[U-Boot] [PATCH] at91: change CONFIG_SYS_HZ to 1000
It seems that resistance is futile... Nearly all boards now use a value of 1000 for CONFIG_SYS_HZ, and a commit from Oct 1 last year in the net code breaks all boards silently that have a different value. So here's a patch for the at91 arm926ejs CPUs and boards that changes get_timer and get_ticks to return milliseconds. This will break boards that are not in the tree but use such CPUs, but at least it'll break them loudly.
Detlef
CHANGELOG: Change at91 CPUs based on arm926ejs to return milliseconds from get_timer and get_ticks. Also changes in the value of CONFIG_SYS_HZ to 1000 in all board configs using these CPUs. This will not compile on boards using these CPUs with a different value for CONFIG_SYS_HZ.
diff -Nrup u-boot-2009.03-rc1.orig/cpu/arm926ejs/at91/timer.c u-boot-2009.03-rc1/cpu/arm926ejs/at91/timer.c --- u-boot-2009.03-rc1.orig/cpu/arm926ejs/at91/timer.c 2009-02-23 00:22:21.000000000 +0100 +++ u-boot-2009.03-rc1/cpu/arm926ejs/at91/timer.c 2009-02-24 14:58:47.000000000 +0100 @@ -30,6 +30,19 @@ #include <asm/arch/io.h>
/* + * This code essentially ignores the settings of AT91_MASTER_CLOCK + * and CONFIG_SYS_HZ, so we just bail out if they're not set to + * the canonical values. + */ +#if (CONFIG_SYS_HZ != 1000) +#error "CONFIG_SYS_HZ must be set to 1000 for this CPU" +#endif +/* We leave some leeway for the master clock... */ +#if (AT91_MASTER_CLOCK < 85000000) || (AT91_MASTER_CLOCK > 115000000) +#error "AT91_MASTER_CLOCK must be set to 100000000 for this CPU" +#endif + +/* * We're using the AT91CAP9/SAM9 PITC in 32 bit mode, by * setting the 20 bit counter period to its maximum (0xfffff). */ @@ -38,6 +51,7 @@ #define READ_TIMER at91_sys_read(AT91_PIT_PIIR) #define TIMER_FREQ (AT91C_MASTER_CLOCK << 4) #define TICKS_TO_USEC(ticks) ((ticks) / 6) +#define TICKS_TO_MSEC(ticks) ((ticks) / 6250)
ulong get_timer_masked(void); ulong resettime; @@ -73,6 +87,21 @@ static inline ulong get_timer_raw(void) return 0xFFFFFFFFUL - (resettime - now) ; }
+static inline ulong get_timer_masked_usec(void) +{ + return TICKS_TO_USEC(get_timer_raw()); +} + +static inline ulong get_timer_usec(ulong base) +{ + ulong now = get_timer_masked_usec(); + + if (now >= base) + return now - base; + else + return TICKS_TO_USEC(0xFFFFFFFFUL) - (base - now) ; +} + void reset_timer_masked(void) { resettime = READ_TIMER; @@ -80,7 +109,7 @@ void reset_timer_masked(void)
ulong get_timer_masked(void) { - return TICKS_TO_USEC(get_timer_raw()); + return TICKS_TO_MSEC(get_timer_raw());
@@ -88,8 +117,8 @@ void udelay_masked(unsigned long usec) { ulong tmp;
- tmp = get_timer(0); - while (get_timer(tmp) < usec) /* our timer works in usecs */ + tmp = get_timer_usec(0); + while (get_timer_usec(tmp) < usec) ; /* NOP */ }
@@ -105,7 +134,7 @@ ulong get_timer(ulong base) if (now >= base) return now - base; else - return TICKS_TO_USEC(0xFFFFFFFFUL) - (base - now) ; + return TICKS_TO_MSEC(0xFFFFFFFFUL) - (base - now) ; }
void udelay(unsigned long usec) diff -Nrup u-boot-2009.03-rc1.orig/include/configs/afeb9260.h u-boot-2009.03-rc1/include/configs/afeb9260.h --- u-boot-2009.03-rc1.orig/include/configs/afeb9260.h 2009-02-23 00:22:21.000000000 +0100 +++ u-boot-2009.03-rc1/include/configs/afeb9260.h 2009-02-24 15:00:19.000000000 +0100 @@ -30,7 +30,7 @@ #define AT91_MAIN_CLOCK 18429952 /* from 18.432 MHz crystal */ #define AT91_MASTER_CLOCK 89999598 /* peripheral = main / 2 */ #define CONFIG_SYS_AT91_PLLB 0x107c3e18 /* PLLB settings for USB */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define CONFIG_SYS_HZ 1000 /* 1ms resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */
diff -Nrup u-boot-2009.03-rc1.orig/include/configs/at91cap9adk.h u-boot-2009.03-rc1/include/configs/at91cap9adk.h --- u-boot-2009.03-rc1.orig/include/configs/at91cap9adk.h 2009-02-23 00:22:21.000000000 +0100 +++ u-boot-2009.03-rc1/include/configs/at91cap9adk.h 2009-02-24 15:00:07.000000000 +0100 @@ -33,7 +33,7 @@ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ #define CONFIG_SYS_AT91_PLLB 0x10073e01 /* PLLB settings for USB */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define CONFIG_SYS_HZ 1000 /* 1ms resolution */
diff -Nrup u-boot-2009.03-rc1.orig/include/configs/at91sam9260ek.h u-boot-2009.03-rc1/include/configs/at91sam9260ek.h --- u-boot-2009.03-rc1.orig/include/configs/at91sam9260ek.h 2009-02-23 00:22:21.000000000 +0100 +++ u-boot-2009.03-rc1/include/configs/at91sam9260ek.h 2009-02-24 15:01:22.000000000 +0100 @@ -33,7 +33,7 @@ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ #define CONFIG_SYS_AT91_PLLB 0x107c3e18 /* PLLB settings for USB */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define CONFIG_SYS_HZ 1000 /* 1ms resolution */
diff -Nrup u-boot-2009.03-rc1.orig/include/configs/at91sam9261ek.h u-boot-2009.03-rc1/include/configs/at91sam9261ek.h --- u-boot-2009.03-rc1.orig/include/configs/at91sam9261ek.h 2009-02-23 00:22:21.000000000 +0100 +++ u-boot-2009.03-rc1/include/configs/at91sam9261ek.h 2009-02-24 15:02:55.000000000 +0100 @@ -32,7 +32,7 @@ #define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define CONFIG_SYS_HZ 1000 /* 1ms resolution */
diff -Nrup u-boot-2009.03-rc1.orig/include/configs/at91sam9263ek.h u-boot-2009.03-rc1/include/configs/at91sam9263ek.h --- u-boot-2009.03-rc1.orig/include/configs/at91sam9263ek.h 2009-02-23 00:22:21.000000000 +0100 +++ u-boot-2009.03-rc1/include/configs/at91sam9263ek.h 2009-02-24 15:03:09.000000000 +0100 @@ -33,7 +33,7 @@ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ #define CONFIG_SYS_AT91_PLLB 0x133a3e8d /* PLLB settings for USB */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define CONFIG_SYS_HZ 1000 /* 1ms resolution */
diff -Nrup u-boot-2009.03-rc1.orig/include/configs/at91sam9rlek.h u-boot-2009.03-rc1/include/configs/at91sam9rlek.h --- u-boot-2009.03-rc1.orig/include/configs/at91sam9rlek.h 2009-02-23 00:22:21.000000000 +0100 +++ u-boot-2009.03-rc1/include/configs/at91sam9rlek.h 2009-02-24 15:03:20.000000000 +0100 @@ -32,7 +32,7 @@ #define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define CONFIG_SYS_HZ 1000 /* 1ms resolution */
Dear Detlef Vollmann,
Detlef
Please use git tools to format and send the patch. Make sure to provide a usable comit message, and place any additional comments below a '---' line.
Also, please don't forget your signed-off-by line.
Please see http://www.denx.de/wiki/U-Boot/Patches for details.
- This code essentially ignores the settings of AT91_MASTER_CLOCK
- and CONFIG_SYS_HZ, so we just bail out if they're not set to
- the canonical values.
This makes no sense - CONFIG_SYS_HZ should be set to 1000 for all boards and processors.
if (now >= base)
return now - base;
Here and elsewhere: please intent by TABs only.
Thanks.
Detlef Vollmann
