[U-Boot-Users] [PATCH 1/2] libfdt: Trivial cleanup for CHECK_HEADER)
Currently the CHECK_HEADER() macro is defined local to fdt_ro.c. However, there are a handful of functions (fdt_move, rw_check_header, fdt_open_into) from other files which could also use it (currently they open-code something more-or-less identical). Therefore, this patch moves CHECK_HEADER() to libfdt_internal.h and uses it in those places.
Signed-off-by: David Gibson david@gibson.dropbear.id.au --- libfdt/fdt.c | 5 +---- libfdt/fdt_ro.c | 7 ------- libfdt/fdt_rw.c | 8 ++------ libfdt/libfdt_internal.h | 7 +++++++ 4 files changed, 10 insertions(+), 17 deletions(-)
diff --git a/libfdt/fdt.c b/libfdt/fdt.c index c61fb53..bd91712 100644 --- a/libfdt/fdt.c +++ b/libfdt/fdt.c @@ -184,10 +184,7 @@ const char *_fdt_find_string(const char *strtab, int tabsize, const char *s)
int fdt_move(const void *fdt, void *buf, int bufsize) { - int err = fdt_check_header(fdt); - - if (err) - return err; + CHECK_HEADER(fdt);
if (fdt_totalsize(fdt) > bufsize) return -FDT_ERR_NOSPACE; diff --git a/libfdt/fdt_ro.c b/libfdt/fdt_ro.c index f08941a..15d5f6b 100644 --- a/libfdt/fdt_ro.c +++ b/libfdt/fdt_ro.c @@ -55,13 +55,6 @@
#include "libfdt_internal.h"
-#define CHECK_HEADER(fdt) \ - { \ - int err; \ - if ((err = fdt_check_header(fdt)) != 0) \ - return err; \ - } - static int nodename_eq(const void *fdt, int offset, const char *s, int len) { diff --git a/libfdt/fdt_rw.c b/libfdt/fdt_rw.c index ac50195..0df472b 100644 --- a/libfdt/fdt_rw.c +++ b/libfdt/fdt_rw.c @@ -69,10 +69,8 @@ static int _blocks_misordered(const void *fdt,
static int rw_check_header(void *fdt) { - int err; + CHECK_HEADER(fdt);
- if ((err = fdt_check_header(fdt))) - return err; if (fdt_version(fdt) < 17) return -FDT_ERR_BADVERSION; if (_blocks_misordered(fdt, sizeof(struct fdt_reserve_entry), @@ -399,9 +397,7 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize) int newsize; void *tmp;
- err = fdt_check_header(fdt); - if (err) - return err; + CHECK_HEADER(fdt);
mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) * sizeof(struct fdt_reserve_entry); diff --git a/libfdt/libfdt_internal.h b/libfdt/libfdt_internal.h index 1e60936..52e1b8d 100644 --- a/libfdt/libfdt_internal.h +++ b/libfdt/libfdt_internal.h @@ -58,6 +58,13 @@ #define memeq(p, q, n) (memcmp((p), (q), (n)) == 0) #define streq(p, q) (strcmp((p), (q)) == 0)
+#define CHECK_HEADER(fdt) \ + { \ + int err; \ + if ((err = fdt_check_header(fdt)) != 0) \ + return err; \ + } + uint32_t _fdt_next_tag(const void *fdt, int startoffset, int *nextoffset); const char *_fdt_find_string(const char *strtab, int tabsize, const char *s); int _fdt_node_end_offset(void *fdt, int nodeoffset);
Jerry Van Baren
