[U-Boot-Users] [PATCH 1/2] Don't panic if a controller driver does ecc its own way.
Some hardware, such as the enhanced local bus controller used on some mpc83xx chips, does ecc transparently when reading and writing data, rather than providing a generic calculate/correct mechanism that can be exported to the nand subsystem.
The subsystem should not BUG() when calculate, correct, or hwctl are missing, if the methods that call them have been overridden.
Signed-off-by: Scott Wood scottwood@freescale.com --- This patch applies to the mtd-2.6.22.1 branch of the nand tree.
drivers/mtd/nand/nand_base.c | 8 ++++++-- 1 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 576b0db..319696d 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2593,8 +2593,12 @@ int nand_scan_tail(struct mtd_info *mtd) chip->ecc.write_oob = nand_write_oob_std;
case NAND_ECC_HW_SYNDROME: - if (!chip->ecc.calculate || !chip->ecc.correct || - !chip->ecc.hwctl) { + if ((!chip->ecc.calculate || !chip->ecc.correct || + !chip->ecc.hwctl) && + (!chip->ecc.read_page || + chip->ecc.read_page == nand_read_page_hwecc || + !chip->ecc.write_page || + chip->ecc.write_page == nand_write_page_hwecc)) { printk(KERN_WARNING "No ECC functions supplied, " "Hardware ECC not possible\n"); BUG();
This should go through the 83xx custodian, but I haven't seen this yet?
Anyway, it does not apply any more:
Applying Don't panic if a controller driver does ecc its own way. error: patch failed: drivers/mtd/nand/nand_base.c:2593 error: drivers/mtd/nand/nand_base.c: patch does not apply fatal: sha1 information is lacking or useless (drivers/mtd/nand/nand_base.c). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge.
Why should it go through 83xx? It's a patch against generic NAND code.
Did you try applying it against the 2.6.22.1 branch of the nand repository (IIRC, the non-commit-message patch comment specified that)?
-Scott
It seems to be 83xx specific code to me?
No, I tried to apply this to the U-Boot repository. Maybe this was my fault? Is this supposed to go into Linux, then?
It's not. It is removing a restriction in the NAND code that happens to interfere with what the FSL NAND driver needs to do.
No, it's supposed to go into the 2.6.22.1 branch of Stefan's u-boot NAND tree. This change is already in the Linux NAND code.
-Scott
I see. OK, so it's really Stefan who needs to react here.
Thanks for the explanations.
I'll update the 2.6.22.1 branch shortly (when time permits). Sorry for the delay.
Best regards, Stefan
Scott Wood
Stefan Roese
