[U-Boot] [U-BOOT] mmc: sdhci: Enable 8-bit bus width only for 3.0 spec onwards
CAP register don't have any information for 8-bit buswidth support on 2.0 sdhci spec, only from 3.0 onwards bit[18] got this information.
Due to this misassignment in sdhci, mmc is setting 8-bit buswidth using mmc_set_bus_width even if controller doesn't support. Below change has code information. "mmc: Properly determine maximum supported bus width" (sha1: 7798f6dbd5e1a3030ed81a81da5dfb57c3307cac)
Bug log: <mmc plus and emmc cards) ------- zynq-uboot> mmcinfo Error detected in status(0x208100)! Device: zynq_sdhci Manufacturer ID: fe .....
So enable 8-bit support only for 3.0 spec using CAP and for below 3.0 assign mmc->host_caps = MMC_MODE_8BIT on respective platform driver if host have a support.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mmc/sdhci.c | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 1eaea04..c5631bf 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -486,8 +486,10 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) mmc->voltages |= host->voltages;
mmc->host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT; - if (caps & SDHCI_CAN_DO_8BIT) - mmc->host_caps |= MMC_MODE_8BIT; + if ((host->version & SDHCI_SPEC_VER_MASK) >= SDHCI_SPEC_300) { + if (caps & SDHCI_CAN_DO_8BIT) + mmc->host_caps |= MMC_MODE_8BIT; + } if (host->host_caps) mmc->host_caps |= host->host_caps;
On Tue, May 21, 2013 at 03:01:36PM +0530, Jagannadha Sutradharudu Teki wrote:
Applied, thanks.
Andy
Andy Fleming
