[PATCH] arm64: zynqmp: Add support for zcu1285 revA board
zcu1285 is the same as zcu1275 but it is using Avnet FMC http://www.ultrazed.org/product/network-fmc-module
Unfortunately not everything is connected now that's why this is only describing system which Xilinx is using.
arch/arm/dts/Makefile | 1 + arch/arm/dts/zynqmp-zcu1285-revA.dts | 245 +++++++++++++++++++++++++++ configs/xilinx_zynqmp_virt_defconfig | 2 +- 3 files changed, 247 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/zynqmp-zcu1285-revA.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a82ba0da9abe..e30186de493b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -281,6 +281,7 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-zcu111-revA.dtb \ zynqmp-zcu1275-revA.dtb \ zynqmp-zcu1275-revB.dtb \ + zynqmp-zcu1285-revA.dtb \ zynqmp-zcu208-revA.dtb \ zynqmp-zcu216-revA.dtb \ zynqmp-zc1232-revA.dtb \ diff --git a/arch/arm/dts/zynqmp-zcu1285-revA.dts b/arch/arm/dts/zynqmp-zcu1285-revA.dts new file mode 100644 index 000000000000..9c1801313889 --- /dev/null +++ b/arch/arm/dts/zynqmp-zcu1285-revA.dts @@ -0,0 +1,245 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * dts file for Xilinx ZynqMP ZCU1285 RevA + * + * (C) Copyright 2018 - 2019, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + * Siva Durga Prasad Paladugu sivadur@xilinx.com + */ + +/dts-v1/; + +#include "zynqmp.dtsi" +#include "zynqmp-clk-ccf.dtsi" + +/ { + model = "ZynqMP ZCU1285 RevA"; + compatible = "xlnx,zynqmp-zcu1285-revA", "xlnx,zynqmp-zcu1285", + "xlnx,zynqmp"; + + aliases { + serial0 = &uart0; + serial1 = &dcc; + spi0 = &qspi; + mmc0 = &sdhci1; + i2c = &i2c0; /* EMIO */ + }; + + chosen { + bootargs = "earlycon"; + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + ina226-u60 { + compatible = "iio-hwmon"; + io-channels = <&u60 0>, <&u60 1>, <&u60 2>, <&u60 3>; + }; + ina226-u61 { + compatible = "iio-hwmon"; + io-channels = <&u61 0>, <&u61 1>, <&u61 2>, <&u61 3>; + }; + ina226-u63 { + compatible = "iio-hwmon"; + io-channels = <&u63 0>, <&u63 1>, <&u63 2>, <&u63 3>; + }; + ina226-u65 { + compatible = "iio-hwmon"; + io-channels = <&u65 0>, <&u65 1>, <&u65 2>, <&u65 3>; + }; + ina226-u64 { + compatible = "iio-hwmon"; + io-channels = <&u64 0>, <&u64 1>, <&u64 2>, <&u64 3>; + }; +}; + +&dcc { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + i2c-mux@75 { + compatible = "nxp,pca9548"; /* u22 */ + #address-cells = <1>; + #size-cells = <0>; + reg = <0x75>; + + i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + /* PMBUS */ + max20751@74 { /* u23 */ + compatible = "maxim,max20751"; + reg = <0x74>; + }; + max20751@70 { /* u89 */ + compatible = "maxim,max20751"; + reg = <0x70>; + }; + max15301@a { /* u28 */ + compatible = "maxim,max15301"; + reg = <0xa>; + }; + max15303@b { /* u48 */ + compatible = "maxim,max15303"; + reg = <0xb>; + }; + max15303@d { /* u27 */ + compatible = "maxim,max15303"; + reg = <0xd>; + }; + max15303@e { /* u11 */ + compatible = "maxim,max15303"; + reg = <0xe>; + }; + max15303@f { /* u96 */ + compatible = "maxim,max15303"; + reg = <0xf>; + }; + max15303@11 { /* u47 */ + compatible = "maxim,max15303"; + reg = <0x11>; + }; + max15303@12 { /* u24 */ + compatible = "maxim,max15303"; + reg = <0x12>; + }; + max15301@13 { /* u29 */ + compatible = "maxim,max15301"; + reg = <0x13>; + }; + max15303@14 { /* u51 */ + compatible = "maxim,max15303"; + reg = <0x14>; + }; + max15303@15 { /* u30 */ + compatible = "maxim,max15303"; + reg = <0x15>; + }; + max15303@16 { /* u102 */ + compatible = "maxim,max15303"; + reg = <0x16>; + }; + max15301@17 { /* u50 */ + compatible = "maxim,max15301"; + reg = <0x17>; + }; + max15301@18 { /* u31 */ + compatible = "maxim,max15301"; + reg = <0x18>; + }; + }; + i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + /* CM_I2C */ + }; + i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + /* SYS_EEPROM */ + eeprom: eeprom@54 { /* u101 */ + compatible = "atmel,24c32"; /* 24LC32A */ + reg = <0x54>; + }; + }; + i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + /* FMC1 */ + }; + i2c@4 { + #address-cells = <1>; + #size-cells = <0>; + reg = <4>; + /* FMC2 */ + }; + i2c@5 { + #address-cells = <1>; + #size-cells = <0>; + reg = <5>; + /* ANALOG_PMBUS */ + u60: ina226@40 { /* u60 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-u60"; + reg = <0x40>; + shunt-resistor = <1000>; + }; + u61: ina226@41 { /* u61 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-u61"; + reg = <0x41>; + shunt-resistor = <1000>; + }; + u63: ina226@42 { /* u63 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-u63"; + reg = <0x42>; + shunt-resistor = <1000>; + }; + u65: ina226@43 { /* u65 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-u65"; + reg = <0x43>; + shunt-resistor = <1000>; + }; + u64: ina226@44 { /* u64 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-u64"; + reg = <0x44>; + shunt-resistor = <1000>; + }; + }; + i2c@6 { + #address-cells = <1>; + #size-cells = <0>; + reg = <6>; + /* ANALOG_CM_I2C */ + }; + i2c@7 { + #address-cells = <1>; + #size-cells = <0>; + reg = <7>; + /* FMC3 */ + }; + }; +}; + +&qspi { + status = "okay"; + flash@0 { + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ + #address-cells = <1>; + #size-cells = <1>; + reg = <0x0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <1>; + spi-max-frequency = <108000000>; /* Based on DC1 spec */ + }; +}; + +&uart0 { + status = "okay"; +}; + +&sdhci1 { + status = "okay"; + xlnx,mio_bank = <1>; +}; diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 7e0fcf15c4f5..2327eeee4acf 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -46,7 +46,7 @@ CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu100-revC" -CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu208-revA zynqmp-zcu216-revA" +CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu1285-revA zynqmp-zcu208-revA zynqmp-zcu216-revA" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y
Michal Simek
