[U-Boot] [PATCH 0/8] sf: MTD core support
These patch-set adds mtd support on top of spi-flash layer.
This series is next development level for spi-nor work, previous work is on below thread patch-set. https://www.mail-archive.com/u-boot@lists.denx.de/msg188073.html
TODO: - spi-nor core addition
Testing: $ git clone git://git.denx.de/u-boot-spi.git $ cd u-boot-spi $ git checkout -b spi-mtd origin/mtd
Jagan Teki (8): sf: Add MTD support to spi_flash sf: Use mtd_info ops instead of spi_flash ops cmd_sf: Use mtd->size instead of flash->size dm-sf: use mtd_ops, drop dm_spi_flash_ops sf: Add MTD support for non-dm spi_flash interface sf: probe: Minor cleanup sf: Drop SPI_FLASH_MTD driver configs: Remove CONFIG_SPI_FLASH_MTD
common/cmd_sf.c | 16 ++--- drivers/mtd/spi/Kconfig | 12 ---- drivers/mtd/spi/Makefile | 1 - drivers/mtd/spi/sf-uclass.c | 16 ----- drivers/mtd/spi/sf_internal.h | 5 -- drivers/mtd/spi/sf_mtd.c | 104 -------------------------------- drivers/mtd/spi/sf_ops.c | 109 ++++++++++++++++++++-------------- drivers/mtd/spi/sf_probe.c | 92 ++++++++++++---------------- include/configs/aristainetos-common.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/socfpga_common.h | 1 - include/spi_flash.h | 104 ++++++-------------------------- 12 files changed, 127 insertions(+), 335 deletions(-) delete mode 100644 drivers/mtd/spi/sf_mtd.c
Hi Heiko,
Any comments on this series?
TODO:
-- 1.9.1
Hello Jagan,
Am 12.10.2015 um 21:47 schrieb Jagan Teki:
TODO:
Could you rebase your patchset against current ML? I just wanted to test it on the aristaientos2 board, but first patch failed:
Base: commit 446d37c1acc76680770400fd90e6c502e49d72df Merge: ab0a6a5 bef87ad Author: Tom Rini trini@konsulko.com Date: Wed Oct 28 16:56:43 2015 -0400
Merge branch 'master' of git://git.denx.de/u-boot-spi
pollux:u-boot hs [20151029_mtd] $ git am mbox Wende an: sf: Add MTD support to spi_flash error: Anwendung des Patches fehlgeschlagen: drivers/mtd/spi/sf_ops.c:146 error: drivers/mtd/spi/sf_ops.c: Patch konnte nicht angewendet werden error: Anwendung des Patches fehlgeschlagen: drivers/mtd/spi/sf_probe.c:14 error: drivers/mtd/spi/sf_probe.c: Patch konnte nicht angewendet werden error: Anwendung des Patches fehlgeschlagen: include/spi_flash.h:87 error: include/spi_flash.h: Patch konnte nicht angewendet werden Anwendung des Patches fehlgeschlagen bei 0001 sf: Add MTD support to spi_flash Die Kopie des fehlgeschlagenen Patches befindet sich in: /home/hs/abb/imx6/u-boot/.git/rebase-apply/patch Wenn Sie das Problem gelöst haben, führen Sie "git am --continue" aus. Falls Sie diesen Patch auslassen möchten, führen Sie stattdessen "git am --skip" aus. Um den ursprünglichen Branch wiederherzustellen und die Anwendung der Patches abzubrechen, führen Sie "git am --abort" aus. pollux:u-boot hs [20151029_mtd] $
Thanks!
bye, Heiko
Heiko Schocher
Jagan Teki
