[U-Boot] [PATCH 1/2] rockchip: px30: Fixup PMUGRF registers layout order
According to the PX30 TRM, the iomux registers come first, before the pull and strength control registers.
Signed-off-by: Paul Kocialkowski paul.kocialkowski@bootlin.com --- arch/arm/include/asm/arch-rockchip/grf_px30.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/grf_px30.h b/arch/arm/include/asm/arch-rockchip/grf_px30.h index c167bb42fac9..3d2a8770322e 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_px30.h +++ b/arch/arm/include/asm/arch-rockchip/grf_px30.h @@ -112,18 +112,18 @@ struct px30_grf { check_member(px30_grf, mac_con1, 0x904);
struct px30_pmugrf { - unsigned int gpio0a_e; - unsigned int gpio0b_e; - unsigned int gpio0c_e; - unsigned int gpio0d_e; - unsigned int gpio0a_p; - unsigned int gpio0b_p; - unsigned int gpio0c_p; - unsigned int gpio0d_p; unsigned int gpio0al_iomux; unsigned int gpio0bl_iomux; unsigned int gpio0cl_iomux; unsigned int gpio0dl_iomux; + unsigned int gpio0a_p; + unsigned int gpio0b_p; + unsigned int gpio0c_p; + unsigned int gpio0d_p; + unsigned int gpio0a_e; + unsigned int gpio0b_e; + unsigned int gpio0c_e; + unsigned int gpio0d_e; unsigned int gpio0l_sr; unsigned int gpio0h_sr; unsigned int gpio0l_smt;
Some generic PX30 SoMs found in the wild use UART3 as their debug output instead of UART2 (used for MMC) and UART5.
Make it possible to use UART3 as early debug output, with the associated clock and pinmux configuration. Two sets of output pins are supported (M0/M1) so a Kconfig option to select between the two is introduced like it's done for UART2.
Future users should also note that the pinmux default in the dts is to use the M1 pins while the Kconfig option takes M0 as a default.
Signed-off-by: Paul Kocialkowski paul.kocialkowski@bootlin.com --- arch/arm/include/asm/arch-rockchip/cru_px30.h | 19 +++++ arch/arm/mach-rockchip/px30/Kconfig | 9 +++ arch/arm/mach-rockchip/px30/px30.c | 77 +++++++++++++++++++ 3 files changed, 105 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_px30.h b/arch/arm/include/asm/arch-rockchip/cru_px30.h index 7d9fd181aca2..798444ae49f5 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_px30.h +++ b/arch/arm/include/asm/arch-rockchip/cru_px30.h @@ -357,6 +357,25 @@ enum { UART2_DIVNP5_SHIFT = 0, UART2_DIVNP5_MASK = 0x1f << UART2_DIVNP5_SHIFT,
+ /* CRU_CLK_SEL40_CON */ + UART3_PLL_SEL_SHIFT = 14, + UART3_PLL_SEL_MASK = 3 << UART3_PLL_SEL_SHIFT, + UART3_PLL_SEL_GPLL = 0, + UART3_PLL_SEL_24M, + UART3_PLL_SEL_480M, + UART3_PLL_SEL_NPLL, + UART3_DIV_CON_SHIFT = 0, + UART3_DIV_CON_MASK = 0x1f << UART3_DIV_CON_SHIFT, + + /* CRU_CLK_SEL41_CON */ + UART3_CLK_SEL_SHIFT = 14, + UART3_CLK_SEL_MASK = 3 << UART3_PLL_SEL_SHIFT, + UART3_CLK_SEL_UART3 = 0, + UART3_CLK_SEL_UART3_NP5, + UART3_CLK_SEL_UART3_FRAC, + UART3_DIVNP5_SHIFT = 0, + UART3_DIVNP5_MASK = 0x1f << UART3_DIVNP5_SHIFT, + /* CRU_CLK_SEL46_CON */ UART5_PLL_SEL_SHIFT = 14, UART5_PLL_SEL_MASK = 3 << UART5_PLL_SEL_SHIFT, diff --git a/arch/arm/mach-rockchip/px30/Kconfig b/arch/arm/mach-rockchip/px30/Kconfig index 109a37be15ad..167517bbd63f 100644 --- a/arch/arm/mach-rockchip/px30/Kconfig +++ b/arch/arm/mach-rockchip/px30/Kconfig @@ -36,6 +36,15 @@ config DEBUG_UART2_CHANNEL For using the UART for early debugging the route to use needs to be declared (0 or 1).
+config DEBUG_UART3_CHANNEL + int "Mux channel to use for debug UART3" + depends on DEBUG_UART_BOARD_INIT + default 0 + help + UART3 can use two different set of pins to route the output. + For using the UART for early debugging the route to use needs + to be declared (0 or 1). + source "board/rockchip/evb_px30/Kconfig"
endif diff --git a/arch/arm/mach-rockchip/px30/px30.c b/arch/arm/mach-rockchip/px30/px30.c index bacdcc0b938d..6b12f4f6a502 100644 --- a/arch/arm/mach-rockchip/px30/px30.c +++ b/arch/arm/mach-rockchip/px30/px30.c @@ -37,6 +37,7 @@ static struct mm_region px30_mem_map[] = { struct mm_region *mem_map = px30_mem_map;
#define PMU_PWRDN_CON 0xff000018 +#define PMUGRF_BASE 0xff010000 #define GRF_BASE 0xff140000 #define CRU_BASE 0xff2b0000 #define VIDEO_PHY_BASE 0xff2e0000 @@ -49,6 +50,23 @@ struct mm_region *mem_map = px30_mem_map;
#define QOS_PRIORITY_LEVEL(h, l) ((((h) & 3) << 8) | ((l) & 3))
+/* GRF_GPIO1BH_IOMUX */ +enum { + GPIO1B7_SHIFT = 12, + GPIO1B7_MASK = 0xf << GPIO1B7_SHIFT, + GPIO1B7_GPIO = 0, + GPIO1B7_FLASH_RDN, + GPIO1B7_UART3_RXM1, + GPIO1B7_SPI0_CLK, + + GPIO1B6_SHIFT = 8, + GPIO1B6_MASK = 0xf << GPIO1B6_SHIFT, + GPIO1B6_GPIO = 0, + GPIO1B6_FLASH_CS1, + GPIO1B6_UART3_TXM1, + GPIO1B6_SPI0_CSN, +}; + /* GRF_GPIO1CL_IOMUX */ enum { GPIO1C1_SHIFT = 4, @@ -128,6 +146,23 @@ enum { GPIO3A1_UART5_RX = 4, };
+/* PMUGRF_GPIO0CL_IOMUX */ +enum { + GPIO0C1_SHIFT = 2, + GPIO0C1_MASK = 0x3 << GPIO0C1_SHIFT, + GPIO0C1_GPIO = 0, + GPIO0C1_PWM_3, + GPIO0C1_UART3_RXM0, + GPIO0C1_PMU_DEBUG4, + + GPIO0C0_SHIFT = 0, + GPIO0C0_MASK = 0x3 << GPIO0C0_SHIFT, + GPIO0C0_GPIO = 0, + GPIO0C0_PWM_1, + GPIO0C0_UART3_TXM0, + GPIO0C0_PMU_DEBUG3, +}; + int arch_cpu_init(void) { static struct px30_grf * const grf = (void *)GRF_BASE; @@ -175,6 +210,11 @@ int arch_cpu_init(void) #ifdef CONFIG_DEBUG_UART_BOARD_INIT void board_debug_uart_init(void) { +#if defined(CONFIG_DEBUG_UART_BASE) && \ + (CONFIG_DEBUG_UART_BASE == 0xff168000) && \ + (CONFIG_DEBUG_UART3_CHANNEL != 1) + static struct px30_pmugrf * const pmugrf = (void *)PMUGRF_BASE; +#endif static struct px30_grf * const grf = (void *)GRF_BASE; static struct px30_cru * const cru = (void *)CRU_BASE;
@@ -191,6 +231,43 @@ void board_debug_uart_init(void) GPIO1C1_MASK | GPIO1C0_MASK, GPIO1C1_UART1_TX << GPIO1C1_SHIFT | GPIO1C0_UART1_RX << GPIO1C0_SHIFT); +#elif defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff168000) + /* GRF_IOFUNC_CON0 */ + enum { + CON_IOMUX_UART3SEL_SHIFT = 9, + CON_IOMUX_UART3SEL_MASK = 1 << CON_IOMUX_UART3SEL_SHIFT, + CON_IOMUX_UART3SEL_M0 = 0, + CON_IOMUX_UART3SEL_M1, + }; + + /* uart_sel_clk default select 24MHz */ + rk_clrsetreg(&cru->clksel_con[40], + UART3_PLL_SEL_MASK | UART3_DIV_CON_MASK, + UART3_PLL_SEL_24M << UART3_PLL_SEL_SHIFT | 0); + rk_clrsetreg(&cru->clksel_con[41], + UART3_CLK_SEL_MASK, + UART3_CLK_SEL_UART3 << UART3_CLK_SEL_SHIFT); + +#if (CONFIG_DEBUG_UART3_CHANNEL == 1) + rk_clrsetreg(&grf->iofunc_con0, + CON_IOMUX_UART3SEL_MASK, + CON_IOMUX_UART3SEL_M1 << CON_IOMUX_UART3SEL_SHIFT); + + rk_clrsetreg(&grf->gpio1bh_iomux, + GPIO1B7_MASK | GPIO1B6_MASK, + GPIO1B7_UART3_RXM1 << GPIO1B7_SHIFT | + GPIO1B6_UART3_TXM1 << GPIO1B6_SHIFT); +#else + rk_clrsetreg(&grf->iofunc_con0, + CON_IOMUX_UART3SEL_MASK, + CON_IOMUX_UART3SEL_M0 << CON_IOMUX_UART3SEL_SHIFT); + + rk_clrsetreg(&pmugrf->gpio0cl_iomux, + GPIO0C1_MASK | GPIO0C0_MASK, + GPIO0C1_UART3_RXM0 << GPIO0C1_SHIFT | + GPIO0C0_UART3_TXM0 << GPIO0C0_SHIFT); +#endif /* CONFIG_DEBUG_UART3_CHANNEL == 1 */ + #elif defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff178000) /* uart_sel_clk default select 24MHz */ rk_clrsetreg(&cru->clksel_con[46],
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- /* CRU_CLK_SEL40_CON */
- UART3_PLL_SEL_SHIFT = 14,
- UART3_PLL_SEL_MASK = 3 << UART3_PLL_SEL_SHIFT,
- UART3_PLL_SEL_GPLL = 0,
- UART3_PLL_SEL_24M,
- UART3_PLL_SEL_480M,
- UART3_PLL_SEL_NPLL,
- UART3_DIV_CON_SHIFT = 0,
- UART3_DIV_CON_MASK = 0x1f << UART3_DIV_CON_SHIFT,
- /* CRU_CLK_SEL41_CON */
- UART3_CLK_SEL_SHIFT = 14,
- UART3_CLK_SEL_MASK = 3 << UART3_PLL_SEL_SHIFT,
- UART3_CLK_SEL_UART3 = 0,
- UART3_CLK_SEL_UART3_NP5,
- UART3_CLK_SEL_UART3_FRAC,
- UART3_DIVNP5_SHIFT = 0,
- UART3_DIVNP5_MASK = 0x1f << UART3_DIVNP5_SHIFT,
- /* CRU_CLK_SEL46_CON */ UART5_PLL_SEL_SHIFT = 14, UART5_PLL_SEL_MASK = 3 << UART5_PLL_SEL_SHIFT,
default 0
help
endif
- GPIO1B7_SHIFT = 12,
- GPIO1B7_MASK = 0xf << GPIO1B7_SHIFT,
- GPIO1B7_GPIO = 0,
- GPIO1B7_FLASH_RDN,
- GPIO1B7_UART3_RXM1,
- GPIO1B7_SPI0_CLK,
- GPIO1B6_SHIFT = 8,
- GPIO1B6_MASK = 0xf << GPIO1B6_SHIFT,
- GPIO1B6_GPIO = 0,
- GPIO1B6_FLASH_CS1,
- GPIO1B6_UART3_TXM1,
- GPIO1B6_SPI0_CSN,
- /* GRF_GPIO1CL_IOMUX */ enum { GPIO1C1_SHIFT = 4,
- GPIO0C1_SHIFT = 2,
- GPIO0C1_MASK = 0x3 << GPIO0C1_SHIFT,
- GPIO0C1_GPIO = 0,
- GPIO0C1_PWM_3,
- GPIO0C1_UART3_RXM0,
- GPIO0C1_PMU_DEBUG4,
- GPIO0C0_SHIFT = 0,
- GPIO0C0_MASK = 0x3 << GPIO0C0_SHIFT,
- GPIO0C0_GPIO = 0,
- GPIO0C0_PWM_1,
- GPIO0C0_UART3_TXM0,
- GPIO0C0_PMU_DEBUG3,
- int arch_cpu_init(void) { static struct px30_grf * const grf = (void *)GRF_BASE;
- (CONFIG_DEBUG_UART_BASE == 0xff168000) && \
- (CONFIG_DEBUG_UART3_CHANNEL != 1)
- static struct px30_pmugrf * const pmugrf = (void *)PMUGRF_BASE;
- /* GRF_IOFUNC_CON0 */
- enum {
- /* uart_sel_clk default select 24MHz */
- rk_clrsetreg(&cru->clksel_con[40],
- rk_clrsetreg(&cru->clksel_con[41],
UART3_CLK_SEL_MASK,
- rk_clrsetreg(&grf->iofunc_con0,
- rk_clrsetreg(&grf->gpio1bh_iomux,
+#else
- rk_clrsetreg(&pmugrf->gpio0cl_iomux,
- #elif defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff178000) /* uart_sel_clk default select 24MHz */ rk_clrsetreg(&cru->clksel_con[46],
Reviewed-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com
with one small question below
- int "Mux channel to use for debug UART3"
- depends on DEBUG_UART_BOARD_INIT
- default 0
- help
- source "board/rockchip/evb_px30/Kconfig"
Would it make sense to rename DEBUG_UART3_CHANNEL to just DEBUG_UART_CHANNEL and reuse it, so that we don't collect similar options for each uart?
Heiko
Heiko,
On 28.11.2019, at 10:44, Heiko Stuebner heiko.stuebner@theobroma-systems.com wrote:
diff --git a/arch/arm/mach-rockchip/px30/Kconfig b/arch/arm/mach-rockchip/px30/Kconfig index 109a37be15ad..167517bbd63f 100644 --- a/arch/arm/mach-rockchip/px30/Kconfig +++ b/arch/arm/mach-rockchip/px30/Kconfig @@ -36,6 +36,15 @@ config DEBUG_UART2_CHANNEL For using the UART for early debugging the route to use needs to be declared (0 or 1). +config DEBUG_UART3_CHANNEL
- default 0
- help
Let me also check what we use on the Jaguar platform, as that will be our baseline platform for PX30 support for TSD boards...
Thanks, Philipp.
Hi Heiko,
- default 0
- help
Yes I like that better too. Will craft a v2 with that.
And thanks for the review!
Cheers,
Paul
Thanks, - Kever
- unsigned int gpio0d_e; unsigned int gpio0l_sr; unsigned int gpio0h_sr; unsigned int gpio0l_smt;
Thanks for that catch Heiko
Heiko Stuebner
Kever Yang
Paul Kocialkowski
Philipp Tomsich
