[U-Boot] [PATCH] cosmetic: Fix typos "privide"
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/clk/clk-ld4.c | 2 +- arch/arm/mach-uniphier/clk/clk-pro4.c | 2 +- arch/arm/mach-uniphier/clk/clk-pro5.c | 2 +- arch/arm/mach-uniphier/clk/clk-pxs2.c | 2 +- arch/arm/mach-uniphier/early-clk/early-clk-ld4.c | 2 +- arch/arm/mach-uniphier/early-clk/early-clk-pro5.c | 2 +- arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c | 2 +- lib/Kconfig | 2 +- 8 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/clk-ld4.c b/arch/arm/mach-uniphier/clk/clk-ld4.c index f11fb53..8744d26 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld4.c +++ b/arch/arm/mach-uniphier/clk/clk-ld4.c @@ -27,7 +27,7 @@ void uniphier_ld4_clk_init(void) writel(tmp, SC_RSTCTRL); readl(SC_RSTCTRL); /* dummy read */
- /* privide clocks */ + /* provide clocks */ tmp = readl(SC_CLKCTRL); #ifdef CONFIG_UNIPHIER_ETH tmp |= SC_CLKCTRL_CEN_ETHER; diff --git a/arch/arm/mach-uniphier/clk/clk-pro4.c b/arch/arm/mach-uniphier/clk/clk-pro4.c index b163e3c..8746d7d 100644 --- a/arch/arm/mach-uniphier/clk/clk-pro4.c +++ b/arch/arm/mach-uniphier/clk/clk-pro4.c @@ -38,7 +38,7 @@ void uniphier_pro4_clk_init(void) readl(SC_RSTCTRL2); /* dummy read */ #endif
- /* privide clocks */ + /* provide clocks */ tmp = readl(SC_CLKCTRL); #ifdef CONFIG_USB_XHCI_UNIPHIER tmp |= SC_CLKCTRL_CEN_USB31 | SC_CLKCTRL_CEN_USB30 | diff --git a/arch/arm/mach-uniphier/clk/clk-pro5.c b/arch/arm/mach-uniphier/clk/clk-pro5.c index 628f5c8..823bb06 100644 --- a/arch/arm/mach-uniphier/clk/clk-pro5.c +++ b/arch/arm/mach-uniphier/clk/clk-pro5.c @@ -31,7 +31,7 @@ void uniphier_pro5_clk_init(void) readl(SC_RSTCTRL2); /* dummy read */ #endif
- /* privide clocks */ + /* provide clocks */ tmp = readl(SC_CLKCTRL); #ifdef CONFIG_USB_XHCI_UNIPHIER tmp |= SC_CLKCTRL_CEN_USB31 | SC_CLKCTRL_CEN_USB30 | diff --git a/arch/arm/mach-uniphier/clk/clk-pxs2.c b/arch/arm/mach-uniphier/clk/clk-pxs2.c index 8548353..76bf856 100644 --- a/arch/arm/mach-uniphier/clk/clk-pxs2.c +++ b/arch/arm/mach-uniphier/clk/clk-pxs2.c @@ -34,7 +34,7 @@ void uniphier_pxs2_clk_init(void) readl(SC_RSTCTRL2); /* dummy read */ #endif
- /* privide clocks */ + /* provide clocks */ tmp = readl(SC_CLKCTRL); #ifdef CONFIG_USB_XHCI_UNIPHIER tmp |= SC_CLKCTRL_CEN_USB31 | SC_CLKCTRL_CEN_USB30 | diff --git a/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c b/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c index c98081f..b6e8b64 100644 --- a/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c +++ b/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c @@ -24,7 +24,7 @@ int uniphier_ld4_early_clk_init(const struct uniphier_board_data *bd) writel(tmp, SC_RSTCTRL); readl(SC_RSTCTRL); /* dummy read */
- /* privide clocks */ + /* provide clocks */ tmp = readl(SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_UMC | SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; writel(tmp, SC_CLKCTRL); diff --git a/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c b/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c index 5fc8cd0..c41a8ea 100644 --- a/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c +++ b/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c @@ -26,7 +26,7 @@ int uniphier_pro5_early_clk_init(const struct uniphier_board_data *bd) writel(tmp, SC_RSTCTRL4); readl(SC_RSTCTRL); /* dummy read */
- /* privide clocks */ + /* provide clocks */ tmp = readl(SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; writel(tmp, SC_CLKCTRL); diff --git a/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c b/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c index 92b2dcb..665ecd5 100644 --- a/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c +++ b/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c @@ -30,7 +30,7 @@ int uniphier_pxs2_early_clk_init(const struct uniphier_board_data *bd) writel(tmp, SC_RSTCTRL4); readl(SC_RSTCTRL4); /* dummy read */
- /* privide clocks */ + /* provide clocks */ tmp = readl(SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; writel(tmp, SC_CLKCTRL); diff --git a/lib/Kconfig b/lib/Kconfig index 7a45336..2b97c2b 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -16,7 +16,7 @@ config USE_PRIVATE_LIBGCC depends on HAVE_PRIVATE_LIBGCC help This option allows you to use the built-in libgcc implementation - of U-Boot instead of the one privided by the compiler. + of U-Boot instead of the one provided by the compiler. If unsure, say N.
config SYS_HZ
2016-03-30 20:17 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
