[U-Boot] [PATCH 1/2] armv8: dts: fsl-lx2160a: add sata node support
One lx2160A, there is one SATA 3.0 advanced host controller interface which is a high-performance SATA solution that delivers comprehensive and fully-compliant generation 3 (1.5 Gb/s - 6.0 Gb/s) serial ATA capabilities, in accordance with the serial ATA revision 3.0 of Serial ATA International Organization.
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/arm/dts/fsl-lx2160a-rdb.dts | 16 ++++++++++++++++ arch/arm/dts/fsl-lx2160a.dtsi | 37 +++++++++++++++++++++++++++++++++++++ 2 files changed, 53 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/fsl-lx2160a-rdb.dts b/arch/arm/dts/fsl-lx2160a-rdb.dts index c3b3a06..7c4f0e7 100644 --- a/arch/arm/dts/fsl-lx2160a-rdb.dts +++ b/arch/arm/dts/fsl-lx2160a-rdb.dts @@ -53,3 +53,19 @@ &esdhc1 { status = "okay"; }; + +&sata0 { + status = "okay"; +}; + +&sata1 { + status = "okay"; +}; + +&sata2 { + status = "okay"; +}; + +&sata3 { + status = "okay"; +}; diff --git a/arch/arm/dts/fsl-lx2160a.dtsi b/arch/arm/dts/fsl-lx2160a.dtsi index c268bd9..c8cab6a 100644 --- a/arch/arm/dts/fsl-lx2160a.dtsi +++ b/arch/arm/dts/fsl-lx2160a.dtsi @@ -238,4 +238,41 @@ bus-range = <0x0 0xff>; ranges = <0x82000000 0x0 0x40000000 0xa8 0x40000000 0x0 0x40000000>; /* non-prefetchable memory */ }; + + sata0: sata@3200000 { + compatible = "fsl,ls2080a-ahci"; + reg = <0x0 0x3200000 0x0 0x10000>; + interrupts = <0 133 4>; + clocks = <&clockgen 4 3>; + status = "disabled"; + + }; + + sata1: sata@3210000 { + compatible = "fsl,ls2080a-ahci"; + reg = <0x0 0x3210000 0x0 0x10000>; + interrupts = <0 136 4>; + clocks = <&clockgen 4 3>; + status = "disabled"; + + }; + + sata2: sata@3220000 { + compatible = "fsl,ls2080a-ahci"; + reg = <0x0 0x3220000 0x0 0x10000>; + interrupts = <0 97 4>; + clocks = <&clockgen 4 3>; + status = "disabled"; + + }; + + sata3: sata@3230000 { + compatible = "fsl,ls2080a-ahci"; + reg = <0x0 0x3230000 0x0 0x10000>; + interrupts = <0 100 4>; + clocks = <&clockgen 4 3>; + status = "disabled"; + + }; + };
Enable related configs to support sata DM feature.
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/lx2160ardb_tfa_defconfig | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index b319cb6..f971d67 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -81,3 +81,6 @@ CONFIG_PHY_INPHI=y CONFIG_INPHI_25G=y CONFIG_HUSH_PARSER=y CONFIG_EMC2305=y +CONFIG_DM_SCSI=y +CONFIG_SATA_CEVA=y +CONFIG_AHCI=y
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Peng Ma Sent: Friday, November 30, 2018 9:04 AM To: York Sun york.sun@nxp.com Cc: Xiaowei Bao xiaowei.bao@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Z.q. Hou zhiqiang.hou@nxp.com; Peng Ma peng.ma@nxp.com; u-boot@lists.denx.de; Rajat Srivastava rajat.srivastava@nxp.com; Yinbo Zhu yinbo.zhu@nxp.com Subject: [U-Boot] [PATCH 2/2] arm64: lx2160ardb: enable DM support for sata
Squashed with lx2rdb and applied to fsl-qoriq master, awaiting upstream.
--pk
Peng Ma
Prabhakar Kushwaha
