[U-Boot] [U-boot] [Patch] keystone2: replace printf on puts where it's possible
It is better to use simple puts() function instead of printf() when it's possible. Also remove redundant sprintf().
Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/cpu/armv7/keystone/ddr3.c | 2 +- arch/arm/cpu/armv7/keystone/keystone.c | 4 ++-- board/ti/ks2_evm/board.c | 7 ++----- board/ti/ks2_evm/ddr3_k2e.c | 4 ++-- board/ti/ks2_evm/ddr3_k2hk.c | 10 +++++----- board/ti/ks2_evm/ddr3_k2l.c | 2 +- 6 files changed, 13 insertions(+), 16 deletions(-)
diff --git a/arch/arm/cpu/armv7/keystone/ddr3.c b/arch/arm/cpu/armv7/keystone/ddr3.c index 923906a..3e65c2e 100644 --- a/arch/arm/cpu/armv7/keystone/ddr3.c +++ b/arch/arm/cpu/armv7/keystone/ddr3.c @@ -352,7 +352,7 @@ void ddr3_err_reset_workaround(void) tmp_b = __raw_readl(KS2_DDR3B_DDRPHYC + KS2_DDRPHY_PGSR0_OFFSET);
if (((tmp_a & 0x0FE00000) != 0) || ((tmp_b & 0x0FE00000) != 0)) { - printf("DDR Leveling Error Detected!\n"); + puts("DDR Leveling Error Detected!\n"); printf("DDR3A PGSR0 = 0x%x\n", tmp_a); printf("DDR3B PGSR0 = 0x%x\n", tmp_b);
diff --git a/arch/arm/cpu/armv7/keystone/keystone.c b/arch/arm/cpu/armv7/keystone/keystone.c index 11a9357..52cb6fc 100644 --- a/arch/arm/cpu/armv7/keystone/keystone.c +++ b/arch/arm/cpu/armv7/keystone/keystone.c @@ -32,7 +32,7 @@ int cpu_to_bus(u32 *ptr, u32 length)
static int turn_off_myself(void) { - printf("Turning off ourselves\r\n"); + puts("Turning off ourselves\r\n"); mon_power_off(0);
psc_disable_module(KS2_LPSC_TETRIS); @@ -42,7 +42,7 @@ static int turn_off_myself(void) "dsb\n" "wfi\n");
- printf("What! Should not see that\n"); + puts("What! Should not see that\n"); return 0; }
diff --git a/board/ti/ks2_evm/board.c b/board/ti/ks2_evm/board.c index 4029493..ff7bc4b 100644 --- a/board/ti/ks2_evm/board.c +++ b/board/ti/ks2_evm/board.c @@ -122,7 +122,6 @@ void ft_board_setup(void *blob, bd_t *bd) int nbanks; u64 size[2]; u64 start[2]; - char name[32]; int nodeoffset; u32 ddr3a_size; int unitrd_fixup = 0; @@ -158,15 +157,13 @@ void ft_board_setup(void *blob, bd_t *bd) }
/* reserve memory at start of bank */ - sprintf(name, "mem_reserve_head"); - env = getenv(name); + env = getenv("mem_reserve_head"); if (env) { start[0] += ustrtoul(env, &endp, 0); size[0] -= ustrtoul(env, &endp, 0); }
- sprintf(name, "mem_reserve"); - env = getenv(name); + env = getenv("mem_reserve"); if (env) size[0] -= ustrtoul(env, &endp, 0);
diff --git a/board/ti/ks2_evm/ddr3_k2e.c b/board/ti/ks2_evm/ddr3_k2e.c index 40fd966..3f100ed 100644 --- a/board/ti/ks2_evm/ddr3_k2e.c +++ b/board/ti/ks2_evm/ddr3_k2e.c @@ -31,7 +31,7 @@ void ddr3_init(void) if (!strcmp(dimm_name, "18KSF1G72HZ-1G6E2 ")) { /* 8G SO-DIMM */ ddr3_size = 8; - printf("DRAM: 8 GiB\n"); + puts("DRAM: 8 GiB\n"); ddr3phy_1600_8g.zq0cr1 |= 0x10000; ddr3phy_1600_8g.zq1cr1 |= 0x10000; ddr3phy_1600_8g.zq2cr1 |= 0x10000; @@ -40,7 +40,7 @@ void ddr3_init(void) } else if (!strcmp(dimm_name, "18KSF51272HZ-1G6K2")) { /* 4G SO-DIMM */ ddr3_size = 4; - printf("DRAM: 4 GiB\n"); + puts("DRAM: 4 GiB\n"); ddr3_init_ddrphy(KS2_DDR3A_DDRPHYC, &ddr3phy_1600_4g); ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_1600_4g); } diff --git a/board/ti/ks2_evm/ddr3_k2hk.c b/board/ti/ks2_evm/ddr3_k2hk.c index a1c3d05..115aed7 100644 --- a/board/ti/ks2_evm/ddr3_k2hk.c +++ b/board/ti/ks2_evm/ddr3_k2hk.c @@ -45,14 +45,14 @@ void ddr3_init(void)
ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_1600_8g); - printf("DRAM: Capacity 8 GiB (includes reported below)\n"); + puts("DRAM: Capacity 8 GiB (includes reported below)\n"); ddr3_size = 8; } else { ddr3_init_ddrphy(KS2_DDR3A_DDRPHYC, &ddr3phy_1600_8g); ddr3_1600_8g.sdcfg |= 0x1000; ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_1600_8g); - printf("DRAM: Capacity 4 GiB (includes reported below)\n"); + puts("DRAM: Capacity 4 GiB (includes reported below)\n"); ddr3_size = 4; } } else if (!strcmp(dimm_name, "SQR-SD3T-2G1333SED")) { @@ -75,17 +75,17 @@ void ddr3_init(void) ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_1333_2g); ddr3_size = 2; - printf("DRAM: 2 GiB"); + puts("DRAM: 2 GiB\n"); } else { ddr3_init_ddrphy(KS2_DDR3A_DDRPHYC, &ddr3phy_1333_2g); ddr3_1333_2g.sdcfg |= 0x1000; ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_1333_2g); ddr3_size = 1; - printf("DRAM: 1 GiB"); + puts("DRAM: 1 GiB\n"); } } else { - printf("Unknown SO-DIMM. Cannot configure DDR3\n"); + puts("Unknown SO-DIMM. Cannot configure DDR3\n"); while (1) ; } diff --git a/board/ti/ks2_evm/ddr3_k2l.c b/board/ti/ks2_evm/ddr3_k2l.c index 15a14f2..32fb4b7 100644 --- a/board/ti/ks2_evm/ddr3_k2l.c +++ b/board/ti/ks2_evm/ddr3_k2l.c @@ -19,7 +19,7 @@ void ddr3_init(void) init_pll(&ddr3_400);
/* No SO-DIMM, 2GB discreet DDR */ - printf("DRAM: 2 GiB\n"); + puts("DRAM: 2 GiB\n"); ddr3_size = 2;
/* Reset DDR3 PHY after PLL enabled */
One of the outcomes of the mini-summit and I think was summarized on the list as well was that we're going to stop with the "use puts instead of printf!" thing as it ends up being more annoying to contributors than useful in terms of functionality and code size.
- env = getenv("mem_reserve_head"); if (env) { start[0] += ustrtoul(env, &endp, 0); size[0] -= ustrtoul(env, &endp, 0); }
- env = getenv("mem_reserve"); if (env) size[0] -= ustrtoul(env, &endp, 0);
This is good to fix however.
Ok, Reject this patch. I will send new patch that delete only sprintf. Thanks!
Ivan Khoronzhuk
