[U-Boot-Users] tiny patch for examples/Makefile (objcopy related)
Hello u-boot-users,
Here is a short patch for the examples/Makefile. This improves reliability in the case of a deficient toolchain.
For example the MontaVista (pro 3.0) ppc_82xx objcopy does not accept srec input, and produces an empty output file which can confuse make.
This patch ensures that the binary image is produced from the elf file and not the srec file, which allows a clean build.
-Cam
PS. MontaVista have 'no general interest in supporting srec input' because of 'how little information srec files contain'.
Cam wrote:
Hello u-boot-users,
Yep, I had noticed this long ago too. Why not just add "-I srec" as in the attached?
-- Regards, George
-Cam
diff -urN u-boot-1.0.0.orig/examples/Makefile u-boot-1.0.0/examples/Makefile --- u-boot-1.0.0.orig/examples/Makefile 2003-10-14 20:43:56.000000000 +0100 +++ u-boot-1.0.0/examples/Makefile 2003-12-03 11:21:04.000000000 +0000 @@ -104,7 +104,7 @@ $(OBJCOPY) -O srec $(<:.o=) $@
%.bin: %.srec
- $(OBJCOPY) -O binary $< $@ 2>/dev/null
- $(OBJCOPY) -O binary $(<:.srec=) $@ 2>/dev/null
Index: examples/Makefile =================================================================== RCS file: /cvsroot/u-boot/u-boot/examples/Makefile,v retrieving revision 1.14 diff -u -r1.14 Makefile --- examples/Makefile 14 Oct 2003 19:43:56 -0000 1.14 +++ examples/Makefile 3 Dec 2003 15:29:11 -0000 @@ -104,7 +104,7 @@ $(OBJCOPY) -O srec $(<:.o=) $@
%.bin: %.srec - $(OBJCOPY) -O binary $< $@ 2>/dev/null + $(OBJCOPY) -I srec -O binary $< $@ 2>/dev/null
Dear Cam,
Thanks, added.
Well, but this is a standard feature in the binutils, and it seems ignorant to me to (intentionally) disable it. Anyway - thanks for the fix.
Hi Wolfgang & Cam,
Dear Cam,
%.bin: %.srec
Thanks, added.
Are you aware, that you effectively have a misleading rule now? The rule says how to generate ".bin" from ".srec" files, while in the command pattern you explicitely use none of the prerequisites but the hand-derived ELF file. This might potentially mess up make's rule algorithm.
As I am on holiday right now, I am too lazy to come up with a cleaner fix, I just wanted to phrase my concern.
Cheers Detlev
On Wed, Dec 10, 2003 at 05:13:55PM +0100, Detlev Zundel wrote:
Hi Wolfgang & Cam,
Dear Cam,
%.bin: %.srec
Thanks, added.
This works without the side-effects too: ; P
-- Regards, George
George
I have a preference for generating the srec and binary outputs from a common input, it seems simpler, and less prone to things going wrong. I realise that the current Makefile achieves this in an obscure way (the bin is made dependent on the srec, however it really depends on a file produced as a side-effect of the srec target).
- $(OBJCOPY) -I srec -O binary $< $@ 2>/dev/null
I really like that, because it is simple. However it does not work for me, as the MontaVista ppc_82xx-objcopy does not support srec input.
If I get some time I will try to do more with the Makefiles, as I would like them to work for Rational ClearCase make (clearmake). Mostly they do right now with the exception of recursive make invocations. However there are greater priorities within the project and I expect I might not get the time to tweak the Makefiles beyond getting it working.
Thanks for the feedback, it's a joy to find such an active and interested community.
-Cam
participants (5)
Cam
Detlev Zundel
George G. Davis
George G. Davis
