[U-Boot] [PATCH] ti_armv7_common: env: Use args_mmc in FIT loading path
The env command 'args_fit' does not define a root path, this forces us to embed the rootfs into the FIT image. FIT images do not need to contain a rootfs, when they do not the kernel will fall-back to the kernel argument 'root', if this is not defined the kernel will not boot. It is safe to add this as when we do have the rootfs in FIT this argument is ignored. As 'loadfit' is only called from the MMC boot path, use 'args_mmc' to correctly populate 'bootargs'.
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com --- include/configs/ti_armv7_common.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index a4ec4ce00a..b2950efd47 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -117,8 +117,7 @@ "fit_loadaddr=0x88000000\0" \ "fit_bootfile=fitImage.itb\0" \ "update_to_fit=setenv loadaddr ${fit_loadaddr}; setenv bootfile ${fit_bootfile}\0" \ - "args_fit=setenv bootargs console=${console} \0" \ - "loadfit=run args_fit; bootm ${loadaddr}#${fdtfile};\0" \ + "loadfit=run args_mmc; bootm ${loadaddr}#${fdtfile};\0" \
/* * DDR information. If the CONFIG_NR_DRAM_BANKS is not defined,
Andrew F. Davis
