[U-Boot] [PATCH v3 0/8] Allow sandbox to use config_distro_bootcmd
Testing whether images will correctly boot with the standard distro bootcmds can be rather time-consuming as it tends to require flashing the images and booting on a device. Ditto for testing changes to config_distro_bootcmd.
Adding support for sandbox to run distro bootcmds makes things a lot more convenient.
Changes in v3: - Fill in bootz_setup *start and *end arguments with proper values - Improve deprecated sb command short line - Don't document subcommands for sb anymore
Sjoerd Simons (8): sandbox: only do sandboxfs for hostfs interface sandbox: Split bootm code out into lib/bootm sandbox: Add support for bootz sandbox: Renamed sb command to host sandbox: Implement host dev [device] config_distro_bootcmd.h: Add shared block definition for the host interface pxe: Ensure all memory access is to mapped memory sandbox: add config_distro_defaults and config_distro_bootcmd
arch/sandbox/cpu/cpu.c | 12 --- arch/sandbox/lib/Makefile | 1 + arch/sandbox/lib/bootm.c | 63 ++++++++++++++ common/Makefile | 2 +- common/cmd_host.c | 176 ++++++++++++++++++++++++++++++++++++++++ common/cmd_pxe.c | 86 +++++++++++++------- common/cmd_sandbox.c | 126 ---------------------------- fs/sandbox/sandboxfs.c | 6 +- include/config_distro_bootcmd.h | 13 +++ include/configs/sandbox.h | 29 ++++++- 10 files changed, 341 insertions(+), 173 deletions(-) create mode 100644 arch/sandbox/lib/bootm.c create mode 100644 common/cmd_host.c delete mode 100644 common/cmd_sandbox.c
Only do sandbox filesystem access when using the hostfs device interface, rather then falling back to it in all cases. This prevents confusion situations due to the fallback being taken rather then an unsupported error being raised.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Simon Glass sjg@chromium.org
Changes in v3: None Changes in v2: - Minor comment coding style improvement
fs/sandbox/sandboxfs.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/fs/sandbox/sandboxfs.c b/fs/sandbox/sandboxfs.c index a920bc0..5acfc03 100644 --- a/fs/sandbox/sandboxfs.c +++ b/fs/sandbox/sandboxfs.c @@ -10,7 +10,11 @@
int sandbox_fs_set_blk_dev(block_dev_desc_t *rbdd, disk_partition_t *info) { - return 0; + /* + * Only accept a NULL block_dev_desc_t for the sandbox, which is when + * hostfs interface is used + */ + return rbdd != NULL; }
int sandbox_fs_read_at(const char *filename, loff_t pos, void *buffer,
Follow the convention of other architectures and move the platform specific linux bootm code into sandbox/lib/bootm.c.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Acked-by: Simon Glass sjg@chromium.org ---
arch/sandbox/cpu/cpu.c | 12 ------------ arch/sandbox/lib/Makefile | 1 + arch/sandbox/lib/bootm.c | 21 +++++++++++++++++++++ 3 files changed, 22 insertions(+), 12 deletions(-) create mode 100644 arch/sandbox/lib/bootm.c
diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index 1aa397c..a0c8106 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -40,18 +40,6 @@ unsigned long __attribute__((no_instrument_function)) timer_get_us(void) return os_get_nsec() / 1000; }
-int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) -{ - if (flag & (BOOTM_STATE_OS_GO | BOOTM_STATE_OS_FAKE_GO)) { - bootstage_mark(BOOTSTAGE_ID_RUN_OS); - printf("## Transferring control to Linux (at address %08lx)...\n", - images->ep); - reset_cpu(0); - } - - return 0; -} - int cleanup_before_linux(void) { return 0; diff --git a/arch/sandbox/lib/Makefile b/arch/sandbox/lib/Makefile index 4c1a38d..3c86cc2 100644 --- a/arch/sandbox/lib/Makefile +++ b/arch/sandbox/lib/Makefile @@ -9,3 +9,4 @@
obj-y += interrupts.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o diff --git a/arch/sandbox/lib/bootm.c b/arch/sandbox/lib/bootm.c new file mode 100644 index 0000000..8ddf4ef --- /dev/null +++ b/arch/sandbox/lib/bootm.c @@ -0,0 +1,21 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +{ + if (flag & (BOOTM_STATE_OS_GO | BOOTM_STATE_OS_FAKE_GO)) { + bootstage_mark(BOOTSTAGE_ID_RUN_OS); + printf("## Transferring control to Linux (at address %08lx)...\n", + images->ep); + reset_cpu(0); + } + + return 0; +}
Add dummy bootz_setup implementation allowing the u-boot sandbox to run bootz. This recognizes both ARM and x86 zImages to validate a valid zImage was loaded.
Changes in v3: - Fill in *start and *end with proper values
Changes in v2: - Move into sandbox/lib/bootm.c - convert to u-boot coding style - Remove unneeded cast
arch/sandbox/lib/bootm.c | 42 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+)
diff --git a/arch/sandbox/lib/bootm.c b/arch/sandbox/lib/bootm.c index 8ddf4ef..d49c927 100644 --- a/arch/sandbox/lib/bootm.c +++ b/arch/sandbox/lib/bootm.c @@ -1,5 +1,6 @@ /* * Copyright (c) 2011 The Chromium OS Authors. + * Copyright (c) 2015 Sjoerd Simons sjoerd.simons@collabora.co.uk * SPDX-License-Identifier: GPL-2.0+ */
@@ -8,6 +9,47 @@
+#define LINUX_ARM_ZIMAGE_MAGIC 0x016f2818 + +struct arm_z_header { + uint32_t code[9]; + uint32_t zi_magic; + uint32_t zi_start; + uint32_t zi_end; +} __attribute__ ((__packed__)); + +int bootz_setup(ulong image, ulong *start, ulong *end) +{ + uint8_t *zimage = map_sysmem(image, 0); + struct arm_z_header *arm_hdr = (struct arm_z_header *)zimage; + int ret = 0; + + if (memcmp(zimage + 0x202, "HdrS", 4) == 0) { + uint8_t setup_sects = *(zimage + 0x1f1); + uint32_t syssize = + le32_to_cpu(*(uint32_t *)(zimage + 0x1f4)); + + *start = 0; + *end = (setup_sects + 1) * 512 + syssize * 16; + + printf("setting up X86 zImage [ %ld - %ld ]\n", + *start, *end); + } else if (le32_to_cpu(arm_hdr->zi_magic) == LINUX_ARM_ZIMAGE_MAGIC) { + *start = le32_to_cpu(arm_hdr->zi_start); + *end = le32_to_cpu(arm_hdr->zi_end); + + printf("setting up ARM zImage [ %ld - %ld ]\n", + *start, *end); + } else { + printf("Unrecognized zImage\n"); + ret = 1; + } + + unmap_sysmem((void *)image); + + return ret; +} + int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) { if (flag & (BOOTM_STATE_OS_GO | BOOTM_STATE_OS_FAKE_GO)) {
On 12 April 2015 at 15:04, Sjoerd Simons sjoerd.simons@collabora.co.uk wrote:
Changes in v3:
Changes in v2:
- Copyright (c) 2011 The Chromium OS Authors.
- Copyright (c) 2015 Sjoerd Simons sjoerd.simons@collabora.co.uk
@@ -8,6 +9,47 @@
uint32_t code[9];
uint32_t zi_magic;
uint32_t zi_start;
uint32_t zi_end;
int ret = 0;
uint32_t syssize =
*start = 0;
*start, *end);
*start, *end);
} else {
ret = 1;
return ret;
int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) { if (flag & (BOOTM_STATE_OS_GO | BOOTM_STATE_OS_FAKE_GO)) { -- 2.1.4
As suggested by Simon Glass, rename the sb command to host but keep the old sb command as an alias
Changes in v3: - Improve deprecated sb command short line - Don't document subcommands for sb anymore
Changes in v2: None
common/Makefile | 2 +- common/{cmd_sandbox.c => cmd_host.c} | 50 ++++++++++++++++++++---------------- 2 files changed, 29 insertions(+), 23 deletions(-) rename common/{cmd_sandbox.c => cmd_host.c} (62%)
diff --git a/common/Makefile b/common/Makefile index 7216a13..ccb5b99 100644 --- a/common/Makefile +++ b/common/Makefile @@ -151,7 +151,7 @@ obj-$(CONFIG_CMD_PXE) += cmd_pxe.o obj-$(CONFIG_CMD_READ) += cmd_read.o obj-$(CONFIG_CMD_REGINFO) += cmd_reginfo.o obj-$(CONFIG_CMD_REISER) += cmd_reiser.o -obj-$(CONFIG_SANDBOX) += cmd_sandbox.o +obj-$(CONFIG_SANDBOX) += cmd_host.o obj-$(CONFIG_CMD_SATA) += cmd_sata.o obj-$(CONFIG_CMD_SF) += cmd_sf.o obj-$(CONFIG_CMD_SCSI) += cmd_scsi.o diff --git a/common/cmd_sandbox.c b/common/cmd_host.c similarity index 62% rename from common/cmd_sandbox.c rename to common/cmd_host.c index 4286969..323a795 100644 --- a/common/cmd_sandbox.c +++ b/common/cmd_host.c @@ -10,25 +10,25 @@ #include <sandboxblockdev.h> #include <asm/errno.h>
-static int do_sandbox_load(cmd_tbl_t *cmdtp, int flag, int argc, +static int do_host_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { return do_load(cmdtp, flag, argc, argv, FS_TYPE_SANDBOX); }
-static int do_sandbox_ls(cmd_tbl_t *cmdtp, int flag, int argc, +static int do_host_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { return do_ls(cmdtp, flag, argc, argv, FS_TYPE_SANDBOX); }
-static int do_sandbox_save(cmd_tbl_t *cmdtp, int flag, int argc, +static int do_host_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { return do_save(cmdtp, flag, argc, argv, FS_TYPE_SANDBOX); }
-static int do_sandbox_bind(cmd_tbl_t *cmdtp, int flag, int argc, +static int do_host_bind(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { if (argc < 2 || argc > 3) @@ -44,7 +44,7 @@ static int do_sandbox_bind(cmd_tbl_t *cmdtp, int flag, int argc, return host_dev_bind(dev, file); }
-static int do_sandbox_info(cmd_tbl_t *cmdtp, int flag, int argc, +static int do_host_info(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { if (argc < 1 || argc > 2) @@ -85,25 +85,25 @@ static int do_sandbox_info(cmd_tbl_t *cmdtp, int flag, int argc, return 0; }
-static cmd_tbl_t cmd_sandbox_sub[] = { - U_BOOT_CMD_MKENT(load, 7, 0, do_sandbox_load, "", ""), - U_BOOT_CMD_MKENT(ls, 3, 0, do_sandbox_ls, "", ""), - U_BOOT_CMD_MKENT(save, 6, 0, do_sandbox_save, "", ""), - U_BOOT_CMD_MKENT(bind, 3, 0, do_sandbox_bind, "", ""), - U_BOOT_CMD_MKENT(info, 3, 0, do_sandbox_info, "", ""), +static cmd_tbl_t cmd_host_sub[] = { + U_BOOT_CMD_MKENT(load, 7, 0, do_host_load, "", ""), + U_BOOT_CMD_MKENT(ls, 3, 0, do_host_ls, "", ""), + U_BOOT_CMD_MKENT(save, 6, 0, do_host_save, "", ""), + U_BOOT_CMD_MKENT(bind, 3, 0, do_host_bind, "", ""), + U_BOOT_CMD_MKENT(info, 3, 0, do_host_info, "", ""), };
-static int do_sandbox(cmd_tbl_t *cmdtp, int flag, int argc, +static int do_host(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { cmd_tbl_t *c;
- /* Skip past 'sandbox' */ + /* Skip past 'host' */ argc--; argv++;
- c = find_cmd_tbl(argv[0], cmd_sandbox_sub, - ARRAY_SIZE(cmd_sandbox_sub)); + c = find_cmd_tbl(argv[0], cmd_host_sub, + ARRAY_SIZE(cmd_host_sub));
if (c) return c->cmd(cmdtp, flag, argc, argv); @@ -112,15 +112,21 @@ static int do_sandbox(cmd_tbl_t *cmdtp, int flag, int argc, }
U_BOOT_CMD( - sb, 8, 1, do_sandbox, - "Miscellaneous sandbox commands", + sb, 8, 1, do_host, + "Deprecated: use 'host' command instead.", "" +); + +U_BOOT_CMD( + host, 8, 1, do_host, + "Miscellaneous host commands", "load hostfs - <addr> <filename> [<bytes> <offset>] - " "load a file from host\n" - "sb ls hostfs - <filename> - list files on host\n" - "sb save hostfs - <addr> <filename> <bytes> [<offset>] - " + "host ls hostfs - <filename> - list files on host\n" + "host save hostfs - <addr> <filename> <bytes> [<offset>] - " "save a file to host\n" - "sb bind <dev> [<filename>] - bind "host" device to file\n" - "sb info [<dev>] - show device binding & info\n" - "sb commands use the "hostfs" device. The "host" device is used\n" + "host bind <dev> [<filename>] - bind "host" device to file\n" + "host info [<dev>] - show device binding & info\n" + "host commands use the "hostfs" device. The "host" device is used\n" "with standard IO commands such as fatls or ext2load" ); +
A common pattern to check if a certain device exists (e.g. in config_distro_bootcmd) is to use: <interface> dev [device]
Implement host dev [device] so this pattern can be used for sandbox host devices.
common/cmd_host.c | 44 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 44 insertions(+)
diff --git a/common/cmd_host.c b/common/cmd_host.c index 323a795..bd7ee2c 100644 --- a/common/cmd_host.c +++ b/common/cmd_host.c @@ -10,6 +10,8 @@ #include <sandboxblockdev.h> #include <asm/errno.h>
+static int host_curr_device = -1; + static int do_host_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -85,12 +87,53 @@ static int do_host_info(cmd_tbl_t *cmdtp, int flag, int argc, return 0; }
+static int do_host_dev(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + int dev; + char *ep; + block_dev_desc_t *blk_dev; + int ret; + + if (argc < 1 || argc > 3) + return CMD_RET_USAGE; + + if (argc == 1) { + if (host_curr_device < 0) { + printf("No current host device\n"); + return 1; + } + printf("Current host device %d\n", host_curr_device); + return 0; + } + + dev = simple_strtoul(argv[1], &ep, 16); + if (*ep) { + printf("** Bad device specification %s **\n", argv[2]); + return CMD_RET_USAGE; + } + + ret = host_get_dev_err(dev, &blk_dev); + if (ret) { + if (ret == -ENOENT) + puts("Not bound to a backing file\n"); + else if (ret == -ENODEV) + puts("Invalid host device number\n"); + + return 1; + } + + host_curr_device = dev; + return 0; +} + static cmd_tbl_t cmd_host_sub[] = { U_BOOT_CMD_MKENT(load, 7, 0, do_host_load, "", ""), U_BOOT_CMD_MKENT(ls, 3, 0, do_host_ls, "", ""), U_BOOT_CMD_MKENT(save, 6, 0, do_host_save, "", ""), U_BOOT_CMD_MKENT(bind, 3, 0, do_host_bind, "", ""), U_BOOT_CMD_MKENT(info, 3, 0, do_host_info, "", ""), + U_BOOT_CMD_MKENT(dev, 0, 1, do_host_dev, "", ""), };
static int do_host(cmd_tbl_t *cmdtp, int flag, int argc, @@ -126,6 +169,7 @@ U_BOOT_CMD( "save a file to host\n" "host bind <dev> [<filename>] - bind "host" device to file\n" "host info [<dev>] - show device binding & info\n" + "host dev [<dev>] - Set or retrieve the current host device\n" "host commands use the "hostfs" device. The "host" device is used\n" "with standard IO commands such as fatls or ext2load" );
Define the common shared block environment for the host interface in preperation for the sandbox build to use config_distro_bootcmd.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Acked-by: Simon Glass sjg@chromium.org Acked-by: Stephen Warren swarren@nvidia.com ---
include/config_distro_bootcmd.h | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index d71e58d..3a360ca4 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -48,6 +48,18 @@ #define BOOTENV_DEV_NAME_BLKDEV(devtypeu, devtypel, instance) \ #devtypel #instance " "
+#ifdef CONFIG_SANDBOX +#define BOOTENV_SHARED_HOST BOOTENV_SHARED_BLKDEV(host) +#define BOOTENV_DEV_HOST BOOTENV_DEV_BLKDEV +#define BOOTENV_DEV_NAME_HOST BOOTENV_DEV_NAME_BLKDEV +#else +#define BOOTENV_SHARED_HOST +#define BOOTENV_DEV_HOST \ + BOOT_TARGET_DEVICES_references_HOST_without_CONFIG_SANDBOX +#define BOOTENV_DEV_NAME_HOST \ + BOOT_TARGET_DEVICES_references_HOST_without_CONFIG_SANDBOX +#endif + #ifdef CONFIG_CMD_MMC #define BOOTENV_SHARED_MMC BOOTENV_SHARED_BLKDEV(mmc) #define BOOTENV_DEV_MMC BOOTENV_DEV_BLKDEV @@ -167,6 +179,7 @@ #define BOOTENV_DEV(devtypeu, devtypel, instance) \ BOOTENV_DEV_##devtypeu(devtypeu, devtypel, instance) #define BOOTENV \ + BOOTENV_SHARED_HOST \ BOOTENV_SHARED_MMC \ BOOTENV_SHARED_USB \ BOOTENV_SHARED_SATA \
Properly map memory through map_sysmem so that pxe can be used from the sandbox.
Tested in sandbox as well as on jetson-tk1, odroid-xu3, snow as peach-pi boards
Changes in v3: None Changes in v2: - Prevent uncessary casts - Always unmap mapped sysmem - Consistently use base variable to refer to unmapped memory - Various coding style fixes
common/cmd_pxe.c | 86 ++++++++++++++++++++++++++++++++++++-------------------- 1 file changed, 56 insertions(+), 30 deletions(-)
diff --git a/common/cmd_pxe.c b/common/cmd_pxe.c index 7e32c95..292f2c1 100644 --- a/common/cmd_pxe.c +++ b/common/cmd_pxe.c @@ -13,6 +13,7 @@ #include <errno.h> #include <linux/list.h> #include <fs.h> +#include <asm/io.h>
#include "menu.h" #include "cli.h" @@ -188,11 +189,12 @@ static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) * * Returns 1 for success, or < 0 on error. */ -static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, void *file_addr) +static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr) { size_t path_len; char relfile[MAX_TFTP_PATH_LEN+1]; - char addr_buf[10]; + char addr_buf[18]; int err;
err = get_bootfile_path(file_path, relfile, sizeof(relfile)); @@ -215,7 +217,7 @@ static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, void *file_addr)
printf("Retrieving file: %s\n", relfile);
- sprintf(addr_buf, "%p", file_addr); + sprintf(addr_buf, "%lx", file_addr);
return do_getfile(cmdtp, relfile, addr_buf); } @@ -227,11 +229,13 @@ static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, void *file_addr) * * Returns 1 on success, or < 0 for error. */ -static int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, void *file_addr) +static int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr) { unsigned long config_file_size; char *tftp_filesize; int err; + char *buf;
err = get_relfile(cmdtp, file_path, file_addr);
@@ -250,7 +254,9 @@ static int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, void *file_addr if (strict_strtoul(tftp_filesize, 16, &config_file_size) < 0) return -EINVAL;
- *(char *)(file_addr + config_file_size) = '\0'; + buf = map_sysmem(file_addr + config_file_size, 1); + *buf = '\0'; + unmap_sysmem(buf);
return 1; } @@ -266,7 +272,8 @@ static int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, void *file_addr * * Returns 1 on success or < 0 on error. */ -static int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, void *pxefile_addr_r) +static int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, + unsigned long pxefile_addr_r) { size_t base_len = strlen(PXELINUX_DIR); char path[MAX_TFTP_PATH_LEN+1]; @@ -287,7 +294,7 @@ static int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, void *pxefile_a * * Returns 1 on success or < 0 on error. */ -static int pxe_uuid_path(cmd_tbl_t *cmdtp, void *pxefile_addr_r) +static int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) { char *uuid_str;
@@ -305,7 +312,7 @@ static int pxe_uuid_path(cmd_tbl_t *cmdtp, void *pxefile_addr_r) * * Returns 1 on success or < 0 on error. */ -static int pxe_mac_path(cmd_tbl_t *cmdtp, void *pxefile_addr_r) +static int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) { char mac_str[21]; int err; @@ -325,7 +332,7 @@ static int pxe_mac_path(cmd_tbl_t *cmdtp, void *pxefile_addr_r) * * Returns 1 on success or < 0 on error. */ -static int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, void *pxefile_addr_r) +static int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) { char ip_addr[9]; int mask_pos, err; @@ -384,9 +391,9 @@ do_pxe_get(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * Keep trying paths until we successfully get a file we're looking * for. */ - if (pxe_uuid_path(cmdtp, (void *)pxefile_addr_r) > 0 || - pxe_mac_path(cmdtp, (void *)pxefile_addr_r) > 0 || - pxe_ipaddr_paths(cmdtp, (void *)pxefile_addr_r) > 0) { + if (pxe_uuid_path(cmdtp, pxefile_addr_r) > 0 || + pxe_mac_path(cmdtp, pxefile_addr_r) > 0 || + pxe_ipaddr_paths(cmdtp, pxefile_addr_r) > 0) { printf("Config file found\n");
return 0; @@ -394,7 +401,7 @@ do_pxe_get(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
while (pxe_default_paths[i]) { if (get_pxelinux_path(cmdtp, pxe_default_paths[i], - (void *)pxefile_addr_r) > 0) { + pxefile_addr_r) > 0) { printf("Config file found\n"); return 0; } @@ -427,7 +434,7 @@ static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, const ch if (strict_strtoul(envaddr, 16, &file_addr) < 0) return -EINVAL;
- return get_relfile(cmdtp, file_path, (void *)file_addr); + return get_relfile(cmdtp, file_path, file_addr); }
/* @@ -790,6 +797,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) else do_bootz(cmdtp, 0, bootm_argc, bootm_argv); #endif + unmap_sysmem(buf); return 1; }
@@ -1054,7 +1062,8 @@ static int parse_integer(char **c, int *dst) return 1; }
-static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, struct pxe_menu *cfg, int nest_level); +static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, + struct pxe_menu *cfg, int nest_level);
/* * Parse an include statement, and retrieve and parse the file it mentions. @@ -1064,12 +1073,14 @@ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, struct pxe_menu *cfg, in * include, nest_level has already been incremented and doesn't need to be * incremented here. */ -static int handle_include(cmd_tbl_t *cmdtp, char **c, char *base, +static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, struct pxe_menu *cfg, int nest_level) { char *include_path; char *s = *c; int err; + char *buf; + int ret;
err = parse_sliteral(c, &include_path);
@@ -1086,20 +1097,25 @@ static int handle_include(cmd_tbl_t *cmdtp, char **c, char *base, return err; }
- return parse_pxefile_top(cmdtp, base, cfg, nest_level); + buf = map_sysmem(base, 0); + ret = parse_pxefile_top(cmdtp, buf, base, cfg, nest_level); + unmap_sysmem(buf); + + return ret; }
/* * Parse lines that begin with 'menu'. * - * b and nest are provided to handle the 'menu include' case. + * base and nest are provided to handle the 'menu include' case. * - * b should be the address where the file currently being parsed is stored. + * base should point to a location where it's safe to store the included file. * * nest_level should be 1 when parsing the top level pxe file, 2 when parsing * a file it includes, 3 when parsing a file included by that file, and so on. */ -static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, char *b, int nest_level) +static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, + unsigned long base, int nest_level) { struct token t; char *s = *c; @@ -1114,7 +1130,7 @@ static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, char *b, break;
case T_INCLUDE: - err = handle_include(cmdtp, c, b + strlen(b) + 1, cfg, + err = handle_include(cmdtp, c, base, cfg, nest_level + 1); break;
@@ -1281,7 +1297,8 @@ static int parse_label(char **c, struct pxe_menu *cfg) * * Returns 1 on success, < 0 on error. */ -static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, struct pxe_menu *cfg, int nest_level) +static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, + struct pxe_menu *cfg, int nest_level) { struct token t; char *s, *b, *label_name; @@ -1303,7 +1320,9 @@ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, struct pxe_menu *cfg, in switch (t.type) { case T_MENU: cfg->prompt = 1; - err = parse_menu(cmdtp, &p, cfg, b, nest_level); + err = parse_menu(cmdtp, &p, cfg, + base + ALIGN(strlen(b) + 1, 4), + nest_level); break;
case T_TIMEOUT: @@ -1328,8 +1347,9 @@ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, struct pxe_menu *cfg, in break;
case T_INCLUDE: - err = handle_include(cmdtp, &p, b + ALIGN(strlen(b), 4), cfg, - nest_level + 1); + err = handle_include(cmdtp, &p, + base + ALIGN(strlen(b), 4), cfg, + nest_level + 1); break;
case T_PROMPT: @@ -1385,9 +1405,11 @@ static void destroy_pxe_menu(struct pxe_menu *cfg) * files it includes). The resulting pxe_menu struct can be free()'d by using * the destroy_pxe_menu() function. */ -static struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, char *menucfg) +static struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg) { struct pxe_menu *cfg; + char *buf; + int r;
cfg = malloc(sizeof(struct pxe_menu));
@@ -1398,7 +1420,11 @@ static struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, char *menucfg)
INIT_LIST_HEAD(&cfg->labels);
- if (parse_pxefile_top(cmdtp, menucfg, cfg, 1) < 0) { + buf = map_sysmem(menucfg, 0); + r = parse_pxefile_top(cmdtp, buf, menucfg, cfg, 1); + unmap_sysmem(buf); + + if (r < 0) { destroy_pxe_menu(cfg); return NULL; } @@ -1556,7 +1582,7 @@ do_pxe_boot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
- cfg = parse_pxefile(cmdtp, (char *)(pxefile_addr_r)); + cfg = parse_pxefile(cmdtp, pxefile_addr_r);
if (cfg == NULL) { printf("Error parsing config file\n"); @@ -1663,12 +1689,12 @@ static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
- if (get_pxe_file(cmdtp, filename, (void *)pxefile_addr_r) < 0) { + if (get_pxe_file(cmdtp, filename, pxefile_addr_r) < 0) { printf("Error reading config file\n"); return 1; }
Make the sandbox setup more generic/examplary by including config_distro_defaults.h and config_distro_bootcmd.h.
Among other things this makes it easy to test whether images will boot though with the standard distro bootcmds by running e.g: u-boot -c 'host bind 0 myimage.img ; boot'
By default there are 2 target host devices to emulate device with multiple storage devices (e.g. internal ("host 0") and external ("host 1") and verify that the prioritization and fallbacks do work correctly.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed by: Simon Glass sjg@chromium.org Acked-by: Simon Glass sjg@chromium.org
include/configs/sandbox.h | 29 ++++++++++++++++++++++++++--- 1 file changed, 26 insertions(+), 3 deletions(-)
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index febbfb6..02c83cd 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -75,7 +75,6 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_COMMAND_HISTORY #define CONFIG_AUTO_COMPLETE -#define CONFIG_BOOTDELAY 3
#define CONFIG_ENV_SIZE 8192 #define CONFIG_ENV_IS_NOWHERE @@ -125,10 +124,21 @@
/* include default commands */ #include <config_cmd_default.h> +#include <config_distro_defaults.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(HOST, host, 1) \ + func(HOST, host, 0) + +#include <config_distro_bootcmd.h>
/* We don't have networking support yet */ #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS +#undef CONFIG_CMD_PING + +/* Can't boot elf images */ +#undef CONFIG_CMD_ELF
#define CONFIG_CMD_HASH #define CONFIG_HASH_VERIFY @@ -165,16 +175,29 @@
#define CONFIG_KEYBOARD
-#define CONFIG_EXTRA_ENV_SETTINGS "stdin=serial,cros-ec-keyb\0" \ +#define EXTRA_ENV_SETTINGS "stdin=serial,cros-ec-keyb\0" \ "stdout=serial,lcd\0" \ "stderr=serial,lcd\0" #else
-#define CONFIG_EXTRA_ENV_SETTINGS "stdin=serial\0" \ +#define EXTRA_ENV_SETTINGS "stdin=serial\0" \ "stdout=serial,lcd\0" \ "stderr=serial,lcd\0" #endif
+#define MEM_LAYOUT_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + "kernel_addr_r=0x1000000\0" \ + "fdt_addr_r=0xc00000\0" \ + "ramdisk_addr_r=0x2000000\0" \ + "scriptaddr=0x1000\0" \ + "pxefile_addr_r=0x2000\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + MEM_LAYOUT_ENV_SETTINGS \ + EXTRA_ENV_SETTINGS + #define CONFIG_GZIP_COMPRESSED #define CONFIG_BZIP2 #define CONFIG_LZO
Hi Sjoerd,
I'd like to apply this series right away. This patch gives conflicts now that sandbox supports networking. I resolved them and pushed the series to u-boot-dm/sandbox-testing, but I still get a build error. It's probably safer if you take a look.
Can you please rebase this patch on u-boot-dm/next and retest? You can either send the series again, or just this patch.
Sjoerd Simons
