun6i.
Patch 7 lets sun8i share PSCI code with sun6i. The routines are the same, except sun8i does not have power clamps.
Patch 8 enables PSCI for sun8i (A23/A33).
Wonder if we still need the SMP support in the kernel?
Regards ChenYu
Chen-Yu Tsai (8): sunxi: Only compile board_nand_init() if CONFIG_NAND is set sunxi: Add extra NAND pins for sun6i ARM: sunxi: Document registers in PSCI code ARM: sunxi: Make PSCI code sun7i specific ARM: sunxi: Add sun6i specific PSCI implementation ARM: sunxi: Enable PSCI for sun6i ARM: sunxi: Share sun6i PSCI backend with sun8i ARM: sunxi: Enable PSCI for sun8i
arch/arm/cpu/armv7/sunxi/Makefile | 4 +- arch/arm/cpu/armv7/sunxi/{psci.S => psci_sun6i.S} | 81 +++++++++++++++-------- arch/arm/cpu/armv7/sunxi/{psci.S => psci_sun7i.S} | 14 ++-- board/sunxi/Kconfig | 9 +++ board/sunxi/board.c | 2 + include/configs/sun6i.h | 7 ++ include/configs/sun8i.h | 6 ++ 7 files changed, 87 insertions(+), 36 deletions(-) copy arch/arm/cpu/armv7/sunxi/{psci.S => psci_sun6i.S} (74%) rename arch/arm/cpu/armv7/sunxi/{psci.S => psci_sun7i.S} (94%)
There's no need to init NAND if we're not building with NAND support. Wrap board_nand_init() in #ifdefs like we do for board_mmc_init(). This fixes build breaks for sun6i and sun9i. Both platforms do not have CONFIG_NAND_SUNXI_GPC_PORTS defined.
Fixes: fbf13d684dcb ("sunxi/nand: Add support to the SPL for loading u-boot from internal NAND memory") Signed-off-by: Chen-Yu Tsai wens@csie.org --- board/sunxi/board.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 3f23f26..f27967b 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -318,6 +318,7 @@ int board_mmc_init(bd_t *bis) } #endif
+#ifdef CONFIG_NAND void board_nand_init(void) { unsigned int pin; @@ -330,6 +331,7 @@ void board_nand_init(void) for (pin = 0; pin < ARRAY_SIZE(ports); pin++) sunxi_gpio_set_cfgpin(SUNXI_GPC(ports[pin]), SUNXI_GPC_NAND); } +#endif
void i2c_init_board(void) {
In addition to pins PC00 ~ PC15, PC24, PC25, and PC26 are mapped to NAND0 DQS, CE2, and CE3 respectively.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- include/configs/sun6i.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/sun6i.h b/include/configs/sun6i.h index 2c24bd2..e1263f6 100644 --- a/include/configs/sun6i.h +++ b/include/configs/sun6i.h @@ -22,6 +22,8 @@
#define CONFIG_SUNXI_USB_PHYS 3
+#define CONFIG_NAND_SUNXI_GPC_PORTS {24, 25, 26} + /* * Include common sunxi configuration where most the settings are */
The PSCI CPU_ON code accesses quite a few registers. Document their names to make it easier to cross reference.
Also explain "lock cpu" and "unlock cpu" as enabling/disabling debug access.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/cpu/armv7/sunxi/psci.S | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/psci.S b/arch/arm/cpu/armv7/sunxi/psci.S index 7ec0500..bbfeec8 100644 --- a/arch/arm/cpu/armv7/sunxi/psci.S +++ b/arch/arm/cpu/armv7/sunxi/psci.S @@ -165,12 +165,12 @@ psci_cpu_on: str r6, [r5] @ Reset CPU
@ l1 invalidate - ldr r6, [r0, #0x184] + ldr r6, [r0, #0x184] @ CPUCFG_GEN_CTRL_REG bic r6, r6, r4 str r6, [r0, #0x184]
- @ Lock CPU - ldr r6, [r0, #0x1e4] + @ Lock CPU (Disable external debug access) + ldr r6, [r0, #0x1e4] @ CPUCFG_DBG_CTL1_REG bic r6, r6, r4 str r6, [r0, #0x1e4]
@@ -178,13 +178,13 @@ psci_cpu_on: movw r6, #0x1ff movt r6, #0 1: lsrs r6, r6, #1 - str r6, [r0, #0x1b0] + str r6, [r0, #0x1b0] @ CPU1_PWR_CLAMP bne 1b
timer_wait r1, TEN_MS
@ Clear power gating - ldr r6, [r0, #0x1b4] + ldr r6, [r0, #0x1b4] @ CPU1_PWROFF_REG bic r6, r6, #1 str r6, [r0, #0x1b4]
@@ -192,8 +192,8 @@ psci_cpu_on: mov r6, #3 str r6, [r5]
- @ Unlock CPU - ldr r6, [r0, #0x1e4] + @ Unlock CPU (Enable external debug access) + ldr r6, [r0, #0x1e4] @ CPUCFG_DBG_CTL1_REG orr r6, r6, r4 str r6, [r0, #0x1e4]
@ l1 invalidate
- ldr r6, [r0, #0x184] @ CPUCFG_GEN_CTRL_REG
Can't we use some defines instead? You seem to do that on a few registers (mostly the GIC's), why not for these?
Maxime
On Thu, May 28, 2015 at 11:23 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
@ l1 invalidate
Sure. Though to be clear GIC wasn't my work. :p
For sun6i there's a bit of offset calculating, so we can't use defines for them all.
ChenYu
The PSCI code only works for sun7i. Rename it with _sun7i suffix, and build only if building for sun7i.
This paves the way for adding PSCI support for other platforms.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/cpu/armv7/sunxi/Makefile | 2 +- arch/arm/cpu/armv7/sunxi/{psci.S => psci_sun7i.S} | 0 2 files changed, 1 insertion(+), 1 deletion(-) rename arch/arm/cpu/armv7/sunxi/{psci.S => psci_sun7i.S} (100%)
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 7ef6b4c..85fbc85 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -35,7 +35,7 @@ obj-$(CONFIG_AXP221_POWER) += pmic_bus.o
ifndef CONFIG_SPL_BUILD ifdef CONFIG_ARMV7_PSCI -obj-y += psci.o +obj-$(CONFIG_MACH_SUN7I) += psci_sun7i.o endif endif
diff --git a/arch/arm/cpu/armv7/sunxi/psci.S b/arch/arm/cpu/armv7/sunxi/psci_sun7i.S similarity index 100% rename from arch/arm/cpu/armv7/sunxi/psci.S rename to arch/arm/cpu/armv7/sunxi/psci_sun7i.S
This adds PSCI support for sun6i. So far it only supports the PWR_ON method.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/cpu/armv7/sunxi/Makefile | 1 + arch/arm/cpu/armv7/sunxi/psci_sun6i.S | 276 ++++++++++++++++++++++++++++++++++ 2 files changed, 277 insertions(+) create mode 100644 arch/arm/cpu/armv7/sunxi/psci_sun6i.S
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 85fbc85..4b783e0 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -35,6 +35,7 @@ obj-$(CONFIG_AXP221_POWER) += pmic_bus.o
ifndef CONFIG_SPL_BUILD ifdef CONFIG_ARMV7_PSCI +obj-$(CONFIG_MACH_SUN6I) += psci_sun6i.o obj-$(CONFIG_MACH_SUN7I) += psci_sun7i.o endif endif diff --git a/arch/arm/cpu/armv7/sunxi/psci_sun6i.S b/arch/arm/cpu/armv7/sunxi/psci_sun6i.S new file mode 100644 index 0000000..2516804 --- /dev/null +++ b/arch/arm/cpu/armv7/sunxi/psci_sun6i.S @@ -0,0 +1,276 @@ +/* + * Copyright (C) 2015 - Chen-Yu Tsai + * Author: Chen-Yu Tsai wens@csie.org + * + * Based on psci_sun7i.S by Marc Zyngier marc.zyngier@arm.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <config.h> +#include <asm/gic.h> +#include <asm/macro.h> +#include <asm/psci.h> +#include <asm/arch/cpu.h> + +/* + * Memory layout: + * + * SECURE_RAM to text_end : + * ._secure_text section + * text_end to ALIGN_PAGE(text_end): + * nothing + * ALIGN_PAGE(text_end) to ALIGN_PAGE(text_end) + 0x1000) + * 1kB of stack per CPU (4 CPUs max). + */ + + .pushsection ._secure.text, "ax" + + .arch_extension sec + +#define ONE_MS (CONFIG_TIMER_CLK_FREQ / 1000) +#define TEN_MS (10 * ONE_MS) +#define GICD_BASE 0x1c81000 +#define GICC_BASE 0x1c82000 + +.macro timer_wait reg, ticks + @ Program CNTP_TVAL + movw \reg, #(\ticks & 0xffff) + movt \reg, #(\ticks >> 16) + mcr p15, 0, \reg, c14, c2, 0 + isb + @ Enable physical timer, mask interrupt + mov \reg, #3 + mcr p15, 0, \reg, c14, c2, 1 + @ Poll physical timer until ISTATUS is on +1: isb + mrc p15, 0, \reg, c14, c2, 1 + ands \reg, \reg, #4 + bne 1b + @ Disable timer + mov \reg, #0 + mcr p15, 0, \reg, c14, c2, 1 + isb +.endm + +.globl psci_fiq_enter +psci_fiq_enter: + push {r0-r12} + + @ Switch to secure + mrc p15, 0, r7, c1, c1, 0 + bic r8, r7, #1 + mcr p15, 0, r8, c1, c1, 0 + isb + + @ Validate reason based on IAR and acknowledge + movw r8, #(GICC_BASE & 0xffff) + movt r8, #(GICC_BASE >> 16) + ldr r9, [r8, #GICC_IAR] + movw r10, #0x3ff + movt r10, #0 + cmp r9, r10 @ skip spurious interrupt 1023 + beq out + movw r10, #0x3fe @ ...and 1022 + cmp r9, r10 + beq out + str r9, [r8, #GICC_EOIR] @ acknowledge the interrupt + dsb + + @ Compute CPU number + lsr r9, r9, #10 + and r9, r9, #0xf + + movw r8, #(SUN6I_CPUCFG_BASE & 0xffff) + movt r8, #(SUN6I_CPUCFG_BASE >> 16) + + @ Wait for the core to enter WFI + lsl r11, r9, #6 @ x64 + add r11, r11, r8 + +1: ldr r10, [r11, #0x48] + tst r10, #(1 << 2) + bne 2f + timer_wait r10, ONE_MS + b 1b + + @ Reset CPU +2: mov r10, #0 + str r10, [r11, #0x40] + + @ Lock CPU + mov r10, #1 + lsl r11, r10, r9 @ r11 is now CPU mask + ldr r10, [r8, #0x1e4] + bic r10, r10, r11 + str r10, [r8, #0x1e4] + + movw r8, #(SUNXI_PRCM_BASE & 0xffff) + movt r8, #(SUNXI_PRCM_BASE >> 16) + + @ Set power gating + ldr r10, [r8, #0x100] + orr r10, r10, r11 + str r10, [r8, #0x100] + timer_wait r10, ONE_MS + + @ Activate power clamp + lsl r12, r9, #2 @ x4 + add r12, r12, r8 + mov r10, #0xff + str r10, [r12, #0x140] + + movw r8, #(SUN6I_CPUCFG_BASE & 0xffff) + movt r8, #(SUN6I_CPUCFG_BASE >> 16) + + @ Unlock CPU + ldr r10, [r8, #0x1e4] + orr r10, r10, r11 + str r10, [r8, #0x1e4] + + @ Restore security level +out: mcr p15, 0, r7, c1, c1, 0 + + pop {r0-r12} + subs pc, lr, #4 + + @ r1 = target CPU + @ r2 = target PC +.globl psci_cpu_on +psci_cpu_on: + push {lr} + + mov r0, r1 + bl psci_get_cpu_stack_top @ get stack top of target CPU + str r2, [r0] @ store target PC at stack top + dsb + + movw r0, #(SUN6I_CPUCFG_BASE & 0xffff) + movt r0, #(SUN6I_CPUCFG_BASE >> 16) + + @ CPU mask + and r1, r1, #3 @ only care about first cluster + mov r4, #1 + lsl r4, r4, r1 + + ldr r6, =psci_cpu_entry + str r6, [r0, #0x1a4] @ PRIVATE_REG (boot vector) + + @ Assert reset on target CPU + mov r6, #0 + lsl r5, r1, #6 @ 64 bytes per CPU + add r5, r5, #0x40 @ Offset from base + add r5, r5, r0 @ CPU control block + str r6, [r5] @ Reset CPU + + @ l1 invalidate + ldr r6, [r0, #0x184] @ CPUCFG_GEN_CTRL_REG + bic r6, r6, r4 + str r6, [r0, #0x184] + + @ Lock CPU (Disable external debug access) + ldr r6, [r0, #0x1e4] @ CPUCFG_DBG_CTL1_REG + bic r6, r6, r4 + str r6, [r0, #0x1e4] + + movw r0, #(SUNXI_PRCM_BASE & 0xffff) + movt r0, #(SUNXI_PRCM_BASE >> 16) + + @ Release power clamp + lsl r5, r1, #2 @ 1 register per CPU + add r5, r5, r0 @ PRCM + movw r6, #0x1ff + movt r6, #0 +1: lsrs r6, r6, #1 + str r6, [r5, #0x140] @ CPUx_PWR_CLAMP + bne 1b + + timer_wait r6, TEN_MS + + @ Clear power gating + ldr r6, [r0, #0x100] @ CPU_PWROFF_GATING + bic r6, r6, r4 + str r6, [r0, #0x100] + + @ re-calculate CPU control register address + movw r0, #(SUN6I_CPUCFG_BASE & 0xffff) + movt r0, #(SUN6I_CPUCFG_BASE >> 16) + + @ Deassert reset on target CPU + mov r6, #3 + lsl r5, r1, #6 @ 64 bytes per CPU + add r5, r5, #0x40 @ Offset from base + add r5, r5, r0 @ CPU control block + str r6, [r5] + + @ Unlock CPU (Enable external debug access) + ldr r6, [r0, #0x1e4] @ CPUCFG_DBG_CTL1_REG + orr r6, r6, r4 + str r6, [r0, #0x1e4] + + mov r0, #ARM_PSCI_RET_SUCCESS @ Return PSCI_RET_SUCCESS + pop {pc} + +.globl psci_cpu_off +psci_cpu_off: + bl psci_cpu_off_common + + @ Ask CPU0 to pull the rug... + movw r0, #(GICD_BASE & 0xffff) + movt r0, #(GICD_BASE >> 16) + movw r1, #15 @ SGI15 + movt r1, #1 @ Target is CPU0 + str r1, [r0, #GICD_SGIR] + dsb + +1: wfi + b 1b + +.globl psci_arch_init +psci_arch_init: + mov r6, lr + + movw r4, #(GICD_BASE & 0xffff) + movt r4, #(GICD_BASE >> 16) + + ldr r5, [r4, #GICD_IGROUPRn] + bic r5, r5, #(1 << 15) @ SGI15 as Group-0 + str r5, [r4, #GICD_IGROUPRn] + + mov r5, #0 @ Set SGI15 priority to 0 + strb r5, [r4, #(GICD_IPRIORITYRn + 15)] + + add r4, r4, #0x1000 @ GICC address + + mov r5, #0xff + str r5, [r4, #GICC_PMR] @ Be cool with non-secure + + ldr r5, [r4, #GICC_CTLR] + orr r5, r5, #(1 << 3) @ Switch FIQEn on + str r5, [r4, #GICC_CTLR] + + mrc p15, 0, r5, c1, c1, 0 @ Read SCR + orr r5, r5, #4 @ Enable FIQ in monitor mode + bic r5, r5, #1 @ Secure mode + mcr p15, 0, r5, c1, c1, 0 @ Write SCR + isb + + bl psci_get_cpu_id @ CPU ID => r0 + bl psci_get_cpu_stack_top @ stack top => r0 + mov sp, r0 + + bx r6 + + .globl psci_text_end +psci_text_end: + .popsection
- Copyright (C) 2015 - Chen-Yu Tsai
- Author: Chen-Yu Tsai wens@csie.org
- Based on psci_sun7i.S by Marc Zyngier marc.zyngier@arm.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
- along with this program. If not, see http://www.gnu.org/licenses/.
- Memory layout:
- SECURE_RAM to text_end :
- ._secure_text section
- text_end to ALIGN_PAGE(text_end):
- nothing
- ALIGN_PAGE(text_end) to ALIGN_PAGE(text_end) + 0x1000)
- 1kB of stack per CPU (4 CPUs max).
- .pushsection ._secure.text, "ax"
- .arch_extension sec
- @ Program CNTP_TVAL
- movw \reg, #(\ticks & 0xffff)
- movt \reg, #(\ticks >> 16)
- mcr p15, 0, \reg, c14, c2, 0
- isb
- @ Enable physical timer, mask interrupt
- mov \reg, #3
- mcr p15, 0, \reg, c14, c2, 1
- @ Poll physical timer until ISTATUS is on
+1: isb
- mrc p15, 0, \reg, c14, c2, 1
- ands \reg, \reg, #4
- bne 1b
- @ Disable timer
- mov \reg, #0
- isb
+.endm
I think I saw some patch to factorize that out. In the Tegra K1 PSCI patches iirc.
- push {r0-r12}
- @ Switch to secure
- mrc p15, 0, r7, c1, c1, 0
- bic r8, r7, #1
- mcr p15, 0, r8, c1, c1, 0
- isb
- @ Validate reason based on IAR and acknowledge
- movw r8, #(GICC_BASE & 0xffff)
- movt r8, #(GICC_BASE >> 16)
- ldr r9, [r8, #GICC_IAR]
- movw r10, #0x3ff
- movt r10, #0
- cmp r9, r10 @ skip spurious interrupt 1023
- beq out
- movw r10, #0x3fe @ ...and 1022
Maybe we could add some defines for these spurious interrupts values ?
- mov r6, lr
- movw r4, #(GICD_BASE & 0xffff)
- movt r4, #(GICD_BASE >> 16)
- ldr r5, [r4, #GICD_IGROUPRn]
- bic r5, r5, #(1 << 15) @ SGI15 as Group-0
- str r5, [r4, #GICD_IGROUPRn]
- mov r5, #0 @ Set SGI15 priority to 0
- strb r5, [r4, #(GICD_IPRIORITYRn + 15)]
- add r4, r4, #0x1000 @ GICC address
- mov r5, #0xff
- str r5, [r4, #GICC_PMR] @ Be cool with non-secure
- ldr r5, [r4, #GICC_CTLR]
- orr r5, r5, #(1 << 3) @ Switch FIQEn on
- str r5, [r4, #GICC_CTLR]
- mrc p15, 0, r5, c1, c1, 0 @ Read SCR
- orr r5, r5, #4 @ Enable FIQ in monitor mode
- bic r5, r5, #1 @ Secure mode
- mcr p15, 0, r5, c1, c1, 0 @ Write SCR
- isb
- bl psci_get_cpu_id @ CPU ID => r0
- bl psci_get_cpu_stack_top @ stack top => r0
- mov sp, r0
- bx r6
- .globl psci_text_end
Isn't it exactly the same function than the A20's? Maybe that can be shared?
Thanks, Maxime
On Thu, May 28, 2015 at 11:22 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
- Memory layout:
- nothing
.arch_extension sec
@ Program CNTP_TVAL
isb
mov \reg, #3
+1: isb
ands \reg, \reg, #4
bne 1b
@ Disable timer
mov \reg, #0
isb
+.endm
Waiting for v2: https://patchwork.ozlabs.org/patch/471694/
push {r0-r12}
@ Switch to secure
bic r8, r7, #1
isb
movw r10, #0x3ff
movt r10, #0
beq out
From the GIC spec:
The read returns a spurious interrupt ID of 1023 if any of the following apply: - forwarding of interrupts by the Distributor to the CPU interface is disabled - signaling of interrupts by the CPU interface to the connected processor is disabled - no pending interrupt on the CPU interface has sufficient priority for the interface to signal it to the processor.
Likewise, 1022 means group 0 secure interrupts aren't forwarded to the processor.
So my understanding is that 1022/1023 just means there's nothing for the processor to process. Maybe a note referring to the spec would be enough?
mov r6, lr
mov r5, #0xff
isb
mov sp, r0
bx r6
Good idea. This might even be shared by some other platforms. "psci_text_end" should always be linked in last though.
ChenYu
- Memory layout:
- nothing
.arch_extension sec
@ Program CNTP_TVAL
isb
mov \reg, #3
+1: isb
ands \reg, \reg, #4
bne 1b
@ Disable timer
mov \reg, #0
isb
+.endm
Note I plan to merge this patch-set as is. I agree that factoring out this bit into a helper is a good idea, but that can be done as a later cleanup.
Regards,
Hans
push {r0-r12}
@ Switch to secure
bic r8, r7, #1
isb
movw r10, #0x3ff
movt r10, #0
beq out
From the GIC spec:
Sorry, that's not what I meant.
What I meant was to do
#define GIC_SPURIOUS_INTERRUPT 1023
movw r10, #GIC_SPURIOUS_INTERRUPT.
mov r6, lr
mov r5, #0xff
isb
mov sp, r0
bx r6
Maybe that can be generated directly by the linker script at the end of the PSCI text section?
Maxime
Now that we have a PSCI backend for sun6i, enable it.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- board/sunxi/Kconfig | 3 +++ include/configs/sun6i.h | 5 +++++ 2 files changed, 8 insertions(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index c6c876d..64d2af8 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -35,8 +35,11 @@ config MACH_SUN5I config MACH_SUN6I bool "sun6i (Allwinner A31)" select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT select SUNXI_GEN_SUN6I select SUPPORT_SPL + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN7I bool "sun7i (Allwinner A20)" diff --git a/include/configs/sun6i.h b/include/configs/sun6i.h index e1263f6..a0ebc7e 100644 --- a/include/configs/sun6i.h +++ b/include/configs/sun6i.h @@ -22,6 +22,11 @@
+#define CONFIG_ARMV7_PSCI 1 +#define CONFIG_ARMV7_PSCI_NR_CPUS 4 +#define CONFIG_ARMV7_SECURE_BASE SUNXI_SRAM_B_BASE +#define CONFIG_TIMER_CLK_FREQ 24000000 + #define CONFIG_NAND_SUNXI_GPC_PORTS {24, 25, 26}
sun8i can share the PSCI backend with sun6i. Only difference is sun8i does not have CPU power clamp controls.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/cpu/armv7/sunxi/Makefile | 1 + arch/arm/cpu/armv7/sunxi/psci_sun6i.S | 4 ++++ 2 files changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 4b783e0..76c7e55 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -37,6 +37,7 @@ ifndef CONFIG_SPL_BUILD ifdef CONFIG_ARMV7_PSCI obj-$(CONFIG_MACH_SUN6I) += psci_sun6i.o obj-$(CONFIG_MACH_SUN7I) += psci_sun7i.o +obj-$(CONFIG_MACH_SUN8I) += psci_sun6i.o endif endif
diff --git a/arch/arm/cpu/armv7/sunxi/psci_sun6i.S b/arch/arm/cpu/armv7/sunxi/psci_sun6i.S index 2516804..d4cb51e 100644 --- a/arch/arm/cpu/armv7/sunxi/psci_sun6i.S +++ b/arch/arm/cpu/armv7/sunxi/psci_sun6i.S @@ -124,11 +124,13 @@ psci_fiq_enter: str r10, [r8, #0x100] timer_wait r10, ONE_MS
+#ifdef CONFIG_MACH_SUN6I @ Activate power clamp lsl r12, r9, #2 @ x4 add r12, r12, r8 mov r10, #0xff str r10, [r12, #0x140] +#endif
movw r8, #(SUN6I_CPUCFG_BASE & 0xffff) movt r8, #(SUN6I_CPUCFG_BASE >> 16) @@ -186,6 +188,7 @@ psci_cpu_on: movw r0, #(SUNXI_PRCM_BASE & 0xffff) movt r0, #(SUNXI_PRCM_BASE >> 16)
+#ifdef CONFIG_MACH_SUN6I @ Release power clamp lsl r5, r1, #2 @ 1 register per CPU add r5, r5, r0 @ PRCM @@ -194,6 +197,7 @@ psci_cpu_on: 1: lsrs r6, r6, #1 str r6, [r5, #0x140] @ CPUx_PWR_CLAMP bne 1b +#endif
sun8i uses the same PSCI backend as sun6i, without power clamps. Since there is no secure SRAM, the backend is placed at the end of DRAM.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- board/sunxi/Kconfig | 6 ++++++ include/configs/sun8i.h | 6 ++++++ 2 files changed, 12 insertions(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 64d2af8..8e27396 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -53,14 +53,20 @@ config MACH_SUN7I config MACH_SUN8I_A23 bool "sun8i (Allwinner A23)" select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT select SUNXI_GEN_SUN6I select SUPPORT_SPL + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN8I_A33 bool "sun8i (Allwinner A33)" select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT select SUNXI_GEN_SUN6I select SUPPORT_SPL + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN9I bool "sun9i (Allwinner A80)" diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h index cd33758..fe8c511 100644 --- a/include/configs/sun8i.h +++ b/include/configs/sun8i.h @@ -20,11 +20,17 @@
#define CONFIG_SUNXI_USB_PHYS 2
+#define CONFIG_ARMV7_PSCI 1 #if defined(CONFIG_MACH_SUN8I_A23) +#define CONFIG_ARMV7_PSCI_NR_CPUS 2 #define CONFIG_NAND_SUNXI_GPC_PORTS {16, 17, 18} #elif defined(CONFIG_MACH_SUN8I_A33) +#define CONFIG_ARMV7_PSCI_NR_CPUS 4 #define CONFIG_NAND_SUNXI_GPC_PORTS {16} +#else +#error Unsupported sun8i variant #endif +#define CONFIG_TIMER_CLK_FREQ 24000000
Hi Chen-Yu,
On Thu, May 28, 2015 at 09:25:26PM +0800, Chen-Yu Tsai wrote:
Hi everyone,
This is great, thanks!
Yeah, and we can expect it to work on the H3 and R16 as well.
Eventually, we can remove it.
However, I think we should wait a bit before doing so. We have a few things that will be required before that: - That these patches get merged (obviously) - That we have a way to replace the Allwinner bootloader in NAND on these SoCs. That's especially true on the A31, which will boot on NAND by default. We don't look so far off though. - That these patches get into enough u-boot releases that we can expect that most of the users to have been moved over (I'd say something like 2-3 releases)
Maxime
On Thu, May 28, 2015 at 11:31 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Hi Chen-Yu,
Hi everyone,
Let's see what the maintainers say. :)
Hmm... Is this somehow related? AFAIK most people can use mmc0, and at least my NAND boot0 seems to check mmc0 for a valid signature, and reboot into that.
Yeah, that seems like a safe bet.
Thanks! ChenYu
I guess it depends on the A31 board then. I have a board here that will completely ignore the MMC unless you press a button.
Maxime
On 28-05-15 15:25, Chen-Yu Tsai wrote:
Hi everyone,
Thanks for your work on this! I've merged this into u-boot-sunxi/next, and tested it on sun6i, sun7i, sun8i-a23 and sun8i-a33 and it works fine everywhere.
Thanks I've squashed these into the patch causing the build failures in the first place.
And I've done a normal merge of the rest, and after testing pushed u-boot-sunxi/next to u-boot-sunxi/master and send a pull-req to Tom to get this included into u-boot 2015.07
Regards,
Hans
Chen-Yu Tsai
Hans de Goede
Maxime Ripard
