[U-Boot] [PATCH] mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver
This is based on Linux kernel -next:
commit a1256b0e087ed3cdb584c683acb966ee885f733c Author: Brian Norris computersforpeace@gmail.com Date: Fri Jul 13 09:28:24 2012 -0700
The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It silently masks off at least one flag that might be set by the driver (NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly others.
Really, as long as driver writers exercise a small amount of care with NAND_* options, this mask is not necessary at all; it was only here to prevent certain options from accidentally being set by the driver. But the original thought turns out to be a bad idea occasionally. Thus, kill it.
Note, this patch fixes some major gpmi-nand breakage.
Signed-off-by: Marek Vasut marex@denx.de Cc: Brian Norris computersforpeace@gmail.com Cc: Eric Nelson eric.nelson@boundarydevices.com Cc: Fabio Estevam festevam@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Scott Wood scottwood@freescale.com --- drivers/mtd/nand/nand_base.c | 7 ++----- include/linux/mtd/nand.h | 3 --- 2 files changed, 2 insertions(+), 8 deletions(-)
NOTE: Please test before applying, I'd like to know it doesn't cause breakage.
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index bfd668f..658b3ad 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2578,9 +2578,7 @@ static int nand_flash_detect_onfi(struct mtd_info *mtd, struct nand_chip *chip, if (le16_to_cpu(p->features) & 1) *busw = NAND_BUSWIDTH_16;
- chip->options &= ~NAND_CHIPOPTIONS_MSK; - chip->options |= (NAND_NO_READRDY | - NAND_NO_AUTOINCR) & NAND_CHIPOPTIONS_MSK; + chip->options |= NAND_NO_READRDY | NAND_NO_AUTOINCR;
return 1; } @@ -2752,8 +2750,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, } } /* Get chip options, preserve non chip based options */ - chip->options &= ~NAND_CHIPOPTIONS_MSK; - chip->options |= type->options & NAND_CHIPOPTIONS_MSK; + chip->options |= type->options;
/* Check if chip is a not a samsung device. Do not clear the * options for chips which are not having an extended id. diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 82704de..0a5aa64 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -205,9 +205,6 @@ typedef enum { #define NAND_SUBPAGE_READ(chip) ((chip->ecc.mode == NAND_ECC_SOFT) \ && (chip->page_shift > 9))
-/* Mask to zero out the chip options, which come from the id table */ -#define NAND_CHIPOPTIONS_MSK (0x0000ffff & ~NAND_NO_AUTOINCR) - /* Non chip related options */ /* * Use a flash based bad block table. OOB identifier is saved in OOB area.
Dear Marek Vasut,
mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs.
NOTE2: This fixes UBI on MX28, MX6Q and soon-to-be MX233 GPMI NAND. Thanks again, Brian!
return 1;
- options for chips which are not having an extended id.
- Use a flash based bad block table. OOB identifier is saved in OOB area.
Best regards, Marek Vasut
mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It silently masks off at least one flag that might be set by the driver (NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly others. Really, as long as driver writers exercise a small amount of care with NAND_* options, this mask is not necessary at all; it was only here to prevent certain options from accidentally being set by the driver. But the original thought turns out to be a bad idea occasionally. Thus, kill it. Note, this patch fixes some major gpmi-nand breakage.
Hi Marek,
This fixes the same issue on the ea20 (davinci), and drop the painful NAND_CHIPOPTIONS_MSK. Thanks !
Regards, Stefano
Dear Stefano Babic,
Hi Marek,
I'm glad. I hope I didn't infringe anything with this patch and that I properly followed this "porting Linux patches" procedure.
Regards, Stefano
Applied to u-boot-nand-flash with the SHA1 updated based on current linux-next: 14f44abf1dafc20ba42ce8616a8fc8fbd1b3712b
-Scott
Dear Scott Wood,
Thanks ... I think the sha1 is irrelevant as next is being constantly rebased anyway :/
btw. this should definitelly go to current release.
On 09/17/2012 07:01:39 PM, Marek Vasut wrote:
Dear Scott Wood,
real
set by
driver
care
was only
by the
They're at -rc6 or so, so maybe this'll be the final one. :-)
The SHA1 should only change if the tree it was pulled from got rebased.
Yes.
-Scott
Scott Wood
Stefano Babic
