[U-Boot] [PATCH] ARM: DTS: Resync am3517-evm.dts with Linux 4.19
Some minor changes have been made to the AM3517-evm and the underlying am3517.dtsi files. This patch re-sync's the DTS and DTSI files with Linux.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/am3517-evm.dts b/arch/arm/dts/am3517-evm.dts index 98aadb0f81..1d158cfda1 100644 --- a/arch/arm/dts/am3517-evm.dts +++ b/arch/arm/dts/am3517-evm.dts @@ -127,6 +127,7 @@ status = "okay"; pinctrl-names = "default"; enable-gpios = <&gpio6 16 GPIO_ACTIVE_HIGH>; /* gpio176, lcd INI */ + vcc-supply = <&vdd_io_reg>;
port { lcd_in: endpoint { @@ -154,6 +155,7 @@ bl: backlight { compatible = "pwm-backlight"; pinctrl-names = "default"; + power-supply = <&vdd_io_reg>; pinctrl-0 = <&backlight_pins>; pwms = <&pwm11 0 5000000 0>; brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; @@ -168,6 +170,13 @@ ti,timers = <&timer11>; #pwm-cells = <3>; }; + + /* HS USB Host PHY on PORT 1 */ + hsusb1_phy: hsusb1_phy { + compatible = "usb-nop-xceiv"; + reset-gpios = <&gpio2 25 GPIO_ACTIVE_LOW>; /* gpio_57 */ + #phy-cells = <0>; + }; };
&davinci_emac { @@ -203,6 +212,7 @@ reg = <0x21>; gpio-controller; #gpio-cells = <2>; + vcc-supply = <&vdd_io_reg>; }; };
@@ -220,15 +230,21 @@ cd-gpios = <&gpio4 31 GPIO_ACTIVE_HIGH>; /* gpio_127 */ };
-&mmc2 { +&mmc3 { status = "disabled"; };
-&mmc3 { - status = "disabled"; +&usbhshost { + port1-mode = "ehci-phy"; +}; + +&usbhsehci { + phys = <&hsusb1_phy>; };
&omap3_pmx_core { + pinctrl-names = "default"; + pinctrl-0 = <&hsusb1_rst_pins>;
leds_pins: pinmux_leds_pins { pinctrl-single,pins = < @@ -287,4 +303,32 @@ OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT | MUX_MODE0) /* dss_data15.dss_data15 */ >; }; + + hsusb1_rst_pins: pinmux_hsusb1_rst_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x20ba, PIN_OUTPUT | MUX_MODE4) /* gpmc_ncs6.gpio_57 */ + >; + }; +}; + +&omap3_pmx_core2 { + pinctrl-names = "default"; + pinctrl-0 = <&hsusb1_pins>; + + hsusb1_pins: pinmux_hsusb1_pins { + pinctrl-single,pins = < + OMAP3430_CORE2_IOPAD(0x25d8, PIN_OUTPUT | MUX_MODE3) /* etk_clk.hsusb1_stp */ + OMAP3430_CORE2_IOPAD(0x25da, PIN_OUTPUT | MUX_MODE3) /* etk_ctl.hsusb1_clk */ + OMAP3430_CORE2_IOPAD(0x25ec, PIN_INPUT | MUX_MODE3) /* etk_d8.hsusb1_dir */ + OMAP3430_CORE2_IOPAD(0x25ee, PIN_INPUT | MUX_MODE3) /* etk_d9.hsusb1_nxt */ + OMAP3430_CORE2_IOPAD(0x25dc, PIN_INPUT | MUX_MODE3) /* etk_d0.hsusb1_data0 */ + OMAP3430_CORE2_IOPAD(0x25de, PIN_INPUT | MUX_MODE3) /* etk_d1.hsusb1_data1 */ + OMAP3430_CORE2_IOPAD(0x25e0, PIN_INPUT | MUX_MODE3) /* etk_d2.hsusb1_data2 */ + OMAP3430_CORE2_IOPAD(0x25ea, PIN_INPUT | MUX_MODE3) /* etk_d7.hsusb1_data3 */ + OMAP3430_CORE2_IOPAD(0x25e4, PIN_INPUT | MUX_MODE3) /* etk_d4.hsusb1_data4 */ + OMAP3430_CORE2_IOPAD(0x25e6, PIN_INPUT | MUX_MODE3) /* etk_d5.hsusb1_data5 */ + OMAP3430_CORE2_IOPAD(0x25e8, PIN_INPUT | MUX_MODE3) /* etk_d6.hsusb1_data6 */ + OMAP3430_CORE2_IOPAD(0x25e2, PIN_INPUT | MUX_MODE3) /* etk_d3.hsusb1_data7 */ + >; + }; }; diff --git a/arch/arm/dts/am3517-som.dtsi b/arch/arm/dts/am3517-som.dtsi index a6d5ff73c1..dae6e458e5 100644 --- a/arch/arm/dts/am3517-som.dtsi +++ b/arch/arm/dts/am3517-som.dtsi @@ -14,6 +14,32 @@ cpu0-supply = <&vdd_core_reg>; }; }; + + wl12xx_buffer: wl12xx_buf { + compatible = "regulator-fixed"; + regulator-name = "wl1271_buf"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_buffer_pins>; + gpio = <&gpio5 1 GPIO_ACTIVE_LOW>; /* gpio 129 */ + regulator-always-on; + vin-supply = <&vdd_1v8_reg>; + }; + + wl12xx_vmmc2: wl12xx_vmmc2 { + compatible = "regulator-fixed"; + regulator-name = "vwl1271"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_wkup_pins>; + gpio = <&gpio1 3 GPIO_ACTIVE_HIGH >; /* gpio 3 */ + startup-delay-us = <70000>; + enable-active-high; + regulator-always-on; + vin-supply = <&wl12xx_buffer>; + }; };
&gpmc { @@ -64,7 +90,6 @@ regulators { vdd_core_reg: VDCDC1 { regulator-name = "vdd_core"; - compatible = "regulator-fixed"; regulator-always-on; regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1200000>; @@ -72,7 +97,6 @@
vdd_io_reg: VDCDC2 { regulator-name = "vdd_io"; - compatible = "regulator-fixed"; regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -80,7 +104,6 @@
vdd_1v8_reg: VDCDC3 { regulator-name = "vdd_1v8"; - compatible = "regulator-fixed"; regulator-always-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -88,7 +111,6 @@
vdd_usb18_reg: LDO1 { regulator-name = "vdd_usb18"; - compatible = "regulator-fixed"; regulator-always-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -96,7 +118,6 @@
vdd_usb33_reg: LDO2 { regulator-name = "vdd_usb33"; - compatible = "regulator-fixed"; regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -126,8 +147,63 @@ }; };
+&mmc2 { + interrupts-extended = <&intc 86 /* &omap3_pmx_core 0x12c */>; + + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <&wl12xx_vmmc2>; + non-removable; + bus-width = <4>; + cap-power-off-card; + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1271"; + reg = <2>; + interrupt-parent = <&gpio6>; + interrupts = <10 IRQ_TYPE_LEVEL_HIGH>; /* gpio_170 */ + ref-clock-frequency = <26000000>; + tcxo-clock-frequency = <26000000>; + }; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + + bluetooth { + compatible = "ti,wl1271-st"; + enable-gpios = <&gpio2 24 GPIO_ACTIVE_HIGH>; /* gpio 56 */ + max-speed = <3000000>; + }; +}; + &omap3_pmx_core {
+ wl12xx_buffer_pins: pinmux_wl12xx_buffer_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2156, PIN_OUTPUT | MUX_MODE4) /* mmc1_dat7.gpio_129 */ + >; + }; + + mmc2_pins: pinmux_mmc2_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2158, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_clk.mmc2_clk */ + OMAP3_CORE1_IOPAD(0x215a, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_cmd.mmc2_cmd */ + OMAP3_CORE1_IOPAD(0x215c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat0.mmc2_dat0 */ + OMAP3_CORE1_IOPAD(0x215e, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat1.mmc2_dat1 */ + OMAP3_CORE1_IOPAD(0x2160, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat2.mmc2_dat2 */ + OMAP3_CORE1_IOPAD(0x2162, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat3.mmc2_dat3 */ + OMAP3_CORE1_IOPAD(0x2164, PIN_OUTPUT | MUX_MODE1) /* mmc2_dat4.mmc2_dir_dat0 */ + OMAP3_CORE1_IOPAD(0x2166, PIN_OUTPUT | MUX_MODE1) /* mmc2_dat5.mmc2_dir_dat1 */ + OMAP3_CORE1_IOPAD(0x2168, PIN_OUTPUT | MUX_MODE1) /* mmc2_dat6.mmc2_dir_cmd */ + OMAP3_CORE1_IOPAD(0x216a, PIN_INPUT | MUX_MODE1) /* mmc2_dat7.mmc2_clkin */ + OMAP3_CORE1_IOPAD(0x21c6, PIN_INPUT_PULLUP | MUX_MODE4) /* hdq_sio.gpio_170 */ + >; + }; + rtc_pins: pinmux_rtc_pins { pinctrl-single,pins = < OMAP3_CORE1_IOPAD(0x20b6, PIN_INPUT_PULLUP | MUX_MODE4) /* gpmc_ncs4.gpio_55 */ @@ -139,4 +215,23 @@ OMAP3_CORE1_IOPAD(0x20d2, PIN_INPUT | MUX_MODE4) /* gpmc_wait3.gpio_65 */ >; }; + + uart2_pins: pinmux_uart2_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2174, PIN_INPUT_PULLUP | MUX_MODE0) /* uart2_cts */ + OMAP3_CORE1_IOPAD(0x2176, PIN_OUTPUT_PULLUP | MUX_MODE0) /* uart2_rts */ + OMAP3_CORE1_IOPAD(0x2178, PIN_OUTPUT | MUX_MODE0) /* uart2_tx */ + OMAP3_CORE1_IOPAD(0x217a, PIN_INPUT | MUX_MODE0) /* uart2_rx */ + OMAP3_CORE1_IOPAD(0x20b8, PIN_INPUT | MUX_MODE0) /* gpio_56 */ + >; + }; +}; + +&omap3_pmx_wkup { + + wl12xx_wkup_pins: pinmux_wl12xx_wkup_pins { + pinctrl-single,pins = < + OMAP3_WKUP_IOPAD(0x2a0c, PIN_OUTPUT | MUX_MODE4) /* sys_boot1.gpio_3 */ + >; + }; }; diff --git a/arch/arm/dts/am3517.dtsi b/arch/arm/dts/am3517.dtsi index 4b6062b631..23ea381d36 100644 --- a/arch/arm/dts/am3517.dtsi +++ b/arch/arm/dts/am3517.dtsi @@ -91,6 +91,11 @@ }; };
+/* Table Table 5-79 of the TRM shows 480ab000 is reserved */ +&usb_otg_hs { + status = "disabled"; +}; + &iva { status = "disabled"; };
Adam Ford
