[PATCH V2] cmd_nandbcb: Support secondary boot address of imx8mn
Add support of secondary boot address for imx8mn. The secondary boot address is hardcoded in the fuse. The value is calculated from there according to the following description:
The fuse IMG_CNTN_SET1_OFFSET (0x490[22:19]) is defined as follows: • Secondary boot is disabled if fuse value is bigger than 10, n = fuse value bigger than 10. • n == 0: Offset = 4MB • n == 2: Offset = 1MB • Others & n <= 10 : Offset = 1MB*2^n • For FlexSPI boot, the valid values are: 0, 1, 2, 3, 4, 5, 6, and 7.
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- Changes V1->V2: - adjust commit message - drop and extra blank line --- arch/arm/mach-imx/cmd_nandbcb.c | 40 +++++++++++++++++++++++++++++++-- 1 file changed, 38 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/cmd_nandbcb.c b/arch/arm/mach-imx/cmd_nandbcb.c index 09622c13c9..bd14b8583a 100644 --- a/arch/arm/mach-imx/cmd_nandbcb.c +++ b/arch/arm/mach-imx/cmd_nandbcb.c @@ -132,6 +132,7 @@ static struct platform_config imx8q_plat_config = {
/* boot search related variables and definitions */ static int g_boot_search_count = 4; +static int g_boot_secondary_offset; static int g_boot_search_stride; static int g_pages_per_stride;
@@ -275,9 +276,9 @@ static int nandbcb_set_boot_config(int argc, char * const argv[], boot_stream2_address = ((maxsize - boot_stream1_address) / 2 + boot_stream1_address);
- if (boot_cfg->secondary_boot_stream_off_in_MB) + if (g_boot_secondary_offset) boot_stream2_address = - (loff_t)boot_cfg->secondary_boot_stream_off_in_MB * 1024 * 1024; + (loff_t)g_boot_secondary_offset * 1024 * 1024;
max_boot_stream_size = boot_stream2_address - boot_stream1_address;
@@ -1269,6 +1270,36 @@ static bool check_fingerprint(void *data, int fingerprint) return (*(int *)(data + off) == fingerprint); }
+static int fuse_secondary_boot(u32 bank, u32 word, u32 mask, u32 off) +{ + int err; + u32 val; + int ret; + + err = fuse_read(bank, word, &val); + if (err) + return 0; + + val = (val & mask) >> off; + + if (val > 10) + return 0; + + switch (val) { + case 0: + ret = 4; + break; + case 1: + ret = 1; + break; + default: + ret = 2 << val; + break; + } + + return ret; +}; + static int fuse_to_search_count(u32 bank, u32 word, u32 mask, u32 off) { int err; @@ -1506,6 +1537,11 @@ static int do_nandbcb(struct cmd_tbl *cmdtp, int flag, int argc, g_boot_search_count); }
+ if ((plat_config.misc_flags) & FIRMWARE_SECONDARY_FIXED_ADDR) { + if (is_imx8mn()) + g_boot_secondary_offset = fuse_secondary_boot(2, 1, 0xff0000, 16); + } + cmd = argv[1]; --argc; ++argv;
Hi Fabio
Any time to review it?
Michael
On Thu, Nov 18, 2021 at 3:01 PM Michael Trimarchi michael@amarulasolutions.com wrote:
(loff_t)g_boot_secondary_offset * 1024 * 1024; max_boot_stream_size = boot_stream2_address - boot_stream1_address;
int err;
u32 val;
int ret;
if (err)
if (val > 10)
switch (val) {
case 0:
ret = 4;
break;
case 1:
ret = 1;
break;
default:
ret = 2 << val;
break;
return ret;
if (is_imx8mn())
-- 2.25.1
Hi Michael,
On Sun, Nov 28, 2021 at 1:58 PM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi Fabio
Please fix the checkpatch warnings:
WARNING: Possible unwrapped commit description (prefer a maximum 75 chars per line) #81: • Secondary boot is disabled if fuse value is bigger than 10, n = fuse value bigger than
CHECK: Unnecessary parentheses around 'plat_config.misc_flags' #162: FILE: arch/arm/mach-imx/cmd_nandbcb.c:1540: + if ((plat_config.misc_flags) & FIRMWARE_SECONDARY_FIXED_ADDR) {
total: 0 errors, 1 warnings, 1 checks, 65 lines checked
I haven't personally touched arch/arm/mach-imx/cmd_nandbcb.c, so I would like to get a review from Ye Li or Han Xu, if possible.
Hi Fabio
On Sun, Nov 28, 2021 at 7:00 PM Fabio Estevam festevam@gmail.com wrote:
Hi Michael,
Hi Fabio
- if ((plat_config.misc_flags) & FIRMWARE_SECONDARY_FIXED_ADDR) {
Let's wait the other feedback and then I will upload the v3. I have tried to stay on the same style of that code section and I forgot to run checkpatch
Mcihael
Fabio Estevam
Michael Trimarchi
