[U-Boot] [PATCH] powerpc/mpc85xx:Add debugger support for e500v2 SoC
Freescale's e500v1 and e500v2 cores (used in mpc85xx chips) have some restrictions on external debugging (JTAG).
So define CONFIG_SYS_PPC_E500_DEBUG_TLB to enable a temporary TLB entry to be used during boot to work around the limitations.
Please refer doc/README.mpc85xx for more information
Signed-off-by: Radu Lazarescu radu.lazarescu@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- arch/powerpc/include/asm/config_mpc85xx.h | 14 ++++++++++++++ 1 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 8654625..957d99c 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -107,6 +107,7 @@ #define CONFIG_MAX_CPUS 1 #define CONFIG_FSL_SDHC_V2_3 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 3 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_FSL_SATA_V2 @@ -123,6 +124,7 @@ #elif defined(CONFIG_P1011) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -134,6 +136,7 @@ #elif defined(CONFIG_P1012) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -148,6 +151,7 @@ #elif defined(CONFIG_P1013) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 #define CONFIG_FSL_SATA_V2 @@ -160,6 +164,7 @@ #define CONFIG_MAX_CPUS 1 #define CONFIG_FSL_SDHC_V2_3 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 3 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_FSL_SATA_V2 @@ -175,6 +180,7 @@ #elif defined(CONFIG_P1015) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -186,6 +192,7 @@ #elif defined(CONFIG_P1016) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -213,6 +220,7 @@ #elif defined(CONFIG_P1020) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -223,6 +231,7 @@ #elif defined(CONFIG_P1021) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -236,6 +245,7 @@ #elif defined(CONFIG_P1022) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 #define CONFIG_FSL_SATA_V2 @@ -261,6 +271,7 @@ #elif defined(CONFIG_P1024) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -272,6 +283,7 @@ #elif defined(CONFIG_P1025) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -286,6 +298,7 @@ #elif defined(CONFIG_P2010) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -294,6 +307,7 @@ #elif defined(CONFIG_P2020) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
Prabhakar Kushwaha
