[PATCH v2] drivers: watchdog: wdt-uclass: Use IS_ENABLED for WATCHDOG_AUTOSTART
There is no separate SPL/TPL config for WATCHDOG_AUTOSTART. So use IS_ENABLED instead of CONFIG_IS_ENABLED to make watchdog working in SPL again.
Fixes: 830d29ac3721 ("watchdog: Allow to use CONFIG_WDT without starting watchdog") Signed-off-by: Teresa Remmet t.remmet@phytec.de Reviewed-by: Stefan Roese sr@denx.de --- Changes in v2: - Added Fixes tag - Added Reviewed-by
drivers/watchdog/wdt-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index a0c2429e5a43..17334dbda6c9 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -53,7 +53,7 @@ int initr_watchdog(void) 4 * reset_period) / 4; }
- if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) { + if (!IS_ENABLED(CONFIG_WATCHDOG_AUTOSTART)) { printf("WDT: Not starting\n"); return 0; }
Applied to u-boot-marvell/master
Thanks, Stefan
Changes in v2:
Added Fixes tag
Added Reviewed-by
- if (!IS_ENABLED(CONFIG_WATCHDOG_AUTOSTART)) { printf("WDT: Not starting\n"); return 0; }
Viele Grüße, Stefan
Stefan Roese
Teresa Remmet
