[PATCH 1/2] watchdog: Add a driver for the photonicat watchdog
This driver supports the photonicat watchdog timers.
Signed-off-by: Coia Prant coiaprant@gmail.com --- drivers/watchdog/Kconfig | 6 + drivers/watchdog/Makefile | 1 + drivers/watchdog/pcat_wdt.c | 218 ++++++++++++++++++++++++++++++++++++ 3 files changed, 225 insertions(+) create mode 100644 drivers/watchdog/pcat_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 0c3e9913..f0a52ecf 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -421,4 +421,10 @@ config WDT_FTWDT010 help Faraday Technology ftwdt010 watchdog is an architecture independent watchdog. It is usually used in SoC chip design. + +config WDT_PCAT + bool "photonicat board watchdog support" + depends on WDT && SERIAL && DM + help + Select this to enable watchdog timer on photonicat board. endmenu diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 7b39adcf..829b5ed1 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -50,3 +50,4 @@ obj-$(CONFIG_WDT_STM32MP) += stm32mp_wdt.o obj-$(CONFIG_WDT_SUNXI) += sunxi_wdt.o obj-$(CONFIG_WDT_TANGIER) += tangier_wdt.o obj-$(CONFIG_WDT_XILINX) += xilinx_wwdt.o +obj-$(CONFIG_WDT_PCAT) += pcat_wdt.o \ No newline at end of file diff --git a/drivers/watchdog/pcat_wdt.c b/drivers/watchdog/pcat_wdt.c new file mode 100644 index 00000000..cac07fb6 --- /dev/null +++ b/drivers/watchdog/pcat_wdt.c @@ -0,0 +1,218 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <dm.h> +#include <dm/device_compat.h> +#include <wdt.h> +#include <asm/gpio.h> +#include <linux/delay.h> +#include <serial.h> +#include <dm/device-internal.h> + +struct pcat_wdt_priv +{ + struct udevice *serial_dev; + struct dm_serial_ops *serial_ops; + uint16_t packet_count; +}; + +static uint16_t pcat_pmu_serial_compute_crc16(const uint8_t *data, + size_t len) +{ + uint16_t crc = 0xFFFF; + size_t i; + unsigned int j; + + for (i = 0; i < len; i++) + { + crc ^= data[i]; + for (j = 0; j < 8; j++) + { + if (crc & 1) + { + crc = (crc >> 1) ^ 0xA001; + } + else + { + crc >>= 1; + } + } + } + + return crc; +} + +static int pcat_wdt_reset(struct udevice *dev) +{ + struct pcat_wdt_priv *priv = dev_get_priv(dev); + uint8_t packet[13] = "\xA5\x01\x81\x00\x00\x03\x00\x01\x00" + "\x00\x00\x00\x5A"; + uint16_t crc; + int err = 0; + unsigned int i; + + packet[3] = priv->packet_count & 0xFF; + packet[4] = (priv->packet_count >> 8) & 0xFF; + priv->packet_count++; + + crc = pcat_pmu_serial_compute_crc16(packet + 1, 9); + packet[10] = crc & 0xFF; + packet[11] = (crc >> 8) & 0xFF; + + i = 0; + while (i < 13) + { + err = priv->serial_ops->putc( + priv->serial_dev, ((const char *)packet)[i]); + if (!err) + { + i++; + } + else if (err == -EAGAIN) + { + ; + } + else + { + pr_err("%s: unable to send watchdog setup " + "request: %d\n", + __func__, err); + break; + } + } + return err; +} + +static int pcat_wdt_setup(struct pcat_wdt_priv *priv, u64 timeout) +{ + uint8_t packet[16] = "\xA5\x01\x81\x00\x00\x06\x00\x13\x00" + "\x3C\x3C\x00\x00\x00\x00\x5A"; + uint16_t crc; + int err = 0; + unsigned int i; + + if (timeout > 255) + { + pr_warn("%s: timeout cannot be more than 255s\n", + __func__); + timeout = 255; + } + + packet[3] = priv->packet_count & 0xFF; + packet[4] = (priv->packet_count >> 8) & 0xFF; + priv->packet_count++; + packet[11] = timeout & 0xFF; + + crc = pcat_pmu_serial_compute_crc16(packet + 1, 12); + packet[13] = crc & 0xFF; + packet[14] = (crc >> 8) & 0xFF; + + i = 0; + while (i < 16) + { + err = priv->serial_ops->putc( + priv->serial_dev, ((const char *)packet)[i]); + if (!err) + { + i++; + } + else if (err == -EAGAIN) + { + ; + } + else + { + pr_err("%s: unable to send watchdog setup " + "request: %d\n", + __func__, err); + break; + } + } + + return err; +} + +static int pcat_wdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct pcat_wdt_priv *priv = dev_get_priv(dev); + + pcat_wdt_setup(priv, timeout); + + return 0; +} + +static int pcat_wdt_stop(struct udevice *dev) +{ + struct pcat_wdt_priv *priv = dev_get_priv(dev); + + pcat_wdt_setup(priv, 0); + + return 0; +} + +static int dm_probe(struct udevice *dev) +{ + struct pcat_wdt_priv *priv = dev_get_priv(dev); + struct udevice *serial_dev = NULL; + struct dm_serial_ops *ops; + int ret; + + ret = uclass_get_device_by_phandle(UCLASS_SERIAL, dev, "port", + &serial_dev); + if (ret) + { + pr_err("%s: unable to find serial port device: %d\n", + __func__, ret); + return ret; + } + + ret = device_probe(serial_dev); + if (ret) + { + pr_err("%s: unable to probe serial port device: %d\n", + __func__, ret); + return ret; + } + + ops = serial_get_ops(serial_dev); + if (!ops) + { + printf("Cannot get ops for PMU serial port!\n"); + return -EINVAL; + } + + if (ops->setconfig) + { + ops->setconfig(serial_dev, SERIAL_DEFAULT_CONFIG); + } + if (ops->setbrg) + { + ops->setbrg(serial_dev, 115200); + } + + priv->serial_dev = serial_dev; + priv->serial_ops = ops; + priv->packet_count = 0; + + pcat_wdt_stop(dev); + + return 0; +} + +static const struct wdt_ops pcat_wdt_ops = { + .start = pcat_wdt_start, + .reset = pcat_wdt_reset, + .stop = pcat_wdt_stop, +}; + +static const struct udevice_id pcat_wdt_ids[] = { + {.compatible = "linux,wdt-pcat"}, + {}}; + +U_BOOT_DRIVER(wdt_pcat) = { + .name = "wdt_pcat", + .id = UCLASS_WDT, + .of_match = pcat_wdt_ids, + .ops = &pcat_wdt_ops, + .probe = dm_probe, + .priv_auto = sizeof(struct pcat_wdt_priv), +}; \ No newline at end of file
Why did you send this driver twice? Please send only 1/1 patch next time.
+config WDT_PCAT
- bool "photonicat board watchdog support"
- depends on WDT && SERIAL && DM
- help
What is a "photonicat board"? Which SoC is used? Manufacturer?
And empty line missing here?
Please sort alphabetically.
Sorting of header includes looks not correct.
- struct udevice *serial_dev;
- struct dm_serial_ops *serial_ops;
- uint16_t packet_count;
size_t len)
alignment?
- uint16_t crc = 0xFFFF;
- size_t i;
- unsigned int j;
- for (i = 0; i < len; i++)
Coding style is wrong. Please use Linux coding style with U-Boot code as well. scripts/checkpatch.pl will help you finding issues.
I'll stop the review here and will continue, once you've sent v2.
Thanks, Stefan
crc ^= data[i];
if (crc & 1)
else
crc >>= 1;
- return crc;
- struct pcat_wdt_priv *priv = dev_get_priv(dev);
- uint8_t packet[13] = "\xA5\x01\x81\x00\x00\x03\x00\x01\x00"
"\x00\x00\x00\x5A";
- uint16_t crc;
- int err = 0;
- unsigned int i;
- packet[3] = priv->packet_count & 0xFF;
- packet[4] = (priv->packet_count >> 8) & 0xFF;
- priv->packet_count++;
- crc = pcat_pmu_serial_compute_crc16(packet + 1, 9);
- packet[10] = crc & 0xFF;
- packet[11] = (crc >> 8) & 0xFF;
- i = 0;
- while (i < 13)
if (!err)
i++;
else
"request: %d\n",
__func__, err);
break;
- return err;
- uint8_t packet[16] = "\xA5\x01\x81\x00\x00\x06\x00\x13\x00"
- uint16_t crc;
- int err = 0;
- unsigned int i;
- if (timeout > 255)
__func__);
timeout = 255;
- packet[11] = timeout & 0xFF;
- crc = pcat_pmu_serial_compute_crc16(packet + 1, 12);
- packet[13] = crc & 0xFF;
- packet[14] = (crc >> 8) & 0xFF;
- i = 0;
- while (i < 16)
if (!err)
i++;
else
"request: %d\n",
__func__, err);
break;
- return err;
- pcat_wdt_setup(priv, timeout);
- pcat_wdt_setup(priv, 0);
- struct udevice *serial_dev = NULL;
- struct dm_serial_ops *ops;
- int ret;
- ret = uclass_get_device_by_phandle(UCLASS_SERIAL, dev, "port",
&serial_dev);
- if (ret)
__func__, ret);
return ret;
- ret = device_probe(serial_dev);
- if (ret)
__func__, ret);
return ret;
- ops = serial_get_ops(serial_dev);
- if (!ops)
return -EINVAL;
- if (ops->setconfig)
- if (ops->setbrg)
- priv->serial_dev = serial_dev;
- priv->serial_ops = ops;
- priv->packet_count = 0;
- pcat_wdt_stop(dev);
- .start = pcat_wdt_start,
- .reset = pcat_wdt_reset,
- .stop = pcat_wdt_stop,
- {.compatible = "linux,wdt-pcat"},
- .name = "wdt_pcat",
- .id = UCLASS_WDT,
- .of_match = pcat_wdt_ids,
- .ops = &pcat_wdt_ops,
- .probe = dm_probe,
- .priv_auto = sizeof(struct pcat_wdt_priv),
Viele Grüße, Stefan Roese
Coia Prant
Stefan Roese
