[U-Boot] [RFC] usb: ehci-mx6: Create MISC USB device wrapper
In preparation to support DM_USB_GADGET, this creates a misc device which binds the host. This is necessary because U_BOOT_DRIVER(usb_mx6) is currently hard coded to UCLASS_USB and if we want to support UCLASS_USB_GADGET_GENERIC we'll need to bind a separate device in the future.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index ba1e6bfa43..25c7e2d6a1 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -134,6 +134,7 @@ config USB_EHCI_MARVELL
config USB_EHCI_MX6 bool "Support for i.MX6 on-chip EHCI USB controller" + select MISC depends on ARCH_MX6 default y ---help--- diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 16abeef3b2..4003b8616f 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -19,6 +19,7 @@ #include <asm/mach-types.h> #include <power/regulator.h> #include <linux/usb/otg.h> +#include <dm/lists.h>
#include "ehci.h"
@@ -567,7 +568,6 @@ static const struct udevice_id mx6_usb_ids[] = { U_BOOT_DRIVER(usb_mx6) = { .name = "ehci_mx6", .id = UCLASS_USB, - .of_match = mx6_usb_ids, .ofdata_to_platdata = ehci_usb_ofdata_to_platdata, .probe = ehci_usb_probe, .remove = ehci_deregister, @@ -576,4 +576,30 @@ U_BOOT_DRIVER(usb_mx6) = { .priv_auto_alloc_size = sizeof(struct ehci_mx6_priv_data), .flags = DM_FLAG_ALLOC_PRIV_DMA, }; + +static int mx6_usb_wrapper_bind(struct udevice *dev) +{ + const void *fdt = gd->fdt_blob; + int node = dev_of_offset(dev); + const char *name = fdt_get_name(fdt, node, NULL); + int ret; + + ret = device_bind_driver_to_node(dev, + "ehci_mx6", + name, + offset_to_ofnode(node), + &dev); + if (ret) + pr_err("mx6_usb - Unable to bind USB host node\n"); + + return ret; +} + +U_BOOT_DRIVER(usb_mx6_wrapper) = { + .name = "mx6-usb-wrapper", + .id = UCLASS_MISC, + .of_match = mx6_usb_ids, + .bind = mx6_usb_wrapper_bind, +}; + #endif
#include "ehci.h"
int ret;
For clarification, this patch, this patch should behave just like it has been in the past. The idea we'd check the dr_mode and/or ID pin inside mx6_usb_wrapper_bind. Instead of binding the ehci_mx6 with UCLASS_USB all the time, we'd bind something with the UCLASS_USB_GADGET_GENERIC based on dr_mode and/or ID pin status. Before I go down a rabit hole, I thought I'd send out the RFC to see what people's thoughts are. If someone else has this driver already updated to support DM_USB_GADGET or is working on it, I'll back off.
"ehci_mx6",
name,
&dev);
if (ret)
return ret;
.id = UCLASS_MISC,
#endif
2.17.1
Hi Adam,
#include "ehci.h"
int ret;
It looks reasonable to me, but Marek is the USB expert.
"ehci_mx6",
name,
&dev);
if (ret)
return ret;
.id = UCLASS_MISC,
#endif
2.17.1
Regards, SImon
Adam Ford
