[U-Boot] [PATCH-ARM] S3C2440: Add support for Embest SBC2440-II Board
Adds support for the Embest SBC2440-II Board (see http://www.embedinfo.com/english/product/sbc2440-II.asp) with u-boot programmed in NOR flash.
Implementation is based on the existing u-boot support for s3C2410-based boards. Where I've copied and modified existing files I've left the style of the original code as it was, including any non-conformance with the u-boot coding style. Where I've added new code I've aimed to use the u-boot coding style. I've run MAKEALL with the LIST_ARM9 targets only as the changes don't affect any other architectures.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk
diff -uprN u-boot-2009.03/MAKEALL u-boot-2009.03-PATCHED/MAKEALL --- u-boot-2009.03/MAKEALL 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/MAKEALL 2009-03-25 21:48:14.171875000 +0000 @@ -512,6 +512,7 @@ LIST_ARM9=" \ omap5912osk \ omap730p2 \ sbc2410x \ + sbc2440ii \ scb9328 \ smdk2400 \ smdk2410 \ diff -uprN u-boot-2009.03/Makefile u-boot-2009.03-PATCHED/Makefile --- u-boot-2009.03/Makefile 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/Makefile 2009-03-22 09:42:11.078125000 +0000 @@ -2821,6 +2821,9 @@ omap730p2_cs3boot_config : unconfig sbc2410x_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm920t sbc2410x NULL s3c24x0
+sbc2440ii_config: unconfig + @$(MKCONFIG) $(@:_config=) arm arm920t sbc2440ii embest s3c24x0 + scb9328_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t scb9328 NULL imx
diff -uprN u-boot-2009.03/board/embest/sbc2440ii/Makefile u-boot-2009.03-PATCHED/board/embest/sbc2440ii/Makefile --- u-boot-2009.03/board/embest/sbc2440ii/Makefile 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/Makefile 2009-03-22 09:44:24.640625000 +0000 @@ -0,0 +1,51 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := sbc2440ii.o flash.o sbc2440ii_cmd.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff -uprN u-boot-2009.03/board/embest/sbc2440ii/config.mk u-boot-2009.03-PATCHED/board/embest/sbc2440ii/config.mk --- u-boot-2009.03/board/embest/sbc2440ii/config.mk 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/config.mk 2009-03-25 21:05:21.281250000 +0000 @@ -0,0 +1,25 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# SAMSUNG SMDK2410 board with S3C2410X (ARM920T) cpu +# +# see http://www.samsung.com/ for more information on SAMSUNG +# +# Modified for EMBEST SBC2440-II board with S3C2440 (ARM920T) cpu by: +# (C) Copyright 2009 +# Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + +# +# SBC2440-II has 1 bank of 64 MB DRAM +# +# 3000'0000 to 3800'0000 +# +# Linux-Kernel is expected to be at 3000'8000, entry 3000'8000 +# +# we load ourself to 33F8'0000 +# +# download area is 3000'0000 + +TEXT_BASE = 0x33F80000 diff -uprN u-boot-2009.03/board/embest/sbc2440ii/flash.c u-boot-2009.03-PATCHED/board/embest/sbc2440ii/flash.c --- u-boot-2009.03/board/embest/sbc2440ii/flash.c 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/flash.c 2009-03-22 21:43:19.765625000 +0000 @@ -0,0 +1,437 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +ulong myflush (void); + +#define FLASH_BANK_SIZE PHYS_FLASH_SIZE +#define MAIN_SECT_SIZE 0x10000 /* 64 KB */ + +flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +#define CMD_READ_ARRAY 0x000000F0 +#define CMD_UNLOCK1 0x000000AA +#define CMD_UNLOCK2 0x00000055 +#define CMD_ERASE_SETUP 0x00000080 +#define CMD_ERASE_CONFIRM 0x00000030 +#define CMD_PROGRAM 0x000000A0 +#define CMD_UNLOCK_BYPASS 0x00000020 + +#define MEM_FLASH_ADDR1 (*(volatile u16 *)(CONFIG_SYS_FLASH_BASE + (0x00000555 << 1))) +#define MEM_FLASH_ADDR2 (*(volatile u16 *)(CONFIG_SYS_FLASH_BASE + (0x000002AA << 1))) + +#define BIT_ERASE_DONE 0x00000080 +#define BIT_RDY_MASK 0x00000080 +#define BIT_PROGRAM_ERROR 0x00000020 +#define BIT_TIMEOUT 0x80000000 /* our flag */ + +#define READY 1 +#define ERR 2 +#define TMO 4 + +/*----------------------------------------------------------------------- + */ + +ulong flash_init (void) +{ + int i, j; + ulong size = 0; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + ulong flashbase = 0; + + flash_info[i].flash_id = +#if defined(CONFIG_AMD_LV400) + (AMD_MANUFACT & FLASH_VENDMASK) | + (AMD_ID_LV400B & FLASH_TYPEMASK); +#elif defined(CONFIG_AMD_LV800) + (AMD_MANUFACT & FLASH_VENDMASK) | + (AMD_ID_LV800B & FLASH_TYPEMASK); +#elif defined(CONFIG_AMD_LV160B) + (AMD_MANUFACT & FLASH_VENDMASK) | + (AMD_ID_LV160B & FLASH_TYPEMASK); +#else +#error "Unknown flash configured" +#endif + flash_info[i].size = FLASH_BANK_SIZE; + flash_info[i].sector_count = CONFIG_SYS_MAX_FLASH_SECT; + memset (flash_info[i].protect, 0, CONFIG_SYS_MAX_FLASH_SECT); + if (i == 0) + flashbase = PHYS_FLASH_1; + else + panic ("configured too many flash banks!\n"); + for (j = 0; j < flash_info[i].sector_count; j++) { + if (j <= 3) { + /* 1st one is 16 KB */ + if (j == 0) { + flash_info[i].start[j] = + flashbase + 0; + } + + /* 2nd and 3rd are both 8 KB */ + if ((j == 1) || (j == 2)) { + flash_info[i].start[j] = + flashbase + 0x4000 + (j - + 1) * + 0x2000; + } + + /* 4th 32 KB */ + if (j == 3) { + flash_info[i].start[j] = + flashbase + 0x8000; + } + } else { + flash_info[i].start[j] = + flashbase + (j - 3) * MAIN_SECT_SIZE; + } + } + size += flash_info[i].size; + } + + flash_protect (FLAG_PROTECT_SET, + CONFIG_SYS_FLASH_BASE, + CONFIG_SYS_FLASH_BASE + monitor_flash_len - 1, + &flash_info[0]); + + flash_protect (FLAG_PROTECT_SET, + CONFIG_ENV_ADDR, + CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); + + return size; +} + +/*----------------------------------------------------------------------- + */ +void flash_print_info (flash_info_t * info) +{ + int i; + + switch (info->flash_id & FLASH_VENDMASK) { + case (AMD_MANUFACT & FLASH_VENDMASK): + printf ("AMD: "); + break; + default: + printf ("Unknown Vendor "); + break; + } + + switch (info->flash_id & FLASH_TYPEMASK) { + case (AMD_ID_LV400B & FLASH_TYPEMASK): + printf ("1x Amd29LV400BB (4Mbit)\n"); + break; + case (AMD_ID_LV800B & FLASH_TYPEMASK): + printf ("1x Amd29LV800BB (8Mbit)\n"); + break; + case (AMD_ID_LV160B & FLASH_TYPEMASK): + printf ("1x Amd29LV160DB (16Mbit)\n"); + break; + default: + printf ("Unknown Chip Type\n"); + goto Done; + break; + } + + printf (" Size: %ld MB in %d Sectors\n", + info->size >> 20, info->sector_count); + + printf (" Sector Start Addresses:"); + for (i = 0; i < info->sector_count; i++) { + if ((i % 5) == 0) { + printf ("\n "); + } + printf (" %08lX%s", info->start[i], + info->protect[i] ? " (RO)" : " "); + } + printf ("\n"); + + Done:; +} + +/*----------------------------------------------------------------------- + */ + +int flash_erase (flash_info_t * info, int s_first, int s_last) +{ + ushort result; + int iflag, cflag, prot, sect; + int rc = ERR_OK; + int chip; + + /* first look for protection bits */ + + if (info->flash_id == FLASH_UNKNOWN) + return ERR_UNKNOWN_FLASH_TYPE; + + if ((s_first < 0) || (s_first > s_last)) { + return ERR_INVAL; + } + + if ((info->flash_id & FLASH_VENDMASK) != + (AMD_MANUFACT & FLASH_VENDMASK)) { + return ERR_UNKNOWN_FLASH_VENDOR; + } + + prot = 0; + for (sect = s_first; sect <= s_last; ++sect) { + if (info->protect[sect]) { + prot++; + } + } + if (prot) + return ERR_PROTECTED; + + /* + * Disable interrupts which might cause a timeout + * here. Remember that our exception vectors are + * at address 0 in the flash, and we don't want a + * (ticker) exception to happen while the flash + * chip is in programming mode. + */ + cflag = icache_status (); + icache_disable (); + iflag = disable_interrupts (); + + /* Start erase on unprotected sectors */ + for (sect = s_first; sect <= s_last && !ctrlc (); sect++) { + printf ("Erasing sector %2d ... ", sect); + + /* arm simple, non interrupt dependent timer */ + reset_timer_masked (); + + if (info->protect[sect] == 0) { /* not protected */ + vu_short *addr = (vu_short *) (info->start[sect]); + + MEM_FLASH_ADDR1 = CMD_UNLOCK1; + MEM_FLASH_ADDR2 = CMD_UNLOCK2; + MEM_FLASH_ADDR1 = CMD_ERASE_SETUP; + + MEM_FLASH_ADDR1 = CMD_UNLOCK1; + MEM_FLASH_ADDR2 = CMD_UNLOCK2; + *addr = CMD_ERASE_CONFIRM; + + /* wait until flash is ready */ + chip = 0; + + do { + result = *addr; + + /* check timeout */ + if (get_timer_masked () > + CONFIG_SYS_FLASH_ERASE_TOUT) { + MEM_FLASH_ADDR1 = CMD_READ_ARRAY; + chip = TMO; + break; + } + + if (!chip + && (result & 0xFFFF) & BIT_ERASE_DONE) + chip = READY; + + if (!chip + && (result & 0xFFFF) & BIT_PROGRAM_ERROR) + chip = ERR; + + } while (!chip); + + MEM_FLASH_ADDR1 = CMD_READ_ARRAY; + + if (chip == ERR) { + rc = ERR_PROG_ERROR; + goto outahere; + } + if (chip == TMO) { + rc = ERR_TIMOUT; + goto outahere; + } + + printf ("ok.\n"); + } else { /* it was protected */ + + printf ("protected!\n"); + } + } + + if (ctrlc ()) + printf ("User Interrupt!\n"); + + outahere: + /* allow flash to settle - wait 10 ms */ + udelay_masked (10000); + + if (iflag) + enable_interrupts (); + + if (cflag) + icache_enable (); + + return rc; +} + +/*----------------------------------------------------------------------- + * Copy memory to flash + */ + +static int write_hword (flash_info_t * info, ulong dest, ushort data) +{ + vu_short *addr = (vu_short *) dest; + ushort result; + int rc = ERR_OK; + int cflag, iflag; + int chip; + + /* + * Check if Flash is (sufficiently) erased + */ + result = *addr; + if ((result & data) != data) + return ERR_NOT_ERASED; + + + /* + * Disable interrupts which might cause a timeout + * here. Remember that our exception vectors are + * at address 0 in the flash, and we don't want a + * (ticker) exception to happen while the flash + * chip is in programming mode. + */ + cflag = icache_status (); + icache_disable (); + iflag = disable_interrupts (); + + MEM_FLASH_ADDR1 = CMD_UNLOCK1; + MEM_FLASH_ADDR2 = CMD_UNLOCK2; + MEM_FLASH_ADDR1 = CMD_UNLOCK_BYPASS; + *addr = CMD_PROGRAM; + *addr = data; + + /* arm simple, non interrupt dependent timer */ + reset_timer_masked (); + + /* wait until flash is ready */ + chip = 0; + do { + result = *addr; + + /* check timeout */ + if (get_timer_masked () > CONFIG_SYS_FLASH_ERASE_TOUT) { + chip = ERR | TMO; + break; + } + if (!chip && ((result & 0x80) == (data & 0x80))) + chip = READY; + + if (!chip && ((result & 0xFFFF) & BIT_PROGRAM_ERROR)) { + result = *addr; + + if ((result & 0x80) == (data & 0x80)) + chip = READY; + else + chip = ERR; + } + + } while (!chip); + + *addr = CMD_READ_ARRAY; + + if (chip == ERR || *addr != data) + rc = ERR_PROG_ERROR; + + if (iflag) + enable_interrupts (); + + if (cflag) + icache_enable (); + + return rc; +} + +/*----------------------------------------------------------------------- + * Copy memory to flash. + */ + +int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) +{ + ulong cp, wp; + int l; + int i, rc; + ushort data; + + wp = (addr & ~1); /* get lower word aligned address */ + + /* + * handle unaligned start bytes + */ + if ((l = addr - wp) != 0) { + data = 0; + for (i = 0, cp = wp; i < l; ++i, ++cp) { + data = (data >> 8) | (*(uchar *) cp << 8); + } + for (; i < 2 && cnt > 0; ++i) { + data = (data >> 8) | (*src++ << 8); + --cnt; + ++cp; + } + for (; cnt == 0 && i < 2; ++i, ++cp) { + data = (data >> 8) | (*(uchar *) cp << 8); + } + + if ((rc = write_hword (info, wp, data)) != 0) { + return (rc); + } + wp += 2; + } + + /* + * handle word aligned part + */ + while (cnt >= 2) { + data = *((vu_short *) src); + if ((rc = write_hword (info, wp, data)) != 0) { + return (rc); + } + src += 2; + wp += 2; + cnt -= 2; + } + + if (cnt == 0) { + return ERR_OK; + } + + /* + * handle unaligned tail bytes + */ + data = 0; + for (i = 0, cp = wp; i < 2 && cnt > 0; ++i, ++cp) { + data = (data >> 8) | (*src++ << 8); + --cnt; + } + for (; i < 2; ++i, ++cp) { + data = (data >> 8) | (*(uchar *) cp << 8); + } + + return write_hword (info, wp, data); +} diff -uprN u-boot-2009.03/board/embest/sbc2440ii/lowlevel_init.S u-boot-2009.03-PATCHED/board/embest/sbc2440ii/lowlevel_init.S --- u-boot-2009.03/board/embest/sbc2440ii/lowlevel_init.S 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/lowlevel_init.S 2009-03-25 21:04:56.656250000 +0000 @@ -0,0 +1,188 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and + * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) + * + * Modified for the Samsung SMDK2410 by + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * Modified for the friendly-arm SBC-2410X by + * (C) Copyright 2005 + * JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> + +/* + * Taken from linux/arch/arm/boot/compressed/head-s3c2410.S + * + * Copyright (C) 2002 Samsung Electronics SW.LEE hitchcar@sec.samsung.com + */ + +#define BWSCON 0x48000000 + +/* BWSCON */ +#define DW8 (0x0) +#define DW16 (0x1) +#define DW32 (0x2) +#define WAIT (0x1<<2) +#define UBLB (0x1<<3) + +#define B1_BWSCON (DW16) +#define B2_BWSCON (DW16) +#define B3_BWSCON (DW16 + WAIT + UBLB) +#define B4_BWSCON (DW16) +#define B5_BWSCON (DW16) +#define B6_BWSCON (DW32) +#define B7_BWSCON (DW32) + +#define B0_Tacs 0x0 +#define B0_Tcos 0x0 +#define B0_Tacc 0x7 +#define B0_Tcoh 0x0 +#define B0_Tah 0x0 +#define B0_Tacp 0x0 +#define B0_PMC 0x0 + +#define B1_Tacs 0x0 +#define B1_Tcos 0x0 +#define B1_Tacc 0x7 +#define B1_Tcoh 0x0 +#define B1_Tah 0x0 +#define B1_Tacp 0x0 +#define B1_PMC 0x0 + +#define B2_Tacs 0x0 +#define B2_Tcos 0x0 +#define B2_Tacc 0x7 +#define B2_Tcoh 0x0 +#define B2_Tah 0x0 +#define B2_Tacp 0x0 +#define B2_PMC 0x0 + +#define B3_Tacs 0x0 /* 0clk */ +#define B3_Tcos 0x3 /* 4clk */ +#define B3_Tacc 0x7 /* 14clk */ +#define B3_Tcoh 0x1 /* 1clk */ +#define B3_Tah 0x3 /* 4clk */ +#define B3_Tacp 0x3 /* 6clk */ +#define B3_PMC 0x0 /* 16data */ + +#define B4_Tacs 0x0 +#define B4_Tcos 0x0 +#define B4_Tacc 0x7 +#define B4_Tcoh 0x0 +#define B4_Tah 0x0 +#define B4_Tacp 0x0 +#define B4_PMC 0x0 + +#define B5_Tacs 0x0 +#define B5_Tcos 0x0 +#define B5_Tacc 0x7 +#define B5_Tcoh 0x0 +#define B5_Tah 0x0 +#define B5_Tacp 0x0 +#define B5_PMC 0x0 + +#define B6_MT 0x3 /* SDRAM */ +#define B6_Trcd 0x2 +#define B6_SCAN 0x1 /* 9bit */ + +#define B7_MT 0x3 /* SDRAM */ +#define B7_Trcd 0x2 /* 4clk */ +#define B7_SCAN 0x1 /* 9bit */ + +/* REFRESH parameter */ +#define REFEN 0x1 /* Refresh enable */ +#define TREFMD 0x0 /* CBR(CAS before RAS)/Auto refresh */ +#define Trp 0x0 /* 2clk */ +#define Trc 0x3 /* 7clk */ +#define Tchr 0x2 /* 3clk */ +#define REFCNT 1259 + +/* BANKSIZE parameter */ +#define BURST_EN 1 /* Enable burst mode */ +#define SCKE_EN 1 /* Enable SDRAM power-down mode */ +#define SCLK_EN 1 /* SCLK is active only during the access */ +#define BK67MAP 2 /* 128M/128M */ + +/* MRSRB6 parameter */ +#define WBL6 0 /* Burst */ +#define TM6 0 /* Modem register set */ +#define CL6 3 /* Latency is 3 clocks */ +#define BT6 0 /* Sequential */ +#define BL6 0 + +/* MRSRB7 parameter */ +#define WBL7 0 /* Burst */ +#define TM7 0 /* Modem register set */ +#define CL7 3 /* Latency is 3 clocks */ +#define BT7 0 /* Sequential */ +#define BL7 0 + +/**************************************/ + +_TEXT_BASE: + .word TEXT_BASE + +.globl lowlevel_init +lowlevel_init: + /* memory control configuration */ + /* make r0 relative the current location so that it */ + /* reads SMRDATA out of FLASH rather than memory ! */ + ldr r0, =SMRDATA + ldr r1, _TEXT_BASE + sub r0, r0, r1 + ldr r1, =BWSCON /* Bus Width Status Controller */ + add r2, r0, #13*4 +0: + ldr r3, [r0], #4 + str r3, [r1], #4 + cmp r2, r0 + bne 0b + + /* everything is fine now */ + mov pc, lr + + .ltorg +/* the literal pools origin */ + +SMRDATA: + .word (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28)) + .word ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) + .word ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) + .word ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) + .word ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) + .word ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) + .word ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) + .word ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) + .word ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) + .word ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT) + .word ((BURST_EN<<7)+(SCKE_EN<<5)+(SCLK_EN<<4)+(BK67MAP)) + .word ((WBL6<<9)+(TM6<<7)+(CL6<<4)+(BT6<<3)+(BL6)) + .word ((WBL7<<9)+(TM7<<7)+(CL7<<4)+(BT7<<3)+(BL7)) diff -uprN u-boot-2009.03/board/embest/sbc2440ii/sbc2440ii.c u-boot-2009.03-PATCHED/board/embest/sbc2440ii/sbc2440ii.c --- u-boot-2009.03/board/embest/sbc2440ii/sbc2440ii.c 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/sbc2440ii.c 2009-03-25 21:05:14.171875000 +0000 @@ -0,0 +1,127 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * (C) Copyright 2005 + * JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <s3c2440.h> + +DECLARE_GLOBAL_DATA_PTR; + +static inline void delay (unsigned long loops) +{ + __asm__ volatile ("1:\n" + "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0" (loops)); +} + +/* Configure the PLLs for MPLL = 400MHz, UPLL = 48MHz + The clock frequency ratios are set to 1:4:8 ie: + PCLK = 50MHz + HCLK = 100MHz + FCLK = 400MHz + */ +/* The MPLL values. */ +#define M_MDIV 0x5C +#define M_PDIV 1 +#define M_SDIV 1 + +/* The UPLL values. */ +#define U_MDIV 0x38 +#define U_PDIV 2 +#define U_SDIV 2 + +/* + * Miscellaneous platform dependent initialisations + */ + +int board_init (void) +{ + S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + S3C24X0_GPIO * const gpio = S3C24X0_GetBase_GPIO(); + + /* to reduce PLL lock time, adjust the LOCKTIME register */ + clk_power->LOCKTIME = 0xFFFFFFFF; + + /* configure UPLL */ + clk_power->UPLLCON = ((U_MDIV << 12) + (U_PDIV << 4) + U_SDIV); + + /* some delay between UPLL and MPLL */ + delay (8000); + + /* configure MPLL */ + clk_power->MPLLCON = ((M_MDIV << 12) + (M_PDIV << 4) + M_SDIV); + + /* configure the GPIO */ + gpio->GPACON = 0x007FFFFF; + gpio->GPBCON = 0x00055555; + gpio->GPBUP = 0x000007FF; + gpio->GPBDAT = 0x000001C0; /* Switch on LED1. */ + gpio->GPCCON = 0xAAAAAAAA; + gpio->GPCUP = 0x0000FFFF; + gpio->GPDCON = 0xAAAAAAAA; + gpio->GPDUP = 0x0000FFFF; + gpio->GPECON = 0xAAAAA800; + gpio->GPEUP = 0x00001FFF; + gpio->GPFCON = 0x000055AA; + gpio->GPFUP = 0x000000FF; + gpio->GPGCON = 0xFD95FFBA; + gpio->GPGUP = 0x0000FFFF; + gpio->GPHCON = 0x0002FAAA; + gpio->GPHUP = 0x000007FF; + gpio->GPJCON = 0x02FAAAAA; + gpio->GPJUP = 0x00001FFF; + + gpio->EXTINT0 = 0x22222222; + gpio->EXTINT1 = 0x22222222; + gpio->EXTINT2 = 0x22222222; + gpio->EINTMASK = 0x00FFFFF0; + + /* arch number of SBC2440-II Board */ + gd->bd->bi_arch_number = MACH_TYPE_SBC2440II; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x30000100; + + icache_enable(); + dcache_enable(); + + return 0; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} diff -uprN u-boot-2009.03/board/embest/sbc2440ii/sbc2440ii_cmd.c u-boot-2009.03-PATCHED/board/embest/sbc2440ii/sbc2440ii_cmd.c --- u-boot-2009.03/board/embest/sbc2440ii/sbc2440ii_cmd.c 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/sbc2440ii_cmd.c 2009-03-25 21:05:37.984375000 +0000 @@ -0,0 +1,61 @@ +/* + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <net.h> + +#if 0 + #define DEBUGN printf +#else + #define DEBUGN(x, args ...) {} +#endif + +static int get_file_tftp(struct cmd_tbl_s *cmftp, int flag, int argc, char *argv[]); + +U_BOOT_CMD( + tftp, 3, 0, get_file_tftp, + "tftp\t- Upload a file via TFTP", + "<address> <file name> - Upload <file name> to <address> via TFTP" +); + +static int get_file_tftp(struct cmd_tbl_s *cmftp, int flag, int argc, char *argv[]) +{ + load_addr = simple_strtoul(argv[1], NULL, 16); + copy_filename(BootFile, argv[2], sizeof (BootFile)); + NetBootFileXferSize = 0; + + DEBUGN("TFTP: Filename: %s Address: 0x%08X\n", BootFile, (unsigned int)load_addr); + + if (NetLoop (TFTP) <= 0) { + printf("ERROR: tftp transfer failed\n"); + return -1; + } + + if (NetBootFileXferSize == 0) { + printf("ERROR: Can't determine file size\n"); + return -1; + } + + printf("File transfer succeeded - file size %lu bytes\n", NetBootFileXferSize); + return 0; +} diff -uprN u-boot-2009.03/board/embest/sbc2440ii/u-boot.lds u-boot-2009.03-PATCHED/board/embest/sbc2440ii/u-boot.lds --- u-boot-2009.03/board/embest/sbc2440ii/u-boot.lds 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/u-boot.lds 2009-03-22 09:49:23.765625000 +0000 @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm920t/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) } + _end = .; +} diff -uprN u-boot-2009.03/cpu/arm920t/s3c24x0/i2c.c u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/i2c.c --- u-boot-2009.03/cpu/arm920t/s3c24x0/i2c.c 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/i2c.c 2009-03-22 09:50:20.312500000 +0000 @@ -34,6 +34,8 @@ #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif #include <i2c.h>
diff -uprN u-boot-2009.03/cpu/arm920t/s3c24x0/interrupts.c u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/interrupts.c --- u-boot-2009.03/cpu/arm920t/s3c24x0/interrupts.c 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/interrupts.c 2009-03-22 09:51:19.890625000 +0000 @@ -30,13 +30,15 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) +#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_S3C2440) || defined (CONFIG_TRAB)
#include <arm920t.h> #if defined(CONFIG_S3C2400) #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
int timer_load_val = 0; @@ -178,6 +180,7 @@ ulong get_tbclk (void) tbclk = timer_load_val * 100; #elif defined(CONFIG_SBC2410X) || \ defined(CONFIG_SMDK2410) || \ + defined(CONFIG_SBC2440II) || \ defined(CONFIG_VCMA9) tbclk = CONFIG_SYS_HZ; #else diff -uprN u-boot-2009.03/cpu/arm920t/s3c24x0/nand.c u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/nand.c --- u-boot-2009.03/cpu/arm920t/s3c24x0/nand.c 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/nand.c 2009-03-25 21:57:32.046875000 +0000 @@ -21,48 +21,114 @@ #include <common.h>
#if 0 -#define DEBUGN printf + #define DEBUGCMD printf #else -#define DEBUGN(x, args ...) {} + #define DEBUGCMD(x, args ...) {} +#endif + +#if 0 + #define DEBUGECC printf +#else + #define DEBUGECC(x, args ...) {} +#endif + +#if 0 + #define DEEPDEBUGECC printf +#else + #define DEEPDEBUGECC(x, args ...) {} #endif
#if defined(CONFIG_CMD_NAND) #if !defined(CONFIG_NAND_LEGACY)
#include <nand.h> -#include <s3c2410.h> +#ifndef CONFIG_S3C2440 + #include <s3c2410.h> +#else + #include <s3c2440.h> +#endif #include <asm/io.h>
#define __REGb(x) (*(volatile unsigned char *)(x)) #define __REGi(x) (*(volatile unsigned int *)(x)) +#define __REGl(x) (*(volatile unsigned long *)(x))
-#define NF_BASE 0x4e000000 -#define NFCONF __REGi(NF_BASE + 0x0) -#define NFCMD __REGb(NF_BASE + 0x4) -#define NFADDR __REGb(NF_BASE + 0x8) -#define NFDATA __REGb(NF_BASE + 0xc) -#define NFSTAT __REGb(NF_BASE + 0x10) -#define NFECC0 __REGb(NF_BASE + 0x14) -#define NFECC1 __REGb(NF_BASE + 0x15) -#define NFECC2 __REGb(NF_BASE + 0x16) - -#define S3C2410_NFCONF_EN (1<<15) -#define S3C2410_NFCONF_512BYTE (1<<14) -#define S3C2410_NFCONF_4STEP (1<<13) -#define S3C2410_NFCONF_INITECC (1<<12) -#define S3C2410_NFCONF_nFCE (1<<11) -#define S3C2410_NFCONF_TACLS(x) ((x)<<8) -#define S3C2410_NFCONF_TWRPH0(x) ((x)<<4) -#define S3C2410_NFCONF_TWRPH1(x) ((x)<<0) +#define NF_BASE 0x4e000000 +#define NFCONF __REGi(NF_BASE + 0x0) +#ifdef CONFIG_S3C2440 + #define NFCONT __REGb(NF_BASE + 0x4) + #define NFCMD __REGb(NF_BASE + 0x8) + #define NFADDR __REGb(NF_BASE + 0xc) + #define NFDATA __REGb(NF_BASE + 0x10) + #define NFSTAT __REGb(NF_BASE + 0x20) + #define NFMECC0 __REGl(NF_BASE + 0x2c) + + #define S3C2440_NFCONT_EN (1<<0) + #define S3C2440_NFCONT_nFCE (1<<1) + #define S3C2440_NFCONT_INITECC (1<<4) + #define S3C2440_NFCONT_MAINECCLOCK (1<<5) + #define S3C2440_NFCONT_SPAREECCLOCK (1<<6) + #define S3C2440_NFCONT_RNBMODE (1<<8) + #define S3C2440_NFCONT_RNBINT (1<<9) + #define S3C2440_NFCONT_ILLEGALINT (1<<10) + #define S3C2440_NFCONT_SOFTLOCK (1<<12) + #define S3C2440_NFCONT_LOCKTIGHT (1<<13) + + #define S3C2440_NFCONF_TACLS(x) ((x)<<12) + #define S3C2440_NFCONF_TWRPH0(x) ((x)<<8) + #define S3C2440_NFCONF_TWRPH1(x) ((x)<<4) +#else + #define NFCMD __REGb(NF_BASE + 0x4) + #define NFADDR __REGb(NF_BASE + 0x8) + #define NFDATA __REGb(NF_BASE + 0xc) + #define NFSTAT __REGb(NF_BASE + 0x10) + #define NFECC0 __REGb(NF_BASE + 0x14) + #define NFECC1 __REGb(NF_BASE + 0x15) + #define NFECC2 __REGb(NF_BASE + 0x16) + + #define S3C2410_NFCONF_EN (1<<15) + #define S3C2410_NFCONF_512BYTE (1<<14) + #define S3C2410_NFCONF_4STEP (1<<13) + #define S3C2410_NFCONF_INITECC (1<<12) + #define S3C2410_NFCONF_nFCE (1<<11) + #define S3C2410_NFCONF_TACLS(x) ((x)<<8) + #define S3C2410_NFCONF_TWRPH0(x) ((x)<<4) + #define S3C2410_NFCONF_TWRPH1(x) ((x)<<0) +#endif
#define S3C2410_ADDR_NALE 4 #define S3C2410_ADDR_NCLE 8
+#ifdef CONFIG_S3C2410_NAND_HWECC +/* new oob placement block for use with hardware ecc generation + */ +static struct nand_ecclayout nand_hw_eccoob = { + .eccbytes = 3, + .eccpos = {0, 1, 2}, + .oobfree = {{8, 8}} +}; +#endif + +static void s3c2410_nand_select_chip(struct mtd_info *mtd, int chip) +{ + if (chip == -1) + { + DEBUGCMD("Negating nFCE\n"); + NFCONT |= S3C2440_NFCONT_nFCE; + } + else + { + DEBUGCMD("Asserting nFCE\n"); + NFCONT &= ~S3C2440_NFCONT_nFCE; + } +} + +#ifndef CONFIG_S3C2440 static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct nand_chip *chip = mtd->priv;
- DEBUGN("hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl); + DEBUGCMD("hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl);
if (ctrl & NAND_CTRL_CHANGE) { ulong IO_ADDR_W = NF_BASE; @@ -83,28 +149,63 @@ static void s3c2410_hwcontrol(struct mtd if (cmd != NAND_CMD_NONE) writeb(cmd, chip->IO_ADDR_W); } +#else +static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) +{ + DEBUGCMD("hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl); + + if (cmd == NAND_CMD_NONE) + { + return; + } + + if (ctrl & NAND_CLE) + { + DEBUGCMD("NFCMD = 0x%08X\n", cmd); + NFCMD = cmd; + } + + if (ctrl & NAND_ALE) + { + DEBUGCMD("NFADDR = 0x%08X\n", cmd); + NFADDR = cmd; + } +} +#endif
static int s3c2410_dev_ready(struct mtd_info *mtd) { - DEBUGN("dev_ready\n"); + DEBUGCMD("dev_ready\n"); return (NFSTAT & 0x01); }
#ifdef CONFIG_S3C2410_NAND_HWECC void s3c2410_nand_enable_hwecc(struct mtd_info *mtd, int mode) { - DEBUGN("s3c2410_nand_enable_hwecc(%p, %d)\n", mtd, mode); - NFCONF |= S3C2410_NFCONF_INITECC; + DEBUGECC("s3c2410_nand_enable_hwecc(%p, %d)\n", mtd, mode); +#ifndef CONFIG_S3C2440 + NFCONF |= S3C2410_NFCONF_INITECC; +#else + NFCONT |= S3C2440_NFCONT_INITECC; +#endif }
static int s3c2410_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code) { +#ifndef CONFIG_S3C2440 ecc_code[0] = NFECC0; ecc_code[1] = NFECC1; ecc_code[2] = NFECC2; - DEBUGN("s3c2410_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02x\n", - mtd , ecc_code[0], ecc_code[1], ecc_code[2]); +#else + unsigned long ecc = NFMECC0; + + ecc_code[0] = ecc; + ecc_code[1] = ecc >> 8; + ecc_code[2] = ecc >> 16; +#endif + DEBUGECC("s3c2410_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02x\n", + mtd , ecc_code[0], ecc_code[1], ecc_code[2]);
return 0; } @@ -112,13 +213,55 @@ static int s3c2410_nand_calculate_ecc(st static int s3c2410_nand_correct_data(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *calc_ecc) { - if (read_ecc[0] == calc_ecc[0] && - read_ecc[1] == calc_ecc[1] && - read_ecc[2] == calc_ecc[2]) - return 0; + unsigned int diff0, diff1, diff2; + unsigned int bit, byte; + + DEBUGECC("s3c2410_nand_correct_data:\n"); + + diff0 = read_ecc[0] ^ calc_ecc[0]; + diff1 = read_ecc[1] ^ calc_ecc[1]; + diff2 = read_ecc[2] ^ calc_ecc[2]; + + DEEPDEBUGECC("rd %02x%02x%02x calc %02x%02x%02x diff %02x%02x%02x\n", + read_ecc[0], read_ecc[1], read_ecc[2], + calc_ecc[0], calc_ecc[1], calc_ecc[2], + diff0, diff1, diff2); + + if (diff0 == 0 && diff1 == 0 && diff2 == 0) + return 0; /* ECC is ok */ + + /* Can we correct this ECC (ie, one row and column change). + * Note, this is similar to the 256 error code on smartmedia */ + + if (((diff0 ^ (diff0 >> 1)) & 0x55) == 0x55 && + ((diff1 ^ (diff1 >> 1)) & 0x55) == 0x55 && + ((diff2 ^ (diff2 >> 1)) & 0x55) == 0x55) { + /* calculate the bit position of the error */ + + bit = ((diff2 >> 3) & 1) | + ((diff2 >> 4) & 2) | + ((diff2 >> 5) & 4); + + /* calculate the byte position of the error */ + + byte = ((diff2 << 7) & 0x100) | + ((diff1 << 0) & 0x80) | + ((diff1 << 1) & 0x40) | + ((diff1 << 2) & 0x20) | + ((diff1 << 3) & 0x10) | + ((diff0 >> 4) & 0x08) | + ((diff0 >> 3) & 0x04) | + ((diff0 >> 2) & 0x02) | + ((diff0 >> 1) & 0x01);
- printf("s3c2410_nand_correct_data: not implemented\n"); - return -1; + DEBUGECC("correcting error bit %d, byte %d\n", bit, byte); + + dat[byte] ^= (1 << bit); + return 1; + } + + DEBUGECC("Failed to correct ECC error\n"); + return -1; } #endif
@@ -128,11 +271,12 @@ int board_nand_init(struct nand_chip *na u_int8_t tacls, twrph0, twrph1; S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER();
- DEBUGN("board_nand_init()\n"); + DEBUGCMD("board_nand_init()\n");
clk_power->CLKCON |= (1 << 4);
/* initialize hardware */ +#ifndef CONFIG_S3C2440 twrph0 = 3; twrph1 = 0; tacls = 0;
cfg = S3C2410_NFCONF_EN; @@ -144,20 +288,49 @@ int board_nand_init(struct nand_chip *na
/* initialize nand_chip data structure */ nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)0x4e00000c; +#else + twrph0 = 3; twrph1 = 1; tacls = 0; + + cfg = S3C2440_NFCONF_TACLS(tacls); + cfg |= S3C2440_NFCONF_TWRPH0(twrph0); + cfg |= S3C2440_NFCONF_TWRPH1(twrph1); + NFCONF = cfg; + + cfg = S3C2440_NFCONT_EN; + cfg |= S3C2440_NFCONT_nFCE; + NFCONT = cfg; + + /* initialize nand_chip data structure */ + nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)0x4e000010; +#endif
/* read_buf and write_buf are default */ /* read_byte and write_byte are default */
+ nand->select_chip = s3c2410_nand_select_chip; + nand->chip_delay = 50; + /* hwcontrol always must be implemented */ nand->cmd_ctrl = s3c2410_hwcontrol;
nand->dev_ready = s3c2410_dev_ready;
#ifdef CONFIG_S3C2410_NAND_HWECC - nand->ecc.hwctl = s3c2410_nand_enable_hwecc; - nand->ecc.calculate = s3c2410_nand_calculate_ecc; - nand->ecc.correct = s3c2410_nand_correct_data; - nand->ecc.mode = NAND_ECC_HW3_512; + nand->ecc.correct = s3c2410_nand_correct_data; + nand->ecc.hwctl = s3c2410_nand_enable_hwecc; + nand->ecc.calculate = s3c2410_nand_calculate_ecc; + nand->ecc.mode = NAND_ECC_HW; + /* change the behaviour depending on whether we are using + * the large or small page nand device */ + if (nand->page_shift > 10) { + nand->ecc.size = 256; + nand->ecc.bytes = 3; + } else { + nand->ecc.size = 512; + nand->ecc.bytes = 3; + nand->ecc.layout = &nand_hw_eccoob; + } + DEBUGECC("ecc: size: %d bytes: %d\n", nand->ecc.size, nand->ecc.bytes); #else nand->ecc.mode = NAND_ECC_SOFT; #endif @@ -168,12 +341,12 @@ int board_nand_init(struct nand_chip *na nand->options = 0; #endif
- DEBUGN("end of nand_init\n"); + DEBUGCMD("end of nand_init\n");
return 0; }
#else - #error "U-Boot legacy NAND support not available for S3C2410" + #error "U-Boot legacy NAND support not available for S3C2410" #endif #endif diff -uprN u-boot-2009.03/cpu/arm920t/s3c24x0/serial.c u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/serial.c --- u-boot-2009.03/cpu/arm920t/s3c24x0/serial.c 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/serial.c 2009-03-22 18:55:46.531250000 +0000 @@ -19,12 +19,14 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) +#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) || defined(CONFIG_S3C2440)
#if defined(CONFIG_S3C2400) || defined(CONFIG_TRAB) #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
DECLARE_GLOBAL_DATA_PTR; diff -uprN u-boot-2009.03/cpu/arm920t/s3c24x0/speed.c u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/speed.c --- u-boot-2009.03/cpu/arm920t/s3c24x0/speed.c 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/speed.c 2009-03-25 21:55:08.562500000 +0000 @@ -30,12 +30,14 @@ */
#define MPLL 0 @@ -67,7 +69,18 @@ static ulong get_PLLCLK(int pllreg) p = ((r & 0x003F0) >> 4) + 2; s = r & 0x3;
+#ifdef CONFIG_S3C2440 + if (pllreg == MPLL) + { + return((2 * CONFIG_SYS_CLK_FREQ * m) / (p << s)); + } + else + { + return((CONFIG_SYS_CLK_FREQ * m) / (p << s)); + } +#else return((CONFIG_SYS_CLK_FREQ * m) / (p << s)); +#endif }
/* return FCLK frequency */ @@ -81,7 +94,21 @@ ulong get_HCLK(void) { S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER();
+#ifdef CONFIG_S3C2440 + switch(clk_power->CLKDIVN & 0x6) { + default: + case 0: + return(get_FCLK()); + case 2: + return(get_FCLK()/2); + case 4: + return((clk_power->CAMDIVN & (1<<9)) ? get_FCLK()/8 : get_FCLK()/4); + case 6: + return((clk_power->CAMDIVN & (1<<8)) ? get_FCLK()/6 : get_FCLK()/3); + } +#else return((clk_power->CLKDIVN & 0x2) ? get_FCLK()/2 : get_FCLK()); +#endif }
/* return PCLK frequency */ @@ -95,7 +122,13 @@ ulong get_PCLK(void) /* return UCLK frequency */ ulong get_UCLK(void) { +#ifdef CONFIG_S3C2440 + S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + + return((clk_power->CLKDIVN & (1<<3)) ? get_PLLCLK(UPLL) /2 : get_PLLCLK(UPLL)); +#else return(get_PLLCLK(UPLL)); +#endif }
-#endif /* defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) */ +#endif /* defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_S3C2440) || defined (CONFIG_TRAB) */ diff -uprN u-boot-2009.03/cpu/arm920t/s3c24x0/usb.c u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/usb.c --- u-boot-2009.03/cpu/arm920t/s3c24x0/usb.c 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/cpu/arm920t/s3c24x0/usb.c 2009-03-22 18:59:36.984375000 +0000 @@ -24,12 +24,14 @@ #include <common.h>
#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) -# if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) +# if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || defined(CONFIG_S3C2440)
#if defined(CONFIG_S3C2400) # include <s3c2400.h> #elif defined(CONFIG_S3C2410) # include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
int usb_cpu_init (void) diff -uprN u-boot-2009.03/cpu/arm920t/start.S u-boot-2009.03-PATCHED/cpu/arm920t/start.S --- u-boot-2009.03/cpu/arm920t/start.S 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/cpu/arm920t/start.S 2009-03-22 19:04:16.140625000 +0000 @@ -132,7 +132,7 @@ copyex: bne copyex #endif
-#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) +#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || defined(CONFIG_S3C2440) /* turn off the watchdog */
# if defined(CONFIG_S3C2400) @@ -146,6 +146,14 @@ copyex: # define CLKDIVN 0x4C000014 /* clock divisor register */ # endif
+# if defined(CONFIG_S3C2440) +# define INTSMASK 0xffff +# define CLKDIVVAL 0x5 +#else +# define INTSMASK 0x3ff +# define CLKDIVVAL 0x3 +# endif + ldr r0, =pWTCON mov r1, #0x0 str r1, [r0] @@ -156,8 +164,8 @@ copyex: mov r1, #0xffffffff ldr r0, =INTMSK str r1, [r0] -# if defined(CONFIG_S3C2410) - ldr r1, =0x3ff +# if defined(CONFIG_S3C2410) || defined(CONFIG_S3C2440) + ldr r1, =INTSMASK ldr r0, =INTSUBMSK str r1, [r0] # endif @@ -165,9 +173,16 @@ copyex: /* FCLK:HCLK:PCLK = 1:2:4 */ /* default FCLK is 120 MHz ! */ ldr r0, =CLKDIVN - mov r1, #3 + mov r1, #CLKDIVVAL str r1, [r0] -#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 */ + +#ifdef CONFIG_S3C2440 + /* Set asynchronous bus mode */ + mrc p15, 0, r1, c1, c0, 0 /* read ctrl register */ + orr r1, r1, #0xc0000000 /* Asynchronous */ + mcr p15, 0, r1, c1, c0, 0 /* write ctrl register */ +#endif /* CONFIG_S3C2440 */ +#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 || CONFIG_S3C2440 */
/* * we do sys-critical inits only at reboot, diff -uprN u-boot-2009.03/drivers/rtc/s3c24x0_rtc.c u-boot-2009.03-PATCHED/drivers/rtc/s3c24x0_rtc.c --- u-boot-2009.03/drivers/rtc/s3c24x0_rtc.c 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/drivers/rtc/s3c24x0_rtc.c 2009-03-22 19:05:14.328125000 +0000 @@ -34,6 +34,8 @@ #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
#include <rtc.h> diff -uprN u-boot-2009.03/include/common.h u-boot-2009.03-PATCHED/include/common.h --- u-boot-2009.03/include/common.h 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/include/common.h 2009-03-22 21:25:48.375000000 +0000 @@ -498,7 +498,8 @@ ulong get_OPB_freq (void); ulong get_PCI_freq (void); #endif #if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || \ - defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400) + defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400) || \ + defined(CONFIG_S3C2440) void s3c2410_irq(void); #define ARM920_IRQ_CALLBACK s3c2410_irq ulong get_FCLK (void); diff -uprN u-boot-2009.03/include/configs/sbc2440ii.h u-boot-2009.03-PATCHED/include/configs/sbc2440ii.h --- u-boot-2009.03/include/configs/sbc2440ii.h 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/include/configs/sbc2440ii.h 2009-03-25 22:09:51.906250000 +0000 @@ -0,0 +1,247 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * Gary Jennejohn gj@denx.de + * David Mueller d.mueller@elsoft.ch + * + * Modified for the friendly-arm SBC-2410X by + * (C) Copyright 2005 + * JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * Configuation settings for the friendly-arm SBC-2410X board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + + +#define CONFIG_IDENT_STRING " for Embest SBC2440-II" + +/* + * If we are developing, we might want to start armboot from ram + * so we MUST NOT initialize critical regs like mem-timing ... + */ +#undef CONFIG_SKIP_LOWLEVEL_INIT /* undef for developing */ + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ +#define CONFIG_S3C2440 1 /* in a SAMSUNG S3C2440 SoC */ +#define CONFIG_SBC2440II 1 /* on an Embest SBC-2440-II Board */ + +/* input clock of PLL */ +#define CONFIG_SYS_CLK_FREQ 12000000/* the SBC2440-II has 12MHz input clock */ + + +#define USE_920T_MMU 1 +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ + +/* + * Hardware drivers + */ +#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ +#define CS8900_BASE 0x19000300 +#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ + +/* + * select serial console configuration + */ +#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SBC2440-II */ + +/************************************************************ + * RTC + ************************************************************/ +#define CONFIG_RTC_S3C24X0 1 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BAUDRATE 115200 + + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_JFFS2_NAND +#define CONFIG_CMD_JFFS2 +#define CONFIG_JFFS2_CMDLINE +#define MTDIDS_DEFAULT "nand0=sbc2440-II-nand" +#define MTDPARTS_DEFAULT "mtdparts=sbc2440-II-nand:2m(kernel),62m(rootfs)" +#define CONFIG_EXTRA_ENV_SETTINGS "autostart=yes" + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "noinitrd root=/dev/mtdblock1 rootfstype=jffs2 init=/linuxrc console=ttySAC0" +#define CONFIG_ETHADDR 08:00:3e:26:0a:5b +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_IPADDR 192.168.0.69 +#define CONFIG_GATEWAYIP 192.168.0.1 +#define CONFIG_SERVERIP 192.168.0.70 +#define CONFIG_ROOTPATH FRNSIDE-1/netshared +#define CONFIG_LOADADDR 30008000 +/*#define CONFIG_BOOTFILE "elinos-lart" */ +#define CONFIG_BOOTCOMMAND "nboot 30008000 0 0" +/*#define CONFIG_NFSBOOTCOMMAND NFS_BOOTARGS*/ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ +/* what's this ? it's not used anywhere */ +#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "[ SBC2440-II ]# " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0x30000000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x33F00000 /* 63 MB in DRAM */ + +#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CONFIG_SYS_LOAD_ADDR 0x33000000 /* default load address */ + +/* the PWM TImer 4 uses a counter of 15625 for 10 ms, so we need */ +/* it to wrap 100 times (total 1562500) to get 1 sec. */ +#define CONFIG_SYS_HZ 1562500 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x30000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ + +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +/* #define CONFIG_AMD_LV400 1 /* uncomment this if you have a LV400 flash */ */ +/* #define CONFIG_AMD_LV800 1 /* uncomment this if you have a LV800 flash */ */ + +#define CONFIG_AMD_LV160B 1 /* uncomment this if you have a LV160DB flash */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ + +#ifdef CONFIG_AMD_LV160B + #define PHYS_FLASH_SIZE 0x00200000 /* 2MB */ + #define CONFIG_SYS_MAX_FLASH_SECT (35) /* max number of sectors on one chip */ + #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x1F0000) /* addr of environment */ +#endif + +#ifdef CONFIG_AMD_LV800 + #define PHYS_FLASH_SIZE 0x00100000 /* 1MB */ + #define CONFIG_SYS_MAX_FLASH_SECT (19) /* max number of sectors on one chip */ + #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x0F0000) /* addr of environment */ +#endif + +#ifdef CONFIG_AMD_LV400 + #define PHYS_FLASH_SIZE 0x00080000 /* 512KB */ + #define CONFIG_SYS_MAX_FLASH_SECT (11) /* max number of sectors on one chip */ + #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x070000) /* addr of environment */ +#endif + +/* timeout values are in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (5*CONFIG_SYS_HZ) /* Timeout for Flash Erase */ +#define CONFIG_SYS_FLASH_WRITE_TOUT (5*CONFIG_SYS_HZ) /* Timeout for Flash Write */ + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SIZE 0x10000 /* Total Size of Environment Sector */ + +/*----------------------------------------------------------------------- + * NAND flash settings + */ +#if defined(CONFIG_CMD_NAND) + #define CONFIG_SYS_NAND_BASE 0x4e00000c + #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ + #define SECTORSIZE 512 +/* #define CONFIG_S3C2410_NAND_HWECC*/ +#endif /* CONFIG_CMD_NAND */ + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_TAG + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_CMDLINE_EDITING + +#ifdef CONFIG_CMDLINE_EDITING +#undef CONFIG_AUTO_COMPLETE +#else +#define CONFIG_AUTO_COMPLETE +#endif + +#endif /* __CONFIG_H */ diff -uprN u-boot-2009.03/include/s3c2440.h u-boot-2009.03-PATCHED/include/s3c2440.h --- u-boot-2009.03/include/s3c2440.h 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/include/s3c2440.h 2009-03-25 21:05:44.750000000 +0000 @@ -0,0 +1,231 @@ +/* + * (C) Copyright 2003 + * David Müller ELSOFT AG Switzerland. d.mueller@elsoft.ch + * + * See file CREDITS for list of people who contributed to this + * project. + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************ + * NAME : s3c2440.h + * Version : 24.10.2008 + * + * Based on S3C2440X User's manual Rev 1.3 + ************************************************/ + +#ifndef __S3C2440_H__ +#define __S3C2440_H__ + +#define S3C24X0_UART_CHANNELS 3 +#define S3C24X0_SPI_CHANNELS 2 + +/* S3C2410 only supports 512 Byte HW ECC */ +#define S3C2410_ECCSIZE 512 +#define S3C2410_ECCBYTES 3 + +typedef enum { + S3C24X0_UART0, + S3C24X0_UART1, + S3C24X0_UART2 +} S3C24X0_UARTS_NR; + +/* S3C2440 device base addresses */ +#define S3C24X0_MEMCTL_BASE 0x48000000 +#define S3C24X0_USB_HOST_BASE 0x49000000 +#define S3C24X0_INTERRUPT_BASE 0x4A000000 +#define S3C24X0_DMA_BASE 0x4B000000 +#define S3C24X0_CLOCK_POWER_BASE 0x4C000000 +#define S3C24X0_LCD_BASE 0x4D000000 +#define S3C2440_NAND_BASE 0x4E000000 +#define S3C24X0_UART_BASE 0x50000000 +#define S3C24X0_TIMER_BASE 0x51000000 +#define S3C24X0_USB_DEVICE_BASE 0x52000140 +#define S3C24X0_WATCHDOG_BASE 0x53000000 +#define S3C24X0_I2C_BASE 0x54000000 +#define S3C24X0_I2S_BASE 0x55000000 +#define S3C24X0_GPIO_BASE 0x56000000 +#define S3C24X0_RTC_BASE 0x57000000 +#define S3C2410_ADC_BASE 0x58000000 +#define S3C24X0_SPI_BASE 0x59000000 +#define S3C2410_SDI_BASE 0x5A000000 + + +/* include common stuff */ +#include <s3c24x0.h> + + +static inline S3C24X0_MEMCTL * S3C24X0_GetBase_MEMCTL(void) +{ + return (S3C24X0_MEMCTL * const)S3C24X0_MEMCTL_BASE; +} +static inline S3C24X0_USB_HOST * S3C24X0_GetBase_USB_HOST(void) +{ + return (S3C24X0_USB_HOST * const)S3C24X0_USB_HOST_BASE; +} +static inline S3C24X0_INTERRUPT * S3C24X0_GetBase_INTERRUPT(void) +{ + return (S3C24X0_INTERRUPT * const)S3C24X0_INTERRUPT_BASE; +} +static inline S3C24X0_DMAS * S3C24X0_GetBase_DMAS(void) +{ + return (S3C24X0_DMAS * const)S3C24X0_DMA_BASE; +} +static inline S3C24X0_CLOCK_POWER * S3C24X0_GetBase_CLOCK_POWER(void) +{ + return (S3C24X0_CLOCK_POWER * const)S3C24X0_CLOCK_POWER_BASE; +} +static inline S3C24X0_LCD * S3C24X0_GetBase_LCD(void) +{ + return (S3C24X0_LCD * const)S3C24X0_LCD_BASE; +} +static inline S3C2440_NAND * S3C2440_GetBase_NAND(void) +{ + return (S3C2440_NAND * const)S3C2440_NAND_BASE; +} +static inline S3C24X0_UART * S3C24X0_GetBase_UART(S3C24X0_UARTS_NR nr) +{ + return (S3C24X0_UART * const)(S3C24X0_UART_BASE + (nr * 0x4000)); +} +static inline S3C24X0_TIMERS * S3C24X0_GetBase_TIMERS(void) +{ + return (S3C24X0_TIMERS * const)S3C24X0_TIMER_BASE; +} +static inline S3C24X0_USB_DEVICE * S3C24X0_GetBase_USB_DEVICE(void) +{ + return (S3C24X0_USB_DEVICE * const)S3C24X0_USB_DEVICE_BASE; +} +static inline S3C24X0_WATCHDOG * S3C24X0_GetBase_WATCHDOG(void) +{ + return (S3C24X0_WATCHDOG * const)S3C24X0_WATCHDOG_BASE; +} +static inline S3C24X0_I2C * S3C24X0_GetBase_I2C(void) +{ + return (S3C24X0_I2C * const)S3C24X0_I2C_BASE; +} +static inline S3C24X0_I2S * S3C24X0_GetBase_I2S(void) +{ + return (S3C24X0_I2S * const)S3C24X0_I2S_BASE; +} +static inline S3C24X0_GPIO * S3C24X0_GetBase_GPIO(void) +{ + return (S3C24X0_GPIO * const)S3C24X0_GPIO_BASE; +} +static inline S3C24X0_RTC * S3C24X0_GetBase_RTC(void) +{ + return (S3C24X0_RTC * const)S3C24X0_RTC_BASE; +} +static inline S3C2410_ADC * S3C2410_GetBase_ADC(void) +{ + return (S3C2410_ADC * const)S3C2410_ADC_BASE; +} +static inline S3C24X0_SPI * S3C24X0_GetBase_SPI(void) +{ + return (S3C24X0_SPI * const)S3C24X0_SPI_BASE; +} +static inline S3C2410_SDI * S3C2410_GetBase_SDI(void) +{ + return (S3C2410_SDI * const)S3C2410_SDI_BASE; +} + + +/* ISR */ +#define pISR_RESET (*(unsigned *)(_ISR_STARTADDRESS+0x0)) +#define pISR_UNDEF (*(unsigned *)(_ISR_STARTADDRESS+0x4)) +#define pISR_SWI (*(unsigned *)(_ISR_STARTADDRESS+0x8)) +#define pISR_PABORT (*(unsigned *)(_ISR_STARTADDRESS+0xC)) +#define pISR_DABORT (*(unsigned *)(_ISR_STARTADDRESS+0x10)) +#define pISR_RESERVED (*(unsigned *)(_ISR_STARTADDRESS+0x14)) +#define pISR_IRQ (*(unsigned *)(_ISR_STARTADDRESS+0x18)) +#define pISR_FIQ (*(unsigned *)(_ISR_STARTADDRESS+0x1C)) + +#define pISR_EINT0 (*(unsigned *)(_ISR_STARTADDRESS+0x20)) +#define pISR_EINT1 (*(unsigned *)(_ISR_STARTADDRESS+0x24)) +#define pISR_EINT2 (*(unsigned *)(_ISR_STARTADDRESS+0x28)) +#define pISR_EINT3 (*(unsigned *)(_ISR_STARTADDRESS+0x2C)) +#define pISR_EINT4_7 (*(unsigned *)(_ISR_STARTADDRESS+0x30)) +#define pISR_EINT8_23 (*(unsigned *)(_ISR_STARTADDRESS+0x34)) +#define pISR_BAT_FLT (*(unsigned *)(_ISR_STARTADDRESS+0x3C)) +#define pISR_TICK (*(unsigned *)(_ISR_STARTADDRESS+0x40)) +#define pISR_WDT (*(unsigned *)(_ISR_STARTADDRESS+0x44)) +#define pISR_TIMER0 (*(unsigned *)(_ISR_STARTADDRESS+0x48)) +#define pISR_TIMER1 (*(unsigned *)(_ISR_STARTADDRESS+0x4C)) +#define pISR_TIMER2 (*(unsigned *)(_ISR_STARTADDRESS+0x50)) +#define pISR_TIMER3 (*(unsigned *)(_ISR_STARTADDRESS+0x54)) +#define pISR_TIMER4 (*(unsigned *)(_ISR_STARTADDRESS+0x58)) +#define pISR_UART2 (*(unsigned *)(_ISR_STARTADDRESS+0x5C)) +#define pISR_NOTUSED (*(unsigned *)(_ISR_STARTADDRESS+0x60)) +#define pISR_DMA0 (*(unsigned *)(_ISR_STARTADDRESS+0x64)) +#define pISR_DMA1 (*(unsigned *)(_ISR_STARTADDRESS+0x68)) +#define pISR_DMA2 (*(unsigned *)(_ISR_STARTADDRESS+0x6C)) +#define pISR_DMA3 (*(unsigned *)(_ISR_STARTADDRESS+0x70)) +#define pISR_SDI (*(unsigned *)(_ISR_STARTADDRESS+0x74)) +#define pISR_SPI0 (*(unsigned *)(_ISR_STARTADDRESS+0x78)) +#define pISR_UART1 (*(unsigned *)(_ISR_STARTADDRESS+0x7C)) +#define pISR_USBD (*(unsigned *)(_ISR_STARTADDRESS+0x84)) +#define pISR_USBH (*(unsigned *)(_ISR_STARTADDRESS+0x88)) +#define pISR_IIC (*(unsigned *)(_ISR_STARTADDRESS+0x8C)) +#define pISR_UART0 (*(unsigned *)(_ISR_STARTADDRESS+0x90)) +#define pISR_SPI1 (*(unsigned *)(_ISR_STARTADDRESS+0x94)) +#define pISR_RTC (*(unsigned *)(_ISR_STARTADDRESS+0x98)) +#define pISR_ADC (*(unsigned *)(_ISR_STARTADDRESS+0xA0)) + + +/* PENDING BIT */ +#define BIT_EINT0 (0x1) +#define BIT_EINT1 (0x1<<1) +#define BIT_EINT2 (0x1<<2) +#define BIT_EINT3 (0x1<<3) +#define BIT_EINT4_7 (0x1<<4) +#define BIT_EINT8_23 (0x1<<5) +#define BIT_BAT_FLT (0x1<<7) +#define BIT_TICK (0x1<<8) +#define BIT_WDT (0x1<<9) +#define BIT_TIMER0 (0x1<<10) +#define BIT_TIMER1 (0x1<<11) +#define BIT_TIMER2 (0x1<<12) +#define BIT_TIMER3 (0x1<<13) +#define BIT_TIMER4 (0x1<<14) +#define BIT_UART2 (0x1<<15) +#define BIT_LCD (0x1<<16) +#define BIT_DMA0 (0x1<<17) +#define BIT_DMA1 (0x1<<18) +#define BIT_DMA2 (0x1<<19) +#define BIT_DMA3 (0x1<<20) +#define BIT_SDI (0x1<<21) +#define BIT_SPI0 (0x1<<22) +#define BIT_UART1 (0x1<<23) +#define BIT_USBD (0x1<<25) +#define BIT_USBH (0x1<<26) +#define BIT_IIC (0x1<<27) +#define BIT_UART0 (0x1<<28) +#define BIT_SPI1 (0x1<<29) +#define BIT_RTC (0x1<<30) +#define BIT_ADC (0x1<<31) +#define BIT_ALLMSK (0xFFFFFFFF) + +#define ClearPending(bit) {\ + rSRCPND = bit;\ + rINTPND = bit;\ + rINTPND;\ + } +/* Wait until rINTPND is changed for the case that the ISR is very short. */ +#endif /*__S3C2440_H__*/ diff -uprN u-boot-2009.03/include/s3c24x0.h u-boot-2009.03-PATCHED/include/s3c24x0.h --- u-boot-2009.03/include/s3c24x0.h 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/include/s3c24x0.h 2009-03-22 19:11:51.437500000 +0000 @@ -126,6 +126,9 @@ typedef struct { S3C24X0_REG32 CLKCON; S3C24X0_REG32 CLKSLOW; S3C24X0_REG32 CLKDIVN; +#ifdef CONFIG_S3C2440 + S3C24X0_REG32 CAMDIVN; +#endif } /*__attribute__((__packed__))*/ S3C24X0_CLOCK_POWER;
@@ -153,8 +156,8 @@ typedef struct { #endif } /*__attribute__((__packed__))*/ S3C24X0_LCD;
- -/* NAND FLASH (see S3C2410 manual chapter 6) */ +#ifdef CONFIG_S3C2410 +/* NAND FLASH (see S3C2410 manual chapter 6 ) */ typedef struct { S3C24X0_REG32 NFCONF; S3C24X0_REG32 NFCMD; @@ -163,6 +166,27 @@ typedef struct { S3C24X0_REG32 NFSTAT; S3C24X0_REG32 NFECC; } /*__attribute__((__packed__))*/ S3C2410_NAND; +#elif defined CONFIG_S3C2440 +/* NAND FLASH (see S3C2440 manual chapter 6 ) */ +typedef struct { + S3C24X0_REG32 NFCONF; + S3C24X0_REG32 NFCONT; + S3C24X0_REG32 NFCMD; + S3C24X0_REG32 NFADDR; + S3C24X0_REG32 NFDATA; + S3C24X0_REG32 NFMECCD0; + S3C24X0_REG32 NFMECCD1; + S3C24X0_REG32 NFSECCD; + S3C24X0_REG32 NFSTAT; + S3C24X0_REG32 NFESTAT0; + S3C24X0_REG32 NFESTAT1; + S3C24X0_REG32 NFMECC0; + S3C24X0_REG32 NFMECC1; + S3C24X0_REG32 NFSECC; + S3C24X0_REG32 NFSBLOCK; + S3C24X0_REG32 NFEBLOCK; +} /*__attribute__((__packed__))*/ S3C2440_NAND; +#endif
/* UART (see manual chapter 11) */ @@ -451,6 +475,64 @@ typedef struct { S3C24X0_REG32 GSTATUS3; S3C24X0_REG32 GSTATUS4; #endif +#ifdef CONFIG_S3C2440 + S3C24X0_REG32 GPACON; + S3C24X0_REG32 GPADAT; + S3C24X0_REG32 res1[2]; + S3C24X0_REG32 GPBCON; + S3C24X0_REG32 GPBDAT; + S3C24X0_REG32 GPBUP; + S3C24X0_REG32 res2; + S3C24X0_REG32 GPCCON; + S3C24X0_REG32 GPCDAT; + S3C24X0_REG32 GPCUP; + S3C24X0_REG32 res3; + S3C24X0_REG32 GPDCON; + S3C24X0_REG32 GPDDAT; + S3C24X0_REG32 GPDUP; + S3C24X0_REG32 res4; + S3C24X0_REG32 GPECON; + S3C24X0_REG32 GPEDAT; + S3C24X0_REG32 GPEUP; + S3C24X0_REG32 res5; + S3C24X0_REG32 GPFCON; + S3C24X0_REG32 GPFDAT; + S3C24X0_REG32 GPFUP; + S3C24X0_REG32 res6; + S3C24X0_REG32 GPGCON; + S3C24X0_REG32 GPGDAT; + S3C24X0_REG32 GPGUP; + S3C24X0_REG32 res7; + S3C24X0_REG32 GPHCON; + S3C24X0_REG32 GPHDAT; + S3C24X0_REG32 GPHUP; + S3C24X0_REG32 res8; + + S3C24X0_REG32 MISCCR; + S3C24X0_REG32 DCLKCON; + S3C24X0_REG32 EXTINT0; + S3C24X0_REG32 EXTINT1; + S3C24X0_REG32 EXTINT2; + S3C24X0_REG32 EINTFLT0; + S3C24X0_REG32 EINTFLT1; + S3C24X0_REG32 EINTFLT2; + S3C24X0_REG32 EINTFLT3; + S3C24X0_REG32 EINTMASK; + S3C24X0_REG32 EINTPEND; + S3C24X0_REG32 GSTATUS0; + S3C24X0_REG32 GSTATUS1; + S3C24X0_REG32 GSTATUS2; + S3C24X0_REG32 GSTATUS3; + S3C24X0_REG32 GSTATUS4; + S3C24X0_REG32 res9; + + S3C24X0_REG32 DSC0; + S3C24X0_REG32 DSC1; + S3C24X0_REG32 MSLCON; + S3C24X0_REG32 GPJCON; + S3C24X0_REG32 GPJDAT; + S3C24X0_REG32 GPJUP; +#endif } /*__attribute__((__packed__))*/ S3C24X0_GPIO;
On 00:14 Thu 26 Mar , kevin.morfitt@fearnside-systems.co.uk wrote:
Adds support for the Embest SBC2440-II Board (see http://www.embedinfo.com/english/product/sbc2440-II.asp) with u-boot programmed in NOR flash.
Implementation is based on the existing u-boot support for s3C2410-based boards. Where I've copied and modified existing files I've left the style of the original code as it was, including any non-conformance with the u-boot coding style. Where I've added new code I've aimed to use the u-boot coding style. I've run MAKEALL with the LIST_ARM9 targets only as the changes don't affect any other architectures.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk
diff -uprN u-boot-2009.03/MAKEALL u-boot-2009.03-PATCHED/MAKEALL --- u-boot-2009.03/MAKEALL 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/MAKEALL 2009-03-25 21:48:14.171875000 +0000 @@ -512,6 +512,7 @@ LIST_ARM9=" \ omap5912osk \ omap730p2 \ sbc2410x \
- sbc2440ii \ scb9328 \ smdk2400 \ smdk2410 \
diff -uprN u-boot-2009.03/Makefile u-boot-2009.03-PATCHED/Makefile --- u-boot-2009.03/Makefile 2009-03-21 21:04:41.000000000 +0000 +++ u-boot-2009.03-PATCHED/Makefile 2009-03-22 09:42:11.078125000 +0000 @@ -2821,6 +2821,9 @@ omap730p2_cs3boot_config : unconfig sbc2410x_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm920t sbc2410x NULL s3c24x0
+sbc2440ii_config: unconfig
- @$(MKCONFIG) $(@:_config=) arm arm920t sbc2440ii embest s3c24x0
scb9328_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t scb9328 NULL imx
diff -uprN u-boot-2009.03/board/embest/sbc2440ii/Makefile u-boot-2009.03-PATCHED/board/embest/sbc2440ii/Makefile --- u-boot-2009.03/board/embest/sbc2440ii/Makefile 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/Makefile 2009-03-22 09:44:24.640625000 +0000 @@ -0,0 +1,51 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
+include $(TOPDIR)/config.mk
+LIB = $(obj)lib$(BOARD).a
+COBJS := sbc2440ii.o flash.o sbc2440ii_cmd.o +SOBJS := lowlevel_init.o
+SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS))
+$(LIB): $(obj).depend $(OBJS) $(SOBJS)
- $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
+# defines $(obj).depend target +include $(SRCTREE)/rules.mk
+sinclude $(obj).depend
+######################################################################### diff -uprN u-boot-2009.03/board/embest/sbc2440ii/config.mk u-boot-2009.03-PATCHED/board/embest/sbc2440ii/config.mk --- u-boot-2009.03/board/embest/sbc2440ii/config.mk 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/config.mk 2009-03-25 21:05:21.281250000 +0000 @@ -0,0 +1,25 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# SAMSUNG SMDK2410 board with S3C2410X (ARM920T) cpu +# +# see http://www.samsung.com/ for more information on SAMSUNG +# +# Modified for EMBEST SBC2440-II board with S3C2440 (ARM920T) cpu by: +# (C) Copyright 2009 +# Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk
please fix
+# +# SBC2440-II has 1 bank of 64 MB DRAM +# +# 3000'0000 to 3800'0000 +# +# Linux-Kernel is expected to be at 3000'8000, entry 3000'8000 +# +# we load ourself to 33F8'0000 +# +# download area is 3000'0000
+TEXT_BASE = 0x33F80000 diff -uprN u-boot-2009.03/board/embest/sbc2440ii/flash.c u-boot-2009.03-PATCHED/board/embest/sbc2440ii/flash.c
please use cfi driver
--- u-boot-2009.03/board/embest/sbc2440ii/flash.c 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-2009.03-PATCHED/board/embest/sbc2440ii/flash.c 2009-03-22 21:43:19.765625000 +0000 @@ -0,0 +1,437 @@ +/*
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Alex Zuepke azu@sysgo.de
- project.
- Memory Setup stuff - taken from blob memsetup.S
- Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and
- Modified for the Samsung SMDK2410 by
- David Mueller, ELSOFT AG, d.mueller@elsoft.ch
- Modified for the friendly-arm SBC-2410X by
- (C) Copyright 2005
- JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com
- Modified for the Embest SBC2440-II by
- (C) Copyright 2009
- Kevin Morfitt, Fearnside Systems Ltd,
please fix
- project.
- MA 02111-1307 USA
- Taken from linux/arch/arm/boot/compressed/head-s3c2410.S
- Copyright (C) 2002 Samsung Electronics SW.LEE
please fix please move define to a header and please use tab for indentation please check your patch with checkpatch.pl please use CAPITAL in macro name
<snip>
+_TEXT_BASE:
- .word TEXT_BASE
- /* memory control configuration */
- /* make r0 relative the current location so that it */
- /* reads SMRDATA out of FLASH rather than memory ! */
- ldr r0, =SMRDATA
- ldr r1, _TEXT_BASE
- sub r0, r0, r1
- ldr r1, =BWSCON /* Bus Width Status Controller */
- add r2, r0, #13*4
+0:
- ldr r3, [r0], #4
- str r3, [r1], #4
- cmp r2, r0
- bne 0b
- /* everything is fine now */
- mov pc, lr
- .ltorg
+SMRDATA:
- .word
- .word
- .word
- .word
- .word
- .word
- .word
- .word ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN))
- .word ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN))
- .word ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)
- .word ((BURST_EN<<7)+(SCKE_EN<<5)+(SCLK_EN<<4)+(BK67MAP))
- .word ((WBL6<<9)+(TM6<<7)+(CL6<<4)+(BT6<<3)+(BL6))
- .word ((WBL7<<9)+(TM7<<7)+(CL7<<4)+(BT7<<3)+(BL7))
please add space before and after '<<' and '+' please becarefull of the line limit 80 chars
- Marius Groeger mgroeger@sysgo.de
- project.
- MA 02111-1307 USA
- __asm__ volatile ("1:\n"
"subs %0, %1, #1\n"
please do this in the timer
- The clock frequency ratios are set to 1:4:8 ie:
PCLK = 50MHz
HCLK = 100MHz
FCLK = 400MHz
- Miscellaneous platform dependent initialisations
- S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER();
- S3C24X0_GPIO * const gpio = S3C24X0_GetBase_GPIO();
- /* to reduce PLL lock time, adjust the LOCKTIME register */
- clk_power->LOCKTIME = 0xFFFFFFFF;
please use proper accessor readx/writex
- /* configure UPLL */
- clk_power->UPLLCON = ((U_MDIV << 12) + (U_PDIV << 4) + U_SDIV);
- /* some delay between UPLL and MPLL */
- delay (8000);
- /* configure MPLL */
- clk_power->MPLLCON = ((M_MDIV << 12) + (M_PDIV << 4) + M_SDIV);
- /* configure the GPIO */
- gpio->GPACON = 0x007FFFFF;
- gpio->GPBCON = 0x00055555;
- gpio->GPBUP = 0x000007FF;
- gpio->GPBDAT = 0x000001C0; /* Switch on LED1. */
- gpio->GPCCON = 0xAAAAAAAA;
- gpio->GPCUP = 0x0000FFFF;
- gpio->GPDCON = 0xAAAAAAAA;
- gpio->GPDUP = 0x0000FFFF;
- gpio->GPECON = 0xAAAAA800;
- gpio->GPEUP = 0x00001FFF;
- gpio->GPFCON = 0x000055AA;
- gpio->GPFUP = 0x000000FF;
- gpio->GPGCON = 0xFD95FFBA;
- gpio->GPGUP = 0x0000FFFF;
- gpio->GPHCON = 0x0002FAAA;
- gpio->GPHUP = 0x000007FF;
- gpio->GPJCON = 0x02FAAAAA;
- gpio->GPJUP = 0x00001FFF;
- gpio->EXTINT0 = 0x22222222;
- gpio->EXTINT1 = 0x22222222;
- gpio->EXTINT2 = 0x22222222;
- gpio->EINTMASK = 0x00FFFFF0;
- /* arch number of SBC2440-II Board */
- gd->bd->bi_arch_number = MACH_TYPE_SBC2440II;
- /* adress of boot parameters */
- gd->bd->bi_boot_params = 0x30000100;
- icache_enable();
- dcache_enable();
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
- project.
- MA 02111-1307 USA
+#if 0
- #define DEBUGN printf
+#else
- #define DEBUGN(x, args ...) {}
please remove add use debug()
+U_BOOT_CMD(
- tftp, 3, 0, get_file_tftp,
- "tftp\t- Upload a file via TFTP",
- "<address> <file name> - Upload <file name> to <address> via TFTP"
please move this file to common add add a REAMDE
- load_addr = simple_strtoul(argv[1], NULL, 16);
- copy_filename(BootFile, argv[2], sizeof (BootFile));
- NetBootFileXferSize = 0;
- DEBUGN("TFTP: Filename: %s Address: 0x%08X\n", BootFile, (unsigned
int)load_addr);
- if (NetLoop (TFTP) <= 0) {
return -1;
- if (NetBootFileXferSize == 0) {
return -1;
- printf("File transfer succeeded - file size %lu bytes\n",
+} diff -uprN u-boot-2009.03/board/embest/sbc2440ii/u-boot.lds u-boot-2009.03-PATCHED/board/embest/sbc2440ii/u-boot.lds --- u-boot-2009.03/board/embest/sbc2440ii/u-boot.lds 1970-01-01 00:00:00.000000000 +0000 diff -uprN u-boot-2009.03/cpu/arm920t/s3c24x0/i2c.c
<snip>
please fix coding style first for a full review and please use git to generate the patch
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
