[U-Boot] pedantic cleanup -- sure is a lot of "#if 0" out there :-)
another observation -- noticed "#if 0" in a header file i'm working with, so did a quick grep from the top:
$ grep -r "^#if 0" * | wc -l 223 $
and, what the heck:
$ grep -r "^#if 1" * | wc -l 37 $
so after next release, i might rummage around in that and submit patches, particularly when i see stuff like:
#if 0 /* already in asm/8xx_immap.h */ #define TBSCR_REFA 0x0080 /* Reference Interrupt Status A */ #define TBSCR_REFB 0x0040 /* Reference Interrupt Status B */ #define TBSCR_REFAE 0x0008 /* Second Interrupt Enable A */ #define TBSCR_REFBE 0x0004 /* Second Interrupt Enable B */ #define TBSCR_TBF 0x0002 /* Time Base Freeze */ #define TBSCR_TBE 0x0001 /* Time Base Enable */ #endif
/*----------------------------------------------------------------------- * PISCR - Periodic Interrupt Status and Control Register 11-31 */ #undef PISCR_PIRQ /* TBD */ #define PISCR_PITF 0x0002 /* Periodic Interrupt Timer Freeze */ #if 0 /* already in asm/8xx_immap.h */ #define PISCR_PS 0x0080 /* Periodic interrupt Status */ #define PISCR_PIE 0x0004 /* Periodic Interrupt Enable */ #define PISCR_PTE 0x0001 /* Periodic Timer Enable */ #endif
after all, if you have a comment that helpfully states that that content is #if 0'ed out because it's already elsewhere, then (after confirming that it is), that seems like a good candidate for deletion.
all in good time ...
rday
Robert P. J. Day
