Pull request: u-boot-rockchip-20250110
Hi Tom,
Please pull the updates for rockchip platform: - Add boards: rk3566: FriendlyARM NanoPi R3S rk3588s: Radxa ROCK 5C, rk3588: Khadas Edge2 - Migrate to OF_UPSTREAM: rk3066a/rk3188; rk3288: tinker, miqi, firefly; - Migrate to TPL: rk3399 kevin and bob;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/24129
Thanks, - Kever
The following changes since commit 38a371110308ebeb277e20531a7b698b7981bbfa:
Merge tag 'tpm-master-07012025' of https://source.denx.de/u-boot/custodians/u-boot-tpm (2025-01-09 11:11:27 -0600)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20250110
for you to fetch changes up to 34df868161e470e5de04db059daa90f12e824693:
rockchip: rk3308: Implement checkboard() to print SoC variant (2025-01-10 15:17:26 +0800)
---------------------------------------------------------------- Cristian Ciocaltea (1): arm64: dts: rockchip: Add HDMI0 node to rk3588
Daniel Semkowicz (1): board: theobroma-systems: Update TF-A setup steps for RK3588 boards
FUKAUMI Naoki (3): arm64: dts: rockchip: add Radxa ROCK 5C rockchip: Add support for Radxa ROCK 5C rockchip: rk3399: expand space for decompressed kernel
Heiko Stuebner (1): clk: rockchip: rk3588: fix mask define for aclk_vop_root
Jacobe Zang (1): board: rockchip: add Khadas Edge2 RK3588 board
Johan Jonker (2): rockchip: use OF_UPSTREAM for rk3066a/rk3188 rockchip: rk3066a/rk3188: use includes from dts/upstream
Jonas Karlman (56): rockchip: rk3288: Use rk3288-power.h from dts/upstream rockchip: clk: rk3288: Drop use of SCLK_MAC_PLL rockchip: rk3288: Use rk3288.dtsi from dts/upstream rockchip: rk3288: Fix bootph prop for vop nodes board: rockchip: rk3288-tinker: Add myself as reviewer to MAINTAINERS rockchip: rk3288-tinker: Sort u-boot.dtsi nodes alphabetically rockchip: rk3288-tinker: Only include required DT nodes in TPL rockchip: rk3288-tinker: Drop unused vcc_sd regulator from SPL rockchip: rk3288-tinker: Include mmc nodes in pre-reloc for env load rockchip: rk3288-tinker: Set cpuid and serial env var rockchip: rk3288-tinker: Sync defconfig options from rk3288-tinker-s rockchip: rk3288-tinker: Use common bss and stack addresses rockchip: rk3288-tinker: Drop use of silent console and late boardinfo rockchip: rk3288-tinker: Drop USE_PREBOOT Kconfig option rockchip: rk3288-tinker: Migrate to OF_UPSTREAM rockchip: rk3288-tinker: Fix slow Ethernet initializion rockchip: rk3288-tinker: Change to use FIT rockchip: rk3288-miqi: Sort u-boot.dtsi nodes alphabetically rockchip: rk3288-miqi: Remove unused work led node from xPL rockchip: rk3288-miqi: Set ethaddr env based on cpuid rockchip: rk3288-miqi: Use TPL with common bss and stack addresses rockchip: rk3288-miqi: Include required DT nodes in xPL rockchip: rk3288-miqi: Include sdmmc regulator in SPL rockchip: rk3288-miqi: Drop use of silent console and late boardinfo rockchip: rk3288-miqi: Drop USE_PREBOOT Kconfig option rockchip: rk3288-miqi: Migrate to OF_UPSTREAM rockchip: rk3288-miqi: Fix slow Ethernet initializion rockchip: rk3288-miqi: Change to use FIT rockchip: rk3288-firefly: Drop unused SPL_LED related code rockchip: rk3288-firefly: Sort u-boot.dtsi nodes alphabetically rockchip: rk3288-firefly: Set ethaddr env based on cpuid rockchip: rk3288-firefly: Use common bss and stack addresses rockchip: rk3288-firefly: Include required DT nodes in xPL rockchip: rk3288-firefly: Include sdmmc regulator in SPL rockchip: rk3288-firefly: Drop use of silent console and late boardinfo rockchip: rk3288-firefly: Drop USE_PREBOOT Kconfig option rockchip: rk3288-firefly: Migrate to OF_UPSTREAM rockchip: rk3288-firefly: Fix slow Ethernet initializion rockchip: rk3288-firefly: Change to use FIT rockchip: rk3399: Fix TPL build of bob and kevin rockchip: rk3399-gru: Use SYS_SPI_U_BOOT_OFFS value in offset prop rockchip: rk3399-gru: Move SPI flash payload offset for bob and kevin rockchip: rk3399-gru: Fix include of TPL in u-boot.rom image rockchip: rk3399-gru: Use TPL with common bss and stack addresses rockchip: rk3399-gru: Include binman generated FIT in u-boot.rom image rockchip: rk3399: Drop common Kconfig options already implied rockchip: rk3399-gru: Remove unused nodes from xPL control FDT rockchip: rk3399-gru: Enable dcache and signature validation in SPL rockchip: rk3399-gru: Use SDMA mode to read from eMMC rockchip: rk3399-gru: Include pinctrl and regulators in SPL rockchip: rk3399: Drop unneeded bob and kevin board specific code rockchip: rk3588-nanopc-t6-lts: Add missing board -u-boot.dtsi rockchip: rk3399-rock-pi-4: Fix Synchronous Abort rockchip: rk356x: Implement checkboard() to print SoC variant rockchip: rk3588: Implement checkboard() to print SoC variant rockchip: rk3308: Implement checkboard() to print SoC variant
Paul Kocialkowski (3): rockchip: rk3399-roc-pc: Hook sysreset gpio to enable full reset rockchip: rk3399-rockpro64: Hook sysreset gpio to enable full reset rockchip: rk3399-rockpro64: Disable bootstage instrumentation config
Sam Edwards (1): arm64: dts: rockchip: Split up RK3588's PCIe pinctrls
Tianling Shen (7): arm64: dts: rockchip: Add FriendlyARM NanoPi R3S board arm64: dts: rockchip: fix model name for FriendlyElec NanoPi R3S arm64: dts: rockchip: replace deprecated snps, reset props for NanoPi R3S arm64: dts: rockchip: sort props in pmu_io_domains node for NanoPi R3S arm64: dts: rockchip: enable eMMC HS200 mode for NanoPi R3S arm64: dts: rockchip: reorder mmc aliases for NanoPi R3S board: rockchip: add FriendlyElec NanoPi R3S
arch/arm/dts/Makefile | 10 - arch/arm/dts/rk3066a-mk808.dts | 241 --- arch/arm/dts/rk3066a-u-boot.dtsi | 20 - arch/arm/dts/rk3066a.dtsi | 880 --------- arch/arm/dts/rk3188-radxarock.dts | 389 ---- arch/arm/dts/rk3188-u-boot.dtsi | 17 - arch/arm/dts/rk3188.dtsi | 815 -------- arch/arm/dts/rk3288-firefly-u-boot.dtsi | 91 +- arch/arm/dts/rk3288-firefly.dts | 43 - arch/arm/dts/rk3288-firefly.dtsi | 491 ----- arch/arm/dts/rk3288-miqi-u-boot.dtsi | 83 +- arch/arm/dts/rk3288-miqi.dts | 16 - arch/arm/dts/rk3288-miqi.dtsi | 417 ---- arch/arm/dts/rk3288-tinker-s-u-boot.dtsi | 13 +- arch/arm/dts/rk3288-tinker-s.dts | 29 - arch/arm/dts/rk3288-tinker-u-boot.dtsi | 53 +- arch/arm/dts/rk3288-tinker.dts | 33 - arch/arm/dts/rk3288-tinker.dtsi | 533 ----- arch/arm/dts/rk3288-u-boot.dtsi | 13 +- arch/arm/dts/rk3288.dtsi | 2035 -------------------- arch/arm/dts/rk3399-gru-u-boot.dtsi | 29 +- arch/arm/dts/rk3399-roc-pc-u-boot.dtsi | 8 + arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 8 + arch/arm/dts/rk3399-u-boot.dtsi | 14 +- arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi | 8 + arch/arm/dts/rk356x-u-boot.dtsi | 4 + arch/arm/dts/rk3588-nanopc-t6-lts-u-boot.dtsi | 3 + arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi | 11 + arch/arm/dts/rk3588s-u-boot.dtsi | 4 + arch/arm/dts/rk3xxx.dtsi | 488 ----- arch/arm/include/asm/arch-rockchip/cru_rk3588.h | 2 +- arch/arm/mach-rockchip/Kconfig | 2 + arch/arm/mach-rockchip/rk3288/Kconfig | 10 +- arch/arm/mach-rockchip/rk3308/rk3308.c | 16 + arch/arm/mach-rockchip/rk3399/Kconfig | 12 - arch/arm/mach-rockchip/rk3399/rk3399.c | 23 +- arch/arm/mach-rockchip/rk3568/rk3568.c | 61 + arch/arm/mach-rockchip/rk3588/Kconfig | 44 + arch/arm/mach-rockchip/rk3588/rk3588.c | 52 + board/firefly/firefly-rk3288/MAINTAINERS | 1 + board/firefly/firefly-rk3288/Makefile | 7 - board/firefly/firefly-rk3288/firefly-rk3288.c | 46 - board/friendlyelec/nanopc-t6-rk3588/MAINTAINERS | 3 +- board/khadas/khadas-edge2-rk3588s/Kconfig | 12 + board/khadas/khadas-edge2-rk3588s/MAINTAINERS | 6 + board/mqmaker/miqi_rk3288/MAINTAINERS | 1 - board/radxa/rock-5c-rk3588s/Kconfig | 12 + board/radxa/rock-5c-rk3588s/MAINTAINERS | 7 + board/radxa/rockpi4-rk3399/rockpi4-rk3399.c | 2 + board/rockchip/evb_rk3568/MAINTAINERS | 7 + board/rockchip/tinker_rk3288/MAINTAINERS | 7 +- board/rockchip/tinker_rk3288/tinker-rk3288.c | 2 +- configs/chromebook_bob_defconfig | 24 +- configs/chromebook_kevin_defconfig | 24 +- configs/firefly-rk3288_defconfig | 39 +- configs/khadas-edge2-rk3588s_defconfig | 215 +++ configs/miqi-rk3288_defconfig | 43 +- configs/mk808_defconfig | 4 +- configs/nanopi-r3s-rk3566_defconfig | 75 + configs/rock-5c-rk3588s_defconfig | 84 + configs/rock_defconfig | 4 +- configs/rockpro64-rk3399_defconfig | 3 - configs/tinker-rk3288_defconfig | 41 +- configs/tinker-s-rk3288_defconfig | 38 +- doc/board/rockchip/rockchip.rst | 3 + doc/board/theobroma-systems/jaguar_rk3588.rst | 6 +- doc/board/theobroma-systems/tiger_rk3588.rst | 6 +- drivers/clk/rockchip/clk_rk3288.c | 8 +- .../src/arm64/rockchip/rk3566-nanopi-r3s.dts | 554 ++++++ .../src/arm64/rockchip/rk3588-base-pinctrl.dtsi | 271 ++- dts/upstream/src/arm64/rockchip/rk3588-base.dtsi | 41 + .../src/arm64/rockchip/rk3588s-rock-5a.dts | 6 +- .../src/arm64/rockchip/rk3588s-rock-5c.dts | 920 +++++++++ include/configs/khadas-edge2-rk3588s.h | 15 + include/configs/rk3399_common.h | 16 +- include/configs/rock-5c-rk3588s.h | 15 + include/dt-bindings/clock/rk3066a-cru.h | 31 - include/dt-bindings/clock/rk3188-cru-common.h | 261 --- include/dt-bindings/clock/rk3188-cru.h | 47 - include/dt-bindings/power/rk3066-power.h | 22 - include/dt-bindings/power/rk3188-power.h | 24 - include/dt-bindings/power/rk3288-power.h | 32 - 82 files changed, 2760 insertions(+), 7246 deletions(-) delete mode 100644 arch/arm/dts/rk3066a-mk808.dts delete mode 100644 arch/arm/dts/rk3066a.dtsi delete mode 100644 arch/arm/dts/rk3188-radxarock.dts delete mode 100644 arch/arm/dts/rk3188.dtsi delete mode 100644 arch/arm/dts/rk3288-firefly.dts delete mode 100644 arch/arm/dts/rk3288-firefly.dtsi delete mode 100644 arch/arm/dts/rk3288-miqi.dts delete mode 100644 arch/arm/dts/rk3288-miqi.dtsi delete mode 100644 arch/arm/dts/rk3288-tinker-s.dts delete mode 100644 arch/arm/dts/rk3288-tinker.dts delete mode 100644 arch/arm/dts/rk3288-tinker.dtsi delete mode 100644 arch/arm/dts/rk3288.dtsi create mode 100644 arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-nanopc-t6-lts-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3xxx.dtsi delete mode 100644 board/firefly/firefly-rk3288/Makefile delete mode 100644 board/firefly/firefly-rk3288/firefly-rk3288.c create mode 100644 board/khadas/khadas-edge2-rk3588s/Kconfig create mode 100644 board/khadas/khadas-edge2-rk3588s/MAINTAINERS create mode 100644 board/radxa/rock-5c-rk3588s/Kconfig create mode 100644 board/radxa/rock-5c-rk3588s/MAINTAINERS create mode 100644 configs/khadas-edge2-rk3588s_defconfig create mode 100644 configs/nanopi-r3s-rk3566_defconfig create mode 100644 configs/rock-5c-rk3588s_defconfig create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts create mode 100644 dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts create mode 100644 include/configs/khadas-edge2-rk3588s.h create mode 100644 include/configs/rock-5c-rk3588s.h delete mode 100644 include/dt-bindings/clock/rk3066a-cru.h delete mode 100644 include/dt-bindings/clock/rk3188-cru-common.h delete mode 100644 include/dt-bindings/clock/rk3188-cru.h delete mode 100644 include/dt-bindings/power/rk3066-power.h delete mode 100644 include/dt-bindings/power/rk3188-power.h delete mode 100644 include/dt-bindings/power/rk3288-power.h
On Fri, Jan 10, 2025 at 06:08:56PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
