[U-Boot] [PATCH v2 0/5] tools: patman: Fixes to improve handling of various wrong usage
This fixes several issues when abnormal tags are given to patman. For example, when we forget to put an 'END' after 'Cover-letter', patman does not handle such cases very well. This adds several additional checking to let patman be a little more tolerant on handling such exceptional paths.
This series is available at u-boot-x86/patman-working for testing.
Changes in v2: - New patch to use cover_match for 'Cover-letter' - Update commit message to explain when such scenario is hit - Add cover_match to the test logic - Generate warning for missing 'END' case - Update commit message to explain when such case is hit - Reset in_section, skip_blank and section variables too - Geneate warning when blank line is not found in 'Series-changes' - New patch to handle missing 'END' in non-last commit of a series
Bin Meng (5): tools: patman: Use cover_match for 'Cover-letter' tools: patman: Handle tag sections without an 'END' tools: patman: Generate cover letter correctly when 'END' is missing tools: patman: Handle missing blank line for 'Series-changes' tools: patman: Handle missing 'END' in non-last commit of a series
tools/patman/patchstream.py | 38 +++++++++++++++++++++++++++++++++++++- 1 file changed, 37 insertions(+), 1 deletion(-)
Like other patman tags, use a new variable cover_match to indicate a match for 'Cover-letter'.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
tools/patman/patchstream.py | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 27d031e..2c4efc5 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -150,6 +150,7 @@ class PatchStream: # Handle state transition and skipping blank lines series_tag_match = re_series_tag.match(line) commit_tag_match = re_commit_tag.match(line) + cover_match = re_cover.match(line) cover_cc_match = re_cover_cc.match(line) signoff_match = re_signoff.match(line) tag_match = None @@ -203,7 +204,7 @@ class PatchStream: self.skip_blank = False
# Detect the start of a cover letter section - elif re_cover.match(line): + elif cover_match: self.in_section = 'cover' self.skip_blank = False
Changes in v2:
Changes in v2:
Applied to u-boot-dm/next, thanks!
'Cover-letter', 'Series-notes' and 'Commit-notes' tags require an 'END' to be put at the end of its section. If we forget to put an 'END' in those sections, and these sections are followed by another patman tag, patman generates incorrect patches. This adds codes to handle such scenario.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org
Changes in v2: - Update commit message to explain when such scenario is hit - Add cover_match to the test logic - Generate warning for missing 'END' case
tools/patman/patchstream.py | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 2c4efc5..ce8ffb8 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -169,6 +169,26 @@ class PatchStream: elif commit_match: self.state = STATE_MSG_HEADER
+ # If a tag is detected, but we are already in a section, + # this means 'END' is missing for that section, fix it up. + if series_tag_match or commit_tag_match or \ + cover_match or cover_cc_match or signoff_match: + if self.in_section: + self.warn.append("Missing 'END' in section '%s'" % self.in_section) + if self.in_section == 'cover': + self.series.cover = self.section + elif self.in_section == 'notes': + if self.is_log: + self.series.notes += self.section + elif self.in_section == 'commit-notes': + if self.is_log: + self.commit.notes += self.section + else: + self.warn.append("Unknown section '%s'" % self.in_section) + self.in_section = None + self.skip_blank = True + self.section = [] + # If we are in a section, keep collecting lines until we see END if self.in_section: if line == 'END':
Changes in v2:
If 'END' is missing in a 'Cover-letter' section, and that section happens to show up at the very end of the commit message, and the commit is the last commit of the series, patman fails to generate cover letter for us. Handle this in CloseCommit of patchstream.
Changes in v2: - Update commit message to explain when such case is hit - Reset in_section, skip_blank and section variables too
tools/patman/patchstream.py | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index ce8ffb8..9ae977f 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -112,6 +112,14 @@ class PatchStream: if self.commit and self.is_log: self.series.AddCommit(self.commit) self.commit = None + # If 'END' is missing in a 'Cover-letter' section, and that section + # happens to show up at the very end of the commit message, this is + # the chance for us to fix it up. + if self.in_section == 'cover' and self.is_log: + self.series.cover = self.section + self.in_section = None + self.skip_blank = True + self.section = []
def ProcessLine(self, line): """Process a single line of a patch file or commit log
Changes in v2:
Changes in v2:
'Series-changes' uses blank line to indicate its end. If that is missing, series internal state variable 'in_change' may be wrong. Correct its state.
Changes in v2: - Geneate warning when blank line is not found in 'Series-changes'
tools/patman/patchstream.py | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 9ae977f..0612612 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -177,10 +177,11 @@ class PatchStream: elif commit_match: self.state = STATE_MSG_HEADER
- # If a tag is detected, but we are already in a section, - # this means 'END' is missing for that section, fix it up. + # If a tag is detected if series_tag_match or commit_tag_match or \ cover_match or cover_cc_match or signoff_match: + # but we are already in a section, this means 'END' is missing + # for that section, fix it up. if self.in_section: self.warn.append("Missing 'END' in section '%s'" % self.in_section) if self.in_section == 'cover': @@ -196,6 +197,11 @@ class PatchStream: self.in_section = None self.skip_blank = True self.section = [] + # but we are already in a change list, that means a blank line + # is missing, fix it up. + if self.in_change: + self.warn.append("Missing 'blank line' in section 'Series-changes'") + self.in_change = 0
Changes in v2:
The following python error:
Traceback (most recent call last): File "./tools/patman/patman", line 144, in <module> series = patchstream.FixPatches(series, args) File "./tools/patman/patchstream.py", line 477, in FixPatches commit = series.commits[count] IndexError: list index out of range
is seen when:
- 'END' is missing in those tags - those tags are put in the last part in a commit message - the commit is not the last commit of the series
Add testing logic to see if a new commit starts.
Changes in v2: - New patch to handle missing 'END' in non-last commit of a series
tools/patman/patchstream.py | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 0612612..69d5cfb 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -177,9 +177,10 @@ class PatchStream: elif commit_match: self.state = STATE_MSG_HEADER
- # If a tag is detected + # If a tag is detected, or a new commit starts if series_tag_match or commit_tag_match or \ - cover_match or cover_cc_match or signoff_match: + cover_match or cover_cc_match or signoff_match or \ + self.state == STATE_MSG_HEADER: # but we are already in a section, this means 'END' is missing # for that section, fix it up. if self.in_section:
is seen when:
Changes in v2:
is seen when:
Changes in v2:
Bin Meng
