[U-Boot] [PATCH] mkimage: check environment for dtc binary location
Currently mkimage assumes the dtc binary is in the path and fails otherwise. This patch makes it check the DTC environment variable first for the dtc binary and then fall back to the default path. This makes it possible to call the u-boot build with make DTC=... and build a fit image with the dtc binary not being the the default path.
Signed-off-by: Hauke Mehrtens hauke@hauke-m.de Cc: Simon Glass sjg@chromium.org --- tools/fit_image.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 4dc8bd8862..d7a7b07faf 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -647,9 +647,14 @@ static int fit_handle_file(struct image_tool_params *params) } *cmd = '\0'; } else if (params->datafile) { + const char* dtc = getenv("DTC"); + + if (!dtc) + dtc = MKIMAGE_DTC; + /* dtc -I dts -O dtb -p 500 datafile > tmpfile */ snprintf(cmd, sizeof(cmd), "%s %s %s > %s", - MKIMAGE_DTC, params->dtc, params->datafile, tmpfile); + dtc, params->dtc, params->datafile, tmpfile); debug("Trying to execute "%s"\n", cmd); } else { snprintf(cmd, sizeof(cmd), "cp %s %s",
if (!dtc)
dtc = MKIMAGE_DTC;
dtc, params->dtc, params->datafile, tmpfile); debug("Trying to execute \"%s\"\n", cmd); } else { snprintf(cmd, sizeof(cmd), "cp %s %s",
-- 2.11.0
But please can you add mention of this to the help (mkimage.1)
if (!dtc)
dtc = MKIMAGE_DTC;
-- 2.11.0
Hi Simon,
where should I add the description?
Somewhere in the OPTIONS list or under DESCRIPTION -> FIT?
Hauke
if (!dtc)
dtc = MKIMAGE_DTC;
-- 2.11.0
Hi Simon,
Yes I think so.
Hauke Mehrtens
