[U-Boot] [PATCH v5 00/13] efi: Enable basic sandbox support for EFI loader
A limitation of the EFI loader at present is that it does not build with sandbox. This makes it hard to write tests, since sandbox is used for most testing in U-Boot.
This series enables the EFI loader feature. It allows sandbox to build and run a trivial function which calls the EFI API to output a message.
This series is at u-boot-dm/efi-working
Changes in v5: - Add new patch to disallow CMD_BOOTEFI_SELFTEST on sandbox - Drop call to efi_init_obj_list() which is now done in do_bootefi() - Drop period after "elf" in comment - Introduce load_options_path to specifyc U-Boot env var for load_options_path - Rebase to master
Changes in v4: - Move the fix to query_console_serial() - Rebase to master - Update SPDX tags
Changes in v3: - Add new patch to init the 'rows' and 'cols' variables - Add new patch to rename bootefi_test_finish() to bootefi_run_finish() - Add new patch to split out test init/uninit into functions - Add patch to create a function to set up for running EFI code - Drop incorrect map_sysmem() in write_smbios_table() - Init the 'rows' and 'cols' vars to avoid a compiler error (gcc 4.8.4) - Rebase to master
Changes in v2: - Rebase to master - Update to use mapmem instead of a cast
Simon Glass (13): efi: Don't allow CMD_BOOTEFI_SELFTEST on sandbox efi: Init the 'rows' and 'cols' variables efi: sandbox: Adjust memory usage for sandbox sandbox: smbios: Update to support sandbox efi: sandbox: Add distroboot support efi: sandbox: Add relocation constants efi: Add a comment about duplicated ELF constants efi: sandbox: Enable EFI loader builder for sandbox efi: Split out test init/uninit into functions efi: sandbox: Add a simple 'bootefi test' command efi: Create a function to set up for running EFI code efi: Rename bootefi_test_finish() to bootefi_run_finish() buildman: Add a --boards option to specify particular boards to build
cmd/bootefi.c | 153 ++++++++++++++++++++++---------- include/config_distro_bootcmd.h | 2 +- include/efi_loader.h | 3 + lib/efi_loader/Kconfig | 12 ++- lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_console.c | 5 +- lib/efi_loader/efi_memory.c | 31 ++++--- lib/efi_loader/efi_runtime.c | 7 ++ lib/efi_loader/efi_test.c | 16 ++++ lib/efi_selftest/Kconfig | 2 +- lib/smbios.c | 32 +++++-- tools/buildman/README | 12 ++- tools/buildman/board.py | 28 +++++- tools/buildman/cmdline.py | 4 +- tools/buildman/control.py | 20 ++++- tools/buildman/test.py | 31 ++++--- 16 files changed, 264 insertions(+), 95 deletions(-) create mode 100644 lib/efi_loader/efi_test.c
This does not work at present and gives the following error:
output: 'ld.bfd: read in flex scanner failed scripts/Makefile.lib:390: recipe for target 'lib/efi_selftest/efi_selftest_miniapp_return_efi.so' failed
It may be possible to figure this out with suitable linker magic but it does not seem to be easy. Also, we will be able to run the tests on sandbox without using the miniapp.
So for now at least, disable this option.
Changes in v4: None Changes in v3: None Changes in v2: None
lib/efi_selftest/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_selftest/Kconfig b/lib/efi_selftest/Kconfig index 59f9f36801..b52696778d 100644 --- a/lib/efi_selftest/Kconfig +++ b/lib/efi_selftest/Kconfig @@ -1,6 +1,6 @@ config CMD_BOOTEFI_SELFTEST bool "Allow booting an EFI efi_selftest" - depends on CMD_BOOTEFI + depends on CMD_BOOTEFI && !SANDBOX imply FAT imply FAT_WRITE help
Changes in v5:
- depends on CMD_BOOTEFI && !SANDBOX
It is sufficient to change the following line in lib/efi_selftest/Makefile to exclude building of efi_selftest_startimage_exit.o and efi_selftest_startimage_return.o:
-ifeq ($(CONFIG_X86_64),) +ifeq ($(CONFIG_X86_64)$(SANDBOX),)
This way we can run all other tests.
Best regards
Heinrich
Hi Heinrich,
Changes in v5:
It can build them but they don't work for me. I would like to leave this as future work as there have been plenty of changes to this long-running series already.
The current code causes a compiler error on gcc 4.8.4 as used by sandbox on Ubuntu 14.04, which is fairly recent. Init these variables to fix the problem.
Changes in v5: None Changes in v4: - Move the fix to query_console_serial()
Changes in v2: None
lib/efi_loader/efi_console.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index ce66c935ec..bd953a1485 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -204,8 +204,11 @@ static int query_console_serial(int *rows, int *cols) return -1;
/* Read {depth,rows,cols} */ - if (term_read_reply(n, 3, 't')) + if (term_read_reply(n, 3, 't')) { + *rows = -1; + *cols = -1; return -1; + }
*cols = n[2]; *rows = n[1];
Is this needed after Alex's http://git.denx.de/?p=u-boot.git;a=commitdiff;h=80483b2ab62ca7cd200db445b692... ?
Best regards
Heinrich
Changes in v3:
Changes in v2: None
*rows = -1;
*cols = -1;
return -1;
I missed that one.
I actually think his is the better fix, since we really shouldn't be setting return values in case of error.
Best regards
Heinrich
Changes in v3:
Changes in v2: None
*rows = -1;
} *cols = n[2]; *rows = n[1];
With sandbox the U-Boot code is not mapped into the sandbox memory range so does not need to be excluded when allocating EFI memory. Update the EFI memory init code to take account of that.
Also use mapmem instead of a cast to convert a memory address to a pointer.
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Update to use mapmem instead of a cast
lib/efi_loader/efi_memory.c | 31 ++++++++++++++++++------------- 1 file changed, 18 insertions(+), 13 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index ec66af98ea..210e49ee8b 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -9,6 +9,7 @@ #include <efi_loader.h> #include <inttypes.h> #include <malloc.h> +#include <mapmem.h> #include <watchdog.h> #include <linux/list_sort.h>
@@ -393,7 +394,7 @@ efi_status_t efi_allocate_pool(int pool_type, efi_uintn_t size, void **buffer) &t);
if (r == EFI_SUCCESS) { - struct efi_pool_allocation *alloc = (void *)(uintptr_t)t; + struct efi_pool_allocation *alloc = map_sysmem(t, size); alloc->num_pages = num_pages; *buffer = alloc->data; } @@ -504,18 +505,22 @@ int efi_memory_init(void)
efi_add_known_memory();
- /* Add U-Boot */ - uboot_start = (gd->start_addr_sp - uboot_stack_size) & ~EFI_PAGE_MASK; - uboot_pages = (gd->ram_top - uboot_start) >> EFI_PAGE_SHIFT; - efi_add_memory_map(uboot_start, uboot_pages, EFI_LOADER_DATA, false); - - /* Add Runtime Services */ - runtime_start = (ulong)&__efi_runtime_start & ~EFI_PAGE_MASK; - runtime_end = (ulong)&__efi_runtime_stop; - runtime_end = (runtime_end + EFI_PAGE_MASK) & ~EFI_PAGE_MASK; - runtime_pages = (runtime_end - runtime_start) >> EFI_PAGE_SHIFT; - efi_add_memory_map(runtime_start, runtime_pages, - EFI_RUNTIME_SERVICES_CODE, false); + if (!IS_ENABLED(CONFIG_SANDBOX)) { + /* Add U-Boot */ + uboot_start = (gd->start_addr_sp - uboot_stack_size) & + ~EFI_PAGE_MASK; + uboot_pages = (gd->ram_top - uboot_start) >> EFI_PAGE_SHIFT; + efi_add_memory_map(uboot_start, uboot_pages, EFI_LOADER_DATA, + false); + + /* Add Runtime Services */ + runtime_start = (ulong)&__efi_runtime_start & ~EFI_PAGE_MASK; + runtime_end = (ulong)&__efi_runtime_stop; + runtime_end = (runtime_end + EFI_PAGE_MASK) & ~EFI_PAGE_MASK; + runtime_pages = (runtime_end - runtime_start) >> EFI_PAGE_SHIFT; + efi_add_memory_map(runtime_start, runtime_pages, + EFI_RUNTIME_SERVICES_CODE, false); + }
#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER /* Request a 32bit 64MB bounce buffer region */
We want to eventually be able to run efi binaries inside sandbox, so we need to expose a 1:1 memory map inside the efi interfaces.
That means the memory argument of efi_allocate_pages() already needs to be set to the virtual address in real VA space. The easiest way to get there is if you just put virtual addresses in the efi memory map.
- /* Add U-Boot */
- if (!IS_ENABLED(CONFIG_SANDBOX)) {
/* Add U-Boot */
~EFI_PAGE_MASK;
false);
I guess it's ok to hide U-Boot from the payload for sandbox, yes. Please extract the code into a function though, so that we don't get into too much indenting.
I guess we do want to indicate RTS, no? But like everything else we want to expose it with the real VA addresses.
Alex
Hi Alex,
Can you please explain that a bit more, or give a code example? I'm not quite sure what you mean.
/* Add U-Boot */
/* Add U-Boot */
~EFI_PAGE_MASK;
false);
OK
I suspect it would never be used but also that we should indicate RTS is present so that things that check for it don't fail. What do you think we should do here?
On 12.06.18 15:48, Simon Glass wrote:
Hi Alex,
In efi_add_known_memory() we populate the EFI memory table with addresses that EFI allocations can return. Because we don't control the payloads that call these functions, we can only return pointers. That means efi_add_known_memory() should add map_sysmem()'ed values into its own table.
Basically while we expose "virtual 0 offset" addresses to the command line, anything internal still works on pointers. And everything EFI internal needs to be considered a pointer, because we don't control the code that deals with them.
So in a nutshell, I mean something like this (untested, probably whitespace broken and line wrapped):
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index ec66af98ea..80211d8c95 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -491,6 +491,9 @@ __weak void efi_add_known_memory(void) u64 start = (ram_start + EFI_PAGE_MASK) & ~EFI_PAGE_MASK; u64 pages = (ram_size + EFI_PAGE_MASK) >> EFI_PAGE_SHIFT;
+ /* Sandbox needs virtual addresses here */ + start = (uintptr_t)map_sysmem(start, pages * EFI_PAGE_SIZE); + efi_add_memory_map(start, pages, EFI_CONVENTIONAL_MEMORY, false); }
/* Add U-Boot */
/* Add U-Boot */
~EFI_PAGE_MASK;
false);
OK
I'm not 100% sure yet. It'll be very hard to support anything that relies on exit_boot_services() from within user space. So yes, just leave it out for sandbox for now.
Alex
Hi Alex,
Hi Alex,
The map_sysmem() call is already when allocated addresses are returned - see elsewhere in the file. So adding it here as well will cause a double translation. Still, I tried this out and it just fails to init.
Does any EFI app have access to the internal tables containing the memory addresses? If not, then perhaps it is OK to use U-Boot addresses here?
In any case Heinrich has mentioned an alignment problem that needs to be resolved.
At present this code casts addresses to pointers so cannot be used with sandbox. Update it to use mapmem instead.
Changes in v5: None Changes in v4: None Changes in v3: - Drop incorrect map_sysmem() in write_smbios_table()
Changes in v2: None
lib/smbios.c | 32 ++++++++++++++++++++++++-------- 1 file changed, 24 insertions(+), 8 deletions(-)
diff --git a/lib/smbios.c b/lib/smbios.c index df3d26b071..fc3dabcbc1 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <mapmem.h> #include <smbios.h> #include <tables_csum.h> #include <version.h> @@ -72,9 +73,10 @@ static int smbios_string_table_len(char *start)
static int smbios_write_type0(ulong *current, int handle) { - struct smbios_type0 *t = (struct smbios_type0 *)*current; + struct smbios_type0 *t; int len = sizeof(struct smbios_type0);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type0)); fill_smbios_header(t, SMBIOS_BIOS_INFORMATION, len, handle); t->vendor = smbios_add_string(t->eos, "U-Boot"); @@ -101,16 +103,18 @@ static int smbios_write_type0(ulong *current, int handle)
len = t->length + smbios_string_table_len(t->eos); *current += len; + unmap_sysmem(t);
return len; }
static int smbios_write_type1(ulong *current, int handle) { - struct smbios_type1 *t = (struct smbios_type1 *)*current; + struct smbios_type1 *t; int len = sizeof(struct smbios_type1); char *serial_str = env_get("serial#");
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type1)); fill_smbios_header(t, SMBIOS_SYSTEM_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -122,15 +126,17 @@ static int smbios_write_type1(ulong *current, int handle)
return len; }
static int smbios_write_type2(ulong *current, int handle) { - struct smbios_type2 *t = (struct smbios_type2 *)*current; + struct smbios_type2 *t; int len = sizeof(struct smbios_type2);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type2)); fill_smbios_header(t, SMBIOS_BOARD_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -140,15 +146,17 @@ static int smbios_write_type2(ulong *current, int handle)
return len; }
static int smbios_write_type3(ulong *current, int handle) { - struct smbios_type3 *t = (struct smbios_type3 *)*current; + struct smbios_type3 *t; int len = sizeof(struct smbios_type3);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type3)); fill_smbios_header(t, SMBIOS_SYSTEM_ENCLOSURE, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -160,6 +168,7 @@ static int smbios_write_type3(ulong *current, int handle)
return len; } @@ -198,9 +207,10 @@ static void smbios_write_type4_dm(struct smbios_type4 *t)
static int smbios_write_type4(ulong *current, int handle) { - struct smbios_type4 *t = (struct smbios_type4 *)*current; + struct smbios_type4 *t; int len = sizeof(struct smbios_type4);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type4)); fill_smbios_header(t, SMBIOS_PROCESSOR_INFORMATION, len, handle); t->processor_type = SMBIOS_PROCESSOR_TYPE_CENTRAL; @@ -214,32 +224,37 @@ static int smbios_write_type4(ulong *current, int handle)
return len; }
static int smbios_write_type32(ulong *current, int handle) { - struct smbios_type32 *t = (struct smbios_type32 *)*current; + struct smbios_type32 *t; int len = sizeof(struct smbios_type32);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type32)); fill_smbios_header(t, SMBIOS_SYSTEM_BOOT_INFORMATION, len, handle);
return len; }
static int smbios_write_type127(ulong *current, int handle) { - struct smbios_type127 *t = (struct smbios_type127 *)*current; + struct smbios_type127 *t; int len = sizeof(struct smbios_type127);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type127)); fill_smbios_header(t, SMBIOS_END_OF_TABLE, len, handle);
return len; } @@ -268,7 +283,7 @@ ulong write_smbios_table(ulong addr) /* 16 byte align the table address */ addr = ALIGN(addr, 16);
- se = (struct smbios_entry *)(uintptr_t)addr; + se = map_sysmem(addr, sizeof(struct smbios_entry)); memset(se, 0, sizeof(struct smbios_entry));
addr += sizeof(struct smbios_entry); @@ -297,6 +312,7 @@ ulong write_smbios_table(ulong addr) isize = sizeof(struct smbios_entry) - SMBIOS_INTERMEDIATE_OFFSET; se->intermediate_checksum = table_compute_checksum(istart, isize); se->checksum = table_compute_checksum(se, sizeof(struct smbios_entry)); + unmap_sysmem(se);
return addr; }
Changes in v2: None
Please change the function argument to indicate that we're no longer dealing with pointers, but instead with "u-boot physical addresses".
Same for the other functions obviously :).
Alex
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
*current += len;
unmap_sysmem(t);
return len;
*current += len;
unmap_sysmem(t);
return len;
unmap_sysmem(se);
return addr;
Hi Alex,
Changes in v2: None
That actually hasn't changed. We are currently passing a U-Boot address around and it is a ulong, as it normally is in U-Boot. What has changed is that sandbox does not have a direct mapping between U-Boot address and memory address, so we have to do the mapping.
While it is try that the ulong can be converted to a pointer with a cast normally, this is not possible with sandbox, so things that need to convert the ulong to a pointer need to do a conversion.
Hi Alex,
Changes in v2: None
Oh, I missed the * in *current. So it already does get passed as a number which then is cast back into a pointer.
That however means that the smbios tables are now u-boot address space relative. So anything that tries to read them from within EFI context will explode.
Alex
Hi Alex,
Hi Alex,
Changes in v2: None
Aren't these tables for the Linux kernel? If so, then this doesn't matter.
But if EFI reads them, we are in trouble. We cannot always put a 64-bit address into a 32-bit word.
I suppose we could support it on 32-bit sandbox, but not a lot of people use that.
On 12.06.18 23:56, Simon Glass wrote:
Hi Alex,
Hi Alex,
Changes in v2: None
Sorry, I must've misremembered. I can not see a single reference of a physical address in the SMBIOS code. So your patch looks correct to me.
Alex
With sandbox these values depend on the host system. Let's assume that it is x86_64 for now.
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
include/config_distro_bootcmd.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index d672e8ebe6..8d11f52da0 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -251,7 +251,7 @@ #elif defined(CONFIG_ARM) #define BOOTENV_EFI_PXE_ARCH "0xa" #define BOOTENV_EFI_PXE_VCI "PXEClient:Arch:00010:UNDI:003000" -#elif defined(CONFIG_X86) +#elif defined(CONFIG_X86) || defined(CONFIG_SANDBOX) /* Always assume we're running 64bit */ #define BOOTENV_EFI_PXE_ARCH "0x7" #define BOOTENV_EFI_PXE_VCI "PXEClient:Arch:00007:UNDI:003000"
I was serious when I said I wanted to have a defined(__x86_64__) guard. Otherwise we'll expose incorrect information. And I doubt that anyone will catch it when porting sandbox to non-x86, because it doesn't error out.
Alex
Hi Alex,
OK I can do a warning but I cannot use the current guard, otherwise it prevents sandbox even building on ARM hosts!
Hi Alex,
Just change defined(CONFIG_X86) into defined(__x86_64__) || defined(__i386__) then? Maybe the same for the other archs?
Alex
Hi Alex,
Hi Alex,
I mean print a warning if sandbox is not being build on x86.
What you are suggesting is some sort of ad-hoc architecture detection in the EFI header file. If we have a problem here, it should be solved centrally. I'll add a comment.
Add these so that we can build the EFI loader for sandbox. The values are for x86_64 so potentially bogus. But we don't support relocation within sandbox anyway.
lib/efi_loader/efi_runtime.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 65f2bcf140..b669a2aa32 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -58,6 +58,9 @@ struct dyn_sym { #define R_ABSOLUTE R_RISCV_64 #define SYM_INDEX 32 #endif +#elif defined(CONFIG_SANDBOX) +#define R_RELATIVE 8 +#define R_MASK 0xffffffffULL #else #error Need to add relocation awareness #endif
Same here. Please guard it with an x86_64 check to make sure anyone who ports sandbox to non-x86 trips over it.
Alex
These constants are defined in arch-specific code but redefined here. Add a TODO to clean this up.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de ---
Changes in v5: - Drop period after "elf" in comment
lib/efi_loader/efi_runtime.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index b669a2aa32..786abb46d8 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -28,6 +28,10 @@ static efi_status_t __efi_runtime EFIAPI efi_unimplemented(void); static efi_status_t __efi_runtime EFIAPI efi_device_error(void); static efi_status_t __efi_runtime EFIAPI efi_invalid_parameter(void);
+/* + * TODO(sjg@chromium.org): These defines and structs should come from the elf + * header for each arch (or a generic header) rather than being repeated here. + */ #if defined(CONFIG_ARM64) #define R_RELATIVE 1027 #define R_MASK 0xffffffffULL
Thanks, applied to efi-next
Alex
This allows this feature to build within sandbox. This is for testing purposes only since it is not possible for sandbox to load native code.
Changes in v5: None Changes in v4: None Changes in v3: - Init the 'rows' and 'cols' vars to avoid a compiler error (gcc 4.8.4)
Changes in v2: None
lib/efi_loader/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index df58e633d1..d471e6f4a4 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -1,6 +1,6 @@ config EFI_LOADER bool "Support running EFI Applications in U-Boot" - depends on (ARM || X86 || RISCV) && OF_LIBFDT + depends on (ARM || X86 || RISCV || SANDBOX) && OF_LIBFDT # We do not support bootefi booting ARMv7 in non-secure mode depends on !ARMV7_NONSEC # We need EFI_STUB_64BIT to be set on x86_64 with EFI_STUB
We plan to run more than one EFI test. In order to avoid duplicating code, create functions which handle preparing for running the test and cleaning up afterwards.
Also shorten the awfully long variable names here.
Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi()
Changes in v4: None Changes in v3: - Add new patch to split out test init/uninit into functions
Changes in v2: None
cmd/bootefi.c | 87 +++++++++++++++++++++++++++++++++++++-------------- 1 file changed, 63 insertions(+), 24 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 707d159bac..a9ebde0c75 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -347,6 +347,60 @@ exit: return ret; }
+#ifdef CONFIG_CMD_BOOTEFI_SELFTEST +/** + * bootefi_test_prepare() - prepare to run an EFI test + * + * This sets things up so we can call EFI functions. This involves preparing + * the 'gd' pointer and setting up the load ed image data structures. + * + * @image: Pointer to a struct which will hold the loaded image info + * @obj: Pointer to a struct which will hold the loaded image object + * @path: File path to the test being run (often just the test name with a + * backslash before it + * @test_func: Address of the test function that is being run + * @return 0 if OK, -ve on error + */ +static efi_status_t bootefi_test_prepare(struct efi_loaded_image *image, + struct efi_object *obj, + const char *path, ulong test_func) +{ + memset(image, '\0', sizeof(*image)); + memset(obj, '\0', sizeof(*obj)); + /* Construct a dummy device path */ + bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)test_func, + (uintptr_t)test_func); + bootefi_image_path = efi_dp_from_file(NULL, 0, path); + efi_setup_loaded_image(image, obj, bootefi_device_path, + bootefi_image_path); + /* + * gd lives in a fixed register which may get clobbered while we execute + * the payload. So save it here and restore it on every callback entry + */ + efi_save_gd(); + + /* Transfer environment variable efi_selftest as load options */ + set_load_options(image, "efi_selftest"); + + return 0; +} + +/** + * bootefi_test_finish() - finish up after running an EFI test + * + * @image: Pointer to a struct which holds the loaded image info + * @obj: Pointer to a struct which holds the loaded image object + */ +static void bootefi_test_finish(struct efi_loaded_image *image, + struct efi_object *obj) +{ + efi_restore_gd(); + free(image->load_options); + list_del(&obj->link); +} +#endif /* CONFIG_CMD_BOOTEFI_SELFTEST */ + static int do_bootefi_bootmgr_exec(void) { struct efi_device_path *device_path, *file_path; @@ -425,31 +479,16 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #endif #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { - struct efi_loaded_image loaded_image_info = {}; - struct efi_object loaded_image_info_obj = {}; - - /* Construct a dummy device path. */ - bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, - (uintptr_t)&efi_selftest, - (uintptr_t)&efi_selftest); - bootefi_image_path = efi_dp_from_file(NULL, 0, "\selftest"); - - efi_setup_loaded_image(&loaded_image_info, - &loaded_image_info_obj, - bootefi_device_path, bootefi_image_path); - /* - * gd lives in a fixed register which may get clobbered while we - * execute the payload. So save it here and restore it on every - * callback entry - */ - efi_save_gd(); - /* Transfer environment variable efi_selftest as load options */ - set_load_options(&loaded_image_info, "efi_selftest"); + struct efi_loaded_image image; + struct efi_object obj; + + if (bootefi_test_prepare(&image, &obj, "\selftest", + (uintptr_t)&efi_selftest)) + return CMD_RET_FAILURE; + /* Execute the test */ - r = efi_selftest(loaded_image_info_obj.handle, &systab); - efi_restore_gd(); - free(loaded_image_info.load_options); - list_del(&loaded_image_info_obj.link); + r = efi_selftest(obj.handle, &systab); + bootefi_test_finish(&image, &obj); return r != EFI_SUCCESS; } else #endif
This jumps to test code which can call directly into the EFI support. It does not need a separate image so it is easy to write tests with it.
This test can be executed without causing problems to the run-time environemnt (e.g. U-Boot does not need to reboot afterwards).
For now the test just outputs a message. To try it:
./sandbox/u-boot -c "bootefi test" U-Boot 2017.09-00204-g696c9855fe (Sep 17 2017 - 16:43:53 -0600)
DRAM: 128 MiB MMC: Using default environment
In: serial Out: serial Err: serial SCSI: Net: No ethernet found. IDE: Bus 0: not available Found 0 disks WARNING: booting without device tree Hello, world! Test passed
Changes in v5: None Changes in v4: - Rebase to master - Update SPDX tags
Changes in v3: - Rebase to master
cmd/bootefi.c | 26 ++++++++++++++++++++------ include/efi_loader.h | 3 +++ lib/efi_loader/Kconfig | 10 ++++++++++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_test.c | 16 ++++++++++++++++ 5 files changed, 50 insertions(+), 6 deletions(-) create mode 100644 lib/efi_loader/efi_test.c
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index a9ebde0c75..ac80074bc4 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -347,7 +347,6 @@ exit: return ret; }
-#ifdef CONFIG_CMD_BOOTEFI_SELFTEST /** * bootefi_test_prepare() - prepare to run an EFI test * @@ -399,7 +398,6 @@ static void bootefi_test_finish(struct efi_loaded_image *image, free(image->load_options); list_del(&obj->link); } -#endif /* CONFIG_CMD_BOOTEFI_SELFTEST */
static int do_bootefi_bootmgr_exec(void) { @@ -431,8 +429,10 @@ static int do_bootefi_bootmgr_exec(void) /* Interpreter command to boot an arbitrary EFI image from memory */ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - unsigned long addr; + struct efi_loaded_image image; + struct efi_object obj; char *saddr; + unsigned long addr; efi_status_t r; void *fdt_addr;
@@ -477,11 +477,25 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) memcpy((char *)addr, __efi_helloworld_begin, size); } else #endif + if (IS_ENABLED(CONFIG_BOOTEFI_TEST) && !strcmp(argv[1], "test")) { + int ret; + + if (bootefi_test_prepare(&image, &obj, "\test", + (ulong)&efi_test)) + return CMD_RET_FAILURE; + + ret = efi_test(&image, &systab); + bootefi_test_finish(&image, &obj); + if (ret) { + printf("Test failed: err=%d\n", ret); + return CMD_RET_FAILURE; + } + printf("Test passed\n"); + + return 0; + } #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { - struct efi_loaded_image image; - struct efi_object obj; - if (bootefi_test_prepare(&image, &obj, "\selftest", (uintptr_t)&efi_selftest)) return CMD_RET_FAILURE; diff --git a/include/efi_loader.h b/include/efi_loader.h index c66252a7dd..0615cfac85 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -442,6 +442,9 @@ efi_status_t EFIAPI efi_set_variable(u16 *variable_name, efi_guid_t *vendor, void *efi_bootmgr_load(struct efi_device_path **device_path, struct efi_device_path **file_path);
+/* Perform EFI tests */ +int efi_test(efi_handle_t image_handle, struct efi_system_table *systab); + #else /* defined(EFI_LOADER) && !defined(CONFIG_SPL_BUILD) */
/* Without CONFIG_EFI_LOADER we don't have a runtime section, stub it out */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index d471e6f4a4..110dcb23c9 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -25,3 +25,13 @@ config EFI_LOADER_BOUNCE_BUFFER Some hardware does not support DMA to full 64bit addresses. For this hardware we can create a bounce buffer so that payloads don't have to worry about platform details. + +config BOOTEFI_TEST + bool "Provide a test for the EFI loader" + depends on EFI_LOADER && SANDBOX + default y + help + Provides a test of the EFI loader functionality accessed via the + command line ('bootefi test'). This runs within U-Boot so does not + need a separate EFI application to work. It aims to include coverage + of all EFI code which can be accessed within sandbox. diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index c6046e36d2..2da28f9c90 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -23,3 +23,4 @@ obj-$(CONFIG_DM_VIDEO) += efi_gop.o obj-$(CONFIG_PARTITIONS) += efi_disk.o obj-$(CONFIG_NET) += efi_net.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += efi_smbios.o +obj-$(CONFIG_BOOTEFI_TEST) += efi_test.o diff --git a/lib/efi_loader/efi_test.c b/lib/efi_loader/efi_test.c new file mode 100644 index 0000000000..4b8d49f324 --- /dev/null +++ b/lib/efi_loader/efi_test.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2017, Google Inc. + */ + +#include <common.h> +#include <efi_api.h> + +int efi_test(efi_handle_t image_handle, struct efi_system_table *systable) +{ + struct efi_simple_text_output_protocol *con_out = systable->con_out; + + con_out->output_string(con_out, L"Hello, world!\n"); + + return 0; +}
From Heinrich's comments it sounded like it wouldn't be hard to make the
selftest work. That sounds more appealing to me to be honest :).
Alex
Hi Alex,
From Heinrich's comments it sounded like it wouldn't be hard to make the selftest work. That sounds more appealing to me to be honest :).
Yes and in fact my hope was to run the tests automatically as part of 'make tests'
But rather than expanding the scope of this series, can we get this in first? Having EFI support in sandbox is a substantial step forward.
Hi Alex,
I agree that it would be amazing to have it in, I just want to make sure we're walking into the right direction. And what I want to have is an easy way to execute EFI binaries from user space :).
Also I don't think that sandbox support is all that far off. Heinrich's patch should have resolved compilation, no?
Alex
Hi Alex,
Hi Alex,
That's a different thing entirely from the purpose of my series. My series is designed to allow EFI applications to be *linked* with sandbox and run just like normal C code, with a full unified stack trace, etc.
I think this is a very useful feature separate from running EFI binaries in user space.
I don't know what it entails but Heinrich says there is a memory alignment problem to resolve. I was able to repeat his FAT failure but adding his patch and a few other tweaks.
I'm happy to look at this once we have basic sandbox support available, but if Heinrich wants to take a look, he is welcome to.
On 12.06.18 23:57, Simon Glass wrote:
Hi Alex,
Hi Alex,
I understand that and I agree that it's useful. I just don't want to drive us into a corner where it blocks the other use case.
Alex
HI Alex,
Hi Alex,
Hi Alex,
I don't thing it does. Am I missing something?
I take it you'd like to boot grub on sandbox. I imagine that will take more work, but should be possible.
The primary purpose from my side is to enable easier testing.
Am 14.06.2018 um 17:12 schrieb Simon Glass sjg@chromium.org:
HI Alex,
On 12.06.18 23:57, Simon Glass wrote: Hi Alex,
On 12.06.18 15:48, Simon Glass wrote: Hi Alex,
> On 12.06.18 07:26, Simon Glass wrote: > This jumps to test code which can call directly into the EFI support. It > does not need a separate image so it is easy to write tests with it. > > This test can be executed without causing problems to the run-time > environemnt (e.g. U-Boot does not need to reboot afterwards). > > For now the test just outputs a message. To try it: > > ./sandbox/u-boot -c "bootefi test" > U-Boot 2017.09-00204-g696c9855fe (Sep 17 2017 - 16:43:53 -0600) > > DRAM: 128 MiB > MMC: > Using default environment > > In: serial > Out: serial > Err: serial > SCSI: Net: No ethernet found. > IDE: Bus 0: not available > Found 0 disks > WARNING: booting without device tree > Hello, world! > Test passed > > Signed-off-by: Simon Glass sjg@chromium.org
Anything exposed via efi interfaces has to contain host virtual adresses, as binary payloads are not aware of the virt/phys memory offset.
I tried, it almost works. I guess the aarch64 version could even succeed.
I agree on that part. So let's make sure both use cases get enabled! :)
Alex
Add a new bootefi_run_prepare() function which holds common code used to set up U-Boot to run EFI code. Make use of this from the existing bootefi_test_prepare() function, as well as do_bootefi_exec().
Also shorten a few variable names.
Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi() - Introduce load_options_path to specifyc U-Boot env var for load_options_path
Changes in v3: - Add patch to create a function to set up for running EFI code
Changes in v2: None
cmd/bootefi.c | 79 ++++++++++++++++++++++++++++----------------------- 1 file changed, 43 insertions(+), 36 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index ac80074bc4..eb3ca68a86 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -253,6 +253,26 @@ static efi_status_t efi_install_fdt(void *fdt) return ret; }
+static efi_status_t bootefi_run_prepare(struct efi_loaded_image *image, + struct efi_object *obj, + const char *load_options_path, + struct efi_device_path *device_path, + struct efi_device_path *image_path) +{ + efi_setup_loaded_image(image, obj, device_path, image_path); + + /* + * gd lives in a fixed register which may get clobbered while we execute + * the payload. So save it here and restore it on every callback entry + */ + efi_save_gd(); + + /* Transfer environment variable as load options */ + set_load_options(image, load_options_path); + + return 0; +} + /* * Load an EFI payload into a newly allocated piece of memory, register all * EFI objects it would want to access and jump to it. @@ -261,8 +281,8 @@ static efi_status_t do_bootefi_exec(void *efi, struct efi_device_path *device_path, struct efi_device_path *image_path) { - struct efi_loaded_image loaded_image_info = {}; - struct efi_object loaded_image_info_obj = {}; + struct efi_loaded_image image; + struct efi_object obj; struct efi_device_path *memdp = NULL; efi_status_t ret;
@@ -283,19 +303,13 @@ static efi_status_t do_bootefi_exec(void *efi, assert(device_path && image_path); }
- efi_setup_loaded_image(&loaded_image_info, &loaded_image_info_obj, - device_path, image_path); + ret = bootefi_run_prepare(&image, &obj, "bootargs", device_path, + image_path); + if (ret) + return ret;
- /* - * gd lives in a fixed register which may get clobbered while we execute - * the payload. So save it here and restore it on every callback entry - */ - efi_save_gd(); - - /* Transfer environment variable bootargs as load options */ - set_load_options(&loaded_image_info, "bootargs"); /* Load the EFI payload */ - entry = efi_load_pe(efi, &loaded_image_info); + entry = efi_load_pe(efi, &image); if (!entry) { ret = EFI_LOAD_ERROR; goto exit; @@ -303,10 +317,10 @@ static efi_status_t do_bootefi_exec(void *efi,
if (memdp) { struct efi_device_path_memory *mdp = (void *)memdp; - mdp->memory_type = loaded_image_info.image_code_type; - mdp->start_address = (uintptr_t)loaded_image_info.image_base; + mdp->memory_type = image.image_code_type; + mdp->start_address = (uintptr_t)image.image_base; mdp->end_address = mdp->start_address + - loaded_image_info.image_size; + image.image_size; }
/* we don't support much: */ @@ -316,8 +330,8 @@ static efi_status_t do_bootefi_exec(void *efi, /* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
- if (setjmp(&loaded_image_info.exit_jmp)) { - ret = loaded_image_info.exit_status; + if (setjmp(&image.exit_jmp)) { + ret = image.exit_status; goto exit; }
@@ -329,7 +343,7 @@ static efi_status_t do_bootefi_exec(void *efi,
/* Move into EL2 and keep running there */ armv8_switch_to_el2((ulong)entry, - (ulong)&loaded_image_info_obj.handle, + (ulong)&obj.handle, (ulong)&systab, 0, (ulong)efi_run_in_el2, ES_TO_AARCH64);
@@ -338,11 +352,11 @@ static efi_status_t do_bootefi_exec(void *efi, } #endif
- ret = efi_do_enter(loaded_image_info_obj.handle, &systab, entry); + ret = efi_do_enter(obj.handle, &systab, entry);
exit: /* image has returned, loaded-image obj goes *poof*: */ - list_del(&loaded_image_info_obj.link); + list_del(&obj.link);
return ret; } @@ -358,11 +372,13 @@ exit: * @path: File path to the test being run (often just the test name with a * backslash before it * @test_func: Address of the test function that is being run + * @load_options_path: U-Boot environment variable to use as load options * @return 0 if OK, -ve on error */ static efi_status_t bootefi_test_prepare(struct efi_loaded_image *image, struct efi_object *obj, - const char *path, ulong test_func) + const char *path, ulong test_func, + const char *load_options_path) { memset(image, '\0', sizeof(*image)); memset(obj, '\0', sizeof(*obj)); @@ -371,18 +387,8 @@ static efi_status_t bootefi_test_prepare(struct efi_loaded_image *image, (uintptr_t)test_func, (uintptr_t)test_func); bootefi_image_path = efi_dp_from_file(NULL, 0, path); - efi_setup_loaded_image(image, obj, bootefi_device_path, - bootefi_image_path); - /* - * gd lives in a fixed register which may get clobbered while we execute - * the payload. So save it here and restore it on every callback entry - */ - efi_save_gd(); - - /* Transfer environment variable efi_selftest as load options */ - set_load_options(image, "efi_selftest"); - - return 0; + return bootefi_run_prepare(image, obj, load_options_path, + bootefi_device_path, bootefi_image_path); }
/** @@ -481,7 +487,7 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) int ret;
if (bootefi_test_prepare(&image, &obj, "\test", - (ulong)&efi_test)) + (ulong)&efi_test, "efi_test")) return CMD_RET_FAILURE;
ret = efi_test(&image, &systab); @@ -497,7 +503,8 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { if (bootefi_test_prepare(&image, &obj, "\selftest", - (uintptr_t)&efi_selftest)) + (uintptr_t)&efi_selftest), + "efi_selftest") return CMD_RET_FAILURE;
This function can be used from do_bootefi_exec() so that we use mostly the same code for a normal EFI application and an EFI test.
Rename the function and use it in both places.
Changes in v5: - Rebase to master
Changes in v3: - Add new patch to rename bootefi_test_finish() to bootefi_run_finish()
Changes in v2: None
cmd/bootefi.c | 35 +++++++++++++++++------------------ 1 file changed, 17 insertions(+), 18 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index eb3ca68a86..7f767aed42 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -273,6 +273,20 @@ static efi_status_t bootefi_run_prepare(struct efi_loaded_image *image, return 0; }
+/** + * bootefi_run_finish() - finish up after running an EFI test + * + * @image: Pointer to a struct which holds the loaded image info + * @obj: Pointer to a struct which holds the loaded image object + */ +static void bootefi_run_finish(struct efi_loaded_image *image, + struct efi_object *obj) +{ + efi_restore_gd(); + free(image->load_options); + list_del(&obj->link); +} + /* * Load an EFI payload into a newly allocated piece of memory, register all * EFI objects it would want to access and jump to it. @@ -355,8 +369,7 @@ static efi_status_t do_bootefi_exec(void *efi, ret = efi_do_enter(obj.handle, &systab, entry);
exit: - /* image has returned, loaded-image obj goes *poof*: */ - list_del(&obj.link); + bootefi_run_finish(&image, &obj);
return ret; } @@ -391,20 +404,6 @@ static efi_status_t bootefi_test_prepare(struct efi_loaded_image *image, bootefi_device_path, bootefi_image_path); }
-/** - * bootefi_test_finish() - finish up after running an EFI test - * - * @image: Pointer to a struct which holds the loaded image info - * @obj: Pointer to a struct which holds the loaded image object - */ -static void bootefi_test_finish(struct efi_loaded_image *image, - struct efi_object *obj) -{ - efi_restore_gd(); - free(image->load_options); - list_del(&obj->link); -} - static int do_bootefi_bootmgr_exec(void) { struct efi_device_path *device_path, *file_path; @@ -491,7 +490,7 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_FAILURE;
ret = efi_test(&image, &systab); - bootefi_test_finish(&image, &obj); + bootefi_run_finish(&image, &obj); if (ret) { printf("Test failed: err=%d\n", ret); return CMD_RET_FAILURE; @@ -509,7 +508,7 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* Execute the test */ r = efi_selftest(obj.handle, &systab); - bootefi_test_finish(&image, &obj); + bootefi_run_finish(&image, &obj); return r != EFI_SUCCESS; } else #endif
At present 'buildman sandbox' will build all 5 boards for the sandbox architecture rather than the single board 'sandbox'. The only current way to exclude sandbox_spl, sandbox_noblk, etc. is to use -x which is a bit clumbsy.
Add a --boards option to allow individual build targets to be specified.
tools/buildman/README | 12 +++++++++++- tools/buildman/board.py | 28 ++++++++++++++++++++++++---- tools/buildman/cmdline.py | 4 +++- tools/buildman/control.py | 20 +++++++++++++++++--- tools/buildman/test.py | 31 +++++++++++++++++-------------- 5 files changed, 72 insertions(+), 23 deletions(-)
diff --git a/tools/buildman/README b/tools/buildman/README index 76601902cb..5a709c6ff9 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -114,6 +114,10 @@ a few commits or boards, it will be pretty slow. As a tip, if you don't plan to use your machine for anything else, you can use -T to increase the number of threads beyond the default.
+ +Selecting which boards to build +=============================== + Buildman lets you build all boards, or a subset. Specify the subset by passing command-line arguments that list the desired board name, architecture name, SOC name, or anything else in the boards.cfg file. Multiple arguments are @@ -138,11 +142,17 @@ You can also use -x to specifically exclude some boards. For example: means to build all arm boards except nvidia, freescale and anything ending with 'ball'.
+For building specific boards you can use the --boards option, which takes a +comma-separated list of board target names and be used multiple times on +the command line: + + buidman --boards sandbox,snow --boards + It is convenient to use the -n option to see what will be built based on the subset given. Use -v as well to get an actual list of boards.
Buildman does not store intermediate object files. It optionally copies -the binary output into a directory when a build is successful. Size +the binary output into a directory when a build is successful (-k). Size information is always recorded. It needs a fair bit of disk space to work, typically 250MB per thread.
diff --git a/tools/buildman/board.py b/tools/buildman/board.py index 272bac0c21..2a1d021574 100644 --- a/tools/buildman/board.py +++ b/tools/buildman/board.py @@ -237,20 +237,30 @@ class Boards: terms.append(term) return terms
- def SelectBoards(self, args, exclude=[]): + def SelectBoards(self, args, exclude=[], boards=None): """Mark boards selected based on args
+ Normally either boards (an explicit list of boards) or args (a list of + terms to match against) is used. It is possible to specify both, in + which case they are additive. + + If boards and args are both empty, all boards are selected. + Args: args: List of strings specifying boards to include, either named, or by their target, architecture, cpu, vendor or soc. If empty, all boards are selected. exclude: List of boards to exclude, regardless of 'args' + boards: List of boards to build
Returns: - Dictionary which holds the list of boards which were selected - due to each argument, arranged by argument. + Tuple + Dictionary which holds the list of boards which were selected + due to each argument, arranged by argument. + List of errors found """ result = {} + warnings = [] terms = self._BuildTerms(args)
result['all'] = [] @@ -261,6 +271,7 @@ class Boards: for expr in exclude: exclude_list.append(Expr(expr))
+ found = [] for board in self._boards: matching_term = None build_it = False @@ -271,6 +282,10 @@ class Boards: matching_term = str(term) build_it = True break + elif boards: + if board.target in boards: + build_it = True + found.append(board.target) else: build_it = True
@@ -286,4 +301,9 @@ class Boards: result[matching_term].append(board.target) result['all'].append(board.target)
- return result + if boards: + remaining = set(boards) - set(found) + if remaining: + warnings.append('Boards not found: %s\n' % ', '.join(remaining)) + + return result, warnings diff --git a/tools/buildman/cmdline.py b/tools/buildman/cmdline.py index e493b1ac4a..49a8a13118 100644 --- a/tools/buildman/cmdline.py +++ b/tools/buildman/cmdline.py @@ -18,6 +18,8 @@ def ParseArgs(): parser.add_option('-B', '--bloat', dest='show_bloat', action='store_true', default=False, help='Show changes in function code size for each board') + parser.add_option('--boards', type='string', action='append', + help='List of board names to build separated by comma') parser.add_option('-c', '--count', dest='count', type='int', default=-1, help='Run build on the top n commits') parser.add_option('-C', '--force-reconfig', dest='force_reconfig', @@ -102,7 +104,7 @@ def ParseArgs(): type='string', action='append', help='Specify a list of boards to exclude, separated by comma')
- parser.usage += """ + parser.usage += """ [list of target/arch/cpu/board/vendor/soc to build]
Build U-Boot for all commits in a branch. Use -n to do a dry run"""
diff --git a/tools/buildman/control.py b/tools/buildman/control.py index bc0819784f..96f8ccfe07 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -41,7 +41,8 @@ def GetActionSummary(is_summary, commits, selected, options): GetPlural(options.threads), options.jobs, GetPlural(options.jobs)) return str
-def ShowActions(series, why_selected, boards_selected, builder, options): +def ShowActions(series, why_selected, boards_selected, builder, options, + board_warnings): """Display a list of actions that we would take, if not a dry run.
Args: @@ -55,6 +56,7 @@ def ShowActions(series, why_selected, boards_selected, builder, options): value is Board object builder: The builder that will be used to build the commits options: Command line options object + board_warnings: List of warnings obtained from board selected """ col = terminal.Color() print 'Dry run, so not doing much. But I would do this:' @@ -79,6 +81,9 @@ def ShowActions(series, why_selected, boards_selected, builder, options): print ' %s' % ' '.join(why_selected[arg]) print ('Total boards to build for each commit: %d\n' % len(why_selected['all'])) + if board_warnings: + for warning in board_warnings: + print col.Color(col.YELLOW, warning)
def CheckOutputDir(output_dir): """Make sure that the output directory is not within the current directory @@ -210,7 +215,15 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None, for arg in options.exclude: exclude += arg.split(',')
- why_selected = boards.SelectBoards(args, exclude) + + if options.boards: + requested_boards = [] + for b in options.boards: + requested_boards += b.split(',') + else: + requested_boards = None + why_selected, board_warnings = boards.SelectBoards(args, exclude, + requested_boards) selected = boards.GetSelected() if not len(selected): sys.exit(col.Color(col.RED, 'No matching boards found')) @@ -292,7 +305,8 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None,
# For a dry run, just show our actions as a sanity check if options.dry_run: - ShowActions(series, why_selected, selected, builder, options) + ShowActions(series, why_selected, selected, builder, options, + board_warnings) else: builder.force_build = options.force_build builder.force_build_failures = options.force_build_failures diff --git a/tools/buildman/test.py b/tools/buildman/test.py index c36bcdf6fb..e9a4ffa024 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -312,60 +312,63 @@ class TestBuild(unittest.TestCase): def testBoardSingle(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['sandbox']), - {'all': ['board4'], 'sandbox': ['board4']}) + ({'all': ['board4'], 'sandbox': ['board4']}, []))
def testBoardArch(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['arm']), - {'all': ['board0', 'board1'], - 'arm': ['board0', 'board1']}) + ({'all': ['board0', 'board1'], + 'arm': ['board0', 'board1']}, []))
def testBoardArchSingle(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['arm sandbox']), - {'sandbox': ['board4'], + ({'sandbox': ['board4'], 'all': ['board0', 'board1', 'board4'], - 'arm': ['board0', 'board1']}) + 'arm': ['board0', 'board1']}, []))
def testBoardArchSingleMultiWord(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['arm', 'sandbox']), - {'sandbox': ['board4'], 'all': ['board0', 'board1', 'board4'], 'arm': ['board0', 'board1']}) + ({'sandbox': ['board4'], + 'all': ['board0', 'board1', 'board4'], + 'arm': ['board0', 'board1']}, []))
def testBoardSingleAnd(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['Tester & arm']), - {'Tester&arm': ['board0', 'board1'], 'all': ['board0', 'board1']}) + ({'Tester&arm': ['board0', 'board1'], + 'all': ['board0', 'board1']}, []))
def testBoardTwoAnd(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['Tester', '&', 'arm', 'Tester' '&', 'powerpc', 'sandbox']), - {'sandbox': ['board4'], + ({'sandbox': ['board4'], 'all': ['board0', 'board1', 'board2', 'board3', 'board4'], 'Tester&powerpc': ['board2', 'board3'], - 'Tester&arm': ['board0', 'board1']}) + 'Tester&arm': ['board0', 'board1']}, []))
def testBoardAll(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards([]), - {'all': ['board0', 'board1', 'board2', 'board3', - 'board4']}) + ({'all': ['board0', 'board1', 'board2', 'board3', + 'board4']}, []))
def testBoardRegularExpression(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['T.*r&^Po']), - {'all': ['board2', 'board3'], - 'T.*r&^Po': ['board2', 'board3']}) + ({'all': ['board2', 'board3'], + 'T.*r&^Po': ['board2', 'board3']}, []))
def testBoardDuplicate(self): """Test single board selection""" self.assertEqual(self.boards.SelectBoards(['sandbox sandbox', 'sandbox']), - {'all': ['board4'], 'sandbox': ['board4']}) + ({'all': ['board4'], 'sandbox': ['board4']}, [])) def CheckDirs(self, build, dirname): self.assertEqual('base%s' % dirname, build._GetOutputDir(1)) self.assertEqual('base%s/fred' % dirname,
Applied to u-boot-dm.
Alexander Graf
